ctopher7 wrote:
loetoeye wrote:
Suryaputra wrote: Tue May 24, 2022 4:56 Yep sy juga kayak gini.
Pakai sisa oli lama dan oli mesran baru ajah.
Karena oil-pan ini tempat nampung oli lama yg udah hitam.
Isinya debris dan unfiltered wear metal
terima kasih om, rencana mau ganti dari PTT dynamic common rail 10w-30 ke q8 ft7000 10w-30
wah sama nih kayak saya. dulu pake ptt 10w30 uda 5000 an uda berasa gaenak. ini pake ft7000 masih ngacir enteng halus aja. mesinnya 2gd
Kenapa T 7000 enak ?
Selain dia Full Syn, liatlah setrip merah
Turboman wrote: Tue May 24, 2022 14:52
Asoy, apalagi FT8800 yaa.
kantongnya aja yg agak ngeri apalagi buat oil-pan nya 2GD wkwkwkwk
sahabatq8
Daily Vehicle: Nissan Xtrail
Post by sahabatq8 »
Suryaputra wrote: Tue May 24, 2022 15:03
ctopher7 wrote: wah sama nih kayak saya. dulu pake ptt 10w30 uda 5000 an uda berasa gaenak. ini pake ft7000 masih ngacir enteng halus aja. mesinnya 2gd
Makanya biar gak penasaran, kapan nih mbah surya upgrade ke ipah rebon, ato mau sekalian ke fortuner 1gd :big_exellent:
yanuarra
Post by yanuarra »
Suryaputra wrote: Tue May 24, 2022 14:24
ctopher7 wrote: Tue May 24, 2022 13:09
Tim teng base oilnya udah enak.
Ibarat raw beans udh grade A
Jadi mau dibikin medium roast atau dark roast aromanya jg enak :big_biglaugh:
Kira2 ada data penjualan base oil secara global nggk ya om? Jd bisa kelihatan pemain besarnya siapa aja... :ungg:
Jgn2 amosil dpt base oil dari timteng :big_biglaugh:
Major players in the base oil market are Chevron Corporation, Exxon Mobil Corporation, Royal Dutch Shell Plc. , Ergon Inc. , Neste Oyj, Nynas AB, S-OIL CORPORATION, Sepahan Oil, Repsol S. A. , Sinopec Limited, BP PLC, Evonik Industries AG, H&R Group, Saudi Aramco, and SK Lubricants Co.
https://finance.yahoo.com/news/oil-glob ... 00263.html
Sepahan oil = Iran
S-OIL = di Korea, tapi parent company nya = Saudi Aramco
Nynas = Sweden
H&R Gruppe = German
Top 10 Lubricant producing nation
Singapore rank 2
Tuas industrial complex
Gileeee
https://www.oil-store.co.uk/blog/the-to ... c-182.html
Turboman wrote: Wed May 25, 2022 0:27 Top 10 Lubricant producing nation
Singapore rank 2
Gileeee
Udah gtu negaranya gak lbh besar dari jakarta pula :mky_01:
sahabatq8 wrote: Tue May 24, 2022 17:18
Turboman wrote: Tue May 24, 2022 14:52 Kenapa T 7000 enak ?
Aamiin
:mky_02:
Conceptu
Post by Conceptu »
Permisi om mau tny
Oli itu harus ada API SN /SP kah?
Soalnya saya beli oli motul specific 5w30 meet acea a5/b5 (katanya) tanpa API SN/SP… ane gagal paham mkstnya boleh tlg d bantu?
Cocok ga ya sama hyundai tucson?
sahabatq8
Post by sahabatq8 »
Conceptu wrote: Wed May 25, 2022 4:00 Permisi om mau tny
Tucson tahun berapa? Hyundai sih biasa gak pilih² olinya. Make sure aja mobilnya bukan yang perlu pake oli a3/b4 (biasanya 5w40).
Conceptu
Post by Conceptu »
sahabatq8 wrote: Wed May 25, 2022 4:15
2011 om.. di manual nya sih 0w 20 - 5w 30
Di oli nya Ga ada status API, cuma ada ACEA itu aman2 aja ya ? Maklum nubie msh kurang paham
sahabatq8
Post by sahabatq8 »
Conceptu wrote: Wed May 25, 2022 4:29
Aman om. Oli memang kadang ada yang sertifikasi/specnya gak lengkap. ACEA Eropa, kalo API US
yanuarra
Post by yanuarra »
Masi mending engga lengkap...
Dripd sertifikasi ada yg diragukan :big_biglaugh:
well
Daily Vehicle: Sepeda Ontel
Post by well »
om, mohon info, T7000 itu bener fully syntetic atau semi? krn di galonnya tidak tertulis full syntetic atau 100% syntetic.
kutumabok
Post by kutumabok »
Om,
Mohon advice kalo setelah dipakai 5400km TBNnya naik dan sootnya turun mungkin ga?
tksh
Full syn
yg 100% Synth itu yg T 8800 / T8900
well
Post by well »
Turboman wrote: Wed May 25, 2022 7:30
Full syn
Mohon koreksi om, setahu sy kalau tulisan syntetic itu biasanya semi sintetis.
Bedanya full sintetis dgn 100% apa om? Apkh 100% syntetis lbh bagus dibanding fully syntetis?
well wrote: Wed May 25, 2022 15:00
Full syn
100% synthetic > full syn > semi syn > mineral
Kualitasnya bagus mana?
Ya tergantung kualitas base oil, dan komposisi aditifnya.
Rumit, intinya mah beli sesuai budget aja dan pastikan asli dan ganti interval sesuai kemampuan oli tsb :big_grin:
kutumabok wrote: Wed May 25, 2022 7:03 tempsnip.png
Om,
tksh
Coba dikonfirmasi ke pihak lab.
Aditif Mg dan wear level Fe (iron) juga agak anomali itu. :upss:
well wrote: om, mohon info, T7000 itu bener fully syntetic atau semi? krn di galonnya tidak tertulis full syntetic atau 100% syntetic.
Full syn
di semua oli Grup 3 / 4 pasti ada sejumlah kecil oli mineral sebagai additive carrier, persentasi di bawah 10%......kalo yg high end di bawah 5%
kalo yg ditulis 100% Synth itu carrier additip pack nya udah pake Grup 3 oil kalo ga salah
CMIIW
vanosz
Post by vanosz »
ane lagi duduk ngopi di pagi hari sambil iseng pirit oli buat mobil ane yg hampir 2 taun blm ganti oli dan motor ane juga,ternyata ada oli bagus kekinian dengan harga terjangkau gans,langsung ane bayar tunai sbelum kehabisan,
ajib nih gans,bukan kaleng kaleng,cocok sama kaum kere ky ane gans,
penjualnya oficial store gans,mantap pake jiwa dan raga,
Bagoosssssss
Sonzz
Post by Sonzz »
Brio 1.2 CVT 2020 tuwir mau coba kembali ke Q8 0w-20 :big_weee: Sayang bgt kmrn ga kebagian promo yang dari Toda, asemmm
Lagi racunin Hrv 1.5 2017 doi dan Brio 1.2 2019 temen pake DGO 0w-16
Semoga DGO nya bisa long drain🤓
Mbah sobatq8
Ini gmn?
Kenal sm sellernya?
sahabatq8
Post by sahabatq8 »
Suryaputra wrote: Thu May 26, 2022 9:31 Mbah sobatq8
Ini gmn?
Kenal sm sellernya?
Gak tau itu siapa.
