y_anjasrana wrote:Kalau tadi duet city car, skrg duet sport car : Toyota FT86 dan Subaru BRZ
(mohon maap kalu ada yg ga setuju 2 mobil ini disebut sport car )
Quote:
Originally Posted by PERRIN_Jeff
This may sound funny but the second thing I did was take off that oil filter. I was dying to see what would really happen. Would it dump oil everywhere? Would it make for a huge mess? Would dirt get sucked down in to the oil? No, No and No. Super clear, super simple, and I can't wait to do an oil change!
Hi,
Interesting take on the oil filter holder. Would anyone happen to know if a sandwich adaptor will fit into the filter housing
I am planning to run some sensors and hoses for the gauges and oil cooler respectively by using a Greddy sandwich adaptor. I am concern if there would be enough space to close the bonnet after installing the adaptor seeing how tight it could already be. We typically would not have such an issue but this time
round, the oil filter is actually facing upwards.
Look forward to some advice from anyone who is planning to do the same.
Andai aja kend. Umum massal semacam mrt segera jadi, kmrin mampir ke spore bndingin jkt ktinggalan bgt (╥﹏╥), *moga aja gubernur dki yg baru bikin gebrakan transpt.
Btw, IIMS tahun ini kelihatan'a seru pngen dtg jga tp kpn'a blm tau mesti ngom nih sm bokap biar diajak.. "̮ƗƗɐƗƗɐƗƗɐ"̮
uchychan wrote:Andai aja kend. Umum massal semacam mrt segera jadi, kmrin mampir ke spore bndingin jkt ktinggalan bgt (╥﹏╥), *moga aja gubernur dki yg baru bikin gebrakan transpt.
jgn terlalu ngarep jg sih sis...
singapor itu memandang seluruh wilayah sbg satu. di metropolitan lain jg begitu.
sdgkan disini terbatasi dg batas2 administrasi wilayah. gubernur hnya punya kekuasaan terbatas di DKI tok. lha pdhl justru byk komuternya tu dr wil bekasi, bogor, tangerag. wilayah sekitar itu mau kerjasama? pesimis deh.
bisa sih bisa, ada gebrakan perubahan yg membaik, itu jelas. tp klo tanpa adanya deal2 dg wil sekitar itu utk development yg terintegrasi, ya outputnya pasti akan dibawah optimal.
andy1800 wrote:hahahaa.... seri 1 sama X1 mah bukan rada2 elek lagi....uelek polll... terutama moncong2nya itu, lbh mirip Ceria....
jd kebanting banget laah sm all new A class ini. sungguh very well designed
menilik cm dari sisi bentuk loh ya
ngiler dulu aaah
setuju ama pak'E....
sekaligus penegasan.....seri 1 ama x1....zueleek.....
*lirik seseorang yang ntah masih nongol di SM ndak yah?
Jelek/bagusnya sebuah design/produk bukan hak anda yang menilai, apalagi anda berkomentar di forum terbuka seperti disini.
mungkin bagi mata anda sebagai orang awam design tsb jelek dan anda sama sekali tidak suka, tapi bagi orang2 yang mengerti akan seni dan estetika its an art.
dan yang paling menyedihkan mungkin anda pikir statement anda lucu? ....sayangnya tidak sama sekali!
Ini forum untuk bebas bertukar / sharing info, pikiran. Kalo menurut anda seni, apakah orang lain harus setuju kalo itu juga seni? Selera orang beda2 Pak.
Kalo ga suka dengan others opinion, gak usah main2 ke forum dan menjudge opini orang seperti itu.
ngiler dulu aaah
salah satu yg menarik perhatian ane di iims, new aveo. sayang ga bisa ambil fotonya krn batre hpnya habis. mungkin selasa depan pas ada jadwal ke sana lagi. yg jelas dgn munculnya aveo, persaingan di kelas 170jt jadi makin padat. disitu ada fiesta, rio, grand avega, dan sekarang aveo. belum lagi yg dr kelas bawah ikut2an kasih spek tinggi biar harga bisa deket2, macam march, brio dan mirage.
kalau liat lampunya, kombinasi antara evo x dan golf ya? cmiiw
barusan baca detik katanya agya tidak bbal lebih dr 130 jt harganya ???? katanya kmaren kmaren paling mahal gak lewat 110. media gak jelas ato memang karena animo besar harga jd naik ?
btw itu etios ama liva kok tetep ditest ya ?? mo masuk di segmen mana ? segmen brio march ? apa gak saingan ma agya ? ato malah buat gantiin yaris tp kasih mesin 1400-1500 ?
klu ga salah spark munculnya bareng film transformer II, klu ga salah pertengahan 2010 kali ya.. ga tau deh knp ga ada matic-nya. mungkin krn penjualannya seret. di jalan juga jarang keliatan.
ane ke sana selasa siang, dari jam 2an sampe jam 5an, di gedung prjnya (ga masuk iims). kalu mw bareng paling sorenya. memang om Andy mw kesana jam brpan?
ic
saya menyinkronkan diri dg jadwalnya Pak Uwo bisanya cabut dari ktr jam brp. tp perkiraan saya stlh jam 12...sampai selesai.
jd bergkatnya sih gak harus bareng, yg ptg meeting poiint disana.
jd klo ada rekan2 yg datengnya jam brp aja ya gpp.....pulang lbh duluan gpp....muter2nya juga bisa bareng2, bisa sendiri2...bisa pisah-ketemu-pisah-ketemu...intinya: "serius tp santai" saja ya om
klo saya sendiri mmg lbh suka klo ada teman ngeliat mobil ini itu, jd ada yg bisa diajak "betengkar" ...klo cm sendirian, saya merasa gak asik, mau adu mulut sm siapa
Ini salah satu mbl idaman saya
@om andi & bro yg lain,
Sempetin TD aveo ini ya, saya nunggu reviewnya
satu hal yang bikin ane kurang suka dengan aveo adalah frame lampu dalam terbuka dari kondisi luar. hal ini akan menyebabkan plastik di sekitar lampu mudah ditempeli oleh bekas kerak air dan kotoran. akan menambah kerjaan dalam perawatan.
andy1800 wrote:ic
kebiasaaan.... nanti pak'E bisa pulang jam 3 pagi dari iims....
design pantatnya juga kurang semok ... ibarat muka cakep pantat tepos ..
wah, kalo ane selalu melihat ke depan om... jadi gak peduli pantatnya kek mana....
kmrn ke booth mazda.
kagum abis ma disain eksterior takeri concept.
maap kmrn ga sempet foto jd ambil di google.
ktnya ini konsep 2011 kmrn tp disainnya bnr2 far2 ahead.
klo liat lgs brgnya jauh lbh buset drpd liat fotonya
ada yg tau apakah ini jd cikal bakal mazda6?
smoga jd diproduksi n ga beda jauh ma konsepnya.
ngiler dulu aaah
salam kenal deh buat om Bimmerrich.
hanya klarifikasi, ada "sesuatu" yg terselubung di dalam postingan Pakbos andy, dan ane, untuk godain seseorang.
nah, ternyata dirimu yg mengomentari, yaa, jika kurang berkenan dengan postingan ane, mohon mangap sebesarnya yaa..
ehh Pak'E, kemana tuh satu orang, kagak nongol2, atau ntar jangan2 register pake nick baru pulak
ini komen teraneh paling menyedihkan sepanjang sy maen 5 forum otomotif indo plus beberapa forum luar. lhah, apa gunanya forum kl nggak boleh beropini?!
tidak ada aturan dari serayamotor.com bahwa member di sini harus designer/engineer/stylist mobil.
siapa pun BERHAK BEROPINI soal sebuah mobil apapun latar belakangnya, sepanjang itu TIDAK PERSONAL ATTACK, semisal 'YANG BELI BMW SERI 1 ITU ORANG [cencored], KOK MOBIL TAMPANG KADUT GITU DIBELI', nah statement barusan jelas lain urusannya.
aneh banget kl nggak boleh wkwkwkw.......
atau, mungkin anda fanboy kelas wahidnya bimmers, nah ini yg repot, wkwkwkwkw......... om fm aja kagak sgitunya belain bmw seri 1 wkwkwkwkw..
