Serba serbi anti karat
Re: Nanya Anti karat
wahhh ... barusan call, nett retail price 1.85jt, gak bisa kurang lagi ......
kumpul ora kumpul ... seng penting mangan ben ora kaliren
Re: Re:
BRO, infor untuk Rust Evader sdh discontinue ?? saya sgb distributor alat tersebut (import langsung), tidak pernah mendengar atau menginformasikan bahwa alat tsb sdh tidak diproduksi kembali. Atau hal ini anda dapat dari tempat/agent anda membeli alat anti karat tsb.
Thanks-Ferdi (0818795905)
krikik wrote:gue baru pasang anti karat yg elektronik, namanya Rust Stop, harga price listnya Rp. 1,85 juta. Kemarin gue dptnya 1,6jt. Produk ini pengganti dari Rust Evader, soalnya udah diskuntinu. Syaratnya kebel aki ga boleh dicabut klo kita mau ninggalin mobil dlm waktu yang lama.boplang wrote:sekalian dunk klo punya nama agentnya, phone, contact person ? gw mo nanya langsung ke agent .... kale harga udah naek belipet
anw, menarik banget tuh ........ thanks !!!
Coba aja hubungi karstadt di 021- 754 5588, tanya2 aja dulu.
FYI
http://corrosion-doctors.org/Car/electr ... r-rust.htm
Be wary! Well it looks good and you want to protect your precious vehicle. So you have become the perfect target of those snake oil merchants that prefer the green in your pocket than to sell you a honest service that achieves the intended purpose.
No sweat, you can beat good old corrosion with a little magic powder and, of course, the green in your wallet. Here is something we have to say about the uselessness of these devices that go by different names, technical descriptions, glossy brochures, and glitzy Web sites.
Cathodic protection (CP), which is the real name of the technique these profiteers are trying to sell you, has been used with success to protect against corrosion on many structures and systems including sea going ships, buried pipelines, and even reinforced concrete. However, there is an area where the technique has no chance to work ... the protection of cars. Human nature being what it is, many entrepreneurs have tried to use the visible successes of CP to make money by offering car owners devices to achieve such protection. They typically offer these snake oil devices at a price that could be reasonable if it did indeed work. In reality, the gizmos they offer are a lost in the suckers pocket and a gain in the entrepreneur crooks bank account. And watch out, they will disguise the same old gadgets with new patents and glitzy technical names, even throwing in a microprocessor!!
Why these gadgets do not work?
One has to understand the principle of CP to understand that the technique works by forcing a protective flow of electrons to the metal that needs protection. For this process to work, you need a complete electrical circuit to bring the electrons back. In the case of an outboard motor on a boat, the sea water completes the circuit. In the case of a bridge, the wet soil completes the circuit.
But in your car, the only way to complete the circuit on all the metal in your car is to drive into seawater or be buried in soil! There are various products on the market claiming to provide cathodic electrochemical protection to your car, just by injecting electrons into your metal work - but they don't work. Countries like Canada and the U.S.A. have actually got court orders to stop these products from being sold - simply because they don't work. In your car, there are lots of little nooks and crannies where dirt and/or water can collect. The rust happens not where the metal is dry, nor where the metal is wet - but at the interface between the wet and dry metal. So if you screwed a bunch of anodes right on the interface or one or two millimeters thereof, you would protect your car. But you would need thousands of these anodes over your car.
Modern car manufacturers often do a process called zinc electroplating on the entire chassis of the car. So long as the zinc is complete, the car will not rust. Your best bet is to regularly clean out all the drain holes so that the water can't collect, scrape off any mud that has collected so that metal does not rust away underneath the mud, and remove the leaves and dirt. And of course, once you've washed the car, you should always take it for a drive so that any trapped water can slosh out.
nah....baru neh..........
serius ney......soalnya ada rencana mo pk anti karat elektro euy
consider yg jenis chatodic protection .... yg pake plat yg dikorbankan sebagai media sasaran karat, klo jenis ini dah jamak dipake di project perminyakan dan kelautan untuk melindungi pipa bawah laut, kapal, rig dsb ..... rust evader jual yg jenis ini juga koq, penah liat displaynya saat IIMS ....
New Panther sebenarnya sudah di anti karat atau belum?
Salam kenal, saya member baru disini.
Saya baru membeli Panther LS 2009, saya lihat di bawah kolong ATAS ban mmg sudah ada lapisan agak kasar gitu. Waktu saya tanya ke variasi tempat saya pasang kaca film katanya juga udah di anti rust ini mobil.
Cuman yang buat saya penasaran, di bawah kolong lebih tengah lagi, hanya terlihat bodinya spt dicat saja, tdk tampak lapisan kasarnya. Dan saya bandingkan dengan innova, dikolongnya pun hitam gelap tertutup cairan spt aspal.
Mhn pencerahan dari para pakar, apakah panther ini sudah dianti karat? Atau jgn2 cuman dianti karat bagian atas ban?
Soalnya saja tdk berani ngeyel dengan staffnya, sebab siapa tahu yang dibawah kolong saya lihat itu adalah anti karat water base sedangkan selama inis aya setahu tahunya anti karat yang oil base kayak aspal gitu.
Thanks alot untuk pencerahannya.
salam,
Richard.
salam,
Richard.
Re: New Panther sebenarnya sudah di anti karat atau belum?
bener banget bos antikarat panther dan mobil sekelasnya hanya ada di atas roda (rumah roda) dan bagian bagian yang rawan karat seperti tanki bensin atau solar.... kalo dibagian lain yah hanya menggunakan metode electro coating.... jadi intinya dianti karat tapi hanya sebagian...
Seeing is believing[*][/size]
kalo di livina lain lagi, kolong2 ampe di bagian tengah aja di kasi anti karat (yg kasar2 atau aspal) gt, tapi malah sepakbor depan dikasi seadanya aja, malah di beberapa sisi kaga dikasi anti karat
utk panther kayanya mendingan di kasi anti karat tambahan dehh, kayanya platnya rada kurang tahan karat bro
setuju, krn anti karat dari aslinye cuma sekedarnya ajah, jadi sebaiknya dipakein anti karat tambahan. Banyak pilihan anti karat, spt ziebart, valugard, dll.DOHC wrote:
utk panther belum diberi anti karat. kalo yg disebutkan diatas itu standar pabrikan, hanya menjaga sementara utk penyimpanan di gudang mereka.
so, bisa diberi anti karat dari ziebart, tuff atau yg elektrik. jika mau sekalian ambil paket utk sound deadening dan anti gores. ini yg saya lakukan di panther 2008.
welcome to SM, bro chonglie!
anti gores ini untuk cat nya ya om ?poeticmind wrote:utk panther belum diberi anti karat. kalo yg disebutkan diatas itu standar pabrikan, hanya menjaga sementara utk penyimpanan di gudang mereka.
yang bagaimana lagi nih ?
regards,
singachu
Anti gores yang kayak gimana ?? Kalau Paint Protection kan rata2 bukan anti gores ??
coba lihat2 penawaran paket di ziebart dan tuff, ada kok option anti gores buat cat... kalo saya kemaren ambil tuff buat mobil gajah keluarga, full package.
maksudnya bukan anti kalo digores parang or kampak gapapa... tapi lebih tahan terhadap debu dan 'sentuhan' ringan. lupa saya taro dimana brosur nya. ntar kalo nemu deh...
Sebenernya itu tergantung kebijakan dealer...
Tapi biasanya yang dikasih anti karat itu cuma "rumah roda" aka Spakbor...
CMIIW...
CMIIW...
memang... malah kalo yg cbu elo perhatiin ga pake beginian... mulus. hanya dicat biasa... kekeke!AD74YA wrote:Sebenernya itu tergantung kebijakan dealer...
CMIIW...
Pantesan kemaren ada temen yg lagi nyari Panther second, kata dia udah ngubek2 setengah mampus tetep susah nyari Panther yg ga karatan..
nyari sehhhh, coba klo beli pasti buanyakkkkkk deh..................y_anjasrana wrote:Pantesan kemaren ada temen yg lagi nyari Panther second, kata dia udah ngubek2 setengah mampus tetep susah nyari Panther yg ga karatan..
apalagi kalo belinye CASHHHHHHHHHHHH...........sjamsul wrote:nyari sehhhh, coba klo beli pasti buanyakkkkkk deh..................y_anjasrana wrote:Pantesan kemaren ada temen yg lagi nyari Panther second, kata dia udah ngubek2 setengah mampus tetep susah nyari Panther yg ga karatan..
-------#BIC-701#--------
beli baru cash sekarang ga worth it, kecuali ada dana nganggur... hehe!
panther nya yg type apa dulu nigh bro, kalo yg kotak emang bener, ampir ga mungkin kaga karatan, apalagi bagian spakbor depan nya tuh, blom lagi lipatan spakbor blakang. kalo yg di spakbor blakang sigh gara2 tuh lobang2 baut buat kursi nya tuh yg nampung air, makanya biasa mulai karat dari situ, lalu cepet deh menjalar ke kubah nya lalu merembet ke triplang... dan bahkan uda dipakein antikarat pun jg kaga menolong banyaky_anjasrana wrote:Pantesan kemaren ada temen yg lagi nyari Panther second, kata dia udah ngubek2 setengah mampus tetep susah nyari Panther yg ga karatan..
nah kalo panther kapsul sigh ada beberapa saya liat yg masi mulus tuh padahal taon uda tua
memang, sejauh ini mobil kantor saya di bali sudah hampir 10tahun baik2 saja kondisi nya... hehe! yg baru 2008 akhir juga mungkin karena baru, belum ada masalah muncul.
bro poetic, kalo panther bro uda 10 tahun, bearti kluaran taon 1999 donk, itu masi jenis panther kotak logh... wahh hebat jg bro bisa kaga karatan...
hampir 10taun bro, kapsul pertama keluar maksudnya... tahun 2000an kan? saya lupa tepatnya beli tahun berapa (2000-2001) hehe, kalo yg kotak (1998) sudah dijual... memang agak karatan di bagian atas, tapi maklum karena di bali kan daerah pantai, sangat rentan besi cepat berkarat.
tapi, saya lihat di bandung jenis2 panther kotak utk travel2 masih bagus2 juga kok, bro... mungkin sangat terawat ya...
Bro potic yang anti karat elektric dulu pernah di bahas tapi ane lupa di mana,untuk harga di kisaran berapa ya Bos..?
