Koleksi hand tools [Part 06]
Re: Koleksi hand tools [Part 06]
DOHC wrote: Fri Jul 09, 2021 4:04
penasaran, orang jerman emg demen pake trelek buat ngencengin apa yah, ampe stinggi itu tork nya
:big_think: :big_think:
kalo baca di website-nya sih, ada tulisan :
Ideal for the truck and/or industrial vehicle sectors
beli mbah... enak lho... buka-buka murbuat jadi gampang.
masa seumur idup mau sambung pipa melulu? gaada treleknya mana enak?
marmut wrote: Fri Jul 09, 2021 4:15
beli seh mau mau aj mbah
cuman
harganya ta liat di amazon, ebay dkk lmayan bkin tensi mendadak melejit
ta pantengin mbah masas aj d
siapa tau nanti kapan doi mau kuar negeri trus rumah nya kosong gt :upss: :upss: :upss:
DOHC wrote: Fri Jul 09, 2021 4:27
cuman
nhaaaa...... kalo gitu, trelek beta sambung pipa besi 50cm, trus di las.
trelek, check.
oglek, check.
gagang panjang, check.
:big_grin:
marmut wrote: Fri Jul 09, 2021 4:34
cuman
trelek, check.
oglek, check.
:big_grin:
sayang sayangin mbah
itu si beta justru panjangnya skrg ud pas buat buka baut2 jahanam intek manipol inofa yg disain nya ngawur banget
mungkin mendingan beli trelek oglek tekiro yg jawa industri standard itu aj kl yah... jd nya mo dilas jg gapapa :big_weee: :big_weee:
yanuarra
Post by yanuarra »
Udah bosen blm mbah? :upss:
yanuarra wrote: Fri Jul 09, 2021 5:52
tukeran sama 730/40 quick, ga pake insert head gapapa. atau 721R/30 aja deh....
marmut wrote: Fri Jul 09, 2021 5:55
:big_biglaugh: :big_biglaugh: :big_biglaugh: :big_biglaugh: :big_biglaugh: :big_biglaugh: :big_biglaugh: :big_biglaugh: :big_biglaugh:
yanuarra
Post by yanuarra »
:glodak:
barang2 ex public figure emang sekennya suka naik harganya
:mky_01: :mky_03:
Profith83
Post by Profith83 »
DOHC wrote: Thu Jul 08, 2021 15:28
Omnibus wrote: Thu Jul 08, 2021 15:09
DOHC wrote: Thu Jul 08, 2021 14:55
kl saya sehh semenjak ganti pake PSF, berasanya enteng ckup signifikan mbah
malah dl waktu si inofa jadul masi blom kjual, bsa side by side comparing, yg ribon stelah ta pakein PSF lebi enteng... padahal waktu baru kuar diler, yg ribon lebi berat muternya, apalagi setir ribon diameter nya lebi kecil dr inofa jadul saya dl
pake psf merk apa mbah yg bikin enteng?
kasih saya yg PALING ENTENG. (*kata2 ane ke GRO di tempat masas) :big_grin:
:mky_03: :mky_03: :mky_03: :mky_03:
saya pake prestone punya aj.. murah seliter cuman gobanan
Bener mbah pakai prestone? Enteng mana sama pakai PS nya Toyota mbah?
Besok sabtu mau service mobilio, mumpung Unior drift punch sudah sampai:
1. Racksteer
2. CV joint paling luar as roda, beri grease
3. Ganti shock depan. Thn lalu dah beli support shock, semoga belum rusak parah.
4. Check kaki kaki, bearing roda, link stabil
5. Check kaliper rem.
Maklum mobil rawatan beres yang belum tentu beres.
josomba
Daily Vehicle: Delman
Post by josomba »
Profith83 wrote: Fri Jul 09, 2021 8:11
1. Racksteer
grease buat si slider pin rem dah nyetok om?
:big_weee:
*nambah2 cart belanja-nya
Profith83
Post by Profith83 »
josomba wrote: Fri Jul 09, 2021 8:21
1. Racksteer
:big_weee:
pakai Rubber grease Seiken wadah seperti odol, warna merah muda
Bisa itu kan?
1. Racksteer
:big_weee:
ayo mbah dibikin list must-haves DIYer :big_grin:
jgn mbah delko yg jd narasumber, bisa2 semua dicoret sama dia:
brake cleaner ❌
penetrant ❌
topwan grease ✅
*kaboooeerrrr sebelum disambit pipa sama trelek oglek beta
mbah, justru yang pasti parah itu sebelah dalem. berani taruhan lontong kupang sepiring.
kalo sebelah luar, jauh dari radiasi panas mesin. yang sisi dalem, kemungkinannya 2, sudah cair seperti eskrim dijemur atau kering.
1. Racksteer
iya mbah
beneran pake prestone yg dihina2 ama mbah masas itu, katanya kmurahan
toyota setau saya dr fabriekan dikasi ATF mbah, tergantung dikasi atf apa... kaya di inofa saya kentel banget, tp di vrz mbah masas katanya encer banget (curiga dikasi atf WS ini)
Omnibus wrote: Fri Jul 09, 2021 8:30
1. Racksteer
:big_weee:
brake cleaner ❌
penetrant ❌
topwan grease ✅
enak ajee :big_smoking: :big_smoking:
kita orang itu justru pecinta penetran ama brek kliner, justru dikit2 semprot penetran trus getok pake martil... thats musatek way :big_weee: :big_weee:
josomba
Post by josomba »
Profith83 wrote: Fri Jul 09, 2021 8:24 pakai Rubber grease Seiken wadah seperti odol, warna merah muda
Bisa itu kan?
Gapapa om seiken, asal jgn Power Tronic merknya
brake cleaner ❌
penetrant ❌
topwan grease ✅
Saya lanjutin list-nya aja ya mbah
brake cleaner
penetrant
topwan grease
gloves
trelek
kunci pas
nasi padang
dendeng batokok
segelas air minum
yanuarra
Post by yanuarra »
Nubi still nyimak aja di pojokan sambil nyemilin rumput :big_smoking:
yanuarra wrote: Fri Jul 09, 2021 8:46 Nubi still nyimak aja di pojokan sambil nyemilin rumput :big_smoking:
yanuarra
Post by yanuarra »
josomba wrote: Fri Jul 09, 2021 8:44
Bisa itu kan?
brake cleaner ❌
penetrant ❌
topwan grease ✅
brake cleaner
penetrant
topwan grease
gloves
trelek
kunci pas
nasi padang
dendeng batokok
segelas air minum
Pawehteronik? Kek ada yg manggil2 :big_think:
josomba
Post by josomba »
yanuarra wrote: Fri Jul 09, 2021 8:57
Bisa itu kan?
brake cleaner ❌
penetrant ❌
topwan grease ✅
brake cleaner
penetrant
topwan grease
gloves
trelek
kunci pas
nasi padang
dendeng batokok
segelas air minum
Yg hitam mbah yg saya maksut :big_biglaugh: :big_biglaugh:
Pake sebulan, cek kaliper lg, dah ilang ntah kemana grease-nya.
Btw kaleng biru paling kanan, bisa kali tuh mbah dicoba buat dijadiin top up oli
:big_slap:
ahhhh bener jg
baru inget belom kuras minyak rem
pantesan tempo hari nyetir sruntulan sempet ada momen pedal mendadak spongy
ternjata ud 12 rebu km dr trakir kuras :upss: :upss:
Profith83
Post by Profith83 »
DOHC wrote: Fri Jul 09, 2021 9:39 ahhhh bener jg
minyak rem 12 rb berapa tahun mbah? harusnya kan 2 thn sekali atau 30rb
Keseringan bongpas tuh nipple nanti iritasi loh ... :big_biglaugh: eh maksudnya bisa sleg/patah
BTW pakai ATE yang dot 3? katanya dot 4 lebih tahan pasan, tapi lebih nyerap air yah?
Untuk ketahanan karet2x bagus yang dot3 atau dot4 yah?
Profith83 wrote: Fri Jul 09, 2021 10:14
12 rebu itu... ummm kira2 pas februari kmaren kuras nya
ohh tenang aj mbah , saya spesial beli konci ring pas sandvik cuman buat buka tutup tu nepel .. kl masi slek atau tugel jg, ta obrak abrik tu fabriek nya
pake dot 3 aj, bukan mobil resing ini... yg penting sering ganti biar tetep pakem
blloewy
Post by blloewy »
Mbah...kl.bersihkan ruang mesin pake engine degreaser gt gpp khan ya? Atau malah pake WD40 semprot2 semua trs dilap.majun?
Ngeliat di bengkel.spesialis lipindut waktu pertama ambil lipondut itu ruang mesin disemprot WD40 trs dilap majun.
