Ranking Dan Pemilihan Oli Mesin - PART 03
juanaxel
Re: Ranking Dan Pemilihan Oli Mesin - PART 03
Post by juanaxel »
takehito wrote:apa kaga salah tuh bro?? shell helix ultra dipake sampai 20 ribu kilo???
bro grade ACEA nya shell helix ultra apa ya???
setau gw itu kan utamanya buat oli mesin bensin.... kalo dipake utk mesin diesel, shrsnya malah kaga bisa panjang km-nya...
karena beda karakteristik oli diesel dg bensin.
Shell answer :
Principle it is correct, that diesel
engines and gasoline
engines has different rquirements
to the lubrication.
Diesel engines: requirements for
more cleaning additives for soot.
Gasoline engines: special
requirements for heat and
shearing
stability.
But, according SHELLs experience, that not always the correct
oil is used for the right motortype,
they are forced to develope
both oils (SHELL HELIX ULTRA and
SHELL HELIX ULTRA DIESEL) so,
that they can be used in both engine types without demaging it.
Shell helix ultra acea B4, api SM/CF, MB229,5.
Saya ganti shell helix ultra pas 20rb km bro, bukannya di pakai sampai 20rb km.
juanaxel
Post by juanaxel »
Acea B4, bukannya dipakai sampai 20rb km bro tp saya ganti pas 20rb km.
Salah satu petunjuknya bro :
www.digest.net/bmw/archive/v7/msg06569.html
report ahh... abis ganti oli utk lipina ane...
pake oli idemitsu full syn yg 5W-30... dpt harga miring dan penghabisan stok beli salah satu toko d atrium...
performance blom banyak yg bsa di komen, scara mesin jg abis di carb jet ama ganti busi dan filter udara, tarikan jelas enteng....
next project, ganti oli si ipah pake q8 yg 5W-30... mudah2an bisa ngobatin bunyi tek2 kalo cold start...
DOHC wrote:report ahh... abis ganti oli utk lipina ane...
Ipah dah jalan brp ?
Kalo dah jalan jauh bgt bisa coba pake oli high detergent dulu utk membersihkan jalur HLA, pake aja 4000 km. Prefer oli Diesel API CI-4
dah jalan 117 rebu km...
oli diesel yg direcommend ama um turbo sendiri apa nehh om ?? trus kalo cuman buat nge flushing gt doank, ane perlu ganti oli filter nya ga, atau nanti stelah selsai flushing 4000 km baru dehh ane ganti oli ama filter nya ??
btw, um turbo cek pm donk, yg mengenai bengkel kelistrikan ipah itu.... thanks..
takehito
Post by takehito »
bro turboman, ane mau nanya nih, kalo oli diesel 10W-40 atau 5W-40 grade CJ-4/SM, ACEA E9, bagus ngga ya??
lebih bagus mana dengan oli dengan ACEA A3/B4, pemakaian utk pajero sport diesel.
takehito wrote:bro turboman, ane mau nanya nih, kalo oli diesel 10W-40 atau 5W-40 grade CJ-4/SM, ACEA E9, bagus ngga ya??
API CJ-4 oke bisa dipake
Kalo API CJ-4 vs oli yg hanya ACEA B4 itu plus - minuslah, masih unggul API CJ-4 sedikit
Tapi kalo API CJ-4 vs CI-4 maka saya akan pilih CI-4 kemana mana
Ini karena kadar sulphur solar di kita tinggi, butuh oli high SAPS / high TBN.
olinya ctv diesel dari dealer
kalo ga salah pernah liat di majalah, ini oli buatan kuwait
klaimnya kuat sampe 20.000km, tapi disarankan 10.000km ganti
bagus ga ya....
juanaxel
Post by juanaxel »
harga nya brp bro evolution?
evolution21 wrote:olinya ctv diesel dari dealer
bagus ga ya....
Dexos 2 / MB 229.51
Jalan 10.000 Km sih mestinya bisa, kalau mau aman ya 7500 Km ganti, karena itu oli Low SAPS sedang di kita solar masih sulphur tinggi.
Kalo mau jalan 10.000 Km maka sebaiknya EGR mesin ditutup.
Oli Q8 buatan Rotterdam, kalau merek Q8 sendiri mmg benar punyanya Kuwait Petr.
harganya sekitar 150rb / liter
ok thanks sarannya um turbo :)
@ evolution : mahal amat om harganya... di atrium ane dapet yg 5w-30 aja sliter cuman 80rebu...
itu harga ane tanya ama bag bengkel dealer chevy
mungkin mahal karena ini harga dealer emang biasa kalah dibanding harga toko kan?
salah obat
Post by salah obat »
mau tanya tentang Motul CRDi Diesel 5W-40 itu bener oli khusus diesel ya?
kok api-nya SL? klo acea-nya B4..
salah obat wrote:mau tanya tentang Motul CRDi Diesel 5W-40 itu bener oli khusus diesel ya?
Ya API SL, karena menyangkut kadar ZDDP nya dimana mesin2 Diesel masih banyak yg flat tappet / sliding / rocker arm baut dan belom banyak yg roller rocker arm, juga terkait kadar SAPS en TBN dimana oli Diesel butuh detergent lebih banyak.
ya oli tsb kalo mau dipake di mesin bensin juga oke sih, malah jarak tempuh bisa lebih jauh drpd API SM.
DOHC wrote:@ evolution : mahal amat om harganya... di atrium ane dapet yg 5w-30 aja sliter cuman 80rebu...
Yg di Atrium mungkin Formula Special aja
Yg di BeRes Chevy : Formula Special G LongLife - Dexos 2, beda type, kelasnya lebih tinggi yg G LongLife
boed2
Post by boed2 »
Bro Turboman, kalau dilihat di
http://www.q8oils.com/uploads/com/broch ... r_oils.pdf
Q8 Long Life oil ada V , M , R dan G
Kalau diliat dari info di brosur tsb. bedanya apa yah?
kalo ane ga salah inget sehh yg G long life itu om... pokok nya ada long life nya dehh..
btw utk yg Q8, ane ada pake buat panther PU ane nehh.. yg formula advance diesel 10W-40... skilas kalo diliat sehh warna nya agak gelap yahh... dan bau nya pun jg beda ama oli2 semi syn merek laen nya.... tp utk sementara yg ane amati, suara si panty lebi alus...
m4rio
Post by m4rio »
DOHC wrote:btw utk yg Q8, ane ada pake buat panther PU ane nehh.. yg formula advance diesel 10W-40... skilas kalo diliat sehh warna nya agak gelap yahh... dan bau nya pun jg beda ama oli2 semi syn merek laen nya.... tp utk sementara yg ane amati, suara si panty lebi alus...
berapaan harga oli-nya klep??? ane tunggu review selanjutnya ya broo tentang oli nie, kalo bagus n harga cocok boleh juga nih ane coba.
kisaran 50an rebu per liter mar... sejauh ini sehh ane coba hasil nya ckup positif... suara si panty lebi alus... utk respon mesin dan tarikan sehh enteng2 aja, scara mesin panther kan sebenernya minta oli kentel... kalo dikasi oli encer yahhh jelas enteng... dan lagi ini oli masi aseli buatan eropa sana walaupun merek nya asal kuwait...
imsus2c
Post by imsus2c »
tempohari sebenarnya mau pakai ini juga, di mesin bensin...
tapi berhubung karena berbagai hal, akhirnya malah coba fastron gold 5w30 SN :mky_01:
imsus2c
Post by imsus2c »
DOHC wrote:kisaran 50an rebu per liter mar... sejauh ini sehh ane coba hasil nya ckup positif... suara si panty lebi alus... utk respon mesin dan tarikan sehh enteng2 aja, scara mesin panther kan sebenernya minta oli kentel... kalo dikasi oli encer yahhh jelas enteng... dan lagi ini oli masi aseli buatan eropa sana walaupun merek nya asal kuwait...
pengurangan volume gimana meneer? siapa tau pakai oli lebih encer, musti sering top up? atau masih tetap (tdiak ada pengurangan) :ungg:
sejauh ini sehh uda jalan ampir 1000 km, blom ada pengurangan volume oli meneer...
imsus2c
Post by imsus2c »
DOHC wrote:sejauh ini sehh uda jalan ampir 1000 km, blom ada pengurangan volume oli meneer...
bagus dong...
bisa dari jeroan mesin yg masih sip, atau memang jenis olinya yg minim pengurangan
soalnya di mesin singa HDI, pakai oli 15w40 (meditran dan motul tekma), pengurangan minim, paling nambah 0.75-1L menjelang ganti oli (5000KM), tapi waktu pakai SHX7-Diesel 10w40, minimal nambah 1.5-2L tiap 1x periode pakai oli (5000km juga), jadi nambah 0.5L tiap 1500km
kenapa ya? :ungg:
