Tanya : Ganti oli transmisi matic
- Daily Vehicle: HRV 2019
Re: Tanya : Ganti oli transmisi matic
Mau nanya om, boleh minta rekomendasi oli matic buat volvo 960 ada pilihan apa aja? Bisa pake atf dexron VI kah?
Aisin AFW VIfannykuncoro wrote: ↑Mon Jul 24, 2023 2:21 Mau nanya om, boleh minta rekomendasi oli matic buat volvo 960 ada pilihan apa aja? Bisa pake atf dexron VI kah?
https://www.aisin.com.sg/wp-content/upl ... n-List.pdf
Specnya Volvo 960 konon Dexron IIE or Mercon
https://www.volvoclub.org.uk/tech/servi ... vicing.pdf
dan yg bikin aisin warner jg
Siap om surya.. Intinya boleh pake dexron VI ya..Suryaputra wrote: ↑Mon Jul 24, 2023 2:29Aisin AFW VIfannykuncoro wrote: ↑Mon Jul 24, 2023 2:21 Mau nanya om, boleh minta rekomendasi oli matic buat volvo 960 ada pilihan apa aja? Bisa pake atf dexron VI kah?
yes itulah hebatnya dexron family yaafannykuncoro wrote: ↑Mon Jul 24, 2023 2:35Siap om surya.. Intinya boleh pake dexron VI ya..Suryaputra wrote: ↑Mon Jul 24, 2023 2:29Aisin AFW VIfannykuncoro wrote: ↑Mon Jul 24, 2023 2:21 Mau nanya om, boleh minta rekomendasi oli matic buat volvo 960 ada pilihan apa aja? Bisa pake atf dexron VI kah?
backward compatible, dah kaya bluray drive bisa nyetel vcd or cd
buat oli cvt daihatsu (DCVT) utk avanza/ xenia/ veloz, bisa pakai oli CVT biasa aja ya yg di pasaran?
Harta Cinta Tahta!!!
Choose yours
Choose yours
metik volvo ada AW ada ZF, tanya dulu yg mana. ketauan dari bentuk shifternya.
Biasa dr dipstick keliatan kan specnya yaa mbah?marmut wrote: ↑Mon Jul 24, 2023 3:31Suryaputra wrote: ↑Mon Jul 24, 2023 2:29Aisin AFW VIfannykuncoro wrote: ↑Mon Jul 24, 2023 2:21 Mau nanya om, boleh minta rekomendasi oli matic buat volvo 960 ada pilihan apa aja? Bisa pake atf dexron VI kah?
Bntr saya tanyain om..marmut wrote: ↑Mon Jul 24, 2023 3:31Suryaputra wrote: ↑Mon Jul 24, 2023 2:29Aisin AFW VIfannykuncoro wrote: ↑Mon Jul 24, 2023 2:21 Mau nanya om, boleh minta rekomendasi oli matic buat volvo 960 ada pilihan apa aja? Bisa pake atf dexron VI kah?
Speknya ikut Toyota CVT FE, atau DCVT FEthe-mantal wrote: ↑Mon Jul 24, 2023 2:54 buat oli cvt daihatsu (DCVT) utk avanza/ xenia/ veloz, bisa pakai oli CVT biasa aja ya yg di pasaran?
Rocky R ADS CVT 2021
Ternyata ZF om marmut...fannykuncoro wrote: ↑Mon Jul 24, 2023 4:00Bntr saya tanyain om..marmut wrote: ↑Mon Jul 24, 2023 3:31Suryaputra wrote: ↑Mon Jul 24, 2023 2:29
Aisin AFW VI
Baca di sini sih bisa Dexron tsb yaa.fannykuncoro wrote: ↑Mon Jul 24, 2023 11:25Ternyata ZF om marmut...
Specnya sama.
https://www.volvoclub.org.uk/faq/FAQPDF ... onAuto.pdf
Ok om surya.. Makasih..Suryaputra wrote: ↑Mon Jul 24, 2023 11:35Baca di sini sih bisa Dexron tsb yaa.
Specnya sama.
Nanya dong suhu2 d sini, ini atf Kroya buat di pake mobil Spec Toyota WS lebih baik gak dibanding Gulf Low visco/standard Toyota WS? Ane skrg pake Gulf LV cuma harga nya udah 150rb/liter. Rencana mau flush pake ini, cuma 99rb/liter , made in Kroya dan dah full synthetic juga.
Bisa mbahRezPrat wrote: ↑Mon Jul 24, 2023 12:33 Nanya dong suhu2 d sini, ini atf Kroya buat di pake mobil Spec Toyota WS lebih baik gak dibanding Gulf Low visco/standard Toyota WS? Ane skrg pake Gulf LV cuma harga nya udah 150rb/liter. Rencana mau flush pake ini, cuma 99rb/liter , made in Kroya dan dah full synthetic juga.
WS dan T-IV compatible
Om, katanya ws untuk fwd, T-IV untuk rwd, itu bener ga? Atau sama aja sebenernya?Suryaputra wrote: ↑Mon Jul 24, 2023 12:47Bisa mbahRezPrat wrote: ↑Mon Jul 24, 2023 12:33 Nanya dong suhu2 d sini, ini atf Kroya buat di pake mobil Spec Toyota WS lebih baik gak dibanding Gulf Low visco/standard Toyota WS? Ane skrg pake Gulf LV cuma harga nya udah 150rb/liter. Rencana mau flush pake ini, cuma 99rb/liter , made in Kroya dan dah full synthetic juga.
wah klo itu balik lg ke manual booknya mbah.fannykuncoro wrote: ↑Thu Aug 03, 2023 3:31Om, katanya ws untuk fwd, T-IV untuk rwd, itu bener ga? Atau sama aja sebenernya?Suryaputra wrote: ↑Mon Jul 24, 2023 12:47Bisa mbahRezPrat wrote: ↑Mon Jul 24, 2023 12:33 Nanya dong suhu2 d sini, ini atf Kroya buat di pake mobil Spec Toyota WS lebih baik gak dibanding Gulf Low visco/standard Toyota WS? Ane skrg pake Gulf LV cuma harga nya udah 150rb/liter. Rencana mau flush pake ini, cuma 99rb/liter , made in Kroya dan dah full synthetic juga.
cuma untuk atf yg dibahas tsb, comply ke WS dan T-IV.
mungkin klo karakternya Low-Visco, akan terasa resing / sentakan di RWD
Klo mobil2 thn 90an & 2000an awal dikasih atf teknologi masa kini (low visco / dexron VI) mungkin akan jadi lebih enteng mungkin ya om? Mestinya kandungan2 dan standarisasi nya kan lebih baik atf masa kini.. Betul ga om?Suryaputra wrote: ↑Thu Aug 03, 2023 3:53wah klo itu balik lg ke manual booknya mbah.fannykuncoro wrote: ↑Thu Aug 03, 2023 3:31Om, katanya ws untuk fwd, T-IV untuk rwd, itu bener ga? Atau sama aja sebenernya?
basically yes... contohnya Dex VI, backward compatible ke Dex IIfannykuncoro wrote: ↑Thu Aug 03, 2023 4:15Klo mobil2 thn 90an & 2000an awal dikasih atf teknologi masa kini (low visco / dexron VI) mungkin akan jadi lebih enteng mungkin ya om? Mestinya kandungan2 dan standarisasi nya kan lebih baik atf masa kini.. Betul ga om?Suryaputra wrote: ↑Thu Aug 03, 2023 3:53wah klo itu balik lg ke manual booknya mbah.fannykuncoro wrote: ↑Thu Aug 03, 2023 3:31
tapi balik lg, kudu cek ATF nya comply apa nggak nya.
katanya siapa?
- Daily Vehicle: All New Veloz 2022 ANR 2018 Avanza K3VE 2011 Wuling Confero S ACT 2020
Kejadian ini di saya, sebelum lebaran kemaren saya flush matic ANR, sebelumnya pakai Q8 Auto JK, lalu karena ada masukan lebih dari THR saya flush matic ke amsoil atf yang biru ( WS )..dan sampai sekarang enak2 aja, lebih enteng, minim slip dibanding pakai auto JK...fannykuncoro wrote: ↑Thu Aug 03, 2023 4:15Klo mobil2 thn 90an & 2000an awal dikasih atf teknologi masa kini (low visco / dexron VI) mungkin akan jadi lebih enteng mungkin ya om? Mestinya kandungan2 dan standarisasi nya kan lebih baik atf masa kini.. Betul ga om?Suryaputra wrote: ↑Thu Aug 03, 2023 3:53wah klo itu balik lg ke manual booknya mbah.fannykuncoro wrote: ↑Thu Aug 03, 2023 3:31
Kena damagenya yang aduhai : 315rb x 8 liter = 2.520 + 75rb ongkos atf changer
Note: di kendaraan lain dan beda user bisa jadi beda yah, karena sebenernya lendirnya ga sesuai rekomendasi
Auto JK mah cocoknya buat matic 4 speed jadul.Chr1stm1 wrote: ↑Thu Aug 03, 2023 8:29Kejadian ini di saya, sebelum lebaran kemaren saya flush matic ANR, sebelumnya pakai Q8 Auto JK, lalu karena ada masukan lebih dari THR saya flush matic ke amsoil atf yang biru ( WS )..dan sampai sekarang enak2 aja, lebih enteng, minim slip dibanding pakai auto JK...fannykuncoro wrote: ↑Thu Aug 03, 2023 4:15Klo mobil2 thn 90an & 2000an awal dikasih atf teknologi masa kini (low visco / dexron VI) mungkin akan jadi lebih enteng mungkin ya om? Mestinya kandungan2 dan standarisasi nya kan lebih baik atf masa kini.. Betul ga om?Suryaputra wrote: ↑Thu Aug 03, 2023 3:53
Itu lbh kentel emg.
Auto MV visconya mirip sm Amsoil ATF biru dan ATF low visco lain yg V100 nya 6 kurleb
Mbah, ANR kan masih 4speed jadul, cmiiwSuryaputra wrote: ↑Thu Aug 03, 2023 8:58Auto JK mah cocoknya buat matic 4 speed jadul.Chr1stm1 wrote: ↑Thu Aug 03, 2023 8:29Kejadian ini di saya, sebelum lebaran kemaren saya flush matic ANR, sebelumnya pakai Q8 Auto JK, lalu karena ada masukan lebih dari THR saya flush matic ke amsoil atf yang biru ( WS )..dan sampai sekarang enak2 aja, lebih enteng, minim slip dibanding pakai auto JK...fannykuncoro wrote: ↑Thu Aug 03, 2023 4:15
Itu lbh kentel emg.
pas km 20rban thn 2021 saya flush ke q8 Auto JK, rasanya enak, smooth pas oper2an gigi, tarikan mirip2 aja dgn bawaannya ( T4 Toyota )
Sebelum lebaran 2023 saya flush lagi ( km 38rban ) ke AMS SS ATF yang biru ( Low Visco ), seharunya ini utk matic 5 speed keatas, tapi iseng2 aja jajal dan impresinya sampai dgn hari ini berasa malah lebih enteng, smoothnya sama dgn q8 auto JK.
Iya auto jk itu visconya terlalu kental.Chr1stm1 wrote: ↑Thu Aug 03, 2023 9:06Mbah, ANR kan masih 4speed jadul, cmiiwSuryaputra wrote: ↑Thu Aug 03, 2023 8:58Auto JK mah cocoknya buat matic 4 speed jadul.Chr1stm1 wrote: ↑Thu Aug 03, 2023 8:29
Itu lbh kentel emg.
Klo auto mv encer bener malah.
Hahahaha.
Itu an rush specnya WS ?
Long termnya gimana ya? Karena beberapa customer juga prefer pake Auto MV buat 4 speed toyota. Belum pernah uoa sih saya. Kalo dexron 3 vs dexron 6 Teorinya sih gak masalah, bahkan lebih bagus karena walaupun startnya low viscosity setelah pemakaian biasanya yang dexron 3 malahan bisa jadi lebih encer dari yang dexron 6 low viscosity.Chr1stm1 wrote: ↑Thu Aug 03, 2023 9:06Mbah, ANR kan masih 4speed jadul, cmiiwSuryaputra wrote: ↑Thu Aug 03, 2023 8:58Auto JK mah cocoknya buat matic 4 speed jadul.Chr1stm1 wrote: ↑Thu Aug 03, 2023 8:29
Itu lbh kentel emg.
Tapi kalo JK dia gak butut butut amat, udah comply sama spek WS walaupun gak se encer itu, minusnya gak dapet benefit fuel savings aja.
- Daily Vehicle: [cencored]
Rasanya ribon atau fortie sudah pake WS deh.fannykuncoro wrote: ↑Thu Aug 03, 2023 3:31 Om, katanya ws untuk fwd, T-IV untuk rwd, itu bener ga? Atau sama aja sebenernya?
