Ranking Dan Pemilihan Oli Mesin - PART 18
Re: Ranking Dan Pemilihan Oli Mesin - PART 18
Fookyoo wrote: Sun Oct 01, 2023 2:03
Suryaputra wrote: Thu Sep 28, 2023 16:06
dinatara wrote: Thu Sep 28, 2023 14:50
Belum sempet cek dipstik mbah, ntar deh saya liat2 dulu dipstik nya
Klo liat standart2 nya, nih PFG uda oke punya bgt ya. Secara bardahl S9 masih dexos 1.
Untuk UOA mbah saturday pake PFG, point mana yg mewakili ketahanan oli untuk dipake jangka waktu lama mbah?
Visco @100C (bandingin sm pds)
Tbn (>2,5 msh ok)
Case by case,
- Oxi
- Sulfur
- Soot
Halo Om.
Baru ambil Swift Sport 2014 with M16A engine, CR 11:1.
The previous owner selalu pakai SGO, nurut BeRes aja.
Any advice pakai oli 5W-30 apa?
Dulu di Mark X selalu pakai PTT atau TQ9000, tapi udah lama gak ikutin dunia oli2-an.
Any opinion or data on Gulf Ultrasynth / Bardhal / Kixx?
Atau tetep TQ9000 aja ya?
Thank you, Om :big_deal:
Halo mbah gan
Iya stick ke 5w30 merk apapun dan ori.
Harga 100rb seliter and up, ganti tiap 5rb km dan filter oli jg ganti.
AbdulHakim wrote: Fri Sep 29, 2023 9:00
Ukuran gasket baut oil drain ini universal khan ya?
Diameter Dalam 12mm
Diameter Luar 21mm
inner diameter 12mm alias M12 dipakai mayoritas toyodai.
mobil lain ada yg M14.
AbdulHakim
Post by AbdulHakim »
marmut wrote: Sun Oct 01, 2023 2:20
Diameter Dalam 12mm
Diameter Luar 21mm
noted mbah marmut, kalo Honda L15 series pake M12 apa M14 mbah?
sama material gasket favoritnya mbah marmut apa? metal? rubber? PTFE?
trebla88
Post by trebla88 »
Tbn (>2,5 msh ok)
Case by case,
- Oxi
- Sulfur
- Soot
Halo Om.
Bardahl s9 5w30 ok di mesin resing nissin hr15de
Cobain aja , ga cocok ganti om
Murah ini :upss:
Kalau mau tes skalian 0w20 aja, harusnya masih bisa nerima tuh mesin m16a
Pake astra premium 0w20 shell made in hongkong di snd 500rban dpt 4ltr
Tp jgn dicekokin 0w16 ya :big_biglaugh:
Ecstar indo lama amat kluarin 0w16.
Di india mesin k15 uda pd pk 0w16
AbdulHakim wrote: Sun Oct 01, 2023 10:19
honda pake M14.
cuman sedia ring almunium aja yg murmer dan saya kasih gratis kalo ada yg ganti oli. ga kaya bengkel anu yg musti bayar.
rubber ga pernah sedia krn biasa yg rubber o-ring dijual sama bautnya juga kaya kepunyaan chevy trax.
ptfe apa? ring atau tape?
ptfe ring ga pernah pake, itu biasa buat drain plug yg dr plastik kaya drain plug kompresor.
ptfe tape? najis banget ga modal..... gblk.
Menarik juga
Harga 110rb seliter di P*nda A*to
Tp dah a3/b4 dan mb 229.3
Buat skutik semakin di depan.. Gass Poll..!!
Claimnya Perawan base oil
Fookyoo
Post by Fookyoo »
Suryaputra wrote: Sun Oct 01, 2023 2:18
Tbn (>2,5 msh ok)
Case by case,
- Oxi
- Sulfur
- Soot
Halo Om.
Halo mbah gan
Oh I see.
Kalau sesama 5W-30 antara Bardahl S9 VS Gulf Ultrasynth VS TQ9000, any info lebih baik yang mana berdasarkan pengalaman atau data, Om?
Atau mungkin yang Om lebih rekomen?
Rencana mobilnya akan jarang dipakai, sesekali pakai jarak jauh dan high RPM. Target 6-7 bulan sekali ganti oli & service.
:big_deal:
Fookyoo wrote: Sun Oct 01, 2023 13:33
Halo Om.
Halo mbah gan
Oh I see.
:big_deal:
Bardahl pernah lihat uoa nya
7-8rb km or 8 bulan ok mbah
Atau fastron gold 5w30 sekalian
Lbh okeh :big_exellent:
RezPrat
Post by RezPrat »
Spies wrote: Sat Sep 30, 2023 0:41
RezPrat wrote: Fri Sep 29, 2023 7:47
daimler wrote: Wed Sep 27, 2023 10:21 Mau tanya sama sesepuh dimari, gasket oli itu wajib banget diganti tiap OCI kah? Mau OCI 5k,10K asal OCI ikut diganti juga?
Kalo misalnya digantinya setelah 2-3 OCI efeknya apa ya? Apa jd rembes olinya?
Soalnya kbetulan habis OCI eh stok gasket di rumah habis, jd pake gasket yg sebelumnya :mky_01:
Nama English nya gasket oli itu "crushed washer", jadi dia biar bisa jadi seal, dia bakal d crushed alias d penyet ke pan and baut. Kalo udah penyet trus d buka maka kekuatan seal akan berkurang drastis....inti nya one time use only om, hihihi....tapi ane pernah koq pake lagi buat cuci mesin pake oli murah, seminggu kemudian oli dibuang dan ganti washer baru.
Gasket yg warna item itu bahannya apa sih om?
Kayaknya bukan logam ya, ringan banget
Saya biasanya kalo ga pake ring aluminium, pake yang dari tembaga. Maksimal 2x pake aja :big_peace:
Kek nya bahan nya kombinasi alumunium sama silicon om. Rata2 beres udah pake yg kek gini. Klo yg pake bahan tembaga atau pure metal alumunium nanti takutnya ngerusak pan lama2.
Fookyoo
Post by Fookyoo »
trebla88 wrote: Sun Oct 01, 2023 10:36
Tbn (>2,5 msh ok)
Case by case,
- Oxi
- Sulfur
- Soot
Halo Om.
Murah ini :upss:
Thank you for your input, Om :big_deal:
Fookyoo
Post by Fookyoo »
Suryaputra wrote: Sun Oct 01, 2023 13:47
Halo mbah gan
Oh I see.
:big_deal:
Wah OK. Thanks for your opinion, Om :big_deal:
melson
Post by melson »
PTT performa synthetic 5w30 kira2 maksimal bisa pake brp km ya om? umur pemakaian skrg hampir 5k dan 6 bulan..
next bakal ganti TQ8000 0w20 GF6
mesin theta sportage 2011
melson wrote: Sun Oct 01, 2023 21:12 PTT performa synthetic 5w30 kira2 maksimal bisa pake brp km ya om? umur pemakaian skrg hampir 5k dan 6 bulan..
Manual book bilang apa mbah?
Performa 5w30 botol emas ya?
Api SN
ACEA A5/b5/c2
Prnh lihat uoanya 7-8rb km / 8-9 bulan bisa
josomba
Daily Vehicle: Delman
Post by josomba »
Just share,
Oli 0w20, masih api sn/gf5 tp berani meet (ga ada approval) Dexos.
4L di kisaran 340ribuan.
Mz175
Post by Mz175 »
josomba wrote: Sun Oct 01, 2023 23:52 Just share,
Pake 4000 km aja mbah :big_grin: Menurut hasil uoa nya.
Mz175 wrote: Mon Oct 02, 2023 1:37
Mending sekalian ini mbah
https://tokopedia.link/Q2oVlivAyDb
Mbah turbo pny tuh hsl uoa nya.
Salah satu oli w20 harga <100rb terbaik
sahabatq8
Daily Vehicle: Nissan Xtrail
Post by sahabatq8 »
Tulis² aja mah boleh mbah :upss:
Eh tapi kyknya itu maksudnya dexos 1 gen 1 deh. Itu olinya memang api sn gf5
daimler
Daily Vehicle: DE 2011
Post by daimler »
Suryaputra wrote: Sun Oct 01, 2023 12:52 Menarik juga
Wah menarikk ini ada di toko ijo kah mbah?
daimler wrote: Mon Oct 02, 2023 5:20
Iya ada mbah
Panda au*o
josomba
Post by josomba »
Woghh iya, dulu keknya om pernah pake n test UOA ya? Kalau ga salah inget, sempet concern V100-nya drop (?)
Abbadayat
Daily Vehicle: All New Rush
Post by Abbadayat »
P*nd* A*to toko ijo Bandung ya Om?
Abbadayat wrote: Mon Oct 02, 2023 11:37
Iya mbahh
pitikkobong
Daily Vehicle: Dual 51KiL
Post by pitikkobong »
om² semua tanya dong,
1. shell helix 5w30 dan ptt performa synthetic 5w30 (botol emas) itu bs long drain/10rb km ga ya?
2. rekomendasi oli 5w30 buat mesin bensin yg bisa long drain 10rb km apa om? selain q8 dan amsoil
3. kalo mobil cm keluar weekend doang, sebaiknya oli yg value per 5000 km apa long drain sekalian ya om?
t105erd
Post by t105erd »
pitikkobong wrote: Tue Oct 03, 2023 0:19 om² semua tanya dong,
1. Kalo yakin sih bisa, kalo ga yakin yaa ga usah sampai 10rb km, selama jarang macet, lancar yaa pasti bisa.
2. Yang sudah di test fastron gold dan bardahl s9, atau cari aja yang sudah ada spek MB 229.51, BMW LL04, Dexos1 gen2/3, Dexos 2, ACEA C3 biasanya bisa long drain.
3. Kalo 1 tahun ga sampai 5000km beli aja yg 90 - 150rb cukup
Spies
Post by Spies »
Fastron Gold 5w30 aja om, udah ada hasil test lab nya beberapa page ke belakang
