Ranking Dan Pemilihan Oli Mesin
Re: Ranking Dan Pemilihan Oli Mesin
ga ada yg punya info eneos yah?
eneos itu oli asal jepang, yg dibuat oleh nippon oil japan..
gw pernah pakai, tp cm yg 20W50 bro.. hehehe..
Permisii
encer di room temp sih ga papa. yg penting kan oli ga jadi terlalu encer ditemp dlm mesin waktu bekerja.GTR wrote:FK memang terkesan agak encer sih even cuma yg mineral SSX 10w30 doang.. kalo diangkat oli di dipstiknya masih mudah netes2..
Performance Japan-brand oil ini setara oli lain yg kelas harganya sama even cuma mineral..
FYI klo dibandingin sm pelumas jadul yg monograde ( mis SAE40) yg kliatan kentel dibotolnya tapi waktu dipake dlm mesin waktu kerja setlh tercapai suhu tertentu dia malah lebih encer drpd yg pelumas multigrade
klo mau pelumas yg bagus kestabilan kekentalannya bisa dicek di specnya ,liat angka VI (viscosity index) nya berapa.
ada prove ga bahwa eneos itu oli bagus sebanding dengan shell ???
http://www.ls1.com.au/forum/archive/ind ... 41554.html
intinya...
oli ntu.. cocok2an
jgn ganti2 merk oli.. klo udah cocok pake merk A.. hrs terus A
belum tentu yg lebih mahal, lebih baik
yg penting.. oli anda bukan T*P 1 kan ??
After several changes on Mobile 1 i recently swaped to Castrol Magnatec because i can get it free. Since the change i have noticed more noises on start up and i also feel as though acceleration isnt as smooth.
Am i imagining this or has anyone else had similar experiences ?
I had magnatec for 5 years, went to Mobil 1 makes more noise.
Every car is different. Give it a try.
I went from Mobil 1 to Magnatec, and I must say car seems to perform better and not rattle like a little baby anymore
But if your car has always been serviced with Mobil 1, then I would stick with it. But otherwise just stick with a good mineral oil and then do a change every 5000km's![]()
intinya...
oli ntu.. cocok2an
stuju bkn oli T---- 1 yg pentingtoyotalover wrote:http://www.ls1.com.au/forum/archive/ind ... 41554.html
Am i imagining this or has anyone else had similar experiences ?I had magnatec for 5 years, went to Mobil 1 makes more noise.
Every car is different. Give it a try.I went from Mobil 1 to Magnatec, and I must say car seems to perform better and not rattle like a little baby anymore
intinya...
oli ntu.. cocok2an
krn yg beredar di indo ada import & lokal.
Tipe2 oli di indo belum tentu sama dgn versi luar dlm hal bahan (& terutama kualitas) nya, walaupun tipenya sama, misalnya Castrol magnatec, dst dst...
ada yg punya info tentang oli BM 1 ?
thx
thx
paling cocok pake elf competition SM.
API SM 10w-40
mesin jadi lebih halus jauh.
dan tenaga lebih berisi.
sebelumnya dari FK Pulse RS 10w-40.
walau nih FK harganya 35% lebih mahal, tapi ga lebih baik dari elf competition SM.
jadi, betul tuh.
cocok2an.
API SM 10w-40
jadi, betul tuh.
cocok2an.
JFC air filter udah tersedia.
yg berminat bisa kemarih:
bukannya FK pulsa RS cuma 50rb an/liter ini masih lebih murah dari elf yah?
kalo ga salah itu oli asli indonesia (BM1 = Biru Megah Satu/1)dungdung wrote:ada yg punya info tentang oli BM 1 ?
thx
coba cek aja di: http://www.bm1oil.com/
- Daily Vehicle: Suzuki S Cross
Bro coba yang 10w-30 elf competition GT, lebih enak broTners wrote:paling cocok pake elf competition SM.
API SM 10w-40
jadi, betul tuh.
cocok2an.
pulse skarang kan pricelistnya 70rb/botol.
elf compe GT, gw ga berani.
mobil gw udah cukup tua.
udah 100.000km lebih.
udah ga sepresisi mobil2 skarang.
bro..mnrt saya...masi byk parameter laen selain properti gesekan spt artikel diatas..CMIIW..PPT...where re you???
wow... at least artikel dari luar itu bener2 independen & gamblang memberikan kritik nya (juga apresiasi).. ga takut sama agen tunggal nya.
@ZombiEE
IMHO,
parameter utama dlm pemilihan oli adalah "daya tahan gesek" disitu di tes, pada suhu normal aja udah baret2 (emang sih extreme).. apalg pada suhu mesin kerja berat...
disitu juga di-test daya tahan terhadap tekanan (Pressure Resistance)
*pdhl..."Mobil 1 SuperSyn" mengiklankan olinya "no wear"
All...Royal Purple Oil are impressive
@GTR
Yoi... kapan indo bisa spt mereka ??
IMHO,
@GTR
AMSOIL dan oli2 jepang lain ga ikut diuji..
oiya..ngmg2 ttg gesekan..dulu ada aditif oli merk vital..yg lgsg di test di depan kita dgn mesin sederhana buat membuktikan daya tahan gesekan..ketika dipakein itu vital..mesin nya jalan trus walo dikasi tekanan sekuat apapun pake tangan..,kalo pake oli mobil ditekan dikit saja sdh jammed tuh..is that the same as the articles above?
ngmg2 ttg indo..hehehe..oli artis tuh di media2 kok reputasinya bagus X yah..hahaha...
oiya oom gt-r..skg kan sdg tren2nya oli jp semacam fk gitu..ada yg tau reviewnya?kalo dari mulut ke mulut sih saya kurang percaya..hehhe
- Daily Vehicle: just a bike
makin bingung tentang oli ini....
Royal Purple bgs tuh di artikel tsb.. tahan tekanan & gesekan
ada yg jual gak yah disini ??
kaya ada yg jual di forum sebelah oom..kalo ga salah yah:)
oli artis gak ikutan tuh ??
hahaha...
