Om turbo, kalo oli yg bagus buat mesin hyundai CRDi merk apa ? Budget maksimal 300rb per liter, di buku manual minta buntut 30 atau 40 acea b4Turboman wrote: Sun Aug 25, 2019 14:24posting hrs lewatin 10 dululaoshizaoan wrote:Maaf om sy msh newbie disini, ga bisa upload foto. apa ada email? Saya email lgsg foto manual book nya. Terima kasihTurboman wrote: Sun Aug 25, 2019 12:40 Coba tolong difoto manual booknya
lebih direkomen 506.01 atau 505.01
gini aja
utk Ambient 30 - 40 C
lebih rekomen 505 atau 506
Daftar oli mesin Diesel yg bikin suara mesin jadi halus
- Daily Vehicle: D4-D and CRDi
Re: Daftar oli mesin Diesel yg bikin suara mesin jadi halus
PTT 5W40 Commonraillaoshizaoan wrote:Enggak ada tulisan gitu om, hanya tertulis spt ini di table nyaTurboman wrote: Sun Aug 25, 2019 14:24posting hrs lewatin 10 dululaoshizaoan wrote: Maaf om sy msh newbie disini, ga bisa upload foto. apa ada email? Saya email lgsg foto manual book nya. Terima kasih
gini aja
All diesel engine without DPF:
Flexible service QI6 (LongLife) VW 506 01
Fixed service QI1, QI2, QI3, QI4, QI7 (based on time/ distance travelled) VW 505 01
The engine oil listed are multigrade high-lubricity oils.
Trus ada tulisan juga;
Another engine oil can be used in the event of emergency if the listed engine oils are not available. To avoid damaging the engine, a maximum quantity of 0.5 liters of the following engine oil may be used only once until hr next oil change:
Diesel engine - standards ACEA C3 or API CJ-4.
Terima kasih
meet VW 505
Ptt 5w40 commonrail yang comply vw505 belum ada sy liat ya om di blibli. Kaya nya yang baru masuk 5w30 aja.Turboman wrote: Mon Aug 26, 2019 1:39PTT 5W40 Commonraillaoshizaoan wrote:Enggak ada tulisan gitu om, hanya tertulis spt ini di table nyaTurboman wrote: Sun Aug 25, 2019 14:24 posting hrs lewatin 10 dulu
gini aja
Terima kasih
meet VW 505
- Daily Vehicle: GUN165R
Iki apik ora mbah Turbo aka Mr A gona 2gd ku
Kalo di banding dgn ptt 5w30 piye mbah?
"BURN RUBBER NOT YOUR SOUL"
M CRDi TBN 9 - 10theansoracing wrote:Iki apik ora mbah Turbo aka Mr A gona 2gd ku
M TRD TBN 7,7
utk BioSol sih pilih seng CRDi
dicoba aja
Biosol pake crdi yah, kalo yg trd pake dex yahTurboman wrote:M CRDi TBN 9 - 10theansoracing wrote:Iki apik ora mbah Turbo aka Mr A gona 2gd ku
M TRD TBN 7,7
dicoba aja
Bener gak?
Oke kan ke 2 tipe oli tsb? Kayak nya motul gak pernah salah bikin oli deh. Cmiiw yah
Yg mantap itu harusnyatheansoracing wrote:Biosol pake crdi yah, kalo yg trd pake dex yahTurboman wrote:M CRDi TBN 9 - 10theansoracing wrote:Iki apik ora mbah Turbo aka Mr A gona 2gd ku
M TRD TBN 7,7
dicoba aja
Bener gak?
MOTUL TEKMA OPTIMA 5W30 & ULTIMA+ 5W30 API CJ-4
Coba aja cari2 siapa tahu ada yg jual
wkwkwwkw
Wah dia tertawa, tanda apakah ini? HeheheTurboman wrote:Yg mantap itu harusnyatheansoracing wrote:Biosol pake crdi yah, kalo yg trd pake dex yahTurboman wrote:M CRDi TBN 9 - 10
M TRD TBN 7,7
dicoba aja
Bener gak?
wkwkwwkw
- Daily Vehicle: G4EE MT 2011 + Hi Grade 1995 C223
Artinya, pake aja oli fav om, test lab. Share d sini. Baru tahu arti nya... [emoji16]theansoracing wrote:Wah dia tertawa, tanda apakah ini? HeheheTurboman wrote:Yg mantap itu harusnyatheansoracing wrote:Biosol pake crdi yah, kalo yg trd pake dex yah
Bener gak?
wkwkwwkw
i am, a sleeper
Baru newbie di diesel/solar, biasa bensin. Makanya berguru disini...bembenk95 wrote:Artinya, pake aja oli fav om, test lab. Share d sini. Baru tahu arti nya... [emoji16]theansoracing wrote:Wah dia tertawa, tanda apakah ini? HeheheTurboman wrote:Yg mantap itu harusnya
wkwkwwkw
525rb neh
Menggiurkan sekali
Menggiurkan sekali
ini barangnya Sumber Berkattheansoracing wrote:525rb neh
Menggiurkan sekali
dulu pernah dapatin PDS HKS Diesel oil yg kemasan lama, termasuk oli low SAPS
masuk akal krn std emisi di Japan sgt ketat, Diesel pada pake DPF
Sumber berkat distributor resmi HKS yg di sawah besar yah. Oli lama berarti, yg jual di bekasi iniTurboman wrote:ini barangnya Sumber Berkattheansoracing wrote:525rb neh
Menggiurkan sekali
Berarti terpercaya yah seller nya
Btw cocok buat 2gd gak pak
Sumber Berkat kantornya di Jl Sangaji - Petojo omtheansoracing wrote:Sumber berkat distributor resmi HKS yg di sawah besar yah. Oli lama berarti, yg jual di bekasi iniTurboman wrote:ini barangnya Sumber Berkattheansoracing wrote:525rb neh
Menggiurkan sekali
mrk punya gedung sendiri 8 lantai, mrk pegang puluhan merek produk automotive aftermarket & OE product
ya buat 2GD dicoba aja pake 7500 km misal, abis itu test lab biar afdol
Eh iya di sangaji deh lupa soalnya, iya dia multi suplai brg2 ajib juga tuhTurboman wrote:Sumber Berkat kantornya di Jl Sangaji - Petojo omtheansoracing wrote:Sumber berkat distributor resmi HKS yg di sawah besar yah. Oli lama berarti, yg jual di bekasi iniTurboman wrote:ini barangnya Sumber Berkat
Owhhh kirain udah pernah pakai juga
Hehehehe
- Daily Vehicle: SR3
Kalo buat longtrip jakarta-medan (total 5000 km sktr 2 minggu), gaya bawa agresif, bakal enakan pake maxduty 5w30 atau turbotruck 5w40 ya?
Kalo 2GD memang std nya 5W30Boeds wrote:Kalo buat longtrip jakarta-medan (total 5000 km sktr 2 minggu), gaya bawa agresif, bakal enakan pake maxduty 5w30 atau turbotruck 5w40 ya?
Kalo di 2KD utk Road trip rekomen buntut 40
Ini buat antb om. Akhir tahun rencana roadtrip jkt-medan.
Saya rencana buang oli acdelco dr beres, sudah jalan hampir 1000km. Weekend ini mau ke dieng. Mungkin dibuang di sekitar 2000-3000km. Sekitar 1 sp 2 bulan lagi. Supaya perkiraan amsoilnya dipake sampai sktr 7000-8000 km. Pulang dr medan baru ganti oli lagi.
Maxduty dan turbotruck sudah di tangan, tinggal mutusin mana yg mo dipake duluan yg lebih enak buat longtrip.
MaxDuty 5W30 dgn HTHS 3.5 bisaBoeds wrote:Ini buat antb om. Akhir tahun rencana roadtrip jkt-medan.
kalo HTHS, turboctruck 5w40 menang lumayan, 4.2 vs 3.5Turboman wrote: Thu Aug 29, 2019 2:27MaxDuty 5W30 dgn HTHS 3.5 bisaBoeds wrote:Ini buat antb om. Akhir tahun rencana roadtrip jkt-medan.
antiwear lebih rendah, 4x vs 6x. kalo spec sih mungkin mirip" ya.
lebih ke "fungsi pelumasan" paling optimal yg mana buat continuously long driving.
harapannya juga sekalian semacam "cuci mesin" setelah selama ini pake oli dr beres.
- Daily Vehicle: Nouvo Z
Kalo unilopal opaljet longlife 3 dexos 2 5w-30 buat captiva fl2 diesel gmn om turbo?
- Daily Vehicle: HRV
Abis tuang oli ptt 5w30 untuk gantiin oli dari beres , suara berubah lebih halus di bandinkan oli sebelumnya. Fc belum di tes
5W40 Full Syn Diesel harga miring
Buat :
- 2KD / 2KD VNT & 2KD modip
- 4D56 Dakar modip
- 2GD yang pake RHF4
- 4N15 ReMap dgn Boost 1,7 bar / up
TBN 10
SAPS 1,2 %
MB 228.3
VW 502 / 505
ACEA A3/B4 - 16 (edisi 2016)
https://www.blibli.com/p/ptt-lubricants ... 60036.html
* bukan seles oli *
Buat :
- 4D56 Dakar modip
TBN 10
SAPS 1,2 %
MB 228.3
VW 502 / 505
* bukan seles oli *
Low SAPS kan itudonype wrote:Kalo unilopal opaljet longlife 3 dexos 2 5w-30 buat captiva fl2 diesel gmn om turbo?
Low SAPS idealnya utk solar Euro 5
Buat 2gd standar dar dar gak cocok yah pakTurboman wrote:5W40 Full Syn Diesel harga miring
Buat :
- 4D56 Dakar modip
TBN 10
SAPS 1,2 %
MB 228.3
VW 502 / 505
* bukan seles oli *
