Moderators: r12qiSonH4ji , avantgardebronze , akbarfit , Ryan Steele , sh00t
kayukayuthe5th
Posts: 931 Joined: Wed May 03, 2017 10:30
Post
by kayukayuthe5th » Wed Jun 25, 2025 7:10
gujax05 wrote: Wed Jun 25, 2025 4:26
kayukayuthe5th wrote: Tue Jun 24, 2025 10:30
gujax05 wrote: Tue Jun 24, 2025 3:44
Sapatau mau nyoba oli BPJS kayak K15B ane Om
ato pake techno hehe selisih gabanyak.
di J24B saya pake techno 5W-30 dari sebelumnya techno 10W-40...makin enteng sih...tapi nguap dikit...
malah senapsaran pengen nyoba ecogreen 5W-30 di J24B...
biasanya sih kalo gwa coba ecogreen ama techno. tarikannya doang sih terutama kalo udah 2000km an ecogreen udah mulai agak2 berat, 4000km kasar
*test in L15z1
kalo techno ini 3500km udah berat n 5000km kasar *review di L15zf
kalo aman sih , aslong as ganti 5000km+filter yah n kondisi ok,
Posts: 12785 Joined: Tue Apr 30, 2013 7:10
Post
by Suryaputra » Wed Jun 25, 2025 7:12
Klo oli makin encer, coba naik grade, misalnya fastron emas
k31k0ku
Posts: 45 Joined: Mon Jan 23, 2017 1:51
Post
by k31k0ku » Thu Jun 26, 2025 4:25
Mau tanya kepada suhu2 disini
Ane baru gnti mobil jdi Chery Tiggo 8 Premium (1.6L TGDI Turbo)
Di buku manual mobilnya sih tulis pakai Oli 5w30
Apakah ane ttp ikutin pakai 5w30 atau hajar 0w20 saja ya?
Dan suhu2 disini apakah ada oli yg di recommend utk mesin Turbo?
sahabatq8
Posts: 2592 Joined: Sun Sep 26, 2021 10:49
Daily Vehicle: Nissan Xtrail
Post
by sahabatq8 » Thu Jun 26, 2025 4:45
k31k0ku wrote: Thu Jun 26, 2025 4:25
Cari oli api SP/ dexos 1 gen 2/3 aja.
Pake Q8 D1 5w30 bisa.
Kalo om mau coba 0w20 baiknya di tes lab buat liat apakah wear levelnya masih ok di 0w20.
kayukayuthe5th
Post
by kayukayuthe5th » Thu Jun 26, 2025 10:22
kasih 5w30 tapi klelas sultan aja mbah, jangan diturunin kalo di buku manual 5w30
untuk GDI-turbo ambil yang API SP wajib om, nanti preignition/detonation issue kalo pake API SN.
Post
by Suryaputra » Thu Jun 26, 2025 10:35
boleh scan atau foto di sini mbah?
kepo mau lihat spec oli mesin nya spt apa, selain visco
sekalian sm oli DCT nya
mkamil
Posts: 306 Joined: Tue Aug 06, 2019 14:02
Daily Vehicle: 1VD - L15Z - FB25
Post
by mkamil » Thu Jun 26, 2025 10:56
Krigger wrote: Mon Jun 23, 2025 13:00
Leonhart wrote: Mon Jun 23, 2025 8:09
Adnoc star suka nguap ya om ? abis baca2 page blkg
ini ane baru bbrp hari ngisi enak tarikan enteng bgt di R18
selama ini pake kendall, Q8, PTT gak pernah nguap2...
gk tau pake adnoc ini gmn
mudah2an gak nguap...
Saya pake di crv turbo 9000km an sih ga ada nguap ya
no nguap sih di saya, walau cuma 4500an km, 5w30 yg relatif encer.
kayukayuthe5th
Post
by kayukayuthe5th » Thu Jun 26, 2025 12:47
Suryaputra wrote: Thu Jun 26, 2025 10:35
karena cherry ini ACTECO mbah turunnya dari AVL penasaran juga sih apakah perlu ACEA or so
t105erd
Posts: 1668 Joined: Sun Mar 20, 2022 1:17
Post
by t105erd » Thu Jun 26, 2025 13:56
mkamil wrote: Thu Jun 26, 2025 10:56
wah Subaru, beberapa kali cek unit banyak yg cover valve nya rembes sama yg sambungan gearbox/diferensial depan dan mesin tuh. Jadi mundur lagi, padahal enak bgt mobil ini.
t105erd
Post
by t105erd » Thu Jun 26, 2025 13:59
murmer crot pakai acdelco dexos1 gen3, Adnoc, Enoc atau Petronas sintium 5w30 yg ada cap dexos 1 gen2 atau gen3
k31k0ku
Post
by k31k0ku » Fri Jun 27, 2025 4:34
Ini om
k31k0ku
Post
by k31k0ku » Fri Jun 27, 2025 4:37
t105erd wrote: Thu Jun 26, 2025 13:59
Harus ada yg cap Dexos 1 gen 2 atau 3 ya om?
Kalo misalnya kaya T.Quartz 9000 5w30 apakah bisa jg om?
Post
by Suryaputra » Fri Jun 27, 2025 4:43
k31k0ku wrote: Fri Jun 27, 2025 4:34
Ini om
Gak ribet oli mesin ini mobil ny
Yg penting comply ke API SP.
Ada cap Dexos 1 Gen2/3 lbh bagus.
Happy hunting dan sesuaikan budget aja.
Sy jg kebetulan siang ini mau ganti lebdir segala macam
t105erd
Post
by t105erd » Fri Jun 27, 2025 4:45
k31k0ku wrote: Fri Jun 27, 2025 4:37
Yaa mungkin bisa juga sih, kalau sudah api SP biasanya bisa, cuma kan generik kalo API, PTT 5W30 yang botol abu2 juga sudah API SP, ga usah mahal2.
kalo dexos1 gen 2 atau 3 setahu saya sih dibuat sama GM khusus untuk mobil2 GDI Turbo.
kayukayuthe5th
Post
by kayukayuthe5th » Fri Jun 27, 2025 5:45
wow walaupun turunan AVL ternyata ga ribet, yang 2.0 itu bisa pake 0w20 ACEA C5 tapi kalo yang 1.6 maksimum 5w30 API SP (tanpa ada embel2)
bisa banget itu TQ9000 salahsatu andalan warga SM
welp gede juga yah 4.5 liter
kayukayuthe5th
Post
by kayukayuthe5th » Fri Jun 27, 2025 5:54
Suryaputra wrote: Fri Jun 27, 2025 4:43
Ini om
API SQ/GF-7 kah?
Posts: 22082 Joined: Mon Dec 12, 2005 5:14
Post
by Turboman » Fri Jun 27, 2025 7:19
Just info
Skg Lubrex 0W20 API SP Dexos 1 G2 bisa dibeli di Apps Toco, selain di Toped / Sopee (td motor)
https://toco.id/link/f43GmfDmUDYWpij91ycZwh
kayukayuthe5th
Post
by kayukayuthe5th » Fri Jun 27, 2025 8:32
toco= toko kuning.
enak jual2in preloved disana hehe.
Post
by Suryaputra » Fri Jun 27, 2025 10:35
Thanks for your service
See you 7rb km lagi
t105erd
Post
by t105erd » Fri Jun 27, 2025 11:29
Suryaputra wrote: Fri Jun 27, 2025 10:35
See you 7rb km lagi
wah aturan berkabar yaa, biar jadi mini kopdar, deket bgt sama rumah saya hehe...
Post
by Suryaputra » Fri Jun 27, 2025 11:47
t105erd wrote: Fri Jun 27, 2025 11:29
See you 7rb km lagi
Wah next time dong yaa
Nyebrang sumarecon dl
Posts: 11952 Joined: Wed Oct 16, 2013 6:27
Post
by marmut » Fri Jun 27, 2025 12:26
Post
by Suryaputra » Fri Jun 27, 2025 13:12
marmut wrote: Fri Jun 27, 2025 12:26
eta jisok naon kang?
Biar resing kang
kayukayuthe5th
Post
by kayukayuthe5th » Fri Jun 27, 2025 13:13
See you 7rb km lagi
wiw sobat adnoc nih
Post
by Suryaputra » Fri Jun 27, 2025 13:22
kayukayuthe5th wrote: Fri Jun 27, 2025 13:13
See you 7rb km lagi
wiw sobat adnoc nih
Yah 400rb / 4 liter
Beda 25rb sm techno
Dah dpt made in abu dhabi
Dexos 1 gen3
nikmat mana yg bisa didustakan
Btw klo sutarbulus eco dah 150k seliter
