Rekomendasi merk rotor disk brake after market
saturday
Re: Rekomendasi merk rotor disk brake after market
Post by saturday »
darrelund wrote: Tue Jul 22, 2025 15:20
saturday wrote: Tue Jul 22, 2025 3:16
marmut wrote: Mon Jul 21, 2025 3:36
mari bertanya kpd p krn saya juga banyak berguru ke beliau.
Urusan rem berguru sama abang gaul spesialis BBK aja. Jangan ngikutin saya.
mohon maaf mbah
oe blum bisa bli brembo, skrg mah yg penting rembro aja
Wahhh
Pamali gan
Tidak boleh pura-pura kere
Nanti tidak bisa masup syurga
Tidak bisa breakdance bareng bidadari syurga
Olala
mohon maaf mbah
:big_biglaugh: :big_biglaugh:
xfraps
Post by xfraps »
2kdpelan wrote: Tue Jul 22, 2025 15:01
xfraps wrote: Tue Jul 22, 2025 13:10
2kdpelan wrote: Tue Jul 22, 2025 3:37
Sah2 aja, gw pake slotted buat harian. Kl buat turunan panjang, use the lowest gear possible. Mesin meraung2 ga akan jebol koq, tp kl brake overheat = wasalam
oversize enga om?
Nooope, plug n play, size asli nya aja.. no issue with braking performance whatsoever soalnya
kampas pake apa om?
2kdpelan
Daily Vehicle: 2012 Fortuner VNT
Post by 2kdpelan »
xfraps wrote: Tue Jul 22, 2025 17:31
oversize enga om?
kampas pake apa om?
Dba, brake line jg ud ganti. Brake fluid dot4 yg murmer2 aja
https://www.tokopedia.com/anugerahberli ... r-4615a243
Harga resmi per piece segini
kualitas jg ala kadarnya :mky_03:
mending aftermarket sekalian
xfraps
Post by xfraps »
2kdpelan wrote: Wed Jul 23, 2025 3:44
kampas pake apa om?
oo pake dba, okok omm
saya pake oversize 320, bagian depan malah jd lebih berat
mobil malah mau lebih ngegelinding :big_biglaugh:
looks nya sih oke jadi penuh
iamwewe
Post by iamwewe »
Suryaputra wrote: Tue Jul 22, 2025 3:53
setuju mbah
mesin meraung engine brake = flow bensin minim (mnrt OBD) = irit :big_biglaugh:
om, kalo misal engine brake pas turunan nih kan mesin meraung = pasti kondisi lagi masuk gigi nih mau itu AT ato cvt. nah kalo gear engaged gitu, ngaruh apa di transmisi gk? misal mesin RPM naik, engine brake makin kuat, maka transmisi jadi lbh cpt panas? apalagi kita cenderung taro di low gear kan. mau itu di AT ato cvt, gk mgkn kan taro di D doang.
special utk mobil RWD gardan, itu gardan juga ada ngaruh apa gak ya kalo kondisi lagi engine brake gini?
valid nih kalo tanya warga bandung, tanjakan turunannya cukup panjang2 hahaha
2kdpelan
Post by 2kdpelan »
xfraps wrote: Wed Jul 23, 2025 17:09
kampas pake apa om?
Maksudnya lbh gelinding gmn?
iamwewe wrote: Thu Jul 24, 2025 1:33
setuju mbah
Hidup itu memang harus memilih mbah:
- panas di girboks (tapi selama ada fluidnya amannn dan dibantu rem juga dikit2), atau...
- panas di rem
:big_biglaugh: ................ :ngacir:
xfraps
Post by xfraps »
2kdpelan wrote: Thu Jul 24, 2025 4:09
beban yg berputar lebih berat di depan om
abis di rem, yg depan masi berasa mau muter
masi nyelonong gitu dah
iamwewe
Post by iamwewe »
Suryaputra wrote: Thu Jul 24, 2025 7:09
setuju mbah
- panas di rem
ok2 temp si gearbox juga naik yak..... kirain yg pengaruhin temp gearbox cuma kalo pas kita betot2 aja dia jadi shifting naik turun gigi nya cpt... nahan gear position juga yak ternyata
darrelund
Post by darrelund »
iamwewe wrote: Thu Jul 24, 2025 15:33
klo di masdut langit
misal enjin brek kelamaan & rem di lepas, dia kyk di loss in sendiri (rpm rebah idle)
saturday
Post by saturday »
darrelund wrote: Thu Jul 24, 2025 15:53
Itu namanya DFCO (Deceleration Fuel Cut Off).
Kalau di Honda saya, ketika sudah mencapai gear/RPM/speed tertentu (tidak yakin parameternya apa saja), DFCO bisa aktif.
Ketika mode DFCO bisa aktif, kalau lepas gas tanpa injak rem, injector fuel cut off untuk coasting (tujuannya fuel economy). Ketika kita sentuh pedal rem sedikit saja, injektor kembali bekerja dan engine braking aktif. Atau kalau parameter DFCO sudah tidak tercapai, injektor kembali aktif.
- panas di rem
Untuk cvt
Krn waktu itu sy testnya di cvt lihat obd.
krn kayanya Dia nahan di belt dan pulinya :mky_03:
