Moderators: r12qiSonH4ji , avantgardebronze , akbarfit , Ryan Steele , sh00t
Posts: 11945 Joined: Wed Oct 16, 2013 6:27
Post
by marmut » Tue Oct 15, 2019 13:53
erwinign wrote: Tue Oct 15, 2019 12:56
om2 kalo oli power steering buat avanza k3ve yg bagus apa ya?
kasih dex III juga cukup.
Turboman wrote: Tue Oct 15, 2019 13:07
avanza bukannya EPS sejak lama ?
gen 1 masih hidrolik.
maastricht889
Posts: 3450 Joined: Sat Apr 19, 2014 3:45
Post
by maastricht889 » Tue Oct 15, 2019 16:02
erwinign wrote: om2 kalo oli power steering buat avanza k3ve yg bagus apa ya?
Yang gen 1 om, seinget saya masih HPS. Lebih berat dari gen 2 stir nya
Posts: 22080 Joined: Mon Dec 12, 2005 5:14
Post
by Turboman » Tue Oct 15, 2019 16:07
Buat Pow Steer pake Aisin AFW+ si mayan enak
harga juga gak mahal
evanbngdor
Posts: 2982 Joined: Sun Sep 13, 2015 3:08
Post
by evanbngdor » Wed Oct 16, 2019 2:10
Kayaknya Avanza baru EPS di gen 2 deh Om. Gen 1 facelift masih hidrolik.
CMIIW
2016 - Honda CRV 2.0 M/T
Post
by Turboman » Wed Oct 16, 2019 10:01
UOA PTT 10W30 API SN - semi Syn
8000 km - 5 bulan di Avanza
TBN akhir masi di 3,89 mg KOH
V 100 di 10,65 cSt
berarti ini oli kalo bablas sampe 8500 km masi aman (or Max 9 bulan lah)
dempotaxam
Posts: 6 Joined: Sat Jun 11, 2011 11:58
Post
by dempotaxam » Wed Oct 16, 2019 12:16
Turboman wrote: Wed Oct 16, 2019 10:01
V 100 di 10,65 cSt
Om kalau yg PTT 0w20 SN+ uda pernah di tes kah?
razorus
Posts: 64 Joined: Sat Jun 13, 2015 10:40
Post
by razorus » Wed Oct 16, 2019 12:50
Turboman wrote: Tue Oct 15, 2019 16:07
+1
Udah ngerasain sendiri, memang enak dibanding OEM Toyota
Post
by Turboman » Wed Oct 16, 2019 12:54
dempotaxam wrote: Turboman wrote: Wed Oct 16, 2019 10:01
V 100 di 10,65 cSt
yg 0W20 SN+ baru test VOA aja
indeskey
Posts: 887 Joined: Fri Nov 23, 2018 9:27
Post
by indeskey » Wed Oct 16, 2019 12:57
Dari VOA bisa dipakai max berapa km./bulan om Turbo?
Makasih
Turboman wrote: dempotaxam wrote: Turboman wrote: Wed Oct 16, 2019 10:01
V 100 di 10,65 cSt
Post
by Turboman » Wed Oct 16, 2019 15:21
indeskey wrote: Dari VOA bisa dipakai max berapa km./bulan om Turbo?
Makasih
konon lagi di test ama Distro nya
mungkin 2 - 3 bulan lagi akan di test lab
ditunggu aja
indeskey
Post
by indeskey » Wed Oct 16, 2019 16:29
Siap om
Turboman wrote: indeskey wrote: Dari VOA bisa dipakai max berapa km./bulan om Turbo?
Makasih
Turboman wrote: yg 0W20 SN+ baru test VOA aja
ditunggu aja
Posts: 12746 Joined: Tue Apr 30, 2013 7:10
Post
by Suryaputra » Thu Oct 17, 2019 0:51
ngecek level oli as in manual-book Honda
MSU
Posts: 1863 Joined: Sun Jan 06, 2019 2:51
Daily Vehicle: Diesel
Post
by MSU » Thu Oct 17, 2019 3:31
Suryaputra wrote: Thu Oct 17, 2019 0:51
apa hubungannya ama isi bensin ya...
Givrun
Posts: 259 Joined: Thu Nov 08, 2018 18:39
Post
by Givrun » Thu Oct 17, 2019 3:50
MSU wrote: Thu Oct 17, 2019 3:31
Takut salah isi ke pengisian oli kali om
Post
by Suryaputra » Thu Oct 17, 2019 4:13
Givrun wrote: Thu Oct 17, 2019 3:50
jadi engine flush om
mkamil
Posts: 297 Joined: Tue Aug 06, 2019 14:02
Daily Vehicle: 1VD - L15Z - FB25
Post
by mkamil » Thu Oct 17, 2019 5:37
as day to day checks or maintenance aja kali, rekomendasi aja dari hongda. Biar sekalian gitu dan terbiasa, walaupun secara awam jarang dilakukan.
Di site setiap kali refueling memang harus buka kap mesin untuk visual check setiap cairan.
Post
by Suryaputra » Thu Oct 17, 2019 5:53
mkamil wrote: Thu Oct 17, 2019 5:37
agree,
just in case lendir dan cairan lain berkurang, bisa nambah / beli di spbu lengkap
rusherman
Posts: 3 Joined: Wed Oct 16, 2019 5:38
Daily Vehicle: Rush
Post
by rusherman » Thu Oct 17, 2019 6:01
Halo all, salam kenal semuanya.. saya mau tanya nih.. apa sudah ada yang test lab oli PTT Performa Synt 5W30? apakah ACEA A5/B5 ini cocok di mobil Anki bensin?
Post
by Turboman » Thu Oct 17, 2019 6:07
rusherman wrote: Halo all, salam kenal semuanya.. saya mau tanya nih.. apa sudah ada yang test lab oli PTT Performa Synt 5W30? apakah ACEA A5/B5 ini cocok di mobil Anki bensin?
ANKI bensin idealnya 0W20
kalo sering RPM tinggi better 0W30......si PTT ada yg 0W30 API SN
zonepublic
Posts: 1020 Joined: Thu Feb 20, 2014 19:08
Post
by zonepublic » Thu Oct 17, 2019 7:46
Oli transmisi AGS suzuki ignis pake apa ya yg bagus?trus penggantiannya segampang oli gardan atau perlu mesin/gearlong spt oli matic?
Post
by Turboman » Thu Oct 17, 2019 8:49
zonepublic wrote: Oli transmisi AGS suzuki ignis pake apa ya yg bagus?trus penggantiannya segampang oli gardan atau perlu mesin/gearlong spt oli matic?
Kalo AMT nya Wuling sih TOTAL 75W90 GL-4
Suziku ada oli 75W80 dan W90 GL-4 juga kan
zonepublic
Post
by zonepublic » Thu Oct 17, 2019 10:21
Turboman wrote: Thu Oct 17, 2019 8:49
Pake bawaan suzuki aja ya?ga perlu aftermarket?
Beda ya oli amt sama oli transmisi manual?
Post
by Turboman » Thu Oct 17, 2019 10:40
zonepublic wrote: Turboman wrote: Thu Oct 17, 2019 8:49
di manual book tertulis spec nya apa ?
rendr
Posts: 1108 Joined: Mon Mar 19, 2018 6:47
Post
by rendr » Fri Oct 18, 2019 0:43
Turboman wrote: Thu Oct 17, 2019 10:40
Bantu jawab om.. seinget saya ignis AGS mintanya MTF 75w80...
gaspol resing tim
HRA
Posts: 44 Joined: Fri Oct 18, 2019 1:22
Daily Vehicle: ANGL CVT 2014
Post
by HRA » Fri Oct 18, 2019 1:39
Ijin bertanya om2 semua, mungkin repost soalnya bingung carinya di search seperti di reject gitu entah kenapa.
Mau tanya oli yg cocok buat ANGL 2014. Kilometer sudah 105 ribu, penggantian oli tiap 5000 km, selama ini pakai Fastron Gold 5W30. Skrg mau ganti Oli yg agak bagusan dikit hehehehe... Karena setelah saya tahu, mesin ANGL ini lebih panas dari mesin2 lain dikelasnya. Barangkali rekan2 SM ada yg bisa kasih advice? Budget sekitar 150-170 ribu per liter ya om.
Makasih buat yg bantu jawab.
