Corolla 2013
MikeTan
SM Affiliate
SM Affiliate
Daily Vehicle: Toyota Innova
Re: Corolla 2013
Post by MikeTan »
:big_biglaugh: untung ga semua dibilang oon...
sedan di indo ini kemahalan pajak nya sih... jadi bikin ga worthed :big_weee:
Toyota auto 2000 Pecindilan
Jl.Pecindilan 42 Surabaya
Michael
0812 8999 3900 / 081 759 3900
Info produk & harga Toyota: Klik Disini!
dubz
Re: Corolla 2013
Post by dubz »
Poin + buat Corolla gen ini bentuknya...kalo buat saya 11-12 dengan Civic facelift dari segi tampang.
Focus sedan fitur lengkap tapi bentuk gak bagus. Reliability Ford juga masih rada2. Impreza bagus tapi bengkel minim.
Mozawa
Re: Corolla 2013
Post by Mozawa »
SAYANG MESIN MASIH BELUM VALVEMATIC.....PAYAH.............
Felixz_Yaris
Re: Corolla 2013
Post by Felixz_Yaris »
yang penting altis masi sayang nonik ada dual airbag ...
sama ABS bia gak nubruk trotoar
[TYCI 917]
[YKC]
Re: Corolla 2013
Sama mesin lama biar tahan premium... :ngacir:
Felixz_Yaris
Re: Corolla 2013
sama immo biar aman pas parkir
[TYCI 917]
[YKC]
hitutbaw
Re: Corolla 2013
Post by hitutbaw »
Masih penasaran aja, sama info mesinnya:
2ZR-FE
The Toyota 2ZR-FE is a DOHC, 16-valve, 1.8 L (1797 cc)/(1798 cc)[2] engine also equipped with Dual VVT-i. This new engine is now replacing the 1ZZ-FE engine in most applications. Output for this engine is rated at 98–100 kW (132–134 hp) at 6000 rpm and 174 N·m (128 lb·ft) of torque at 4400 rpm for the Corolla, Matrix, and Vibe and 95 kW (128 hp) and 171 N·m (126 lb·ft) of torque in the Scion xD.
Atau yg valvematic:
2ZR-FAE
The Toyota 2ZR-FAE is a DOHC, 16-valve, 1.8 L (1797 cc) this engine adopts the Valvematic system. This all-new engine is progressively replacing the 1ZZ-FED and 2ZR-FE engine in most applications. Output for this engine is rated at between 105 kW and 110 kW and 173 N·m and 179 N·m of torque. Compression ratio is 10.5:1 and redline is at 6600 rpm. The engine consumes 5 - 10% less fuel than the 2ZR-FE depending on application.[3]
Gak ada satu pun yg nyebutin 151 ps (111 kw atau 149 hp) dan 19.4 kgm (190 Nm) kyk di berita2 launching itu...
Re: Corolla 2013
Bukann y dual vvti itu udah sama aja valvematic
yg mesin nav1 itu udh valvematic tho? Sm yg dipake altis 2000
hitutbaw
Re: Corolla 2013
Post by hitutbaw »
Beda om..
http://paultan.org/2007/06/13/toyota-re ... echnology/
Toyota has something new up it’s sleeves – Valvematic, an evolution of the VVT-i mechanism which now incorporates continuous valve lift control together with VVT-i’s existing valve timing control. Valvematic also eliminates the need for a throttle valve, instead controlling the volume of intake air using valve lift instead.
Hihi.. Mesin nav1 (valvematic) lebih canggih dibanding new corolla altis (dual vvti)?
Btw... Googling2, mesin toyota tetap no1 dari sisi durability.. Tapi kok kesannya keterlaluan konsumen dikasih teknologi jadul. Torsion beam, bahkan teknology matic cvt nya (again sy cm modal browsing) itu oleh gm udah dari sejak 90 an..
Imho semua punya penggemarnya, kalau nggak
, gak mgkn lah corolla jd mobil paling laku sepanjang masa sejagad.
Tapi yg mengganggu informasi 151 ps 190 nm itu.. Mudah2an toyota memang gak bohong...dan kalau benar, berarti indonesia memang spesial, sampai mesin aja beda dgn belahan dunia lain.
Re: Corolla 2013
Corolla di Indonesia rata2 emang dapet varian mesin yg gede kan... :ungg:
Contoh di ANC '00, altis gen1, gen2, disini 1.8L, sedangkan di negara lain cuma pake yg 1.6L doang... :mky_01:
campoeran
Re: Corolla 2013
Post by campoeran »
tp spek mesin 1800cc mmg ada kan , cm ya itu spek mesin 1800cc kali ini kok nyeleneh
Mozawa
Re: Corolla 2013
Post by Mozawa »
walid_007 wrote:Bukann y dual vvti itu udah sama aja valvematic
Ini om beda valve matic with dual vvti ama dual vvti aja....
DUAL VVTI :
Ketinggian katup selalu sama / fixed baik saat iddle atau saat rpm tinggi.
Akibatnya kurang efisien.
Saat kondisi iddle ( misal kondisi jalanan macet ) , tinggi katup tetap sama dibandingkan saat full speed , misal di jalan tol.
Akibatnya bensinnya ngocor terus / lebih boros. dan tenaga tidak efisien.
VALVEMATIC WITH DUAL VVTI.
Ketinggian katup berubah2 secara kontinus.
saat iddle , ketinggian bukaan katup hanya 1 mm.
saat full speed / full rpm maksimal ketinggian katup 11 mm.
Jadi mesin lebih ekonomis.
Ini gambar sederhana / diagram yang ane buat untuk komparasi. CMIIW
berikut juga variant corolla altis.Yang valvematic adalah hanya type ECO.
terlihat secara spec memang lebih irit dibandingkan varian yang lain.
campoeran
Re: Corolla 2013
Post by campoeran »
Hmmm
makanya kok pas liburan sekolah , konsumsi bensin dalkot 1:10
kl udah sklh , iddle tiap hari selama 20mnt lsg anjlok ke 1:8.5
haha mgkn kl valvematic masih bisa nahan ke 1:9.5 kali ye
Re: Corolla 2013
artoodetoo wrote:Torsion beam di Corolla itu sudah sejak pertama kali pake nama Altis :upss:
Yach, saya juga bertanya2 soal hal itu. Mestinya insinyur2 Toyota gak tuli akan hujatan2 soal Torsion Beam ini. Namun kenapa tetap bertahan? Mungkin pertimbangan mereka tetap soal durability. Gimanapun Toyota selalu menang di sektor ini khan?
Jangankan engineer Toyota.
Engineer Hando aja jd dudul. Full Independent Suspension di Honda SX8GM yang harganya below 200jeteng dicopot.
Di Honda GD series ga pake FIS lagi. Katanya kalo pasang FIS mahal. Ganti torsion beam dah... :frm_bang_head:
Tanya kenapa... :shrug:
HouseOfDetailing
Re: Corolla 2013
Post by HouseOfDetailing »
Njess n Siti masih bisa di terima om Metket,yang dudul itu FN2R.Bawa emblem Type R tapi suspensi Torsion Beam,rem pun Nissin standar yang blong dalam 2 lap saja...sungguh terlalu pemangkasan biayanya Hando.
Re: Corolla 2013
HouseOfDetailing wrote:Njess n Siti masih bisa di terima om Metket,yang dudul itu FN2R.Bawa emblem Type R tapi suspensi Torsion Beam,rem pun Nissin standar yang blong dalam 2 lap saja...sungguh terlalu pemangkasan biayanya Hando.
Wow wow... bentar...
FN2-R??? Itu kan Sipik HB Type R UK yg katanya dewa itu... :big_chicken:
Ancur bener dah kalo mobil gitu di kasi torsion beam dan rem yg teler dalam 2 lap...
TypeR seharusnya jadi creme de la creme nya Ahond... seharusnya jadi Honda yang barbar dan spartan.
*meski SX8GM ane rem nya nyerah dalam 3x straight line... kepanasan...* :ungg:
Re: Corolla 2013
Kepanasan?
Bueuk_32
Re: Corolla 2013
Post by Bueuk_32 »
hitutbaw wrote:Masih penasaran aja, sama info mesinnya:
2ZR-FE
Atau yg valvematic:
2ZR-FAE
palingan bentar lagi ada yg pake kaos bertulisan "mobil gw NGAK 151 PS" :mrgreen:
"The Power of ren-Dreams"
HouseOfDetailing
Re: Corolla 2013
Sebenarnya ngga seburuk itu sebuah torsion beam selama di kasih sasis yang baik,Renault Megane RS Trophy the fastest fwd car at Nurburgring juga...torsion beam.Kalau FN2R emang patut di kasihani,understeer total dan bisa di tekuk dengan mudah oleh FD2R...saudara kandungnya sendiri.
Anyway...semoga Corolla generasi baru ini memiliki dekapan jok yang lebih baik dari generasi yang dia gantikan.Generasi sebelumnya punya dekapan layaknya triplek super flat...
dubz
Re: Corolla 2013
Post by dubz »
Buat everyday use juga gak kerasa torsion beam/independent...ya itulah peruntukannya Corolla, buat kuda beban hari2. Kalo buat kebut2an...pertimbangannya paling segelintir dari konsumen corolla yg begitu.
Re: Corolla 2013
Mobil kutu mah ga bisa buat balapan omm....
Pantesny buat kenyaman an aja... klo mau balapan beli semprot car donk...
campoeran
Re: Corolla 2013
Post by campoeran »
+1 dah
campoeran
Re: Corolla 2013
Post by campoeran »
komparasi old altis v new altis
interior
2ndrow
Ini malaysia market, di indo trimnya warna krem ya :) . Kl pendapat ane sih depan bagus yg lama belakang bagus yang baru . Interior 2nd row mmg kliatan lbh lega yg baru
yaseinotulip
Re: Corolla 2013
Post by yaseinotulip »
wah ada komparasinya...
menurut gw sih bagusan yang baru keseluruhan... lebih sporty..
dimalaysia dapet mesin 2.0 ga kaya di d indo ya ?
campoeran
Re: Corolla 2013
Post by campoeran »
Iya disana kebagian 2.0 ...... disini TAM pede dengan mesin 1800cc harga 11-12 ama pesaingnya yg 2000cc bahkan ford jauh lbh murah
