kompresorz
Post by kompresorz »
Turboman wrote: Tue Dec 17, 2019 3:09 ReMap mantap di ACT
suara mesin tetap alus
Mesin tetap terasa spt mesin std tapi dgn cc lebih besar, mesin 4 Cyl jadi serasa spt mesin V6 / V8 std
ini gw demennn....
toyota gitu lohhhh...
ehhhhh diseelll....
tenaga setara v8 tapi kencang irit....semriwing booooo......
apalg pigibakkkkkk..........
bisa putus V8...
stop n go.....
Auror
Daily Vehicle: Innova Diesel
Post by Auror »
Turboman wrote: Fri Nov 22, 2019 8:56 Perawatan & Penyehatan mesin
- Purging tiap 20 - 25 rb km
- Kuras tangki tiap 80 rb km
- Air filter pastikan bersih
- EGR tutup
Om, utk obat purging om turbo bisikin dong pake apa. Mbl saya innova diesel apa bisa pakai jg?
Thank you om turbo. :mky_01:
- EGR tutup
Bisik ???
Rajin2 Browse2 & Gugel aja.......
Riki9988
Daily Vehicle: Mobil
Post by Riki9988 »
ACT itu apa ya om,,? Dan dmn...??
Turboman wrote:ReMap mantap di ACT
Auto Cartrix qq si B3bonk
Paramon Serpong
tuh ada trit nya, owner nya juga monitor SM
Riki9988 wrote:ACT itu apa ya om,,? Dan dmn...??
Mrvin
Post by Mrvin »
Auror wrote: Tue Dec 31, 2019 17:47
- EGR tutup
Bantu jawab, kalo saya sih dulu pake merk HWK injector cleaner bagus sih... Kerasa perbedaan nya setelah di purging
Atau alternatif lainnya jg bisa merk liqui moly diesel purge
supergiant
Daily Vehicle: avanza + panther AT and 2KD on weekend
Post by supergiant »
Mau share pengalaman liburan:
PP di tol trans jawa pakai biosol
berangkat abis 3 kaleng PTT Diesel
pulang pakai PSDK dgn perbandingan 1 ml vs 20 ltr
hasilnya sdh tdk bisa berpaling ke lain hati deh
tommi1756
Daily Vehicle: bajaj
Post by tommi1756 »
supergiant wrote: Thu Jan 02, 2020 1:49 Mau share pengalaman liburan:
wih PSDK nya awet bgt dong ya bisa buat ratusan kali ngisi..btw cara masukin 1 ml atau 3 ml/60 liter gmn cara nya om? pake sendok obat??
PSDK paling mantap = 200 ml / 50 L solar
minimal 150 ml lah
100 ml mah kurang
cuman suara mesin gak sehalus PTT DFC
evanbngdor
Post by evanbngdor »
Turboman wrote: Thu Jan 02, 2020 3:42 PSDK paling mantap = 200 ml / 50 L solar
minimal 150 ml lah
100 ml mah kurang
Nah bener nih, saya jg baru aja coba PTT DFC 1 kaleng untuk full tank Innova, ditambah lg mesin baru ganti pake oli delvac 1. Suara pas idle sih masih kedengeran ketukan khas diesel, tp begitu digas apalagi waktu RPM tinggi berasa kayak mesin bensin.
:mky_02:
Cuma kayaknya tenaga terutama RPM tinggi masih lebih oke PSDK dikiiiiiit
2016 - Honda CRV 2.0 M/T
supergiant
tommi1756 wrote: Thu Jan 02, 2020 2:53 wih PSDK nya awet bgt dong ya bisa buat ratusan kali ngisi..btw cara masukin 1 ml atau 3 ml/60 liter gmn cara nya om? pake sendok obat??
maaf salah: 100ml untuk 20ltr solar, pakai botol bekas obat yg 100ml
hasilnya joss bgt ya PSDK,
tadinya sdh skeptis sih, pakai aditif kaya ngga ada beda nya.
PTT padahal sempat dipakai agak kental 1 kaleng vs 30 liter juga.
soal suara hiks maaf kok ga bisa bedain ya antara biosol polos vs ptt vs psdk
K8055PK
Post by K8055PK »
numpang curhat om.
2kd tua lagi flu, tiap di starter pagi keluar asap putih beberapa detik, hbs itu normal.
kira2 apanya ya om?
benzz89
Post by benzz89 »
Ane juga baru selingkuh lagi ke PSDK. Sebelumnya ACB + SDT.
PSDK 200 ml per 40 literan bio solar sih lebih jos yah banding ACB 100 ml + SDT 100 ml per 40 literan bio solar.
Kedepannya kayanya bakalan stick di PSDK aja, gak ribet urus 2 racun.
ACB + SDT sih mesin lebih halus dikit banding PSDK, tapi tendangan tenaga beda lumayan (PSDK menang)
K8055PK wrote:numpang curhat om.
kira2 apanya ya om?
Purging udah ?
Do
- Supply pump initialize
- Injector qty learn
with Scanner
K8055PK
Post by K8055PK »
Turboman wrote: Thu Jan 02, 2020 6:40
kira2 apanya ya om?
Purging udah ?
Do
with Scanner
purging baru 3bln
kemarin habis ganti ring piston, hbs itu sy lht di reset semua injecting sistemnya, trmsk supply pump intialize, g tau kl yg injector quantity learning.
dari baunya g kyk oli bocor / rembes tp kyk bau asem solar. mngkn mirip2 mesin karbu kebanjiran bensin.
kira2 apanya ya om?
Purging udah ?
Do
with Scanner
purging baru 3bln
Ganti ring piston ?
Odo udah 500 rb - 1 jt Km ?
apa pernah kena oli acdc ?
arau pernah naek hp sampe 300 lebih ?
K8055PK
Post by K8055PK »
Turboman wrote: Thu Jan 02, 2020 9:27
K8055PK wrote:
Turboman wrote: Thu Jan 02, 2020 6:40 Purging udah ?
Do
with Scanner
purging baru 3bln
Ganti ring piston ?
odo 220rb
oli sepertinya aman
cm remap kurleb 140an hp
2th lalu sblm remap jg ganti ring piston, kata bengkelnya ring & packing setnya ori tapi gbox jd jebol. trs kemarin pakai ring TP japan & packing silinder head ori tp made in china.
aneh juga KM 220 rb udah ganti ring
itu Ipah KaWe 2005 tuningan Bkl Usaha kita yg tiap bulan ikut Drag, odo udah 400 rb km lebih belom pernah ganti ring, mesin masih sehat, padahal spec 280 bhp
K8055PK wrote: purging baru 3bln
Ganti ring piston ?
odo 220rb
oli sepertinya aman
Auror
Post by Auror »
Mrvin wrote: Wed Jan 01, 2020 14:56
- EGR tutup
Thank you om mrvin.. setelah googling2 bingung antara xado, liqui moly, wynns. Coba deh cari d toko ijo hwk nya.
SPBU AKR kembali jual Solar subsidi 5150 di th 2020....
https://www.akr.co.id/news-detail/akra- ... tahun-2020
aipiesblue
Post by aipiesblue »
nyebrang ke bali ya om sampe habis 3 botol?
saya kemarenan PP ke jkt-jogja pake 2GD cuman ngabisin 2 kaleng PTT.
DrgFredysen
Daily Vehicle: Innova diesel
Post by DrgFredysen »
Om, mau nanya donk. Tensioner innova diesel normal kah bergetar? Tidak oblak, cuman goyang2 naik turun selaras aksis fanbelt. Pas cuci mobil dibilang sama tukang cuci mobil perlu ganti. Pas dibawa ke bengkel kenalan katanya normal. Yang benar yang mana ya? Kondisi setiap siap cuci mobil bunyi tali kipas kuramg lebih 20 menit.
evanbngdor
DrgFredysen wrote: Sun Jan 05, 2020 16:15 Om, mau nanya donk. Tensioner innova diesel normal kah bergetar? Tidak oblak, cuman goyang2 naik turun selaras aksis fanbelt. Pas cuci mobil dibilang sama tukang cuci mobil perlu ganti. Pas dibawa ke bengkel kenalan katanya normal. Yang benar yang mana ya? Kondisi setiap siap cuci mobil bunyi tali kipas kuramg lebih 20 menit.
Tensioner fan belt sih memang auto adjust cuma kalo sampe bergetar sih ngga beres itu. Fan belt berdecit jg mesti diperiksa apa udah getas atau gimana.
Usia berapa tahun/KM itu fanbelt&tensioner?
DrgFredysen
evanbngdor wrote: Mon Jan 06, 2020 2:19
Dia bergetarnya naik turun seperti auto adjust kadang butuh longgar kadang butuh ketat. Tidak oblak. Km 60rb km, uda 7 tahun si fan belt nya. Cek fisik si gak ada retakan. Sangsi lahar tensioner nya. Soalnya 1 bengkel(plus cuci mobil) bilang lahar tensioner nya kena. 2 bengkel luar malah bilang normal.
DrgFredysen
Takut dikadalin sama bengkel doorsmeer.
