Tentang Penembakan Direktur PT Putra Rajawali Banjaran
Prive
Re: Tentang Penembakan Direktur PT Putra Rajawali Banjaran
Post by Prive »
kalo udah gini jualan armored car laku kali yah, kayak panser amphibi gitu, ditembak gak mempan, macet2an serempetan gak penyok, giliran banjir masih bisa jalan - ngimpi mode : on
:off_sleep: HOI BANGUN NGIMPI TERUS!
ok lanjut Om topicnya :mrgreen: :mrgreen: :mrgreen:
datsu
Post by datsu »
hahaha... gak tau hukum fisika gw.. :P tapi memang semua jenis KF itu lemah sampai dia nempel di kaca.. nah kalo udah nempel di kaca, cuman cutter yang bisa motong.. ama benda2 yang mungkin setajam/lebih tajam dr cutter... itu juga alesannya KF ini ditaro di dalem.. karena fungsinya bukan menahan peluru.. tapi membantu menahan peluru...
I'm flying with my Siti
Powered by L15Z1 N/A
gemelli
Post by gemelli »
yang gue tau sih kaca anti peluru bukan kaca film... biasanya ini custom made n di pasang fixed alias jadi mati gak bisa di buka/tutup.. jadi musti pasang ac kalo ga mao gosong hehe...
ketebalan kaca mah krg pengaruh.. jadi bukan makin tebel makin tahan tuh kalo yg di lawan-nya pelor mah..
TUFF Stough
Daily Vehicle: Ipin - Ipah
Post by TUFF Stough »
AFAIK ketebalan juga pengaruh kok.
Pernah nonton liputan soal hadiah mobil dari Fiat untuk Paus Yohanes Paulus II, kacanya bullet resistance dengan ketebalan sekitar 7 ~ 7.5cm.
wikipedia wrote:Bulletproof glass is a colloquial term for glass that is particularly resistant to being penetrated when struck by bullets. Since manufacturing glass of usable thicknesses capable of fully stopping most bullets cannot currently be done, the industry generally refers to it as bullet-resistant glass instead.
Bullet-resistant glass is usually constructed using a strong but transparent material such as polycarbonate thermoplastic or by using layers of laminated glass. The desired result is a material with an appearance and light-transmitting behavior of standard glass but offers varying degrees of protection from small arms fire.
The polycarbonate layer, usually consisting of products such as Makroclear, Cyrolon, Lexan or Tuffak, is often sandwiched between layers of regular glass. The use of plastic in the laminate provides impact-resistance, such as physical assault with a hammer, an axe, etc. The plastic provides little in the way of bullet-resistance. The glass, which is much harder than plastic, flattens the bullet and thereby prevents penetration. This type of bullet-resistant glass is usually 70–75 mm (2.8–3.0 in) thick.
Bullet-resistant glass constructed of laminated glass layers is built from glass sheets bonded together with polyvinyl butyral, polyurethane or ethylene-vinyl acetate. This type of bullet-resistant glass has been in regular use on combat vehicles since World War II; it is typically about 100–120 mm (3.9–4.7 in) thick and is usually extremely heavy.
fadhlil
Post by fadhlil »
gemelli wrote:yang gue tau sih kaca anti peluru bukan kaca film... biasanya ini custom made n di pasang fixed alias jadi mati gak bisa di buka/tutup.. jadi musti pasang ac kalo ga mao gosong hehe...
bisa dibuka tutup koq bos, mobil kantor bokap (landcruiser) waktu di Aceh dlu pake kc antipelor..
*tp saya masi ragu, itu KC antipelor ato KF antipelor...maklum dlu pas masi sd ga bgitu merhatiin hal sperti itu*
dan emg tu kaca tebel banget, tapi seinget saya bisa dibuka tutup koq
daftar sini yaa, buat nambah uang bulanan
sini :D
sini juga
sini bisa
sini bisa
sini juga bole
semuanya ud di test..
thx..
avansa
Post by avansa »
iya neh ane penasaran ama KF anti pelor di potongya paka cater..gak logis yah,harusnya motongya pakai gerinda potong apa pakai las...kalau kaca mungkin ane bisa nyerna,anti pecah karena tebal dan motongya di jamin pasti pakai alat berat bukan cater :e-think:
DennyJazzie
Post by DennyJazzie »
Dah mulai terungkap nih..
Bikin kaget jg yah.. :e-snooty:
Abu2
Daily Vehicle: just a bike
Post by Abu2 »
apanya tersingkap....eeehhh terungkap bos? cerita dong.....ane gak update nih ..
asudarsono
Post by asudarsono »
Itu orang yg suka buka2 sms orang, sms sendiri kebuka deh
Ready to Race
wongcilik
Post by wongcilik »
Kaca anti peluru, kalau ditembak lagi di titik yg persis sama dengan "titik tembak" sebelumnya (titik singgung, menurut geometri), pasti bablas --- ini juga tergantung pada ketebalan kaca anti pelurunya, kalau "agak" tebal - mungkin perlu tambahan/susulan tembakan ke 3 atau ke 4 pada "titik tembak" tersebut :mrgreen: CMIIW
wongcilik
Post by wongcilik »
wongcilik wrote:Kaca anti peluru, kalau ditembak lagi di titik yg persis sama dengan "titik tembak" sebelumnya (titik singgung, menurut geometri), pasti bablas --- ini juga tergantung pada ketebalan kaca anti pelurunya, kalau "agak" tebal - mungkin perlu tambahan/susulan tembakan ke 3 atau ke 4 pada "titik tembak" tersebut :mrgreen: CMIIW
Sudut tembak yg paling ideal = 90 derajat
€lj€p€
Post by €lj€p€ »
sesuai dengan perkembangan jaman.. maka logo terpaksa diubah menjadi
Dari Solo ke Oslo
esh
Post by esh »
Hehehe, bisa saja om €lj€p€ :D
