If the site's translations are accurate, the vehicle will boast a 2.0-liter flat-four producing 197 horsepower at 7,000 rpm and 150 pound-feet of torque at 6,600 rpm. While not overwhelming numbers, if the handling is as good as we've been hearing, the powertrain should be enough to hustle the 2,667-pound coupe around your favorite twisty road at a respectable pace
konon NA (masih intip2 aja, belon pasti) - tujuannya mobil ini mobil sport yg simple dan ringan (mur mer)ak4ng wrote:2.0L nya N/A atw turbo??
What is it?asudarsono wrote:2000 cc, 6600 rpm kudu ditiup turbo baru dapet 200 HP bukan? Sayang ya, padahal awalnya mau main N/A. Padahal menurut saya 170 HP juga cukup buat di jalanan.
Honda Civic Type R bisa 225 HP tapi 8000+ rpm.
Makanya BACA yg bener dulu, baru nyerocos...Toyota emang mau bikin sports car murah meriah dengan mobil ini. Target harganya dibawah RX-8.solar_kerosen wrote:versi retailnya sangat jauh dengan konsepnya tapi saya menduga ini masalah harga, kalau mereka menjual yg tipe concept diatas maka harganya akan bersaing dengan BMW Z4 3 liter dan tentu saja susah lakunya dibanding kalau dijual dengan harga katakanlah Mazda RX-8
toyota toyota maunya cari untung gede ... tapi mengecewakan penggemar karena jauh dari konsep
...The great thing about the FT-86 though is, as promised, it really handles. It lets you choose how you want to corner. Add any amount of power and it’ll turn at least neutral. Trail the brakes into a bend, give a mid-corner throttle-lift or, well, just give the steering a bit of a bung and lots of throttle and it’ll either straighten its line or give you armfuls of oversteer, utterly as you prefer.
There’s still a bit of tweaking to do on the damping, but it’s 90 per cent of the way there. As it is, in third gear the FT-86 will run out of power to keep a long slide going (if you like that sort of thing), so inevitably it takes momentum rather than power to play games with the chassis. But if you add more power to compensate then you’ll want a turbo and bigger stoppers too, and that adds weight, and, well – that’s where the downward spiral starts, right?
“The key development for the FT-86 is that it’s a front-engined, rear-drive car with intuitive handling,” says Toyota.
“A fun car is a car you can control. We rejected the idea of a car developed using numbers. It must have front-engine/rear-drive, a naturally-aspirated engine and a low centre of gravity.”...
Kalau dibandingkan Evo-X yang 2.0 L - 295 HP;dieselkiki wrote: coba masuk di mari harga 300-500
Kurang dari separuh harga Evo X, RX maupun Lotus Elise .... wih wih wihMitshuToyo wrote:Kalau dibandingkan Evo-X yang 2.0 L - 295 HP;dieselkiki wrote: coba masuk di mari harga 300-500
harganya segitu emang cocok...
Sama sekali beda om...ini tujuannya mobil sport murah meriah, bukan technology showcase seperti LFA. Kalo soal harganya di Indonesia, ya tergantung TAM mau untung berapacampoeran wrote:ini ama lexus lfa sama gak ya ? ato itu cm premium branded dr FT86 ini ? modelnya mirip .
Hm... kl 400-500 gak mgkn deh , pasti diset ke 600-650an . tp ttp aja sedep ya . asli bagus banget modelnya
kalo seharga fortie mungkin ga???FortunerMan wrote:Sama sekali beda om...ini tujuannya mobil sport murah meriah, bukan technology showcase seperti LFA. Kalo soal harganya di Indonesia, ya tergantung TAM mau untung berapacampoeran wrote:ini ama lexus lfa sama gak ya ? ato itu cm premium branded dr FT86 ini ? modelnya mirip .
