Remap ECU tanpa pigyback
B064RT
Daily Vehicle: Escape
Re: Remap ECU tanpa pigyback
Post by B064RT »
b8099ok wrote: Thu Aug 24, 2017 0:36 Ecu skr rata" uda smart,...
Semakin banyak sensor, semakin akurat pula sang ecu memerintahkan mesin bekerja sesuai kemampuan yg dimappingkan,...
Banyak yg tersembunyi di settingan ecu,...
Misalnya, emergency limp mode iff egt detected over [cencored] degree, dimana settingan standar ga ada, dan bisa diinject fitur tsb krn msh banyak yg kosong,... Juga emergency limp mode if water temp over value, emergency limp mode if knock retard beyond range, dll. Its all about the editor, idea, brain, and iq. Tools and software everyone can buy it, but the idea is the point.
escape 2007 bisa mbah? idle 220kph
fitur apa aja yang bisa di open
r12qiSonH4ji
SM Moderator
SM Moderator
Daily Vehicle: Gerobak sayur
Post by r12qiSonH4ji »
B064RT wrote: Thu Aug 24, 2017 0:36
B3M0 wrote: Wed Aug 23, 2017 13:14
Nainggolan21 wrote: Kalo liat di mbah Goegle malah lain mbah Paidjo...
D = n Dablek
B = m Blangsat
Ngacir[emoji85] [emoji51]
send from my house
Jadi kapan kopdar? Hehe
sent from ladies room
kapan kopdar oom-om sekalian? denger2 sekalian line up STREET RACING BSD?
aku diajak ya... dah lama ga bejek jesscape
diajak koq om, klo kopdar kan siapa aja boleh dtg. Mobilnya Escape ya ? Jangan melarikan diri ya klo diasepin
Hahahahaha
b8099ok
Post by b8099ok »
B064RT wrote: Thu Aug 24, 2017 0:38
Mana eskepnya,... :big_cat:
FWD + eRWD + 4WD + 4WD = :big_cat:
B064RT
Post by B064RT »
b8099ok wrote: Thu Aug 24, 2017 0:52 Mana eskepnya,... :big_cat:
segera mbah.. kalo tol cikampek dah sepi... diberlakukan nomer bilangan prima,,,
r12qiSonH4ji
SM Moderator
SM Moderator
MAB wrote: Wed Aug 23, 2017 16:53 saatnya pasang dash cam om F
atau saatnya ganti 2GD ke 1VD-FTV om?
dijamin si kecil merah cabe rawit yang kap mesinnya melengkung itu bakal kena asap ..........
F 272 wrote: Wed Aug 23, 2017 9:41
r12qiSonH4ji wrote: Wed Aug 23, 2017 8:18 - cut -
kaki ane aman om, jarang ngebut,
Ngga ngebut dari Hongkong..????
Lari 212 Kpj di Cipali apa masih bisa dibilang santai..?
sekarang udh gk melengkung lg om MAB, udh lurus lagi. Tp lg istirahat dlu di garasi, skrg lg doyan mainin yg putih, hahahahaha
SiulTurbo
Daily Vehicle: Fortuner 2KD
Post by SiulTurbo »
it's a good point
tapi gw bingung kenapa escape, xtrail dan mobil gw dia nyerah ngak bisa di remap cuma di elus2 doang
efact
Post by efact »
Nah.. :frm_salut: :frm_salut: :frm_salut:
2011 Hyundai ix35
2001 BMW E39 530i
B064RT
Post by B064RT »
SiulTurbo wrote: Thu Aug 24, 2017 1:18
it's a good point
escape bisa beliau.... saya nya yang belum sempat..
beliau pernah bertutur bahwa kemarin dulu ada escape v6 yang diremap.... konon lari 120 mph dengan mudah nya
paidjho
Post by paidjho »
aldilee18 wrote:serem nih anggota sm roadtrip mobilnya remap an semua
Tp semoga & kayaknya gak ada yg ditinggalin kok Om...
B3M0 wrote:Rame nih trit nya, asikk...halo om2 semua apa kabar?
Hmmmm.... tukang colok suster ini...
Pakabar Dok?
SiulTurbo
Post by SiulTurbo »
it's a good point
tapi gw bingung kenapa escape, xtrail dan mobil gw dia nyerah ngak bisa di remap cuma di elus2 doang :big_grin: :big_grin:
b8099ok wrote:Ecu skr rata" uda smart,...
Mesin2 Diesel mobil2 di Indo dari pabriknya gak ada EGT sensor - nya di knalpot nya
ECU bisa ambil tindakan masuk Limp mode berdasarkan bacaan sensor
kalo suhu ATF nah......ada sensornya biasanya
suhu bahan bakar juga
Andai bisa pasang EGT sensor di knalpot lalu konek ke ECU, dan kita set above x00 deg C ECU kasi warning......let say konek ke salah 1 LED di panel cluster.....akan sgt menarik
Jadi kalo Temp over, LED nyala......mantap dah (andai bisa)
KelinciPutih047
Daily Vehicle: Ford Everest
Post by KelinciPutih047 »
Turboman wrote: Thu Aug 24, 2017 1:58
Om TurboMan
Pertanyaan bodoh dari orang bodoh ....... kenapa pabrik ga bikin atau pasang EGT Sensor ?
piggypig77
Post by piggypig77 »
Kalo gitu berarti ya gausah beli EGT meter dong
kepo2601
Daily Vehicle: TGN 41 - 2005 Kijang Innova 2700V AT
Post by kepo2601 »
piggypig77 wrote: Thu Aug 24, 2017 2:10
Kasian yang jualan EGT ntar ngga laku :mky_01:
As simple as possible to make it easier for you and everyone else
TGN 41 - 2005 Kijang Innova 2.7V A/T
Om TurboMan
Karena asumsi nya kan mesin dlm kondisi std semua sudah diperhitungkan oleh pabrik
Kecuali ada mesin2 tertentu yg Euro V comply (ada DPF nya) ane lihat ada yg pake EGT sensor dari pabriknya
tapi feeling saya ini tujuannya bukan utk orientasi performa, tapi utk baca seberapa panas suhu di sekitar DPF.......sebagaimana kita tahu saat Regenerating DPF suhu bisa sgt panas sekali
DPG regenerating = proses pembersihan DPF dgn "membakar" perticulate2 di DPF
DPF = Diesel Particulate Filter
Kita sebagai user akan sgt bahagia jika semua mesin Diesel dari pabriknya dilengkapi EGT sensor
lalu data bisa di streaming out dari OBD2......pake ELM konek ke HP misalnya.....jadi gak usah beli EGT meter lagi.......hahahahahahahha
masalahnya mobil Diesel mana di Indo yg ada sensor EGT bawaan pabrik oommmmm.......
Salah 1 mesin Diesel yg banyak sensor di exhaust yg ane pernah liat sendiri = Honda 1.6 i-DTEC di CRV baru (Thailand)........total ada 3 sensor di exhaust, salah 1 nya Lambda sensor.....entah 2 nya lagi apa......
Well
apa yg ane sharing semata2 demi kebaikan user2 juga......demi keawetan mesin2 mobil rekan2
Ane pribadi nggak anti modif (piggy / remap).......ane juga planning mau remap mobil ane (belom tahu dimana)
Sekedar share bahwa yg namanya modif dgn naekkin horsepower (terutama di TurboDiesel) itu ada konsekuensi-nya......dan jika mesin mau awet, ada baiknya hal2 pendukung nya juga diterapkan
Sebetulnya kalo mau dibuat daftar lengkapnya nih :
- Amputasi Katalik & ganti dgn downpipe plong (krn lama2 katalik akan mampat, krn kadar sulphur solar di Indo)
- Free flow air filter (ini sih terserah, krn mungkin ada bbrp user yg seribg lewat dusty area, better AF std aja)
- ATF cooler (kecuali ANPJS / Everest 2500 TDCi yg ATF cooler bawaan pabrik dah bagus)
- Fuel cooler
- Oli full synthetic
ATF cooler sesuatu yg sgt worthed menurut ane, harga gak seberapa, bisa membuat ATF lebih awet.
Fuel cooler akan sgt terasa manfaatnya jika nyetir 2 jam lebih non stop, kinerja mesin lebih stabil
Well......just sharing demi kebaikan......at the end is up to user
Jika ada yg berminat utk discuss lebih lanjut bisa WA ane (PM aja)......utk step by step apa yg sebaiknya dilakukan......yg benar2 sesuai kebutuhan aja
Salam Fun to drive & mesin awet
* Bukan seller meter2 / parts2 modip *
B064RT
Post by B064RT »
josephw1905 wrote: Thu Aug 24, 2017 2:06
Om TurboMan
mau bantu jawab.. cuma dikiria kuminter..
pertanyaan gini biasanya oom ginting yang bisa menjelaskan secara gamblang... geser mic ke oom ginting
fizrmen
Daily Vehicle: Civic FD2
Post by fizrmen »
kepo2601 wrote: Thu Aug 24, 2017 2:13
loh situ sales EGT meter?
2009 Honda Civic FD2
2015 Honda CR-V 2.4l A/T
b8099ok
Post by b8099ok »
Use cat sensor, its temp probe anyway. Just need to be creative and use all the sensor potential as much as possible.
Berimajinasi spt FRD berimajinasi ttg anin,...
Temp probe sensor sih kayaknya banyak yg bikin dan jual yah
tinggal gimana colok ke ECU nya.....hehehhe
Kalo mobil Diesel merek Jepang di Indo apa ada yg pake sensor di katalik spt Lambda sensor ?
yg ane pernah lihat salah 1 nya sih di Hyundai i20 CRDi......
gak tahu kalo mobil2 Diesel Eropa ya
b8099ok
Post by b8099ok »
Several have, but not all :ngacir:
Rakean
Post by Rakean »
hmmmm good good :big_blushing:
*ane gak ngerti dah.... sing penting si hitler bisa ngancir dan aman :big_biglaugh:
b8099ok wrote:Several have, but not all :ngacir:
Mantap yg std nya udah ada.......berarti kayak i20 CRDi bisa kita set if Temp exceed x00 deg C lgs set fuel supply balik ke std pabriknya dong yah
Kalo di Dastek dulu kan ada AUX input bisa baca Exhaust Temp sensor......misal EGT over bisa diprogram lgs pindah MAP scr otomatis spy EGT turun
ransyah1234
Post by ransyah1234 »
Kalo mobil bensin NA yang diremap perlu pasang tools buat mantau apa sebaiknya om oom sekalian?
*Adrenaline meter ada ga? Biar ga napsu2 amat injek gas
