Nah ane jg liat di webnya cuma ada mesin 1.5L Ti-VCT. Mungkin ini yg paling cocok utk pasar Indo. Balik lagi ke selera konsumen yg nyatanya masih suka ngisi premium
Tp ga tau jg bener atau ga ya, harus tunggu petinggi FMI yg bicara.
Yg baru dari New Fiesta ini:
- Transmisi 6-speed dual clutch dgn tiptronic spt Ford Focus (Power Shift)
- Start Stop engine dgn tombol
- Sensor otomatis utk wiper dan lampu
Pertama dikelasnya
- Voice Command dan Hands-Free Call dgn SYNC, bisa ngatur temperatur AC dgn perintah suara
Lebih advance dari yg skrng sptnya.
- Hill Launch Assist (HLA), rasanya di Fiesta skrng jg ada fitur ini
Ditanjakan mobil ga akan gelosor, ada jeda waktu beberapa detik untuk kaki pindah dari pedal rem ke pedal gas
- Eco Mode yg bisa kasih tau kalau kita berkendara irit atau ga
Copy paste dari web Ford Indo:
http://www.ford.co.id/en/cars/new-fiesta
1.5L Ti-VCT petrol engine
If you're more comfortable knowing you've always got something in reserve when you need it, the 1.5L Ti-VCT gives you enviably low consumption rates in the city and out of town, without sacrificing its punch.
6-speed PowerShift
How do you get the responsiveness of a manual and the ease of an automatic in one transmission? You let the dual-clutch design of our 6-speed PowerShift automatic transmission give you the best of both worlds. Best of all, it’s designed to be maintenance-free for the life
of the car.
EcoMode
So many things affect how far you can go on a tank of fuel. Including the way you drive. EcoMode gives you tips on how you can change the way you drive, while you’re driving. So you can drive more and refuel less often.
Low maintenance
Everyone can be a little high maintenance sometimes. But your car shouldn’t. So the time between services on your Fiesta is now up 10,000km.
Hands-free phone calls
You’ve got to L.O.V.E. a car that lets you use your Bluetooth phone and still keep your hands on the wheel and your eyes on the road. Call your friends, dial numbers and answer calls with a few simple words. SYNC™ keeps you and your social life safely under control.
Who needs keys?
Never fumble to find your keys in the dark again. Keyless Entry with Push-button Start means your Fiesta unlocks when you pull the door handle, as long as your key fob is in your pocket or bag. Then you simply put your foot on the brake, press the start button and drive away. It’s almost too easy.
Less to think about
There are enough decisions in life. So here are a few you no longer have to think about. Rain-sensing Wipers turn-on automatically and adjust their speed for heavy or light rain. Auto Headlights also turn-on as soon as they sense there’s not enough light so you can see what’s ahead.
Perfect hill starts
Does stopping and starting on hills cause a little anxiety? Then relax. Hill Launch Assist stops your Fiesta from rolling downhill for the few seconds it takes your foot to leave the brake and press the accelerator.
Love those airbags
With airbags for both the driver and front passenger, the Fiesta gives you extra peace of mind when you drive.
Super strong safety
If boron steel has what it takes for the aerospace industry, it has what it takes to help protect you. Four times stronger than standard high strength steel, it reinforces your Fiesta at key points, creating an extra level of safety around you.
