Seluk-Beluk Modifikasi All New Fortuner & All New Kijang Innova [PART 3]
theansoracing
Daily Vehicle: GUN165R
Re: Seluk-Beluk Modifikasi All New Fortuner & All New Kijang Innova [PART 3]
Post by theansoracing »
barusan nanya di toda gading PTT LV1 kena 1100k include flushing 10 liter
q8 t65 220k/liter
"BURN RUBBER NOT YOUR SOUL"
osbertc0ol
Post by osbertc0ol »
theansoracing wrote: Thu Sep 26, 2019 1:48
theansoracing wrote: Thu Sep 26, 2019 3:18 barusan nanya di toda gading PTT LV1 kena 1100k include flushing 10 liter
q8 t65 220k/liter
Baut check posisinya agak atas om, samping atas gitu.
Thx om infonya, ok juga harganya..
theansoracing
q8 t65 220k/liter
Ada fotonya gak? Ribet neh kalo kudu meraba2
andyez86
Daily Vehicle: Innova
Post by andyez86 »
theansoracing wrote: Thu Sep 26, 2019 3:34
q8 t65 220k/liter
yg di samping itu bukan baut check....baut check ATF ada di dasar pan yg pke kunci bintang gt......yg di samping pake baut gede itu buat top up nya
andyez86
Post by andyez86 »
ini foto baut cek atf level di ANKI dan ANF......monggo dilihat....
theansoracing
andyez86 wrote: Thu Sep 26, 2019 4:09 ini foto baut cek atf level di ANKI dan ANF......monggo dilihat....
wah kudu ngolong yah? kirain gampang hehehe
thx info nya pak
andyez86
Post by andyez86 »
theansoracing wrote: Thu Sep 26, 2019 5:42
thx info nya pak
iy om...kudu ngolong ato cek pas servis berkala aja di BeRes hahhha....yg model skrg ud ga ada dipstick nya...agk repot mmg klo mau cek atf level nya
theansoracing
andyez86 wrote: Thu Sep 26, 2019 6:01
thx info nya pak
itu baut kalo di buka lsg keluar atf atau tidak? atau di buka ada tanda High or Low nya gak?
andyez86
Post by andyez86 »
theansoracing wrote: Thu Sep 26, 2019 6:10
thx info nya pak
klo dibuka dikit lgs ngocor ya brti cukup...lgs tutup lg aja...ga ada high ato low nya hahhahaha
theansoracing
andyez86 wrote: Thu Sep 26, 2019 7:23
kalo di buka ngocor berarti kudu di tambahin dikit lagi dong, kan ada yg terbuang heheheheh
ok thx pak info nya
andyez86
Post by andyez86 »
theansoracing wrote: Thu Sep 26, 2019 7:27
ok thx pak info nya
ya baut nya jgn sampe lepas..puter sampe longgar aja bgtu netes dikit lgs tutup lg...brti cukup....ada jg yg dibuka baut itu ngga ngocor trs dia nambah 1liter lebih....
theansoracing
andyez86 wrote: Thu Sep 26, 2019 7:35
ok thx pak info nya
ok pak andyez86 NOTED
osbertc0ol
andyez86 wrote: Thu Sep 26, 2019 4:05
Ah iyaa. thanks om koreksinya..
Betul om setau saya seperti yg om andy bilang, pas di top up, sambil dilonggarin bautnya, kalo ud ada mulai netes berarti ud full.
theansoracing
akhirnya beli PTT LV1 10 liter @98rb dan DFC serta Q8 T65 4 liter @140rb
semoga hari ini atau besok brg dtg
andyez86
Post by andyez86 »
theansoracing wrote: Fri Sep 27, 2019 1:23 akhirnya beli PTT LV1 10 liter @98rb dan DFC serta Q8 T65 4 liter @140rb
DFC saya stok banyakan....hahhaha....kmren di rmh masih banyak tp beli lg krn ada promo....mayan lah beli selusin buat stok sampe bbrp bln ke depan....soalnya kualitas solar makin acak adut....kmren isi solar dikasi DFC lgs beda bgt krn sblmnya sempet 1x isi solar tanpa DFC
andyez86
Post by andyez86 »
osbertc0ol wrote: Thu Sep 26, 2019 16:20
theansoracing wrote: Thu Sep 26, 2019 3:34 Ada fotonya gak? Ribet neh kalo kudu meraba2
sama2 om....hhehhehhe........
theansoracing
Saya beli 1 karton itu dfc hehehehehe
Buat stok ampe thn depan kali yah
Lebih berasa beda kalo pake psdk seh, cuma suara berisik gak kayak ptt dfc yg rada silent
standrolla19
Post by standrolla19 »
osbertc0ol wrote: Wed Sep 25, 2019 15:16
theansoracing wrote: Wed Sep 25, 2019 11:20
tesna wrote:ada yang pernah bilang ATF PTT itu ok (tp gue lupa exact type, gue googling ada 2 jenis PTT ngeluarin ATF buat non CVT, gue pernah baca siapa gitu ya yg bilang kalau aisin AFW+ kurang enak dipakainya di anki kalau diforsir. Gue juga bentar lagi mau kuras ATF nih, masih galau antara mau stay di toyota or coba PTT.
Sekarang sih pake ATF toyota ga ada masalah berarti ya, so galau sekali ini. paling mau ditambahin ATF cooler nanti :D
Makanya next time kayaknya gue mau ke bengkel aja yang punya semuanya jadi gue ga takut2 salah ahahahah
EDIT: jenis ATF PTT nya itu Automat ATF LV-1 yang cocok buat ANKI (cmiiw)
Gw juga galau antara :
PTT LV1 hrg 98rb/lt,
TOTAL MVLV hrg 135rb/lt,
Q8 AUTO JK 140rb/lt atau
AISIN AFW+ hrg 80rb/lt
Murmer seh aisin yah, tp aisin ya itu Toyota juga
standrolla19 wrote:
cara tahu cairan ATF kurang ny gmn cara y om osbertc0ol? secara sy jg penasaran apa di 2GD sy sdh ckp apa msh kurang, pernah tmbah / top up yg ada rasanya tarikan / akselerqsi lebih berat dr sblm tmbah, tpnsukurny wktunitu top up cm 200ml dl, jd ga diteruskan lg top upny smpai 1 liter.
Kalo ada dipstick bisa lewat situ, cuma 2gd katanya gak ada dipstick, udah cari2 gak nemu spt nya hrs ke bengkel
Ada baut "CHECK" om. cek nya pas panas (Abis jalan). Jadi oli akan cukup jika saat di top up udah ngucur dikit...
Yg lg terkenal sekarang sih merk PTT om.. betul PTT LV buat ANKI / ANF.
gw sendiri lagi bingung kl mau beli PTT itu kuras dimana wkwkwk Shop n Drive deket rumah gamau kalo oli nya bkn dari dia..
So mesti ke bengkel pake oli yg dijual deh sepertinya...
Betul om sy pake eneos 75w90, kemaren top up ATF pake merk FK
ya bgitu om, habis jalan trus tranmisi sybpindah" ke P R N sm D berulang" spt anjuran om Turboman, baru sy buka baut check yg kunci L itu, tak ada tetesan ATF ... dan sy lanjut refill donk di lubang refill (kunci24) yg didinding kanan tranmisi, smbil refill sm lihat di lubang baut check, ttp ga da tetesan... smpai top up sekitatlr 200ml lebih... ttp ga da tetesan. habis selesau top up sy test drive yg ada alamak berasa lbh berat tarikan... jd ga sy terusin top up ny smpai keluar tetesan di baut chek itu... hmmm gmn itu y?
andyez86
Post by andyez86 »
theansoracing wrote: Fri Sep 27, 2019 3:56
saya sih pake di ANKI dosis nya 1 kaleng buat 2x full tank...hahhha...ga berani kebanyakan jg sih...
theansoracing
andyez86 wrote: DFC saya stok banyakan....hahhaha....kmren di rmh masih banyak tp beli lg krn ada promo....mayan lah beli selusin buat stok sampe bbrp bln ke depan....soalnya kualitas solar makin acak adut....kmren isi solar dikasi DFC lgs beda bgt krn sblmnya sempet 1x isi solar tanpa DFC
Saya seh 1 kaleng buat isi fulltank, isi full kalo jarum udah deket mau tiarap
theansoracing
Finally datang semua ptt LV1, ptt dfc dan Q8 t65
Senin kudu ke A2k Serang kalo gitu
tesna
Post by tesna »
ada yang udah coba ecushop ultra boost? harganya menarik banget nih
W212 M272 '10
AN140 2GD '18
theansoracing
tesna wrote: Sat Sep 28, 2019 7:10 ada yang udah coba ecushop ultra boost? harganya menarik banget nih
cobain tes, liat di ig nya seh udah ada yg pasang dan seting via android tuh
brpan seh hrg nya?
kompresorz
Post by kompresorz »
santai bisa..kencang jos..buat ketemu relasi oke..jadi mobil angkot hayoo...
pokoe serba bisa lah...
namanya jg mobil harus ikut apa guwe mauuu...
kencang irit kuat ac dingin kulkas...gagah pula...
harian pigibak isi solar murni...
bolak balik bberapa hari ini bawa belanjaan ampir 1 ton...malam pun tetap kerjaa...
mobil josss ....
ky lagu senangnya hatiku..mobilku gagah kencang irit kuat awet ac dingin kulkas...gak susahin...
theansoracing
kompresorz wrote:santai bisa..kencang jos..buat ketemu relasi oke..jadi mobil angkot hayoo...
mobil josss ....
Kalo monokok kuat gak yah ngangkut begituan
