Sedan kedua utk daily (Markx 2012 vs Camry 3.5 Q 2008 vs Lexus GS300 2008)
Re: Sedan kedua untuk daily use
Alhamdulillah udah ngangkat honda accord cm7 bottomlift. gak tau kenapa si nyonya dirumah lebih suka ini than camry, ternyata bener handling nya much better than camry. Thanks all. Case closed
- Daily Vehicle: Civic FK4
Aah good pick then oom.... enjoy the new rideAwakhan wrote:Alhamdulillah udah ngangkat honda accord cm7 bottomlift. gak tau kenapa si nyonya dirumah lebih suka ini than camry, ternyata bener handling nya much better than camry. Thanks all. Case closed
Ditunggu user review nya
ChZ wrote:Aah good pick then oom.... enjoy the new rideAwakhan wrote:Alhamdulillah udah ngangkat honda accord cm7 bottomlift. gak tau kenapa si nyonya dirumah lebih suka ini than camry, ternyata bener handling nya much better than camry. Thanks all. Case closedold Honda never gone wrong, they just go faster
Nubie gak enak bikin review nya mod chz, lagian setau saya udah ada beberapa kan user review soal accord cm5/cm7 di SM. Hehehe..
Fotonya dong oom, cakep ni sedan asli....
Selamat buat new ride nya om, ane tunggu reviewnya secara ane akhir2 ini lagi pertimbangin CM5 buat pengganti sedan ane yg sama merk sama jenisnya
Ahh ngga apa2 kok om bikin review nya, toh review harrier gen2 aja sampe 3 biji hoho
upload dulu oom di flickr / facebook / emberpoto... err.. photobucket. nanti linknya post disiniAwakhan wrote:Cara post foto piye? Hehehe..
[img]link[/img]
Reason: bantu edit gambarnya
Ganteng buangeeet, apalagi item the best lah buat CM series...
mulus nya
best lah
Bentar...pelat Bandung ini?
Good choice oom
, apalagi kalo dapet v6 nya
Good choice oom
Thanks mod udah di bantuin tongolin gambar nya..amfibi wrote:Ganteng buangeeet, apalagi item the best lah buat CM series...
Lucky me, dapet unit eks owner pps teflon. Unit nya kinclong luar dalem..jason28 wrote:mulus nyabest lah
Iya om pelat Bandung, nanti tinggal mutasi sendiri aja pas pajak nya mati..imingwahyudi wrote:Bentar...pelat Bandung ini?
Good choice oom, apalagi kalo dapet v6 nya
Sebentar... Ini cat accordnya udah dipakein PPS Teflon??
Pastinya om, secara unit ini eks owner pps teflon..tapi nanti pengen saya ceramic coating, kurang begitu ngefans ama teflon teflonan terlalu banyak pantangan. Gak bisa nge wax sendiri..amfibi wrote:Sebentar... Ini cat accordnya udah dipakein PPS Teflon??
Walaah ini mah beruntung banget atuh catnya rawatanAwakhan wrote:Pastinya om, secara unit ini eks owner pps teflon..tapi nanti pengen saya ceramic coating, kurang begitu ngefans ama teflon teflonan terlalu banyak pantangan. Gak bisa nge wax sendiri..amfibi wrote:Sebentar... Ini cat accordnya udah dipakein PPS Teflon??
Pantes di fotonya item deep bgt...
Muantap om Accordnya
