Grand Livina Users..! - PART 06
Re: Grand Livina Users..! - PART 06
DOHC wrote: Wed Jul 15, 2020 15:43
mungkin benzene nya perlu dicampur oli samping mbah, biar ga brisik
btw punya lipindut mah musti sering2 d geber donk.. sayang, kan ud enjin resing, oli keraton.. masa dianggurin doank
mau pake gasoli yang biru apa merah?
P47hos
Post by P47hos »
blloewy wrote: Wed Jul 15, 2020 5:24 Om Klep, Mbah Marmut kl suara engine HR15 begini apakah itu suara Tumble Valve di Intake Manifold?
https://voca.ro/c4NCgdBBvLQ
Posisi Oli PTT 5W-30 baru pake 350 km.
Manual kah om? Suaranya Bukan dr arah transmisi? Injek kopling hilang gak
blloewy
Post by blloewy »
P47hos wrote: Thu Jul 16, 2020 0:50
Iya manual...
Kl itu beda Om suaranya...
Ngga sekasar itu kl transmisi MT Livina
Cm seerrr.....seeer....seeeerrr doang.
blloewy wrote: Thu Jul 16, 2020 6:33
Iya manual...
Biar tenang d turun mesin aj
Abis itu di oversize 0.5
Parts2 lengkap koq d atrium, aseli made in jepun pula
Ntar mobilnya jd makin resing
blloewy
Post by blloewy »
DOHC wrote: Thu Jul 16, 2020 6:49
Iya manual...
saran sesat ini mah....bagi yg ngga pny duit :D
atrium toko mana yg rekomen om klep kl mau beli parts Livina?
Champion Motor ya?
blloewy wrote: Thu Jul 16, 2020 12:37
Iya manual...
Champion Motor ya?
kl rencana mau pakai ampe 20 taon lg yah mending dr skrg ud d turun mesin om.. jadinya hati tenang 20 taon ke depan
champion bsa, GT motor jg bsa... kl yg laen, sila dcoba dgn konsekuensi sendiri
ohh satu lagi, sudah hukum adat kl beli busi d atrium (palagi busi batu makam) utk di buka dan di check lg busi nya
blloewy
Post by blloewy »
DOHC wrote: Thu Jul 16, 2020 15:04
Champion Motor ya?
Turun mesin ganti seal.klep dkk ya Om?
Ada tuch di grup turun mesin krn sludge olinya sampe di tutup oli bisa diserok.
Btw, kenapa emang businya Om kl beli disono?
Jambangan
Post by Jambangan »
blloewy wrote: Thu Jul 16, 2020 22:59
Champion Motor ya?
Banyak cerita livina oil sludge sampe mesti turun mesin
Kalo kata mod DOHC gara2 mesin livina terlalu panas sedangkan kapasitas oli cuman 3 L
Pernah liat livina lagi dibongkar gara2 oil sludge metal2 baret semua serem
P47hos
Post by P47hos »
Iya manual...
Klo bearing transmisinya sdh kena jg bunyinya bakal kasar om. Tp klo diinjek kopling ilang suaranya
Jambangan wrote: Fri Jul 17, 2020 1:45
kalok cerita kijang super kek mana rupanya lae?
P47hos wrote: Fri Jul 17, 2020 13:44
kalo injek pedal kopling suara hilang, clutch release bearing yang kena. atau monteur asem reges biasa bilang druk lager. lokasinya di bell housing, tidak di dalam transmisi.
bearing transmisi adanya di dalam transmisi, selalu kerendem oli.
selama oli masih ada, ngga akan rusak ataupun bunyi kecuali volume oli sangat sedikit sekali.
marmut wrote: Fri Jul 17, 2020 14:40
kl utk kes old nissan grand livina super resing dgn girbox RS5F9 5 speed, memang scara default ad bunyi mbah, bahkan mau di masukin veet jg bakal tetep bunyi..
bunyi nya itu bukan karena bearing, tp krn hub assembly gigi mundur + synchro nya yg muter2 mulu, dtambah bell housing yg posisi hadep ban (warna item) yg rada kopong (krn kayanya ini bell housing yg dipake jg utk RS6F9 6 speed yg lebi padet berisi montok dgn gear ke 6) shg bunyi si gear di resonasi oleh si ruang kopong tsb, makanya pas lg neutral ad bunyi krrrrrrr krrrrrr kenceng
blloewy
Post by blloewy »
Iya manual...
Bearing transmisi maksudnya itu synchronesh?
Kayanya ngga dech Om.
blloewy
Post by blloewy »
DOHC wrote: Fri Jul 17, 2020 16:46
Om klep sdh bersabda...
Bawaan orok Vina itu.
1. Ndut2an di gigi 1-2 rpm under 1500
2 suara transmisi saat netral
3 bunyi injector nya kenceng
Itu aja kayanya bawaan lahir yg ngga bs sembuh kecuali no 1 diremap...
Btw, injector Vina ada brp ya Om Klep?
Sekalian nanya....carbon clean alias gurah itu sebenernya perlu atau ngga ya om?
Atau cukup purging injector aja?
Mobil sdh 8 thn pengen cek injector nya sekaligus kalibrasi...meskipun pake petromax trs tetep aja itu fuel pump kotor krn endapan yg entah drmn :big_peace:
josomba
Daily Vehicle: Delman
Post by josomba »
blloewy wrote: Sat Jul 18, 2020 0:37 Om klep sdh bersabda...
carb clean sih .... paling bener copot busi n liat sendiri om kondisinya pegimana d dalem ruang bakar .... cuman setahu saya untuk akses busi-nya lipindut kan agak laknat ya .... n 8 tahun kalau pemilik sebelumnya kagak pernah bebersih, ya ga ada salahnya lgsg aja merem bebersih...
Praktis sejam beres ya ke toda, pake liquimoly jetronic-nya dia lgsg tancep alatnya ke fuel rail jd lgsg bersihin fuel rail + injector + combustion chamber. Kaga ada buka2 busi dll. n 700 ribu++ melayang sudah pasti.
Mau metode lebih bersih tp agak lama, ya copot atu2 .... skalian bersihin TB, intake manifold, payung klep masuk, ruang bakar, fuel rail, injector, ruang bakar .... pengerjaan tapi ya mungkin seharian. Harga variatip, gimana bengkel getoknya aja.
Tapi kalau di tempat mbah @marmut mungkin 10 menit beres, karena punya asisten kucing di lantai yg sangat rajin membantu :big_biglaugh: :big_biglaugh:
:ngacir: :ngacir:
blloewy
Post by blloewy »
josomba wrote: Sat Jul 18, 2020 1:35
:ngacir: :ngacir:
Ada tuch yg bagian akhir Om...yg dicopot satu2 dari mulai TB, EGR dibersihin.
Intake manifold dicopot dan dibersihkan jg dan dilepas satu2 tumble valve plastiknya...
Terakhir ya copot koil, bersihkan busi dan semprot di ruang bakar sampe bersih...
Emang seharian sich...tp okelah dicoba yg itu krn lbh deket rumah :)
Lipindut ndut2an itu biasanya terbiasa bawa kijang kapsul, panther atau apanja. Kl yg perna bawa cityZ, dangan atau sebangsanya mahh, lipindut ga ad seupil2 nya
Injector trgantung
Kl old nissan grand livina 2007 HR15DE L10 with Rs5F9 gearbox single cvtc yg always bbm.pertamax itu single injector
Tp kl ANGL HR15DE Jatco CVT twin cvtc itu twin injector
Carbon clean wajip donk, mesin berkerak nanti jd ga resing mesin nya
:ngacir: :ngacir:
Kl cuman sekedar masukin obat2 an doank trus jebrettt ratusan rebu mah lupakan aj... masa mesin super grand resing di rawat gampangan gt, penipuan yg lebi parah dr kutang berbusa tebel
Harus copotin satu2 donk, bersihin leleran oli berliter2 d intake manifold, EGR dibersihin stelah berkerak 10 cm, tumble flaps dibersihin stelah dibungkus kerak lengket item kaya ingus thanos.. blom lg klep masuk dan head in yg ud dilapisin kerak setebel panci mamang nasgor beneran (bukan yg pake HT)
Itu musti dibersihin pelan2, minimal kl ga mau copot head, ya musti disikat satu2, trus d lap.. dl aj saya bsa abis seharian buat bersihin gt doank
Nahh itu, coba berguru ke mbah marmut aj, masda item skyaktif busi brisk resing yg kap mesin nya kinclong wangi dan disc brake 4 roda d veet aj berobat ke dia
blloewy
Post by blloewy »
DOHC wrote: Sat Jul 18, 2020 3:01
:ngacir: :ngacir:
kudu pm mbah @marmut dulu nanya lokasi bengkel dan estimasi biaya bersih2 seperti kata om @dohc
maklum pemilik engine resing tp pemakai BPJS :big_peace:
P47hos
Post by P47hos »
blloewy wrote: Sat Jul 18, 2020 0:33
Saya punya ganti set kopling sama drek lahar nya tetap aja kenceng bunyinya. habis ganti bearing transmisi bunyi krrr kencang jd normal kembali kaya baru. Cuma ongkosnya mahal bener. Ini mobil serba salah mau dijual harga jatuh, jd akhirnya diservis aja. Tp siapkan aja 30jtan klo sudah 10 tahun /150rb km. Btw klo om punya sdh 8 tahun siap2 fuel pump minta ganti.
blloewy
Post by blloewy »
P47hos wrote:Sat Jul 18, 2020 3:41
sblm ganti dibersihkan dulu om kl fuelpump nya.
30 jutaan buat apaan?
ganti transmisi apa ganti engine itu? :big_think:
P47hos
Post by P47hos »
blloewy wrote: Sat Jul 18, 2020 3:48 sblm ganti dibersihkan dulu om kl fuelpump nya.
Engine mounting set 1.2
Koil + busi 2.5
Kaki2 +/- 15
AC 3
Transmisi bongkar + kopling set 6.5
Fuelpump 1.6
Radiator 1
Itu yg saya ingat om 😁
blloewy
Post by blloewy »
P47hos wrote: Sat Jul 18, 2020 4:09
Koil + busi 2.5
Kaki2 +/- 15
AC 3
Fuelpump 1.6
Radiator 1
Mihil.sekali sampeyan Om.
Transmisi bongkar plus kopling set plus seal drive shaft kemaren 3 juta di beres
AC 700 rebu clean all evap, kompresor dan ganti oli kompresor.
Kaki2 msh aman jaya...nunggu promo beres akhir tahun ganti semua bushing kena 3 jt exclude shockbreaker aja :big_peace:
Fuelpump skrg naek om jd 2,5 jt tp so far msh aman jaya :big_smile]
josomba
Post by josomba »
Gapapa laa mbah, money maker banget itu liquimoly jetronic :big_weee:
Mestinya mbah marmut sediain juga d bengkelnya drpd pusingin milih kunci pas yg bagus... :big_biglaugh:
josomba wrote: Sat Jul 18, 2020 7:22
mana mau si mbah, colok2 doank, tangan bersih.. ga berasa kerja itu, ga bsa kluarin kebon binatang sgala..
kopi ama tahu goreng masi anget, kerjaan ud klaar.. ga seru donk
Koil + busi 2.5
Kaki2 +/- 15
AC 3
Fuelpump 1.6
Radiator 1
kaki2 15 juta ?? bukannya ini harga jaman dulu ya, jaman OGL
masa skrg masi belasan jt ?
fuel pump jgn ganti full set, ganti motor nya aj, seinget saya dl di atrium ad jual koq , murah pake banget
