Moderators: Ryan Steele , sh00t , r12qiSonH4ji , avantgardebronze , akbarfit
trebla88
Posts: 631 Joined: Mon Jun 06, 2016 10:35
Post
by trebla88 » Thu Jun 23, 2022 6:33
blloewy wrote: ↑ Wed Jun 22, 2022 22:38
trebla88 wrote: ↑ Wed Jun 22, 2022 8:27
Abis dielus2 ma mbah dukun di garasi 58
Ganti minyak rem
Rekomen banget d sini dapet ilmu banyak
Next kuras oli cvt nunggu part dateng dari batam
L11 segera ke Beres ganti modul ABS plus karena CVT jadi minta update program CVT nya sesuai yang terbaru.
Harusnya keduanya free ya
Ga ada abs nya om
Airbag jg bebas recall nik nya
Cvt blm tahu uda diupdtae belum
Feb 2022 ini uda tap refill ama pemilkk sebelumnya di beres,kmungkinan ud adiupdate harusnya
Spies
Posts: 455 Joined: Thu Feb 11, 2021 6:17
Post
by Spies » Wed Aug 10, 2022 3:25
Mbah, kalo mesin HR15 pake busi nikel biasa apa ada pengaruh buruk ke mesin?
Standarnya kan pake busi iridium fxe20he11 itu
blloewy
Posts: 1924 Joined: Mon Nov 18, 2019 1:54
Daily Vehicle: HR15 - 2012
Post
by blloewy » Wed Aug 10, 2022 3:35
Spies wrote: ↑ Wed Aug 10, 2022 3:25
paling ya usianya aja ngga tahan lama mungkin Om.
Posts: 26930 Joined: Sat Jan 31, 2009 17:48
Post
by DOHC » Wed Aug 10, 2022 3:43
Busi nikel ??
Jangan2 abis dr j*smin ya ??
Kl ud ganti, mending cepet2 balikin lg ke iridium asalnya
Posts: 11332 Joined: Tue Apr 08, 2008 10:12
Post
by Omnibus » Wed Aug 10, 2022 3:47
DOHC wrote: ↑ Wed Aug 10, 2022 3:43
Busi nikel ??
bisa brebet emang mbah?
Post
by DOHC » Wed Aug 10, 2022 3:49
Omnibus wrote: ↑ Wed Aug 10, 2022 3:47
Busi nikel ??
Pertama brebet jarang2, lalu jd agak sering
Trus coil mati
Dan trakir kena ke sekring gede nya mbah, kl kata montir beres waktu itu, kita orang masi hoki tu sekring putus, kl ga kena ke ECU
blloewy
Post
by blloewy » Wed Aug 10, 2022 3:57
DOHC wrote: ↑ Wed Aug 10, 2022 3:49
Busi nikel ??
Trus coil mati
WUSYET...begimana nyang pake busi iridium KW 1000
busi nikel yg NHK 30 rebuan khan ada mbah klep...
ORI dari NHK.
Post
by Omnibus » Wed Aug 10, 2022 4:07
blloewy wrote: ↑ Wed Aug 10, 2022 3:57
Trus coil mati
ORI dari NHK.
yaa langsung brataktak kaya mobil rally ....
Post
by DOHC » Wed Aug 10, 2022 4:29
Trus coil mati
ORI dari NHK.
Soal bsa apa nga, kita orang ga brani iyain krn pengalaman dulu ama si j*smin dipakein busi nikel kaya gt
Akhirnya malah buntung, ganti coil 4 biji, busi iridium 4 biji, kena ongkos scan d beres
Beda ama inofa rebon, dipakein iridium atau nikel ga masalah
Post
by Omnibus » Wed Aug 10, 2022 5:41
DOHC wrote: ↑ Wed Aug 10, 2022 4:29
Trus coil mati
ORI dari NHK.
oh begini toh ceritanya .... ya ya ta catet dulu
pantes kesel langsung beli trelek ini itu beralih jd ngerjain sendiri
Spies
Post
by Spies » Wed Aug 10, 2022 6:03
Trus coil mati
ORI dari NHK.
Wkwkwk di toko ijo banyak yg beli itu
Trus coil mati
ORI dari NHK.
Wah ngeri juga kalo gitu mbah..
Berarti mending tetap pake iridium ya sesuai aslinya
blloewy
Post
by blloewy » Wed Aug 10, 2022 7:23
Spies wrote: ↑ Wed Aug 10, 2022 6:03
Kl bisa beli Iridium ya bagus
kl ngga sanggup pake platinum yg NHK dari beres juga sdh lumayan kok
Post
by DOHC » Wed Aug 10, 2022 7:52
Omnibus wrote: ↑ Wed Aug 10, 2022 5:41
ORI dari NHK.
Bener mbah
Mobil bersejarah itu
Blajar copot pasang ini itu, bahkan ampe subframe crossmember jg gara2 mobil itu
Akirnya skrg ud jago nyolong delko dr kolong jg gara2 mobil itu
Post
by DOHC » Wed Aug 10, 2022 7:55
blloewy wrote: ↑ Wed Aug 10, 2022 7:23
Kl kita orang seh highly saranin iridium yg bawaan ya, awet nya lmayan banget koq, 70-80 rebu km merem mata dapet lah
Sbiji nya jg blom smahal iridium nya si inofa rebon
Posts: 2916 Joined: Sat Aug 05, 2017 12:00
Post
by josomba » Wed Aug 10, 2022 8:07
DOHC wrote: ↑ Wed Aug 10, 2022 7:55
inofah kena berapa memangnya mbah buat sebiji iridium?
Post
by DOHC » Wed Aug 10, 2022 8:56
josomba wrote: ↑ Wed Aug 10, 2022 8:07
Dua ratus lima puluh ribu rupiah mbah
brehohisme
Posts: 14 Joined: Mon Aug 23, 2010 2:17
Post
by brehohisme » Thu Sep 08, 2022 1:07
Pagi rekan2 SM, mau tanya, livina sy (L10 1.18AT 11’) kl jalan ada bunyi dengung halus sekali, dan kl turunan panjang seperti ada bunyi besi begesek mayan keras, makin kenceng kecepatannya makin keras, itu knp ya biasanya? Tks sblmnya
blloewy
Post
by blloewy » Thu Sep 08, 2022 1:17
brehohisme wrote: ↑ Thu Sep 08, 2022 1:07
cek bearing roda dan ball joint atau sekitaran kaki2.
Spies
Post
by Spies » Thu Sep 08, 2022 6:23
Kemarin iseng cek TB udah item banget.. Dibersihin deh pake carb cleaner sampe kinclong, sengaja soket tb ga dicabut..
Habis bersih2 reset ecu manual via pedal gas..
Tapi kok sekarang idle jadi 950 rpm ya
Terus pas oper gigi rpm nya kaya gantung gitu, lambat turunnya
blloewy
Post
by blloewy » Thu Sep 08, 2022 6:55
Spies wrote: ↑ Thu Sep 08, 2022 6:23
reset ngga sempurna
terus cek lagi buka tutup katup kupu2 nya itu msh ada kotoran apa ngga.
atau ada kotoran nyangkut ngga keluar dari dalam TB
Posts: 11034 Joined: Wed Oct 16, 2013 6:27
Post
by marmut » Thu Sep 08, 2022 7:14
blloewy wrote: ↑ Thu Sep 08, 2022 6:55
reset ngga sempurna
musti
dulu ke mbah suhu
Post
by DOHC » Thu Sep 08, 2022 8:50
marmut wrote: ↑ Thu Sep 08, 2022 7:14
reset ngga sempurna
musti
dulu ke mbah suhu
The real mbah nya lipindut ini
Post
by marmut » Thu Sep 08, 2022 9:16
tul.
saya banyak belajar dari beliau.
Post
by DOHC » Thu Sep 08, 2022 9:31
marmut wrote: ↑ Thu Sep 08, 2022 9:16
tul.
uda bole lah gantiin si j0k0 nya j*smin
Post
by marmut » Thu Sep 08, 2022 12:21
saya curiga udah tandem ama mbah nyang atu lagi buka tapi gaada plang. jadi setengah ilegal....
