Ranking Dan Pemilihan Oli Mesin - PART 19
sahabatq8
Daily Vehicle: Nissan Xtrail
Re: Ranking Dan Pemilihan Oli Mesin - PART 19
Post by sahabatq8 »
AbdulHakim wrote: Fri Apr 19, 2024 11:18
marmut wrote: Fri Apr 19, 2024 9:17 cvt digeber?
mbah marmut,
mobil-mobil skrg sudah banyak yang pake E-CVT planetary gear bukan sabuk baja lagi.
IMHO isu sabuk baja cvt ambrol ke depannya bakal ditemui di mobil-mobil CVT konvensional saja, khususon yang oli matic dan filternya ga pernah diganti.
Yang gak pake belt bukanya hybrid ya. Kalo kyk raize gitu kan masih pake belt walaupun ada planetary gearnya
mbah marmut,
Pindah Cost Center aja itu mbah.
- Mesin bensin: biaya bbm dan ganti daleman cvt
- Hybrid: ganti batre
AbdulHakim
Post by AbdulHakim »
Suryaputra wrote: Fri Apr 19, 2024 12:06
mbah marmut,
exactly mbah Surya :big_grin:
sahabatq8 wrote: Fri Apr 19, 2024 11:54
mbah marmut,
iya betul om sahabatq8 mostly hybrid yang pure planetary gear, sedangkan yang duo kembar RR AvXen itu D-CVT low speed pake gear kalo high speed pake sabuk baja CVT CMIIW
Krigger
Daily Vehicle: L15zf - HRV E 2018
Post by Krigger »
Krigger wrote: Fri Apr 19, 2024 9:06
, kmrn digeber naik turun bukit ke tasik lewat nagrek libas tanpa perlu ganti ke S,
cvt digeber?
percuma donk mobil ane udah diurut sama suhu klo msh ambrol :mky_04: :big_smoking:
sesuai arahan mbah klo mobil mau panjang umur harus sering dibejekk... ............:ngacir:
MSU
Daily Vehicle: Diesel
Post by MSU »
AbdulHakim wrote: Fri Apr 19, 2024 12:30
mbah marmut,
mbah marmut,
Kayaknya kebalik om...planetary-nya di high speed >60kmh
Aneh jg logikanya kerja transmisi lebih berat pas stop & go ya
sahabatq8
Post by sahabatq8 »
mbah marmut,
mbah marmut,
Kalo si DCVT kebalikannya Toyota punya. D-CVT daihatsu malah planetarynya buat high speed. Yang low speed/launch pake gear biasa itu lexus apa gitu (mungkin toyota jg tapi saya lupa)
sahabatq8
Post by sahabatq8 »
MSU wrote: Fri Apr 19, 2024 12:48
Beda tujuan kykyna kalo si DCVT karena pairingnya mesin yang tenaganya pas pasan jadi biar powerloss lebih kecil dia pake gear biasa saat high speed.
mbah marmut,
apakah e-cvt sudah tidak menggunakan friction plate lg?
almer18
Daily Vehicle: Proton Exora
Post by almer18 »
Duvebriliant0 wrote: Fri Apr 19, 2024 6:50 sudah pas sebulan sejak ybs terakhir online :ngacir: :ngacir: :ngacir:
Wah rame lg.. Kita tunggu hasil tes labnya..
:ngacir: :big_smile]
Slipkopling
Daily Vehicle: k3ve
Post by Slipkopling »
sahabatq8 wrote: Fri Apr 19, 2024 12:51
Betul mbah, planetary dcvt aktifnya di high speed. Pernah liat di group malay perodua alza 2nr (avxen nya disni), oddo nya sudah 500.000++, tapi cvt masih aman. Belum pernah turun transmisi. :big_exellent:
AbdulHakim
marmut wrote: Fri Apr 19, 2024 14:32
mbah marmut,
daripada saya jadi sotoy dan ngasih jawabannya ngaco..
mending saya jawab jujur saja mbah, saya tidak tahu.
mungkin penjelasan dari video berikut ini dapat membantu
trebla88
Post by trebla88 »
Cvt rocky raize pake cvt daihatsu gear nya di high speed
Yg pake buat low speed cvtnya yoyota
Edit nemu merek ini kirain hitachi :upss:
RezPrat
Post by RezPrat »
Kayaknya bukan deh dcvt (dual CVT Daihatsu)itu yg d high speed pake gear. Pada low sampe not-so-fast speed ttp belt and pulley.
Yg di low speed pake gear itu juga DCVT(direct CVT) punyanya Toyota.
AbdulHakim
RezPrat wrote: Sat Apr 20, 2024 5:57
iya om, terimakasih
udah dikoreksi juga oleh suhu-suhu di atas :big_okay:
jacko
Daily Vehicle: Suzuki Ertiga
Post by jacko »
ijin bertakon mbah, kr saya ertiga 2013, kondisi unit sudah jalan 190 rb km, nah permasalahan dimesin tidak ada oli rembes,knalpot kering, garasi juga kering, tapi kenapa penyusutan oli tinggi ya mbah, oli yang pernah di pakai kyu kyu 5w30, total 5w 30 sam kerang 5w30, terakhir kemarin ganti pake fastron gold 5w 30 tapi sebelumnya di flush dengan menggunakan autoprofi line oil flush dengan system tuang di oli idel mesin 15 menit, kondisi sebelum ganti oli nguap sampe 800an ml per 5000 km. mohon arahannya mbah.
AbdulHakim wrote: Sat Apr 20, 2024 4:00
terimakasih... tp karena saya ketularan juragan delko, nontonnya masih dicepetin dan blm nemu clutch pack-nya.
nanti mau ditonton lg dgn saksama.
:big_deal:
sahabatq8
Post by sahabatq8 »
jacko wrote: Sat Apr 20, 2024 10:34 ijin bertakon mbah, kr saya ertiga 2013, kondisi unit sudah jalan 190 rb km, nah permasalahan dimesin tidak ada oli rembes,knalpot kering, garasi juga kering, tapi kenapa penyusutan oli tinggi ya mbah, oli yang pernah di pakai kyu kyu 5w30, total 5w 30 sam kerang 5w30, terakhir kemarin ganti pake fastron gold 5w 30 tapi sebelumnya di flush dengan menggunakan autoprofi line oil flush dengan system tuang di oli idel mesin 15 menit, kondisi sebelum ganti oli nguap sampe 800an ml per 5000 km. mohon arahannya mbah.
Cooling system sehat?
sudah cek warna busi?
kalau ada borescope, boleh diintip kondisi dinding silinder keempatnya spt apa.
odometer segitu yg paling masuk akal ya seal klep sudah mengeras (kalau pakai seal klep).
misal memang pakai seal klep dan sudah mengeras, wajar oli rembes masuk ke ruang bakar sedikit².
jacko
Post by jacko »
sahabatq8 wrote: Sun Apr 21, 2024 11:03
nah ini saya kepikiran jalur ini om, ada rencana mau ganti motor kipas sama thermostat, kalau air setiap dua tahun ganti pakai seiken yang 50%. sementara itu yang saya kepikiran, apakah ada tambahan selain yang disebut diatas om..
jacko
Post by jacko »
marmut wrote: Sun Apr 21, 2024 11:07
busi sampai saat ini bagus om, terakhir ganti 8 bulan yang lalu, pada saat uji emisi juga kemarin bagus semua.
untuk seal klep kemarin saya sudah ganti sendiri, memang sudah mengeras pada waktu dibongkar, baru 4 bulan yang lalu saya ganti seal klepnya.
untuk alat borescope masih belum dicoba om.
jacko wrote: Sun Apr 21, 2024 13:38
lha kalo ganti seal klep berarti angkat head.
kalo angkat head ya kondisi dinding silinder keliatan, kondisi ring piston jg ketauan..... ngga perlu borescope lg.
bos klep diukur nggak? ganti seal klep kalo ternyata bos klep dan/atau batang klep ikutan aus ya percuma.
jacko
Post by jacko »
marmut wrote: Sun Apr 21, 2024 13:50
hahahah maafkan om bukan seal klep yang saya ganti tapi seal busi. :big_peace: :big_peace:
MarYuko
Post by MarYuko »
mencoba 5w30 ecogreen buat GV, dapat di SPBU pertamina 230ribuan per galon 3,5L
impresi lumayan enak, mungkin dipake 5000km aja cukup....
MarYuko wrote: Mon Apr 22, 2024 3:25 mencoba 5w30 ecogreen buat GV, dapat di SPBU pertamina 230ribuan per galon 3,5L
klo ada fastron gold w30 sikat mbah.
MarYuko
Post by MarYuko »
Suryaputra wrote: Mon Apr 22, 2024 3:54
malah gk ada mbah, cuman ada yg techno 10w40 di SPBU sini
waktu ditanya mreka bilang emang gk pernah stok, maklum SPBU pedalaman
