Kasus Pertamax RON 92 isinya RON 90 (Kolubzi di Pertamina)
darrelund
Re: Kasus Pertamax RON 92 isinya RON 90 (Kolubzi di Pertamina)
Post by darrelund »
DOHC wrote: Sat Mar 01, 2025 8:57 kl liat begini
bearti bagusan beli bensin yg warna merah aj, lebi sulit mo dicampur ama pertalit
jgn beli yg warna biru , krn gampang di campur2 ama yg ijo (pertalit)
*kadang lucu jg dsini, makanan dikasi pewarna, minuman dikasi pewarna, ampe bensin aj dikasi pewarna
oe siy nungguin tar bbrp taun kemudian
ada gebrakan apa di sektor EV
klo bengsin kan ud nih :big_biglaugh:
daimler
Daily Vehicle: DE 2011
Post by daimler »
darrelund wrote: Sat Mar 01, 2025 9:31
Salvanost wrote: Fri Feb 28, 2025 10:08 Dioplos pake pertalite + timbal
GOSIPNYA gitu
Karena pertalite ga ada timbal tapi pertamax ada timbal
klo beneran pke timbal
bisa di gruduk tree huggers/ lembaga kesehatan terkait tuh
*klo bisa*
Kali emg sengaja dicampur timbal, biar generasi penerusnya bisa dijadiin buzzer nya konoha :big_weee:
“Lead is able to reach the bloodstream once it’s inhaled as dust, or ingested, or consumed in water,” Reuben said. “In the bloodstream, it's able to pass into the brain through the blood-brain barrier, which is quite good at keeping a lot of toxicants and pathogens out of the brain, but not all of them.”
One major way lead used to invade bloodstreams was through automotive exhaust.
To answer the complex question of how leaded gas use for more than 70 years may have left a permanent mark on human health, Reuben and his co-authors Michael McFarland and Mathew Hauer, both professors of sociology at Florida State University, opted for a fairly simple strategy.
sumber
Salvanost
Post by Salvanost »
fansdiesel wrote: Sat Mar 01, 2025 4:26 Tidak usah terlalu menghujat, kita semua kalau ada kesempatan begitu juga pasti ikutngegarong :big_biglaugh:
Saya ikutan make baju gini aja :big_biglaugh:
Salvanost
Post by Salvanost »
darrelund wrote: Sat Mar 01, 2025 9:35
Harga naik 2x lipat om... :off_no:
pesimis lah soal EV
urusan bensin yg teknologi jaman baheula aj dari jaman baheula ampe skrg ga beres2
Salvanost
Post by Salvanost »
DOHC wrote: Sat Mar 01, 2025 14:07
pesimis lah soal EV
Ngenes om...
Mau jadi negara besar dan maju
Tapi yg maju malah korupsinya
Udah korupsi, kualitasnya makin parah
Pendidikan juga
Ekonomi juga
Kriminalitas juga
Pemberantasan kriminal dan korupsi juga
Makin parah semuanya...
Nasib ini negara macam apa jadinya...
b0ku
Post by b0ku »
:upss:
di mainland mah mobil loe di sabotase
garansi kan??? terus situ claim di downgrade batre barunya :wkkk:
kalo gak batrenya gak ada inden :upss:
ev lebih gampang lagi bensin kan di oplos ev voltase charging turun gila2xan tadiannya cuma 30-1jem bisa lama karena kebagi2x listriknya gak cukup ongkosnya fast charging :mky_07:
Salvanost wrote: Sat Mar 01, 2025 16:48
pesimis lah soal EV
Ngenes om...
Pendidikan juga
Ekonomi juga
Kriminalitas juga
makanya kuar hastag
gelap lah
kabur aj yuk
dsb
ama pemerintah dianggep angin lalu, malah di tantang balik, sono pergi ga usa balik skalian
tp ya suda lah, mau gmana lagi, toh ini kan plihan mayoritas... mayoritas yg cuman 78 (bahkan takutnya yg sebela kanan garuda jg sama) :mky_03: :mky_03: :mky_03:
ilhami
Post by ilhami »
Ahli konversi energi dari ITB
kayukayuthe5th
Post by kayukayuthe5th »
bisa jadi elektrolitnya dioplos om ato katoda anoda voltage di"edit" :mky_03:
Bibieight
Post by Bibieight »
kayukayuthe5th wrote: Sun Mar 02, 2025 5:42 bisa jadi elektrolitnya dioplos om ato katoda anoda voltage di"edit" :mky_03:
Kalo pada perhatian, kecuali Hyundai yang pake NMC811 semua EV yg masuk pakai fasilitas itu pake LiFePo, padahal salah satu alasan EV digadang2 dimari itu karena Indonesia punya banyak nikel. Nah, ntar oplosannya di TKDN, sim salabim LiFePo = 100% kandungan lokal :big_biglaugh: :big_biglaugh: :big_biglaugh:
Lha investasi si CATL aja dikepras :
https://scopecorner.com/investasi-catl- ... 5-triliun/
Kayaknya gara2 ini IBC digantung LG :
https://ekonomi.bisnis.com/read/2025021 ... -terganjal
Ntar tau2 LG kasih harga 2x lipat gara2 under capacity, itu boss IBC bisa nyusul boss ASDP yg akuisisi perusahaan kemahalan :
https://www.google.com/amp/s/www.cnbcin ... miliar/amp :big_weee: :big_weee: :big_weee:
AbdulHakim
Post by AbdulHakim »
DOHC wrote: Sun Mar 02, 2025 0:23
pesimis lah soal EV
Ngenes om...
Pendidikan juga
Ekonomi juga
Kriminalitas juga
makanya kuar hastag
gelap lah
kabur aj yuk
dsb
hmm.. yang menghajar para koruptor ini khan presiden pilihan 78% om, gimana siy pola pikirnya :big_think:
vanosz
Post by vanosz »
Next 2029,
Tulang ane,
b0ku
Post by b0ku »
vanosz wrote: Sun Mar 02, 2025 12:10 Next 2029,
Tulang ane,
aneh tuh orang om keknya ada yang gak beres ahok itu ud jelasin ngedetail padahal :mky_07:
gw kalo nyuci duit juga kalo ada mesin cuci paket lengkap ngerti hukum koneksi banyak dan image bagus gw bakalan pilih mesin cuci kek gitu sih.......................... :ngacir:
vanosz
Post by vanosz »
Hhhmmmm,
:big_think:
Jadi maunya siapa nih jadi pemimpin,
Biar bisa solid,ky kampanye kmaren,teriak menggugah,sambil angkat tongkat sakti warisan mbah,
Solid
Solidd
Solidddd
Merdekaaaaa
b0ku
Post by b0ku »
vanosz wrote: Sun Mar 02, 2025 21:59 Hhhmmmm,
:big_think:
Solid
Solidd
Solidddd
Merdekaaaaa
ane maunya si dari dulu si mulut ember tau sendiri lah siapa.......... :ngacir:
itu jelas orang dendam sama pejabat jd cocok buat ngabisin yang ngawur2x......
vanosz
Post by vanosz »
b0ku wrote: Sun Mar 02, 2025 22:27
:big_think:
Solid
Solidd
Solidddd
Merdekaaaaa
Hhhmmmm
:big_think:
Tetap aja sulit gans,
Minimal ketua parte,
Klo kacunnk parte tetap aja diatur,
Ya sadar diri aja,
Klo agans punya duit 1 T,
Buat apa sih kolup ratusan triliun,cuma angka nambah di buku rekening gans,
Yang 1 T aja gak tau abisinnya,
Semua juga akan ditinggalkan,
Nikmati aja hidup dengan santui,
Ya berdoa aja om wowo bisa sehati gans,.
Duitnya kan ktnya T,
Semoga ya,
Sing penting selama 5 tahun,
Solid
Solidd
Soliddd
Merdekaaaaa
b0ku
Post by b0ku »
vanosz wrote: Sun Mar 02, 2025 23:09
:big_think:
Solid
Solidd
Solidddd
Merdekaaaaa
Hhhmmmm
:big_think:
Ya sadar diri aja,
Semoga ya,
Solid
Solidd
Soliddd
Merdekaaaaa
mendingn kacunk partai om daripada jongos pribadi noh liat aja ud kebobolan 2x kita mana yang kemaren masih mendingan pas dia jadi kacunk partai sejak keluar lsg jd full time jongos pribadi dari situ semua acak2xan.............. :big_biglaugh:
inget om sekarang megatron narasinya bukan pilihan rakyat padahl saya inget banget dulu waktu pemilu partainya megatron menang cuma di jegal di MPR yang di pilih malah gusdur :big_bored:
MSU
Daily Vehicle: Diesel
Post by MSU »
kemaren baru isi bensin lg...memang biasa pake shell
edun antriannya...terutama motornya...pegawainya jg ngaku belakangan ini tambah rame sejak kasus itu
sayang aja sistem bayarnya kurang cepet....di saya ga tiap pom dikasi mesin gesek kartu debit...jadinya antri ke kasirnya
tapi memang pas dulu bensin swasta kosong & terpaksa isi petromax, berasa berubah lari mobil sy...sendatan di rpm bawah kumat...padahal cuma avanza cvt
kayukayuthe5th
MSU wrote: Mon Mar 03, 2025 1:00 kemaren baru isi bensin lg...memang biasa pake shell
iya sih ini jeleknya shell musti ke kasir akhirnya antrean mengular mungkin bisa contoh BP, kalo nontunai ke kasir kalo tunai bisa langsung.
*tergantung station juga y
kayukayuthe5th
Bibieight wrote: Sun Mar 02, 2025 5:53
bisa jadi sih wkwkwkw, ato pake Li-Ni sekalian aja mbah solid state itupun kalo pejabatnya ngerti :mky_03: gwa kira even yang penting kepentingan menlen mbah , semua lancar. kalo LG karena mereka mau cepet2an bikin di US (issue tarrif) selain itu juga emang karena demands EV mulai lemah sih jadi mereka ga jor2an plus kondisi market liat indonesia ini lagi gabaik2 aja, jadi mereka agak ragu invest disini. [emo-police]
b0ku
Post by b0ku »
kayukayuthe5th wrote: Mon Mar 03, 2025 1:16
kemaren di pik si disamperin om :big_grin:
mobilkutu
Post by mobilkutu »
b0ku wrote: Sun Mar 02, 2025 23:46
Hhhmmmm
:big_think:
Ya sadar diri aja,
Semoga ya,
Solid
Solidd
Soliddd
Merdekaaaaa
Kl ga da gusdur lu blm imlekan loh bosku :mky_03:
b0ku
Post by b0ku »
mobilkutu wrote: Mon Mar 03, 2025 2:19
ngerti boss cuma masalahnya orang suka ngawur ngomongnya :big_biglaugh:
tesna
Post by tesna »
ilhami wrote: Sat Mar 01, 2025 2:42 Shell 92 sudah euro4
Pertamax 92 belum euro4
setau saya shell yang euro 4 cuman yg nitro+, yang v power biasa (ron95) blum. ga disebut soalnya di spec shell. klo pertamax green 95 udah euro 4 (menurut spec nya ya)
W212 M272 '10
AN140 2GD '18
