Ranking Dan Pemilihan Oli Mesin - PART 13
Re: Ranking Dan Pemilihan Oli Mesin - PART 13
boleh ngga enjin yurop sebangsa mersi bmw audi dipakein oli normal formula (bukan european formula)?
apa konsekuensinya?
apa konsekuensinya?
ternjata diem2 ud bungkus mobil yuropOmnibus wrote: Wed Jan 27, 2021 10:45 boleh ngga enjin yurop sebangsa mersi bmw audi dipakein oli normal formula (bukan european formula)?
apa konsekuensinya?
ya ya
dicatet, baru beli mobil yurop
klo baca dr sini : https://scanneranswers.com/why-are-merc ... gh-prices/Omnibus wrote: Wed Jan 27, 2021 10:45 boleh ngga enjin yurop sebangsa mersi bmw audi dipakein oli normal formula (bukan european formula)?
apa konsekuensinya?
depends ke ownernya lagi.
if you need peace of mind are second to none... yah pakai spec yg sesuai
is it ok or not, yurop using premium japanese car oil?
can be yes & no...
if you have limited budget, yaa do it, just drain per 5K km / 6 months kali yah & pray.
otherwise, use proper engine oil as stated in manual book
wah alhamdulillah
Kalau liat buku manual mobil yurop kelas jelata sih katanya kalau bukan pake oli yang ACEA A3-B3 harus dipendekin interval ganti olinya jadi setengahnya dari standarOmnibus wrote: Wed Jan 27, 2021 10:45 boleh ngga enjin yurop sebangsa mersi bmw audi dipakein oli normal formula (bukan european formula)?
apa konsekuensinya?
Suryaputra wrote: Wed Jan 27, 2021 11:01klo baca dr sini : https://scanneranswers.com/why-are-merc ... gh-prices/Omnibus wrote: Wed Jan 27, 2021 10:45 boleh ngga enjin yurop sebangsa mersi bmw audi dipakein oli normal formula (bukan european formula)?
apa konsekuensinya?
if you need peace of mind are second to none... yah pakai spec yg sesuai![]()
can be yes & no...![]()
kalau pakenya oli keraton spec acea A5/B5?Taufiq6210 wrote: Wed Jan 27, 2021 11:28
soalnya yg pake even european formula banyak jg yg akhirnya kena variable valve actuator (VVT) nya, ga peduli merk apa. jangan2 kl dikasih oli keraton ala forum SM malah ga kenapa2 tuh actuator.
pandemi ...... no kangtawDOHC wrote: Wed Jan 27, 2021 10:59
ya ya
klo sy jd Om sih, selama pk oli kelas keraton dgn comply spec D1 G2, A5/B5.. udh cukup banget sihOmnibus wrote: Wed Jan 27, 2021 12:09Suryaputra wrote: Wed Jan 27, 2021 11:01klo baca dr sini : https://scanneranswers.com/why-are-merc ... gh-prices/Omnibus wrote: Wed Jan 27, 2021 10:45 boleh ngga enjin yurop sebangsa mersi bmw audi dipakein oli normal formula (bukan european formula)?
apa konsekuensinya?
otherwise, use proper engine oil as stated in manual bookkalau pakenya oli keraton spec acea A5/B5?Taufiq6210 wrote: Wed Jan 27, 2021 11:28
ya ya
dicatet, baru beli mobil yurop![]()
krn kemampuannya juga di atas rata2 oli lain nya.
yg sy bold, engga mbah beneran ga punya. cuma iseng nanya doank .....Suryaputra wrote: Wed Jan 27, 2021 12:23
klo sy jd Om sih, selama pk oli kelas keraton dgn comply spec D1 G2, A5/B5.. udh cukup banget sih![]()
sip .... setuju mbah, sikat pake keraton. eh, nanti maksudnya kl punya
ga punya yah... hmm ya ya , masi blom mau ngakuOmnibus wrote: Wed Jan 27, 2021 12:33yg sy bold, engga mbah beneran ga punya. cuma iseng nanya doank .....Suryaputra wrote: Wed Jan 27, 2021 12:23
sip .... setuju mbah, sikat pake keraton. eh, nanti maksudnya kl punya![]()
gapapa, ntar pelan2 jebakan betmen nya.. pelan2
Itu om @chrisha ada stok ptt eco 0w20 4 galon.. 2 galon api SN 2 galon api SP.. yg minat DM beliau aja.. lokasi jakbarSuryaputra wrote: Wed Jan 27, 2021 10:45pantesan PTT eco bnyk kosong.akbrn wrote: Wed Jan 27, 2021 10:00Penasaran oom VOA nya, soalnya UOA before 1000 miles masih luar biasa...Suryaputra wrote:
VOA hanya merupakan acuan awal aja, buat estimasi bisa dipakai brp lama dan aditifnya apa aja.
tapi untuk lbh pastinya UOA yg menentukan.
Contoh:
Q8 formula API SN stok lama, biasa ajah, nothing special, aditif so so dan std ajah.
Lihat MSDSnya, gak ada tuh PAO, ester dsb![]()
Namun setelah lihat hasil UOA punya om suhu turbo dan suhu aria (dengan pemakaian setahun),
hasil wear metal nya bisa compete dgn average UOA Amsoil Signature yg jauh lbh mahal & TBN masih di angka 3 koma.
Rahasianya apa?
mungkin crude oil dari arab emg udah "sweet", jadi proses refining nya pun menghasilkan base oil mumpuni.
Apalagi yg baru, udh comply ke API SP, Dexos 1 G2, dll,
bisa jadi hasilnya relatif lbh baik dibanding yg lama
Soalnya Amsoil XL 10w30 iseng sy coba di vespa matic berasa enak cuma sampe 3000 km lebih dikit. Bahan bakar mayoritas pertalite...
Di bukman wajib pake 10W40 castrol power 1, tp pake oli itu suara mesin malah jd kasar & ada suara "ngeletrek"
Skrg lg coba pake agip scooter 5w40 ganti di beres, berasa langit & bumi rasanya sama amsoil XL
Hahaha, kl sy mah sebisa mungkin minimal baca pds nya dl biar tenang wkwkwkrendr wrote:
aye sih dah merem ama ni oli... gaspol aja wkwkwkwk
udh mau jalan 8rb km di apv... makin maknyusssssssss
Soalnya ada Amsoil yg VOA nya agak2 dhuafa ngga ky varian amsoil yg lainnya (foto terlampir dibawah)
Iya ini ptt jg sampe ngumumin bakal ada keterlambatan restockFertille wrote:Maaf sedikit OOT, kemungkinan besar supply chain sangat terhambat dengan ada nya ini. Terutama pecinta lendir "non lokal"![]()
https://www.cnbc.com/2021/01/22/shippin ... -rise.html
itu muter barangnya cepet soalnya.
Pake oli high saps paling cepet mampet aja katalis mbah...Omnibus wrote: Wed Jan 27, 2021 10:45 boleh ngga enjin yurop sebangsa mersi bmw audi dipakein oli normal formula (bukan european formula)?
apa konsekuensinya?
Tujuannya low saps biar neken emisi dan biar katalis ga cepet mampet.. terutama mobil2 yg udh 3way catalyst...
gaspol resing tim
ya ya
dibilangin kaga percaya....
dia orang bungkus unimog 1 unit ama g-klasse brabus V12 (beneran 12 biji pistonnya gapake diskon) 1 unit.
sedari taon lalu pesennya.
iya betul paling gitu ya om. nah kl mobil yg dijual di 3rd world bukannya sdh disesuaikan emission control systemnya dgn rendahnya kualitas bbm di negara yg dituju. kl begitu ga wajib pake low saps dong ya.rendr wrote: Wed Jan 27, 2021 13:35
low saps bukannya lebih rendah anti wear properties nya dibanding mid saps atau full saps ya?
udah muncul 1. tinggal 1 lagi nih prof propokator yg itu, ntar lagi jg munculmarmut wrote: Wed Jan 27, 2021 13:44DOHC wrote: Wed Jan 27, 2021 10:59
ya ya
dibilangin kaga percaya....![]()
lagi ah, hibernasi.
Nah yuropnya apa duluuu nih.... Polo sih msh euro 3 di spec sheet, f10 keatas dah euro 4 deh setau saya.. apa euro 5.. cmiiw...Omnibus wrote: Wed Jan 27, 2021 13:55iya betul paling gitu ya om. nah kl mobil yg dijual di 3rd world bukannya sdh disesuaikan emission control systemnya dgn rendahnya kualitas bbm di negara yg dituju. kl begitu ga wajib pake low saps dong ya.rendr wrote: Wed Jan 27, 2021 13:35
Bmw indonesia skrg default pake BMW LL-01 untuk bensin/diesel nya... Mid saps, jaga2 bensin disini kali ya... Indonesia kan salah satu yg terbelakang urusan bersih2 begini...
Iya oli low saps paling keliatan yg diteken zinc sama calcium nya ya...
Btw buat mobil dan mesin apa om? Kalo bisa lebih spesifik sih enak bahasnya hahahahaha
gaspol resing tim
enggaaaa ...... ga buat apa2 cuma nanya2 doangrendr wrote: Wed Jan 27, 2021 14:04
*ampir kena jebakan betmen, tuh ada yg ngintip dr dalem kardus om (si om dohc sm kroni2nya)
ngga, soalnya kl dulu ane ganti oli paling liat spec bmw LL01 atau mersi 229.5 aja kan utk yg long drain. kl skrg amsoil aja ada pake bikin european formula segala gitu om. sekedar pengen update aja dgn perolian enjin yurop.
Saya juga lagi pake olinya OE 0W20 curah beli di tokped R'Boy, jalan 3rbkm di 1NR..lemonadelovers wrote: Sat Jan 23, 2021 5:07Budget kere hore versi saya:kibo66 wrote: Fri Jan 22, 2021 14:41 Disini ada yang tau jual PTT eco 0w20 dimana ya selaian di OS storenya ? yang rekomen. Manteb bener ini PTT murah tapi performa enak bener. cek di Online shop kosong semua adanya yang non eco. udah mau 5rb KM mau ganti beli kosong semua. selain PTT eco yang budget kere hore per 5rb KM ganti apa ya ?? yang mirip mirip PTT lah performanya.
Aisin greentech 0w-20 255rb/4 liter
Amsoil oe 0w-20 curah/ repack dari drum 60rb seliter
unimog U5000 dan G klasse brabus V12.rendr wrote: Wed Jan 27, 2021 14:04
seriusannnnn baaahhh topppppp.....
kendaraan doomsday protocol hahahahaha
sungkem dulu
oooooh amsoil biasa ama yuroop bisa liat dari visco mbahh... oli yurop pan minta oli2 kentel HTHS diatas 3,5 cP atau V100 diatas 12 cSt kalo saya lihat2.... beda sama amsoil macem oe xl ama sign yg acuannya Acea A1/B1 A5/B5 yg minta sebaliknya... makanya dipisahinnnn...Omnibus wrote: Wed Jan 27, 2021 14:26enggaaaa ...... ga buat apa2 cuma nanya2 doangrendr wrote: Wed Jan 27, 2021 14:04
ngga, soalnya kl dulu ane ganti oli paling liat spec bmw LL01 atau mersi 229.5 aja kan utk yg long drain. kl skrg amsoil aja ada pake bikin european formula segala gitu om. sekedar pengen update aja dgn perolian enjin yurop.![]()
oiya untuk longdrain buat yurop so far masih mb 229.5 yg paling robust.. sampe SLS pun mintanya mb229.5 ehehehehe
gaspol resing tim
Ada yang pernah nyobain pake oli Xten di mobil ? penasaran juga nih mau nyobain biar anti mainstream wkwkwkk
pantesan di tret om wah ud nanya2 soal roadtrip ke danau toba sgala trus mendadak nanya oli yurop spek
ternjata ud ad 2 mobil yurop baru
- Daily Vehicle: Crv RE
Ada yang pernah coba valvoline synpower 5w30 recomend ga ya? Apa banyak acdcnya
- Daily Vehicle: 1KR-DE_Ayla-2014
bagus itu om, sdh sn + juga kn om.sidarta94 wrote: Thu Jan 28, 2021 16:18 Ada yang pernah coba valvoline synpower 5w30 recomend ga ya? Apa banyak acdcnya
Ane pernah pake untuk 1KR-DE. Dl ane belimya di pasargambreng cari aja di toko ijo dan toko biru.
Kalau boleh tahu untuk mobil apa om.
Abs ganti oli pake amsoil enak juga y, bener2 effortless di 1nz
Saya jg baru beli valvoline 5w30 synpower tp belum dicoba , toko pasargambreng rekomended ya om?doko86 wrote: Fri Jan 29, 2021 6:19bagus itu om, sdh sn + juga kn om.sidarta94 wrote: Thu Jan 28, 2021 16:18 Ada yang pernah coba valvoline synpower 5w30 recomend ga ya? Apa banyak acdcnya
Pake Honda CRV RE. Ini saya coba beli di jd.id kayaknya official store karena dikirim oleh jd.id cuma 335rb 4liter. Ini di toko ijo malah ada yg jual cuma 302.500 cuma gtw ori atau ga https://tokopedia.link/uj3fQ8oGrdbdoko86 wrote: Fri Jan 29, 2021 6:19bagus itu om, sdh sn + juga kn om.sidarta94 wrote: Thu Jan 28, 2021 16:18 Ada yang pernah coba valvoline synpower 5w30 recomend ga ya? Apa banyak acdcnya
