Moderators: r12qiSonH4ji , avantgardebronze , akbarfit , Ryan Steele , sh00t
Posts: 6542 Joined: Thu Sep 30, 2010 16:20
Post
by Nightster Guy » Fri Jul 22, 2011 12:48
DOHC wrote: @ nitesteer guy : beda nya kalo yg di taiwan aftermarket gt... lama2 mika bening nya jadi menguning gt... jelek jadi nya... tau dehh kalo yg si fortuner punya ini bakal menguning jg atau kaga..
Iya mods..
Uda pengalaman di Cudo, pake yang merah putih non Altezza. Umurnya 6 bulan doank, mulai kuning, lalu mulai bocor pula. Halah, copot ajalah, back to tail lamp ori hehehe..
Posts: 10473 Joined: Sun Aug 15, 2010 7:20
Post
by ak4ng » Fri Jul 22, 2011 12:50
Nightster Guy wrote: ak4ng wrote: Hansen wrote: Ya buat nyekop udara lah...
apa ga jadi hambatan sen????
Haizzzz....
Y kagaklah k4ng.. segede apa emang si airscoop itu?
air scoop tu kap mesinnya bolong ke bawah ??? lha kl oprut masuk lumpur gmn???
INFO KOPI KLIK:
KOPI MALABAR
Posts: 16497 Joined: Tue Apr 03, 2007 14:24
Post
by Hansen » Fri Jul 22, 2011 13:02
Posts: 27667 Joined: Sat Jan 31, 2009 17:48
Post
by DOHC » Fri Jul 22, 2011 13:20
bener jg... duhh atoyot...
padahal ane berharap sehh fortuner dikasi yg VN turbo tsb.. yahh biar si PS ada saingan lahh...
Post
by Hansen » Fri Jul 22, 2011 13:30
Kalo ane malah berharap si ipah kebagian juga mesin VN tsb...
Post
by DOHC » Fri Jul 22, 2011 13:59
tapi itu smua cuman mimpi siong ternyata... ipah ama fotuner tetep aja pake d4d "biasa"
Post
by Hansen » Fri Jul 22, 2011 14:28
belum ketauan sih pastinya pake apa chiong... detailnya masih misterius & belum jelas, liat aja tuh emblem2 yg ada di body juga kagak dipasang oleh TAM
Post
by DOHC » Fri Jul 22, 2011 14:33
si johny ternyata suka rahasia2an yah siong.... tp ane sehh tetep lebi harep si fortuner dipakein vn turbo... kalo ipah mahh emang kodrat nya mobil kluarga... asalkan kuat tanjakan jg uda cukup... kalo fortuner kan selaen buat kluarga tapi jg ada "wild side" nya... kan katanya the world is mine... masa tenaga nya pas2an...
Post
by FortunerMan » Fri Jul 22, 2011 14:35
Emang udah liat di IIMS? Saya sih baru dr Paul Tan aja yg putih itu 2.7 V bensin (4WD)...sedangkan yg hitam gak ada embel2nya (polos)...kalo emang masih D4D jadoel...yo wis beli PS aja
Mana embell2 D4D nya?
Post
by Hansen » Fri Jul 22, 2011 15:01
Abu2
Posts: 8765 Joined: Tue Jun 12, 2007 8:46
Daily Vehicle: just a bike
Post
by Abu2 » Fri Jul 22, 2011 15:19
kayaknya dari D4D jadi D2D (djadoel to Djadoel)
Posts: 14444 Joined: Thu Nov 06, 2008 9:28
Post
by maskopat » Fri Jul 22, 2011 15:56
Yo wis lah... Fortie fortie... Huhuhu....
Post
by Hansen » Fri Jul 22, 2011 16:03
Hiksssss.....
Post
by maskopat » Fri Jul 22, 2011 16:14
Gimana kalo kita demo aja ke TAM?
Kalo kita mau fortie D4D VN.... Yuk ah... Siapin spanduk kita pasang di IIMS...
Post
by ak4ng » Sat Jul 23, 2011 0:46
yang putih2 ane demen dah.....
INFO KOPI KLIK:
KOPI MALABAR
Post
by ak4ng » Sat Jul 23, 2011 0:51
ni fortie PU juga ga apa de.....
INFO KOPI KLIK:
KOPI MALABAR
And45
Posts: 136 Joined: Tue May 31, 2011 8:56
Post
by And45 » Sat Jul 23, 2011 6:16
@ maskopat : mang kalo ga ad air scoop pasti pake d4d jadoel y?
itu kaan hanya ditulis tipe g
jangan" itu versi bensin lagi
BADAK
Posts: 6024 Joined: Fri Dec 21, 2007 4:45
Post
by BADAK » Sat Jul 23, 2011 6:27
maskopat wrote: Gimana kalo kita demo aja ke TAM?
Gimana kalo ente sekalian demo mogok makan didepan kantor TAM, om?
Live as if you'll die today
Post
by ak4ng » Sat Jul 23, 2011 6:36
eee maap om kopat.. TAM tu apa ya.... bukannya itu makanan ringan.......
INFO KOPI KLIK:
KOPI MALABAR
And45
Post
by And45 » Sat Jul 23, 2011 6:43
ak4ng wrote: eee maap om kopat.. TAM tu apa ya.... bukannya itu makanan ringan.......
mobilnya avanza ko ga tau ya?
Toyota Astra Motor lho
cmiimw
Post
by ak4ng » Sat Jul 23, 2011 6:49
ioa ya.... hehehhee........ sy kira drum 3 biji yg buat ngamen itu.........
INFO KOPI KLIK:
KOPI MALABAR
bivanos88
Posts: 373 Joined: Mon Jul 14, 2008 10:02
Post
by bivanos88 » Sat Jul 23, 2011 11:51
FortunerMan wrote: Emang udah liat di IIMS? Saya sih baru dr Paul Tan aja yg putih itu 2.7 V bensin (4WD)...sedangkan yg hitam gak ada embel2nya (polos)...kalo emang masih D4D jadoel...yo wis beli PS aja
Pertama liat fortuner item ini manual, ane langsung yakin ini versi d4d.. Tachometer jg redline di 4500rpm..
Mata langsung menuju kap mesin, trnyata tidak ada air scoop..
Untuk meyakinkan, ane buka kap mesinnya.. Dan ternyata, ane tidak menemukan kehadiran Intercooler, apalagi turbo vnt segala..
Mesin masih sama dengan pendahulunya..
Cape dehh.. Yakin amat si atoyot ama 2kd 'jadul' ini..
FMEAKD
Posts: 1497 Joined: Sat Mar 26, 2011 6:18
Post
by FMEAKD » Sat Jul 23, 2011 12:08
alsan hilux turn speck oleh karena gak tahan solar busuk dari 177 ps jadi 144ps
BADAK
Post
by BADAK » Sat Jul 23, 2011 12:23
FMEAKD wrote: alsan hilux turn speck oleh karena gak tahan solar busuk dari 177 ps jadi 144ps
Emang apa neh hubungannya om?
bivanos88
Post
by bivanos88 » Sat Jul 23, 2011 12:31
Kan tenaganya turun karena kapasitas mesin turun.. Jadi bukan dari mesin yang sama dan tenaganya diturunin..
