Khusus TOP SPEED
handling
Post by handling »
pak conan & pak wp, sepertinya type potenza yg dipake di 318i, hiu, baleno dll sudah stop produksi digantikan type lain blm lama ini, sy gak inget namanya. kalo sya liat kembangnya lebih bagus type potenza dibandingkan penggantinya.
kalo mau pake potenza mesti buruan, mumpung bebrapa toko masih py stok.
pak wp, tulisan turbo ini cuma tempelan saja pak wp, dari generasi pertama charade masuk ke indo sdh ditempeli dgn emblem turbo. dan masuk dgn 3cylinder. kalo yg pak wp liat itu mgkn yg generasi kedua...cmiiw.
lain halnya dgn 740GLE, kalo yg ini intercoolerturbo beneran....hikhsihkksssss
Bram
Daily Vehicle: BRIO black elegant
SPEECHLESS
Post by Bram »
Code: Select all
Mr. Bram, you got me wrong. I never said I didn't believe your Soluna can reach 180 kph. Given enough horsepower, enough time and enough stretch of the road, there's no reason why it can't be done. But whether it's really something safe and responsible to do 180 kph with a Soluna. Apakah Soluna Anda ada airbag, misalnya?
WELL ....I really appreciate it ur opinion...u were rait Mr.conan I was Wrong....Luckly..Gw & Bung Digi SELAMAT....actually ..I...Realized dat 'ga aman Max speed apalagee ampe mentok...180Kph...Soal ban gw jg tauu min Bridgestone Potenzas yg recommended..tp 'lon ada Fulus-nyaaa..... :e-naughty:
Gw..hanya pembuktian apa adanya ..sajahhh...
Bahwasanya my Blue SOLUNA GLi'00 reach at 180kph TOP SPEED...
......ONCE AGAIN ....TESTED..... :vamp:
Code: Select all
Saran : ganti kap mesinnya dengan karbon kevlar. Udah ringan kemudian kuat bgt ! Harga sih emang cukup mahal >3.5 jtan kalo ngga salah. Hehehe... gimana tuh saran gw Bram ?
[code] Seep Boss...'ntar....UUD....(ujung2nya duit jg) lg bokek nech... :e-think:
To all of u Fox...espc..SM community...mohon disikapi dg Bonarrr....(is Totally not recommended ..nge-Tes Top Speed at TOL CIPULARANG...'Coz is really2 Dangerous..so Boys 'N gal don't try at TOL Cipularang..'klo di SENTUL sok waeee asal..siapin azah...budget-nya yg guedee...bila perlu Over-time buat Workers...part time job buat yg masih student...)
Abis...gw kesel....koq 'ga ada yg percaya pd awalnya.. ttg Top Speed My SOLUNA...ampe2 bung Digi jd Saksi..... :silly:
Soal Bimmer, Jag 'n Mercy....Shame on them....masa High perform tp lari ky teenagers yg baru belajar Nyetirr....Soalnya mereka2 pada PD abish berada Di jaLur KANAN..yg NOTA BENE buat Jalurr tancap abishh...KESEL tauu..mentang2 di belakangnya SOLUNA dianggap enteng... :snipersmile:
In closing 2 mr. conan....Percayalah masih ada warga yg JUJUR di INDONESIA  yg kita cintai-ini..yg 'ga bener berarti OKNUM...
..PEACE..... :e-clap:
szli
Post by szli »
Yang suka ngebut banget just inggat ini :
" Power is nothing without control ! "
So if U lose control nanti, all the high speed is meaningless.
Seperti golf swing. Orang suka bisa pukul driver sejauh jauhnya. Tapi sadarkah mereka kalau arahnya miring, justru makin jauh makin gawat. Bolanya pasti masuk kolam, pasir, atau out of bounds. Mending jaraknya lebih pendek 30% tapi lumayan lurus dan accurate.
Bram
THX 4 ur VALUE WARNING
Post by Bram »
Code: Select all
FORTUNATELY ' POWER IS UNDER CONTROL'
HOLE in one 180kph SOLUNA GLi'00
I'm not a mad man...Juz...Org JUJUR yg berkata apa adanya...
THX any way Mr.szli ....
4 ur MOST VALUE WARN....I really appreaciate it... :D
......PEACE.....
DigitALL
Post by DigitALL »
handling wrote:
DigitALL wrote:Ada yg tau beli avgas dimana ? Aman ngga ?
kalo di bdg, saya belum tahu beli dimana? ntar sy coba tanyain deh....
untuk amannya, selama ini saya juga baru tahu...hikhiskhsiks ketinggalan berita....belumpernah denger ada masalah...
cuma jeleknya saya jadi ikutan ketagihan juga....saya udah pake 2x isi bensin, saya berasa sekali mobilnya jadi irit. ....
Kalo di Jkt loe beli dimana handling ? Selain irit, akselerasinya gimana ? Ngaruh ngga ke performance ?
DigitALL
Post by DigitALL »
You said you've got GT Radial/Dunlop. I say you might want to have at least Bridgestone Potenzas. Performance tires from Michelin or Pirelli are even better. Jangan lupa bahwa pada kecepatan tinggi, ban adalah elemen yang sangat vital. It's the only thing connecting you with the road.
Kalo pake Pirelli P6000 aman ngga ya ?! Soalnye gw pake ban tipe itu. Katanya sih support sampe >200km/h.
Check again, bung Digi. Aku baca di test Otomotif. Octane booster itu jika dibilang menambah octane sebesar 5 skala, artinya bukan menambah angka RON 5 tapi 0.5, dst.
Hehehe ... iya tuh, bung conan betul. Thanks utk koreksinya !
DigitALL
Post by DigitALL »
Kalo ngga salah itu kan slogan yg ada di iklannya PIRELLI "Power is nothing w/o control !".
But thanks szli atas nasihatnya.
mpoezz
Post by mpoezz »
pirelli pasti aman dong mr digi,harga nya juga langsung mengamankan duit didalam kantong kekekekeke
handling
Post by handling »
pak digi, daerah cililitan. biasanya org pake cara ampuh ini utk ngilangin knocking, tapi malah lebih banyak yg iseng utk peforma mobil.
sy tes pake gigi 5 di kecepatan 45km/h tekan mendadak jangan dilepas sampe kecepatan 80km/h, tdk terdengar ngelitik sama sekali (sy coba dgn keadaan kaca jendela setir terbuka, supaya lebih jelas terdengar kalo memang ada suara knocking) ya ada adlh suara dengung pertanda kekurangan tenaga.
kalo pake premium/pertamax selain suara dengung juga ditambah suara knocking.
DigitALL
Post by DigitALL »
ic ic ...
Gile juga daya ledak avgas ! Coba jangan ya ?! Hehehe ...
WP
Post by WP »
handling wrote:pak conan & pak wp, sepertinya type potenza yg dipake di 318i, hiu, baleno dll sudah stop produksi digantikan type lain blm lama ini, sy gak inget namanya. kalo sya liat kembangnya lebih bagus type potenza dibandingkan penggantinya.
tapi pak handling, saya pernah dengar lho katanya memang beneran ada Charade Turbo tapi tetap 3 silinder.........dan sebagian masuk Indonesia...
Kalo cuma tempelan, berarti Daihatsu sini bohong donk???
And, Mr handling, Volvo 740 GLE itu ga pakai turbo, yang pakai turbo adalah 740 TURBO INTERCOOLER..., bedanya bisa liat di emblem sama di panel instrumen, kalo 740 TURBO ada Turbo boost indicator-nya... trus biasanya 740 Turbo sini automatic....Tarikan mobil ini sih.....wuuuuihh kenceng bro!!! tinggal colek gas maka Turbo bakalan bekerja...
WP
Post by WP »
Pak Digi, yg punya pak Digi itu PIRELLI P6 atau P6000?
coba liat thread "BAN IMPOR UNTUK JALANAN INDONESIA" deh for more details. . .
handling
Post by handling »
WP wrote: tapi pak handling, saya pernah dengar lho katanya memang beneran ada Charade Turbo tapi tetap 3 silinder.........dan sebagian masuk Indonesia...
bagaimana dgn tempelan Limited edition yang di starlet 90-98? lol: :lol: :lol: hayo coba.... apa memang benar limited...lol: :lol: :lol:
And, Mr handling, Volvo 740 GLE itu ga pakai turbo, yang pakai turbo adalah 740 TURBO INTERCOOLER..., [/quote]
ya pak wp , terimakasih atas koreksinya, maksud saya juga seperti pak wp, tulisan intercooler ada di kap bagasi belakang.
ahbeng
Post by ahbeng »
Mazda 2003 Type S (3000 cc V6)
gue pernah ngebut ampe 125 mph ( pas ujan rintik2 di hiway) stabil ga tau masih bisa naik apa ngga krn uda ga ada nyali buat lewat dari segitu :P
Bram
KARIMUN TOP SPEED
Post by Bram »
Guys...
Ada yg pernah Cuba Top Speed-nya KARIMUN 'ga...???
Katanya bisa Tembus >140Kph ..bener 'ga..??
Code: Select all
eh di jakarta ada tol yang banyak tikungan nya nih.....di tol serpong arah cipete/fatmawati, tol ini kalo di terusin arah pondok pinang, tempat kejadian kecelakaan honda dity yang gua posting itu..,,
Yaah....Bung handling ane jd tatut nech.....padahal Pwk-bdg ane sering tancep abish..'ga peduli bini ampe ngomel2.....'ga kebayang...city yg ada airbag-nya azah 'ga ngaruh yak tewas ditempat..amit2..... :e-think:
'Tlus pas test ama bung digi untung SALAMAT....mana ban pake Gt radial front...Dunlop back....Mix tires ky genee kan bahaya yaaa..bung conan..??
Jadi kepikiran beli KARIMUN azah...dech....buat PP ke Luar Kota Recomended ga yah...???
conan
Re: KARIMUN TOP SPEED
Post by conan »
Bram wrote:Guys...
Code: Select all
Bisa, ada kawanku pernah coba. Tapi sekarang ditahan di max 120 kph. Karena lebih sayang nyawa.
Aku tidak yakin Anda akan 'aman' membawa Karimun, bung Bram, karena Anda terbiasa ngebut 180 kph dengan Soluna. Dengan Karimun, pada 140 kph jika Anda tiba2 bermanuver ria (karena otak Anda ingatnya sedang bawa Soluna), kemungkinan thread ini akan berkurang seorang pengunjung tetap :mrgreen:
Dunlop + GT Radial = bukan cuma berbahaya karena dicampur aduk, bung Bram...tapi kedua ban itu masing2 (apalagi GT Radial) aku sangat meragukan keamanannya pada kecepatan tinggi. Beli ban lebih bagus bung, Anda lebih sayang duit atau nyawa, right?
handling
Post by handling »
kalo rasanya akan beda banget kalo lari ke karimun. karimun kan biar seken juga mahal bok. temen gua sempet cari seken 6bln kmrn, sy juga kaget sekennya. pikiran sy dulu karimun waktu launch 70an. eh sekarang udah 90jtan.
kalo carry 89 dulu sy pernah cobaa sampe 110km/h,.kalo katana gak berani. mgkn 120 kali. kalo karimun syy rasa gak bisa 140 deh. soalnya mesinnya cuma 970cc.. dgn 55hp .cmiiw. sy rasa paling 125km/h itupun butuh waktu.
WP
Post by WP »
ya pak wp , terimakasih atas koreksinya, maksud saya juga seperti pak wp, tulisan intercooler ada di kap bagasi belakang.[/quote]
Wah, saya sih ndak tahu bener ato gak ya pak... saya cuma pernah lihat stikernya di pintu bagasinya sama baca di majalah otomotif sih....
kalo Starlet SE-Limited ato Corolla SE-Limited (twincam), itu sih cuma emblem-nya aja... sama juga kaya Jeep Cherokee Limited...
Kalo Toyota Soluna S-Limited sama Daihatsu Taruna G-Limited itu baru beneran limited pak... :D
DigitALL
Post by DigitALL »
Yg gw pake Pirelli P6000.
Oke nti gw cek threadnya.
DigitALL
Post by DigitALL »
Bram wrote:Guys...
Code: Select all
Gw punya Karimun juga Bram, mesin sih udah bukan standar lagi alias udah di oprek. Kalo tembus 140 km/h gw rasa bisa koq Bram, cuman butuh waktu lama. Waktu gw bawa di tol pernah 140 km/h, ngga berani lebih karena udah ngga stabil. Bawa segitu kek udah lari 200km/h aje rasanya :lol: Ngga percaya ?! :shock: Mau test lagi nih di Cipularang ?! :lol:
Udah Bram, ganti aja Bridgestone Potenza. Biar larinya lebih manteb ! Jangan downgrade ke Karimun, ntar nyesel loe baru tau.
DigitALL
Post by DigitALL »
Harga second Karimun emang lumayan tinggi karena peminatnya cukup banyak.
Ngga percaya ya Karimun bisa 140 km/h ... Biar cuma 970cc 55HP tapi larinya oke, cuman emang butuh track panjang. Naeknya rada lama kalo dari 130 ke 140km.h Dia cuma oke di tarikan menengah aja. Kalo gigi 1 nya pendek bener ... Payah !
conan
Post by conan »
DigitALL wrote:Waktu gw bawa di tol pernah 140 km/h, ngga berani lebih karena udah ngga stabil. Bawa segitu kek udah lari 200km/h aje rasanya :lol: Ngga percaya ?! :shock: Mau test lagi nih di Cipularang ?! :lol:
Bung Digi betul, Karimun bisa koq 140 kph.
Btw bung Digi and bung Bram, kalau mau coba lagi di Cipularang, konon kalau naik Karimun pada 160 kph, bisa melihat terowongan yang ada cahaya putih di ujungnya...dan tiba2 merasa damai, semua beban terlepas...Anda berdua mungkin berminat mencobanya? :mrgreen: :twisted:
handling
Post by handling »
ahbeng wrote:Mazda 2003 Type S (3000 cc V6)
mantap abis....ngomong mazda 3000cc v6 Hpnya berapa pak ahbeng?
handling
Post by handling »
anything possible dgn oprekan.
kalo kondisi standar bisa 140km/h pasti butuh waktu yang lama sekali. blm lagi rpm nya mendekati redline.
Bram
Post by Bram »
Code: Select all
Waduch...bung conan Sentimen euy..
Masalahnya kan cuma berkata jujur boss ..di topic Top Speed...
Bahwasanya Top Speed Soluna ane bisa reach at 180Kph...
Dapet tanggepan Bull- [cencored] tuch si Bram....ngada2...
So Mr. digi dech.. jadi witness...gimana gilanya lari at 180Kph..
My Soluna teh....Saya memberi bukti..walau akhirnya dapet masukan berharga dr rekan SM-ers baik yg Pro..'n Kontra...
Masih sayang nyawa boss ...
So 'klo Taxi bisa Max speed jg Sirik Duonk..J/K...
LON' LIFE SOLUNAIS..... :vamp:
INGA2.....MASIH ADA ORANG YG JUJUR DI NKRI INI........ :mrgreen:
