honda karisma vs jupiter z
Gue mau tau kalo motor honda karisma di bandingkan dengan yamaha jupiter z lebih baik mana spesifikasinya....ada yg punya info?
TETAP SEMANGAT MAN...!!!!!
HONDA KARISMA :
Panjang x Lebar x Tinggi 1901x708x1078 mm.
Jarak sumbu roda 1246 mm.
Jarak terendah ke tanah 137 mm.
Berat kosong 102,2 kg (NF125D), 101,6 kg (NF125).
Tipe rangka Tulang punggung
Tipe suspensi depan Teleskopik
Tipe suspensi belakang Lengan ayun dan peredam kejut ganda.
Ukuran ban depan 2,50 – 17 38L
Ukuran ban belakang 2,75 – 17 41P
Rem depan Cakram hidrolis (NF125D), Tromol (NF125)
Rem belakang Sistem tromol
Kapasitas tangki bahan bakar 3,7 liter
Tipe mesin 4 langkah, SOHC, pendinginan udara
Diameter x langkah 52,4 x 57,9 mm.
Volume langkah 124.9 cc.
Perbandingan kompresi 9,0 : 1
Daya maksimum 9,3 PS/7500 rpm.
Torsi maksimum 10,1 N.m/4000 rpm.
Kapasitas minyak pelumas mesin 0.70 liter pada penggantian periodik
Kopeling Otomatis, tipe basah, tipe ganda
Gigi transmisi 4 kecepatan, rotary
Pola pengoperan gigi 1- N - 2 - 3 - 4 - N
Starter Pedal dan elektrik
Aki MF 12 V - 3,5 Ah
Busi ND U20EPR9, NGK CPR6EA-9
Sistem Pengapian CDI-DC, Battery
YAMAHA JUPITER Z :
Engine
Type................ SOHC 4 stroke
Bore x Stroke.............................. 51.0 mm x 54,0 mm
Displacement............................. 110,3 cc
Compression Ratio....................... 9.3 : 1
Carburation............................ VM 17 x 1 MIKUNI
Fuel Tank Capacity............................ 4,5 lt
Dimension
LxWxH...................... 1.910 x 675 x 1.040 mm
Seat height....................... 760 mm
Wheelbase............................ 1.225 mm
Minimum Ground Clearance................... 130 mm
Weight Tank Empty................. 97 kg
Chassis
Front Tyre...................... 70/90-17 38 P
Rear Tyre....................... 80/90-17 44 P
Rear Brake............................. Teromol
Front Suspension.................. Telescopic Fork
Rear Suspension.................. Swing Arm
Electric
Ignition System......................... CDI
Maximum Power......................... 9,0 PS/8000 rpm
Maximum Torque .................. 9,2 N-m/5000 rpm
YAMAHA JUPITER Z :
Engine
Dimension
Chassis
Electric
Re: honda karisma vs jupiter z
kalo kharisma punyanya anjas kalo jupiter punyanya om yongis tuh bung jetlag kalo utk bagus model n tarikan jupiter Z bagus ko kalo utk jalan jauh n irit kharisma tuhjetlag wrote:Gue mau tau kalo motor honda karisma di bandingkan dengan yamaha jupiter z lebih baik mana spesifikasinya....ada yg punya info?
1991 4T Honda CG 125
1994 2T Vespa VX 150 Super
1996 2T Yamaha RXZ 135
1998 2T Honda NSR 150R
2000 2T Yamaha RX King 135
2002 4T Suzuki New Shogun 110R
2005 4T Suzuki ShogunSP 125R
2008 4T Minerva 150R
hmmmm.....saya pake jupiter biasa gak puas nih.....ganti jupiter Z??? enggak lah yaw..kalo saya punya duit daku mo ganti Kharisma ajah....entah kenapa ngeliat bentuknya daku selalu ingat motor nya si rossi padahal gak ada miripnya sama sekali wong motor gp sama motor bebek lokal ,jauuh banget.......hehe
Bener banget. Gaya lekuk body-nya mirip-mirip RC112V. Mungkin disainnya mengacu kesana. Tapi gak jiplak abiz, soalnya kalu diterapin ke bebek gak pantes khan.
Yg daku rasa dilihat dari bentuk batok lampu depan yg meruncing, terutama dilihat dari samping. Truz bagian bokongnya juga melebar dan pinggirnya bersudut. Dilihat dari samping juga meruncing ke atas.
yup jupiter z pake teknologi mesin balap wah kalo me liat sih seimbang sama kharisma degh tapi kalo soal lari menang yamaha jupiter z degh
hehe me pernah iseng iseng main ke pameran disono ada stan yamaha trus me tanya jupiter z kenceng ngga eh kata si penjual bilang wah bisa jupiter z bisa ngejar shogun mas ehhe gw diem aja semabri ketawa hehe
shogun dilawan ngikuttt
