Masa sih om bikin sludge?arfs wrote: Mon Nov 19, 2018 8:15 Biscuit nissin ganti2 mesin kalau sesama kode HR masih rajin bikin sludge gk yah wkwk?
Base eligible cars for swap & which Engine to go?
Re: Base eligible cars for swap & which Engine to go?
Nimbrung dikit...
Honda B series: B16A, B16A2, B16A3, B16B, B17A1, B18C, B18C1 --> 400hp an
4AGE, 3SGTE nanggung buat kompetisi.
Honda K series: K20A2/24A2
Toyota 1JZ
Subaru FB
Honda F series: the best dr honda familly
Honda J series
Nissan: SR20
Toyota 2JZ favorite selain cast iron & upgrade twin turbo
SR26DETT head to head dgn 2JZ
GM LS, v8 camaro engine...
Ford Flathead
Nissan VK56
Diesel:
Diesel cummins 6.8L, 5.7L
Diesel ford power stroke 6.7L, 7.3L
LB7 duramax
1VD, favorit nya mbah bebonk...
Duitnya yg gak kuat, bikin engaaabbb...
[emoji28] [emoji28] [emoji28]
Toyota 1JZ
Subaru FB
Honda J series
Nissan: SR20
Ford Flathead
Nissan VK56
Diesel:
LB7 duramax
Mabok lo? SR26DETT? SR20DET kalipaidjho wrote: Mon Nov 19, 2018 23:42 Nimbrung dikit...
Toyota 1JZ
Subaru FB
Honda J series
Nissan: SR20
Ford Flathead
Nissan VK56
Diesel:
LB7 duramax
Head 2 head JZ bkn RB??VIPSERIES wrote:Mabok lo? SR26DETT? SR20DET kalipaidjho wrote: Mon Nov 19, 2018 23:42 Nimbrung dikit...
Toyota 1JZ
Subaru FB
Honda J series
Nissan: SR20
Ford Flathead
Nissan VK56
Diesel:
LB7 duramax
Sent from my LG-H845 using Tapatalk
Utk nissan krg lbh listnya: (hsl comot sana/i)
1. CA18DETT
Kapasitas : 1.8 L
Tipe : DOHC I4 Turbo
Power : 170 hp
Torque : 166 lbft
Redline : 8000 rpm
Stroke : 83,6 mm
Bore : 83 mm
Compression ratio : 8.5:1
Berat : 128 Kg
Potensi Mesin : 300-400 hp
Asal mesin : Nissan Silvia, Nissan Bluebird, Nissan Auster
Swap Engine ke : Nissan Sunny/ Sentra B13, Nissan Sunny/ Sentra B14
2.SR20DET
Produksi : 1989 – 2002
Kapasitas : 2.0 L
Power : 201 – 250 hp @ 6000 – 6400 rpm
Torque : 196 – 220 lbft @ 4000 – 4800 rpm
Redline : 7400 rpm
Stroke : 86 mm
Bore : 86 mm
Compression ratio : 8.3:1 – 8.5:1
Berat : 149 Kg
Potensi Mesin : 400+ hp
Asal mesin : Nissan Silvia, Nissan Bluebird, Nissan Avenir, Nissan Liberty, Nissan Pulsar
Swap Engine ke : Nissan Sunny/ Sentra B13, Nissan Sunny/ Sentra B14, Nissan Cefiro, Nissan Terrano
3.RB20DET
Produksi : 1984 – 2002
Kapasitas : 2.0 L
Tipe : DOHC I6 Turbocharger
Power : 215 hp @ 6400 rpm
Torque : 195 lbft @ 3200 rpm
Redline : 7600 rpm
Stroke : 69,7 mm
Bore : 78 mm
Berat : 230 Kg
Asal mesin : Nissan Skyline R32, Nissan Cefiro, Nissan Laurels
Swap Engine ke : Nissan Cefiro
4.RB25DET
Produksi : 1991 – 2001
Kapasitas : 2.5 L
Power : 250-280 hp @ 6400 rpm
Torque : 268 lbft @ 3200 rpm
Redline : 7200 – 7600 rpm
Stroke : 71,7 mm
Bore : 86 mm
Compression ratio : 8.5:1 – 9.0:1
Berat : 245 Kg
Asal mesin : Nissan Skyline R33, Nissan Skyline R34, Nissan Stagea
5.RB26DETT
Kapasitas : 2.6 L
Tipe : DOHC I6 Twin Turbocharger
Power : 280 hp @ 6800 rpm
Torque : 289 lbft @ 4400 rpm
Redline : 7500 – 8000 rpm
Stroke : 73,7 mm
Bore : 86 mm
Berat : 273 Kg
Potensi Mesin : 1000+ hp
Asal mesin : Nissan Skyline GT-R
6.VG30DETT
Produksi : 1989 – 1999
Kapasitas : 3.0 L
Power : 280 – 300 hp
Torque : 283 lbft
Redline : 6800 – 7000 rpm
Stroke : 83 mm
Bore : 87 mm
Berat : 275 Kg
Potensi Mesin : 500 hp
Asal mesin : Nissan Fairlady Z, Nissan 300ZX
Swap Engine ke : Nissan Cedric/ Gloria, Nissan Terrano
*cefiro tampaknya memenuhi aspek buat bahan mengingat hubungannya dg skyline.
1. CA18DETT
Kapasitas : 1.8 L
Power : 170 hp
Torque : 166 lbft
Redline : 8000 rpm
Stroke : 83,6 mm
Bore : 83 mm
Berat : 128 Kg
2.SR20DET
Kapasitas : 2.0 L
Redline : 7400 rpm
Stroke : 86 mm
Bore : 86 mm
Berat : 149 Kg
3.RB20DET
Kapasitas : 2.0 L
Redline : 7600 rpm
Stroke : 69,7 mm
Bore : 78 mm
Berat : 230 Kg
4.RB25DET
Kapasitas : 2.5 L
Stroke : 71,7 mm
Bore : 86 mm
Berat : 245 Kg
5.RB26DETT
Kapasitas : 2.6 L
Stroke : 73,7 mm
Bore : 86 mm
Berat : 273 Kg
6.VG30DETT
Kapasitas : 3.0 L
Torque : 283 lbft
Stroke : 83 mm
Bore : 87 mm
Berat : 275 Kg
Kalo M15 gimana oom? [emoji1]dsign1990 wrote:m16 emang oke katanyaransyah1234 wrote: Sat Nov 17, 2018 2:52Mesin baleno/vitara mungkin?dsign1990 wrote: Fri Nov 16, 2018 5:37 jimny / katana enaknya dijejelin mesin apa ya ?
sering liat panjat2 lincah bgt di medan off road berat dg ban gede kyknya gak mungkin pake mesin std meski punya body ringan
saya sih baru katanya2 yabismo16 wrote: Tue Nov 20, 2018 6:57Kalo M15 gimana oom? [emoji1]dsign1990 wrote:m16 emang oke katanya
dari page 1 cuma numpang nanya hehehe
cuma kebetulan pernah pake baleno next G taarikannya krg enak gk kayak jazz/ city vtec gen awal padahal spek di atas kertas beda dikit entah gara2 transmisi atau apa
Bayangkan saja, HR15DE pake oli cuman 3 liter, dibanding suzuki punya M15A pake oli 4 liter.
Jadi otomatis perputaran oli nya saat dipakai lebih cepet babak belur HR15DE nya batu makam...
HR15DE mah bknnya pake 4 liter om? Klo yg HR12DE iya pake 3 lt hehe... sy sih selama pake ga pernah jd sludge ya, amit2 jg jgn sampe
- Daily Vehicle: LMPV + LCGC
Innova di masukin mesin 1UZ/1GR om hehe, kalo ogut punya impian Ford Fiesta di masukin engine 1500 cc ecoboost nya Focus atau 1600 cc ecoboost nya Fiesta ST
2ZZ swap ke yaris bakpao.. hahaha buat ********* honda driver yg merasa sok kencjang.......
"straight 6 forever"
3 liter juga om di HR15DE, itu lah kehebatan mesin nya batu makam, kgk perlu oli banyak2 (tp pada jd sludge karena perputaran oli nya jd lebih cepat)...Zined876 wrote: Tue Nov 20, 2018 9:56 HR15DE mah bknnya pake 4 liter om? Klo yg HR12DE iya pake 3 lt hehe... sy sih selama pake ga pernah jd sludge ya, amit2 jg jgn sampe![]()
Tag ChZ donkfatmike21 wrote: Wed Nov 21, 2018 2:27 2ZZ swap ke yaris bakpao.. hahaha buat ********* honda driver yg merasa sok kencjang.......
- Daily Vehicle: [cencored]
- Daily Vehicle: City type z
katana masukin mesin diesel aja
yg udah ada ipah 2JZ, tokisul n papansa 1UZ
We have FRD, use it as brake. The ultimate brakes system
Toyota/Lexus 1UZ V8 ke bodi Kijang LGX or Krista boleh uga tuh, eksterior biarin standar aja ato perlu downgrade look ke tipe LX
- Daily Vehicle: honda beat
abis nonton youtube saya jadi tertarik w202 c180 swap m104 3200cc.
minum premium dan masih dapet 1:12 ngillerrr...
dulu th 2007an di tabloid otomotif ada jimny/katana dijejelin 1uzMordecai20 wrote: Tue Mar 31, 2020 10:27 Toyota/Lexus 1UZ V8 ke bodi Kijang LGX or Krista boleh uga tuh, eksterior biarin standar aja ato perlu downgrade look ke tipe LX![]()
Klo saya pengen lc200 bensin tahun awal mesin swap ke 1gd / 2gd remap.. isi dex
Klo pake 2gd bisa tukeran mesin sama hilux mt 200jt udah dpt mblnya dan tinggal ganti ecu yg AT
Exterior di facelift..
Joss
Joss
V8: 1UR-FSE{|}8AT
V6: 2GR-FE{|}6AT
V6: G6DF{|}6AT
Eco Mode
DDiS 1.3
1NR-VE
K10C
V8: 1UR-FSE{|}8AT
V6: 2GR-FE{|}6AT
V6: G6DF{|}6AT
Eco Mode
DDiS 1.3
1NR-VE
K10C
Bisa banget sih itu mestinya.lemonadelovers wrote: Wed Apr 01, 2020 0:57 Klo saya pengen lc200 bensin tahun awal mesin swap ke 1gd / 2gd remap.. isi dex
Joss
Ini aja bisa https://www.youtube.com/watch?v=mj56gDJ ... e=youtu.be
2016 - Honda CRV 2.0 M/T
hm.. kalo fj40 dikasi 2kd reliable ga ya?lemonadelovers wrote: Wed Apr 01, 2020 0:57 Klo saya pengen lc200 bensin tahun awal mesin swap ke 1gd / 2gd remap.. isi dex
Joss
‘14 PY-VPS
‘01 B20B
‘01 B20B
- Daily Vehicle: Toyota
Share cerita saja dr tour guide offroad yg pernah saya ajak obrol, untuk reliability bisa dipertimbangkan FJ40 swap engine truk hino hijau (W04D), seminggu dipakai minimal 3-4 kali tour offroad ringan/berat tergantung permintaan dan aman2 saja. Review dari saya ya karena memang mesin truk jadi rasanya jg sperti naik truk
