Kalo E5-E10 doang mah aman. Kalo mobil eropa gitu malah E30 masih bisa , lebih dari itu kadang injector/fuel pump harus di upgradeHaiqalesha wrote: ↑Thu Aug 31, 2023 3:31 "The Toyota 1NZ-FE engine has electronic fuel injection system, VVT-i (Variable Valve Timing with intelligence) system on the intake side, ETCS-i (Electronic Throttle Control System-intelligent) and DIS-4 ignition system with individual ignition coil for each spark plug.
The 1NZ-FE engine was redesigned in 2003 due to the introduction of Euro IV emissions regulations. The following changes were made to the engine:
Piston shape was changed;
The shape of the exhaust manifold was modified;
Construction of the three-way catalytic converter was changed;
Three-way catalytic converter was fitted;
The 16 tit ECU was changed to 32 bit.
The engine produced 110 PS (81 kW; 109 HP) at 6,000 rpm of maximum horsepower and 143 Nm (14.6 kg·m; 105.6 ft·lb) at 4,000 rpm of peak torque
SOURCE : https://www.engine-specs.net/toyota/1nz ... e_vignette"
Kalau udah Euro 4 aman yah pakai etanol etanolan ?
Pertamax Green RON92 menggantikan Pertalite RON90 sebagai BBM bersubsidi mulai tahun 2024?
Forum rules
Re: Pertamax Green RON92 menggantikan Pertalite RON90 sebagai BBM bersubsidi mulai tahun 2024?
IG: @sahabatq8
Kemaren seh selama roadtrip di europ (german-austria) smua pom bensin yg ane datengin paling mentok jual gasoline campuran E10 ntah shell; agip/eni; jettankstelle; avanti dan kawan2 nya.
Harga paling murah tuh 1.5 euro / liter .. mobil rentalan gw isi aja bgituan terus sampe dibalikin no problemo at all
Sheer Repairing Pleasure
- Daily Vehicle: DE 2011
blm lg soal maintenance nya, bus2 di sini gatau dah soal servis rutinnya gimana yg penting asal bisa gelinding kayanya , kayaknya injektornya pd masalah makanya asepnya item dan bau solar ga kebakar di combustion chamber langsung keluar ke knalpot
lah di yerman aja malah pd ditutupin PLTN nya gara2 protes pendukung grinpis, balik ke coal lgSuryaputra wrote: ↑Thu Aug 31, 2023 3:51ganti PLTU ke PLTNChZ wrote: ↑Thu Aug 31, 2023 3:46konon semua kendaraan di atas thn 2000 udah bisa comply ke E10.Haiqalesha wrote: ↑Thu Aug 31, 2023 3:31 "The Toyota 1NZ-FE engine has electronic fuel injection system, VVT-i (Variable Valve Timing with intelligence) system on the intake side, ETCS-i (Electronic Throttle Control System-intelligent) and DIS-4 ignition system with individual ignition coil for each spark plug.
ethanol di luar negeri jg bukan barang baru. minimal kalo mobil "standar global" harusnya aman.
nunggu preskon ATPM aja. nanti kan pasti pada rame rame preskon terkait keamanan bensin campuran E3.
kalo goalnya mau kurangi emisi ya udah bener pertalite dihapus ganti pertamax E3.
tapi... bisa ARB itu Coal Stocks
https://www.dw.com/en/germans-split-ove ... o-65334441
https://www.base.bund.de/EN/ns/nuclear- ... e%20latest.
Gara2 ada Presiden mau naikin produksi Ethanol
Cuma mau bilang Thailand campurannya 10%
Brazil campurannya 25%
Indonesia masih 5%
Indonesia masih 5%
Kualitas BBM jelek jadi pembakaran tidak sempurna akhirnya keluar polutan Particulate Matter (PM), NO2, CO, dan HC (methane, ethane, propane, butane). Biasanya bis/truk lama tidak punya catalytic converter, atau rusak tidak diganti karena mahal, padahal punya peran penting merubah sisa pembakaran menjadi gas ramah lingkungan N2 dan CO2.
udah 3 harian cobain pertamax green 95, selang ungu
beli di rest area
hasilnya mayan enak, mungkin krn ada ethanol jadi lebi padet rasanya mirip 98, jauh rasanya sama shell 92
di obd juga keliatan, timing advance nya lebi agresif
pke shell 92 paling banter 0-20 deg, max 40-45deg
pke green 95 bisa 0-40deg, sering 30-40, max 50-65deg
ga konklusif mmg tapi ya rasanya lebi padet
beli di rest area
- Daily Vehicle: Diesel
koq aneh ya om...darrelund wrote: ↑Thu Apr 04, 2024 6:37 udah 3 harian cobain pertamax green 95, selang ungu
beli di rest area
kalo timing bs lebih advance gini kan artinya lebih ok kualitasnya ya
sy pernah baca bbrp artikel infonya yg green ini akan bikin lebih boros bbm karena kalornya lebih rendah
apa betul fuel cons-nya lbh boros?
mobilnya apa om dan pakai obd apa bisa lihat timing pengapian ?darrelund wrote: ↑Thu Apr 04, 2024 6:37 udah 3 harian cobain pertamax green 95, selang ungu
beli di rest area
susah ngomong ya klo bbm um, krn kan beda pengunaan beda hasil
tapi sejauh ini ud jalan 290km, range sisa 350km. normal sih sama kyk pake 92/98. malah membaik sedikit dibanding shell 92. mungkin krn tenaganya lebi dapet jadi gausa injek dalem"
mesti butuh banyak sample lagi um sampe pertagreen ini ada hasilnya konklusif
sepertinya sih krn kualitasnya lebi bagus ya, dan kyknya E5 yg bikin perbedaan
mazda 2 sky um
pake torquepro (beli di playstore) + AAtorque (untuk display di android auto)
https://github.com/agronick/aa-torque
Om, boleh minta info link alat dan harga obd2 tersebut ?
- Daily Vehicle: Civic FK4
pake Ethanol gini konon kabarnya dituning bisa lebih dapet tuh soalnya pengapian bisa lebih advance ada yg tuning M4 G82 beda 50hp pake E10 apa E15 ya.darrelund wrote: ↑Fri Apr 05, 2024 1:35
moga moga kualitasnya gak caur kayak awal pertalet dulu ama skrg. kalo dulu awal2 pertalet kualitasnya bagus, skrg ya makin caur udah
kalo jatohnya subsidi ngeri ah om soalnya karena kebiasaan saya isi turbo jadi ketauan meterannya nyolong termasuk shell tuh gitu jugaChZ wrote: ↑Fri Apr 05, 2024 5:41 pake Ethanol gini konon kabarnya dituning bisa lebih dapet tuh soalnya pengapian bisa lebih advance ada yg tuning M4 G82 beda 50hp pake E10 apa E15 ya.
belom ntar nyimpennya gak jelas suka tinggi kandungan aernya
saya ada hitung2 om kalau driver bluebird sama driver gocar / grabcar dari pertalite ke pertamax itu yg biasa isi 100.000 sehari bakalan megap2 nombok 25-30k sehariChZ wrote: ↑Fri Apr 05, 2024 5:41pake Ethanol gini konon kabarnya dituning bisa lebih dapet tuh soalnya pengapian bisa lebih advance ada yg tuning M4 G82 beda 50hp pake E10 apa E15 ya.darrelund wrote: ↑Fri Apr 05, 2024 1:35
saya doain deh semoga aja beneran ada pertamax green buat versi subsidi
Menaikkan bbm dan menaikkan subsidi rasanya sulit sekali.
Perbanyak saja pohon peneduh untuk menyerap polusi. Kalau suasana teduh orang juga nyaman jalan kaki
Akhir akhir ini konsumsi bbm gerobak ane memburuk. MID nggak pernah saya reset. Biasanya manteng di 6.4ltr/100km. Sekarang di 6.6ltr/100km. Gaya mengemudi, rute sama. Nggak pernah jadi genset. Ane curiga pertamax 92 ini diturunin kualitasnya. Another conspiracy theory . Dan isinya selalu di spbu COCO.
Tekanan ban?Mz175 wrote: ↑Fri Apr 05, 2024 11:55 Akhir akhir ini konsumsi bbm gerobak ane memburuk. MID nggak pernah saya reset. Biasanya manteng di 6.4ltr/100km. Sekarang di 6.6ltr/100km. Gaya mengemudi, rute sama. Nggak pernah jadi genset. Ane curiga pertamax 92 ini diturunin kualitasnya. Another conspiracy theory . Dan isinya selalu di spbu COCO.
Cb bikin 40 psi
Entenggg
klo pun mau tetep lanjut bbm subsidi, mnding skalian diperjelas & diperketat regulasinya. klo msh kyk skrg yg aturannya gk jelas, jgn harap subsidinya bisa tepat sasaran.
mobilnya apa om? soalnya klo mnurut saya ini msh termasuk irit lho hahaha. bedanya gk trlalu jauh (0.2 liter).Mz175 wrote: ↑Fri Apr 05, 2024 11:55 Akhir akhir ini konsumsi bbm gerobak ane memburuk. MID nggak pernah saya reset. Biasanya manteng di 6.4ltr/100km. Sekarang di 6.6ltr/100km. Gaya mengemudi, rute sama. Nggak pernah jadi genset. Ane curiga pertamax 92 ini diturunin kualitasnya. Another conspiracy theory . Dan isinya selalu di spbu COCO.
sbenernya bnyk faktor yg mempengaruhi. mnurut nubi, bisa coba langkah2 ini:
1. tekanan ban disamain sesuai dgn rekomendasi pabrik.
2. tune up.
3. pake oli yg lbh encer.
4. engine flush.
4 wheels:
Toyota KUN40 [2013 - now]
Nissan ND1W [2019 - now]
2 wheels:
Yamaha V100 [1988 - now]
2 wheels:
Mau irit:
- Tekanan ban bikin 40 psi
- Pakai oli 0W16
- Klo matic, ngegas jangan lebih dari 2,5k RPM
- Pakai RON minimal 95
- Begitu nyalain mobil, nunggu 5 detik aja, lgs jalan, gak usah dipanasin segala
- Gak usah pakai AC klo malam
- Pastikan Kondisi mesin, busi, kelistrikan, dll prima
- Pakai oli 0W16
aminken aja lahChZ wrote: ↑Fri Apr 05, 2024 5:41
cuma concernnya itu, aer
secara ni pertagreen ga semua spbu nulis di papan gede klo ada, mesti masup dlu klo ada selang ungu baru ketauan
buat mesin NA hi comp/ turbo sih cucok ni etanol
aplg turbo honda sih gurih tuh
tanggung lahSuryaputra wrote: ↑Fri Apr 05, 2024 13:18 Mau irit:
- Pakai oli 0W16
pke 0W-8 sekalian
buset om.... ban 40psi lsg grabak grubuk itu bnr2 bawaannya. matic gas pelan2 gitu sih nyiksa diri, apalagi kalo perjalanan jauh kapan nyampenya. apalagi gk pake ac di jakarta. itu bulu ketek lsg jadi ubur2 ketek basah. blm lagi tangan jadi keringetan, kombo maut kalo setir kulit lsg tangan bau dan penuh bakteriSuryaputra wrote: ↑Fri Apr 05, 2024 13:18 Mau irit:
- Pakai oli 0W16
Kan lomba irit mbahiamwewe wrote: ↑Sat Apr 06, 2024 13:31buset om.... ban 40psi lsg grabak grubuk itu bnr2 bawaannya. matic gas pelan2 gitu sih nyiksa diri, apalagi kalo perjalanan jauh kapan nyampenya. apalagi gk pake ac di jakarta. itu bulu ketek lsg jadi ubur2 ketek basah. blm lagi tangan jadi keringetan, kombo maut kalo setir kulit lsg tangan bau dan penuh bakteriSuryaputra wrote: ↑Fri Apr 05, 2024 13:18 Mau irit:
- Pakai oli 0W16
Bsa jg kelakuannnya kayak cumi darat settingan AFR solar dibikin rich, biar ngebut
V engine enthusiast:
V6: VQ35DE{|}CVT
V8: 1UR-FSE{|}8AT
predecessor
V6: 2GR-FE{|}6AT
V6: VQ35DE{|}CVT
V8: 1UR-FSE{|}8AT
predecessor
V6: 2GR-FE{|}6AT
Aturan nya emisi mah dah jelas
Yang ga jelas itu punishment nya
Kalo mau digalakin nanti demo lagi
Dituduh zolim sama wong cilik
b0ku wrote: ↑Fri Apr 05, 2024 6:51kalo jatohnya subsidi ngeri ah om soalnya karena kebiasaan saya isi turbo jadi ketauan meterannya nyolong termasuk shell tuh gitu jugaChZ wrote: ↑Fri Apr 05, 2024 5:41 pake Ethanol gini konon kabarnya dituning bisa lebih dapet tuh soalnya pengapian bisa lebih advance ada yg tuning M4 G82 beda 50hp pake E10 apa E15 ya.
Seriusan Shell meterannya nyolong om?
