Koleksi hand tools [Part 02]
Re: Koleksi hand tools [Part 02]
marmut wrote: Tue Oct 13, 2020 1:59
Omnibus wrote: Mon Oct 12, 2020 17:19
ane emang gitu orangnya ....
batere henpon baru 99% aja udah ane cas lagi
............ :ngacir:
bohlam jangan lupa diganti. yang halogen kalo ngga salah inget lifespan cuma 200an jam.
lampu depan belakang sdh led
lampu cabin udah ganti pake neon rumah
marmut wrote: Tue Oct 13, 2020 1:47
DOHC wrote: Tue Oct 13, 2020 1:27
Percaya lah om, nanti itu smua jg bakal beli nya di beres
Aneh si mbah mah, demen banget beli spare part beres
BeRes itu punya dia. kalopun ada faktur dipajang dimari, itu hanya formalitas.
*kabur sebelum disambit colenak.
pagi2 udah pada ghibah ......
LANJUTKEUN ....!
:mky_04:
benzz89
Post by benzz89 »
DOHC wrote:Oke
Kl gt d list down dl biar ga lupa
Trekstang
Oli cvt amsoil
Boot trekstang + oetikerclamp
Accessory belt
Vet steering rack + cv joint
Link stabilizer
Busi ampe 2 kali ganti
Vet steering collumn
Vet bearing shock
Ban michelin
Soon
Harmonic damper
Disc rotor +pad
Ganti dashboard
Ganti enjin head
Ganti seal klep
Ganti ring piston + honning liner
Ganti metal duduk ama jalan + seal kruk as
Ganti rante keteng
Ganti water pump
Ganti fuel pump
Ganti alternator
Eet dah, ini mobil baru belasan rebu km
Bujugggg... sehat kali ntu njess... cetiaw KM juga masih berdiri gagah ntar njess GK5 nya Om Omni... semuanya kelas 1... no play2 [emoji106]
yanuarra
Post by yanuarra »
Bohlam? Org headlamp jg mau ganti segelondong mbah :big_grin:
Kl gt saya mau komplen ah
Apaan tuh injector cleaner ampe pegoceng.. wong d asemreges musatek aj pd jual cuman saban
Apaan tuh servis ac cuman semprot2 fogging ac aj ampe nopeceng plus kadang malah bkin ac bau asem, wong tukang ac beneran aj paling mahal cepeceng
Minta refund donk
marmut wrote: Tue Oct 13, 2020 2:06
DOHC wrote: Tue Oct 13, 2020 1:46
Kadang yg pengen bkin tawuran tuh harga pad rem 1KR-UZ.. saya belom lama ganti pake bendix gct, beli d atrium kena 210 rebu + ongkos ojol kurir 36 rebu.. lah ini barusan iseng2 nyari bendix buat inofa lah koq 200an jg..
Padahal ntuh pad si 1KR ud kaya pad nya honda beat aj imut2 gt
210 tu buat yang m/t?
kalo a/t, sori aja.... lebih mahal dari xv40 cuy....
kalo mau pake bendix jangan yang heavy duty kecuali kecepatan maksimal 60kmh.
Metik mbah
Emg nya beda mbah metik atau manual
Itu saya bendik biasa koq.. wong kampas cuman seupil gt, ngapain heavy duty
blloewy
Post by blloewy »
DOHC wrote: Tue Oct 13, 2020 1:25
blloewy wrote: Tue Oct 13, 2020 0:36
DOHC wrote: Mon Oct 12, 2020 17:28 Btw
Ngomongin pad rem
Antara advics ama bendix yg gct, bagusan mana yah ?
Mbah Rektor...bendics biasanya sich bagus.
Cuma mungkin disc nya duluan yg modyar dibanding brake pad nya...
Rekomen dipake di engine resing HR15 :big_exellent:
Batu makam resing dl saya pake nya paraut.. enak pakem dan ga makan disc.. mirip2 OEM nya hitachi cungkwo
Nah itu mbah marmut jg sdh sebut merk lain si akehbondo juga bagus...
Paraut made in mana tu om klep?
Kl tie rod ama long tie rod nya hr15 emang cm 150-200 rebuan ya sebiji?
blloewy wrote: Tue Oct 13, 2020 6:03
mbah klep nyebut paraut jadi inget masa kecil sering liat itu merk di proyek senen lantai 4, nama tokonya champion motor.
marmut wrote: Tue Oct 13, 2020 6:23
Lah saya beli si paraut jg ama si champion batu makam d atrium mbah
Trekstang nya lipindut itu aslinya awett pake banget
Yg 150 200 rebu itu saya ga tau asli atau kaga
DOHC wrote: Tue Oct 13, 2020 6:35
ternyata dunia memang cuma selebar daun kelor ya ...
ya itu bubaran dari proyek senen waktu kebakaran. pas atrium dibangun, pada pindah kesana semua....
Omnibus wrote: Tue Oct 13, 2020 6:39
Dunia nya asemregesers mbah
Muter2 nya cuman musatek, senen, fatmawati, blok m
mana ini paket2 yg baru sampai ... dimohon segera diposting :big_bored:
Omnibus wrote: Tue Oct 13, 2020 8:36 mana ini paket2 yg baru sampai ... dimohon segera diposting :big_bored:
sabar. ini hari baru dikirim. kalo lancar, besok sore sampe....
:big_comfort:
yanuarra
Post by yanuarra »
Beli apaan ya mbah marmut :big_bored:
hi hi hi hi
pe na sa ran ....
yanuarra
Post by yanuarra »
Omnibus wrote: Tue Oct 13, 2020 9:32 hi hi hi hi
pe na sa ran ....
Bisikin mbah shifu :big_childish:
Taufiq6210
Post by Taufiq6210 »
Omnibus wrote: Mon Oct 12, 2020 5:51 ini mbah, hasil dr promo monotaro ... refill cutter sama beli alas potongnya juga yg ga pernah liat dimana2 even di gramed.
Masa di toga mas atau baltos juga ga ada om?
yanuarra wrote: Tue Oct 13, 2020 9:35
pe na sa ran ....
oh tidak bisa ......
:mky_08:
Taufiq6210 wrote: Tue Oct 13, 2020 10:30
ini murah bgt om waktu itu. disc 70% refillnya.
kl cutting mat nya ngga disc.
yanuarra wrote: Tue Oct 13, 2020 9:30 Beli apaan ya mbah marmut :big_bored:
beli oli jè...
yanuarra
Post by yanuarra »
Mana nih mbah marmut belom aplod... Kami haus akan foto penampakan :mky_03:
setuju
saya lagi tidur sampai terhentak terbangun jam 4 subuh, seperti melihat silhouette mbah marmut lagi unboxing sambil bergumam "hentul hentul hentul ...." (hand tool maksudnya)
.............. :ngacir:
baeklah para pembaca yang budiman dimanapun anda berada, kali ini saya akan memberi bukti ke-kerehore-an saya, yang mana, telah lama diasuh oleh, daripada mbah DOHC.
berikut pembuktiannya,
apakah ini? silahkan disimak daripada gambar berikut...
demikian sedikit gambar yang dapat saya tayangken saat ini.
cc : mbah DOHC
bcc : mbah shifu Omnibus
