All about VOLVO
Re: All about VOLVO
front end is typical car in its era...
Re: All about VOLVO
told the current curator (dr ruud haig) the license plate coloring shouldve been black with white alphabetic n numerical
Re: All about VOLVO
ha, satu lagi informasi berharga dari oom NR........
Re: All about VOLVO
Re: All about VOLVO
Volvo Group's operations include:
Mack Trucks (light-duty trucks for close distribution and heavy-duty trucks for long distance transportation)
Renault Trucks (heavy-duty trucks for regional transportations and heavy-duty trucks for the construction work segment)
SDLG (Shandong Lingong Construction Machinery Co., Ltd., China)
UD Trucks (midsize-duty trucks)
Volvo Buses (complete buses and bus chassis for city traffic, line traffic and tourist traffic)
VE Commercial Vehicles Ltd (VECV), a 50:50 joint venture between the Volvo Group and Eicher Motors Limited
Volvo Construction Equipment (construction machines) (previously Volvo BM, see also AB Bolinder-Munktell)
Volvo Financial Services (customer financing, inter-group banking, as real estate administration)
Volvo Information Technology
Volvo Penta (marine engine systems for leisure boats and commercial shipping, diesel engines and drive systems for industrial applications)
Volvo Trucks (midsize-duty trucks for regional transportation and heavy-duty trucks for long distance transportation, as well as heavy-duty trucks for the construction work segment)
Brands
Eicher (50:50 joint venture with Eicher Motors, India)
Mack Trucks
Nova Bus
Prevost
Renault Trucks
SDLG (Shandong Lingong, China)[citation needed]
UD Trucks
Volvo Buses
Volvo Penta
Volvo Rents
Volvo Trucks
http://www.volvogroup.com/group/global/ ... /mack.aspx
http://www.volvogroup.com/group/global/ ... es/CE.aspx
Brands
Mack Trucks
Nova Bus
Prevost
Renault Trucks
UD Trucks
Volvo Buses
Volvo Penta
Volvo Rents
Volvo Trucks
Re: All about VOLVO
when its public duty ends
a police cruiser awaits its turn for scrap
Re: All about VOLVO
Di scrap juga gapapa sih, mobil polisi/taxi/public services gt pasti masa pakainya udh abis & tinggal buluknya aja...
Re: All about VOLVO
Peleknya cakep tuh om. Pcd berapa ya? Masih 108 gak sih?
Re: All about VOLVO
58yo prof fogelstrom n his 58yo v-445 leveranschassi (original in all including powersteering, 1600cc 4cyl 6volt engine) ...ex belgium embassy jakarta
Re: All about VOLVO
perhaps ths justifies previous ugliness
Re: All about VOLVO
Volvo 940 mesin 2.3 non turbo, dikasih bensin premium.. ada efek samping gak yaa?
Re: All about VOLVO
tdk apa kan lambda system tdk di pasang di indo
Re: All about VOLVO
nggak ada tenaga dan bensin boros. engine B230E minta oktan minimum 92 karena kompresinya 9,3:1. saya juga pake engine B230E redblock, selalu isi pertamax dan hasilnya konsumsi bensin lebih irit.didietkeren wrote:Volvo 940 mesin 2.3 non turbo, dikasih bensin premium.. ada efek samping gak yaa?
Re: All about VOLVO
ralat, B230E / B230F kompresinya 9,8:1. kompresi segitu mau dikasih oktan 88? tega bener.......
Re: RE: Re: All about VOLVO
Apanjah klo gk slh kompresi 11:1 ya om? Lebih tega lg berarti yg ngisi 88 di apanjah.. [emoji1]marmut wrote:ralat, B230E / B230F kompresinya 9,8:1. kompresi segitu mau dikasih oktan 88? tega bener.......
Re: All about VOLVO
@ ceiszha,
saya nggak tau. diliat aja angka di businya berapa, itu bisa jadi salah satu patokan kompresi mesin ada di kisaran berapa. ya maka dari itu manual book dibaca, mesin minta oktan berapa?
orang2 yang isi oktan 88 di mesin kompresi tinggi cocoknya makan nasi aking sama minum air kali.
Re: All about VOLVO
FC pake ron92 dalkot/lukot kisaran berapa Om?marmut wrote:nggak ada tenaga dan bensin boros. engine B230E minta oktan minimum 92 karena kompresinya 9,3:1. saya juga pake engine B230E redblock, selalu isi pertamax dan hasilnya konsumsi bensin lebih irit.didietkeren wrote:Volvo 940 mesin 2.3 non turbo, dikasih bensin premium.. ada efek samping gak yaa?
Baru baca manual book disarankan ron95 malah..
Mohon bimbingannya nubie Volvo..
Re: All about VOLVO
940 manual apa matic? yang pernah saya pake tempo hari matic ZF dalkot 1:9 dan luar kota 1:14.
kalo mau kasih oktan 95 boleh, tapi kompresi masih dibawah 10 cukup oktan 92 aja.
Re: All about VOLVO
940 matic zf juga Om..marmut wrote:940 manual apa matic? yang pernah saya pake tempo hari matic ZF dalkot 1:9 dan luar kota 1:14.
Wow.. Lmyn irit jg ya.. Saya masih adaptasi sama karakter throttle nya.. Biasanya bawa manual berkarbu.
Trik supaya irit gmn Om?
Re: All about VOLVO
lha emang yang sekarang FC berapa? trik supaya irit sama kaya mobil lain. periksa celah klep, ganti koinnya kalo memang perlu. busi pake standarnya, kalo saya pake NGK bkr6. trus kabel busi diperiksa tahanannya kalo udah lebih dari 20 K ohm mending ganti. bisa pake punya mercedes atau ngakalin sedikit pake punya daihatsu zebra.
diperhatiin juga andaikata pake kabel busi yang ada resistornya, businya jangan yang ada resistor supaya api nggak kecil.
Re: All about VOLVO
2015.11.26 di tanah-es @ tindfjallajökull airstrip n industrial testing ground facility ... bruntung single engine prop yg sy tumpang abis bensin n isi disini
hr ini kata supir sy itu mobil kliatan di keflafik dkat airport dg RN licenseplate (RN= temporary dgn red background)
Re: All about VOLVO
Kira2 tipe apa ini om ?newrubble wrote:2015.11.26 di tanah-es @ tindfjallajökull airstrip n industrial testing ground facility ... bruntung single engine prop yg sy tumpang abis bensin n isi disini
XC70 baru ato yg estate ?
Re: All about VOLVO
sy ga tau tapi tanah-es itu mmg testing ground smua prelaunch cars yg ada di EU market ... disini mrk pakai IS license plate dg red background dan RN alphabetical start ...mobil mobil dg physical presence bgitu umumnya diuber automotive papparazzi
Re: All about VOLVO
antara seri V atau XC sepertinya.
Re: All about VOLVO
barusan sy ktmu teman skantor yg real native swedish n bekas guru svenska n sy tanya bgmn volvo perfectly pronounced
dia bilang tiga kali...
WULWU
karena O bacanya U
kalo Ö dibaca OA
sedangkan U bacanya EUW bukan U atau YU
tar abis minum minum kalo dia ditanya masih bilang WULWU artinys dia benar n svenska dia bagus krn mmg pribumi dr sono
WULWU
karena O bacanya U
kalo Ö dibaca OA
