Moderators: akbarfit , Ryan Steele , sh00t , r12qiSonH4ji , avantgardebronze
bambangwijanarka
Posts: 48 Joined: Fri Sep 11, 2020 4:07
Post
by bambangwijanarka » Mon Mar 08, 2021 13:54
nyotsaeba wrote: Kebetulan lg cari jg, kandidat yg pnp:
Bosch 58024 74ah 680 cca
Amaron 58024
Incoe 58024
Yuasa 58024
Paling murah yuasa, tp jarang yg jual, paling mahal amaron.
Lainnya ada jg merek delkor, koba, gs yg gold shine
Kalo yg incoe 58024,cca cuma 300an.
Ga tahu kalo merk GS dan Yuasa brp cca nya.
nyotsaeba
Posts: 433 Joined: Thu May 04, 2017 14:22
Daily Vehicle: Innova
Post
by nyotsaeba » Tue Mar 09, 2021 8:21
bambangwijanarka wrote: nyotsaeba wrote: Kebetulan lg cari jg, kandidat yg pnp:
Amaron 58024
Incoe 58024
Yuasa 58024
Kalo incoe yg ini 600cca om,
Amaron 690cca, bosch 640cca
bambangwijanarka
Post
by bambangwijanarka » Tue Mar 09, 2021 8:33
Kalau liat dr katalognya Incoe tipe 58024 koq CCA nya 300 ya
nyotsaeba
Post
by nyotsaeba » Wed Mar 10, 2021 2:51
bambangwijanarka wrote: Kalau liat dr katalognya Incoe tipe 58024 koq CCA nya 300 ya
Itu yg dus nya kyk gini om
bambangwijanarka
Post
by bambangwijanarka » Wed Mar 10, 2021 3:10
nyotsaeba wrote: bambangwijanarka wrote: Kalau liat dr katalognya Incoe tipe 58024 koq CCA nya 300 ya
O,ternyata beda jenisnya ya meski sama2 aki kering. Kalo yg basah tipe DIN tapi CCA 600 merk incoe ada jg kah?
nyotsaeba
Post
by nyotsaeba » Wed Mar 10, 2021 3:18
bambangwijanarka wrote: nyotsaeba wrote: bambangwijanarka wrote: Kalau liat dr katalognya Incoe tipe 58024 koq CCA nya 300 ya
Incoe basah din ada, incoe premium 58024
Info dr toko aki ktnya aki basah cca rata2 lebih kecil dari aki kering, paling sekitar 300 an
Valach
Posts: 193 Joined: Wed Mar 03, 2021 4:51
Daily Vehicle: Dakkar 2019
Post
by Valach » Wed Mar 10, 2021 3:47
punya saya masih GS suhuuuu masih bawaan dealer
Valach
Post
by Valach » Wed Mar 10, 2021 3:48
oiya suhu sekalian mau tanya kalo aki kering sama basah bagusan mana ya? dari sisis ketahanan keawetan dengan pemilik yang rajin cek accu tentunya
bambangwijanarka
Post
by bambangwijanarka » Wed Mar 10, 2021 3:59
Valach wrote: oiya suhu sekalian mau tanya kalo aki kering sama basah bagusan mana ya? dari sisis ketahanan keawetan dengan pemilik yang rajin cek accu tentunya
Pengalaman kalo pake aki basah life time bisa sampe 5 thn,asal rajin cek level air.Kalo aki kering paling 2 thn an.Makanya lebih prefer aki basah drpada aki kering.
Valach
Post
by Valach » Wed Mar 10, 2021 5:53
bambangwijanarka wrote: ↑ Wed Mar 10, 2021 3:59
iya om.. saya rajin kok cek level air accunya sekalian cek lain lain macem air radiator sama rem dll. kalo suhu suhu dimari prefer pada pake accu apa om?
Jagonyaaki
Posts: 180 Joined: Mon Jan 11, 2016 2:08
Post
by Jagonyaaki » Wed Mar 10, 2021 7:08
Umur aki yg beredar d indo secara teori skrng sekitar 2 tahun an. Ad yg bilang merk/jenis A lbh awet dr merk/jenis B, begitu pula sebalik nya.. umur aki lbh k faktor pemakain, perawatan (aki basah), kondisi kendaraan, dan faktor hoki2 an.
Tp intinya kl sdh sampai 2 tahun bearti sdh ckp bagus, sukur2 bs lebih.
Kl ingin memilih aki kering pastikan kode produksinya jng lbh dr 6 bulan. Sukur2 dpt yg bener2 fresh..
Soal cca yg tercantum d kardus itu bukan menunjukan nilai cca yg sebenarnya. Beberapa kali cek rata2 selalu lbh besar nilai cca pd saat d tes ulang. Kadang2 beda alat tes bs beda nilai cca nya.
Cmiiw
Posts: 5684 Joined: Thu Jun 05, 2014 13:03
Post
by sintoni » Wed Mar 10, 2021 7:19
Kalau ane sih suka beli aki basah.
Soalnya kalau aki basah, kalau kita masukin air zuur kan baru diitung usianya, kalau aki kering ga.
Terus dulu pernah baca kalau untuk negara tropis lebih cocok aki basah, kjalau ga salah baca di SM jg.
triport13
Posts: 144 Joined: Thu Apr 26, 2018 7:08
Daily Vehicle: AVS
Post
by triport13 » Tue Mar 16, 2021 3:33
Numpang share suhu2,
Avanza 1.5S taun 2009 kilometer 120.[cencored]
Dari November 2016 pake Aki GS hybrid NS60 dan baru terasa berat banget di minggu pertama Maret 2021, akhirnya memutuskan untuk ganti pake Amaron NS60.
Tukang Akinya lumayan bingung sih kok akinya bisa awet banget, sebelumnya lagi pake GS hybrid juga di taun 2013 juli baru mati total di november 2016.
Untuk aksesori tambahan saya pake grounding cable aja pasang sendiri tapi ada tambahan extra fan dan audio (DSP dan Sub Kolong), apakah Grounding cable ini pengaruh ke keawetan aki suhu2?
well
Posts: 832 Joined: Thu Jul 02, 2020 3:03
Daily Vehicle: Sepeda Ontel
Post
by well » Tue Mar 16, 2021 3:58
sintoni wrote: ↑ Wed Mar 10, 2021 7:19
Saya jg suka aki basah, lbh murah... biasanya beli yg hybrid supaya penguapannya lbh minim..
terakhir beli 2018 november, sampe hari ini masih joss bgt.. air aki tidak pernah terlambat
Anggipopey2
Posts: 1 Joined: Mon Mar 29, 2021 11:37
Daily Vehicle: Avanza
Post
by Anggipopey2 » Mon Mar 29, 2021 11:45
Yg mw aki mobil motor saya ada lengkap,bisa jg untuk upgrade ke amper yg lbh besar bagi yg pecinta audio
Bisa telf/wa 088238252368
Bisa antar+pasang untuk para meber seraya
Gratisss...
Daerah serang,rangkasbitung,tanggerang
Post
by sintoni » Thu Jul 08, 2021 7:52
Untuk panther pikap 2.3 tipe aki yg dipake apa ya?
Apa bener NS70? Ada jg N70 beda dimana ya?
Posts: 26894 Joined: Sat Jan 31, 2009 17:48
Post
by DOHC » Thu Jul 08, 2021 8:42
sintoni wrote: ↑ Thu Jul 08, 2021 7:52
NS70 mirip ama aki bawaan panther kotak yg 4JA1 donk mbah ??
MSU
Posts: 1477 Joined: Sun Jan 06, 2019 2:51
Daily Vehicle: Diesel
Post
by MSU » Thu Jul 08, 2021 8:51
NS70 setau saya 65A...N70 baru 70A
BADAK
Posts: 6007 Joined: Fri Dec 21, 2007 4:45
Post
by BADAK » Thu Jul 08, 2021 12:34
Idealnya kasih N70Z aja. Biar ringan starter nya.
NS70 itu bawaan panther kapsul. Kl panther pickup lama N70. Kalo panther pickup baru bawaannya gak hafal.
Live as if you'll die today
Post
by sintoni » Thu Jul 08, 2021 13:15
DOHC wrote: ↑ Thu Jul 08, 2021 8:42
Bisa jadi mbah, ane ga tau bawaannya ini berapa.
BADAK wrote: ↑ Thu Jul 08, 2021 12:34
Lah, kalau dikasi NS70 aman aja kan om? Emang panther kapsul sama pikap bedanya dimana sampe perlu aki yg beda?
Beda lumayan dari NS70 ke N70 hampir 150rb. Hahaha.
Post
by DOHC » Thu Jul 08, 2021 13:54
sintoni wrote: ↑ Thu Jul 08, 2021 13:15
cari yg kpala nya sama aj mbah
ama amper minimal 65
Post
by sintoni » Thu Jul 08, 2021 14:15
DOHC wrote: ↑ Thu Jul 08, 2021 13:54
Iya mbah, kalau misal std ampere 70 dikasi 65 efek buruknya gimana ya?
Apa kalau starter harus lebi panjang?
Kalau keawetan bukannya tergantung di CCA ya?
Post
by DOHC » Thu Jul 08, 2021 15:04
sintoni wrote: ↑ Thu Jul 08, 2021 14:15
justru yg lazim nya biasa orang ganti aki itu ke ampere yg gedean mbah
kl kecilin, wah saya ga tau deh, belom perna coba jg
pernahmiskin
Posts: 677 Joined: Tue Apr 19, 2016 5:48
Post
by pernahmiskin » Thu Jul 08, 2021 15:50
Sy pakai incoe gold ns70 buat panther pick up dan semua canter sy setelah aki bawaan rewel.
Aki bawaan rata2 mentok 2 tahun.
Tukar tambah dgn aki lama nambah 600rb
Seapesnya minim 2 tahun baru rewel, kalau rejeki bisa 3tahun lebih.
Perawatan rajin cek air aja, dan per 6 bulan kasih edta 1sdm buat 6 lobang.
Post
by sintoni » Fri Jul 09, 2021 3:06
DOHC wrote: ↑ Thu Jul 08, 2021 15:04
Iya sih mbah, harganya beda jauh sihh.. Mungkin beli yg 65 Ampere aja lah..
pernahmiskin wrote: ↑ Thu Jul 08, 2021 15:50
Wah, makasih infonya om..
Akhirnya sudah bulat cukup beli yg NS70 aja.
