Page 1 of 5
Mitsu 4N15 Performance Update (MIVEC kicked in YO !)
Posted: Tue Mar 22, 2016 9:58
by Turboman
Eng Ing Ennggggggggg........................................
Re: Mitsu 4N15 Performance Update
Posted: Tue Mar 22, 2016 10:08
by sintoni
Wih. Mantap jg outputnya om.
Ini spek gimana? Atau cuma main pigibek?
Posted: Tue Mar 22, 2016 11:36
by Fiz
bukan maen.. ni di indo pula yak.. kirain baru di thai yang udah berani oprek oprek..
255hp..
Posted: Tue Mar 22, 2016 12:14
by alvin23
buset ini +70 hp main apa aja?
Posted: Tue Mar 22, 2016 12:33
by stevenanthony
Wah mantep makin salut ane sama mesin ini... #dieselpower
Posted: Tue Mar 22, 2016 12:35
by Turboman
Just MonsMax
and nothing else
Koonon Turbo di set di 1,6 - 1,7 bar
Posted: Tue Mar 22, 2016 13:05
by mr-saga
Turboman wrote:Just MonsMax
and nothing else
info yg mantab om Turbo... makasi..
oiya om, menurut anda jika torsi max diletakkan di rpm yg sama dg spek standarnya kira2 bisa/tidak om?
- apakah perolehan angka torsinya lebih kecil dari hasil settingan yg ini?
Posted: Tue Mar 22, 2016 14:05
by Chevyman
Kira2 kapan di ckd-in ya...klo ckd apa pasti turun harga?....bener2 bikin galau...ga ada dealer yg mau kasi diskon....ternyata emang lebih menjual dari sebelah
Posted: Tue Mar 22, 2016 16:51
by Bulgogi
Ini potensi mesinnya udah mentok di 255 ya?
Posted: Wed Mar 23, 2016 0:01
by Turboman
Bulgogi wrote:Ini potensi mesinnya udah mentok di 255 ya?
Masih bisa lebih
Tapi tuner ambil safe nya aja
Posted: Wed Mar 23, 2016 0:26
by brintanizer
Chevyman wrote:Kira2 kapan di ckd-in ya...klo ckd apa pasti turun harga?....bener2 bikin galau...ga ada dealer yg mau kasi diskon....ternyata emang lebih menjual dari sebelah
Imho . Anps ini cm dakar yg sgt menarik beda ama fotuner yg dari G ampe vrz rasa nya sama aja . No ofsns
Posted: Wed Mar 23, 2016 3:10
by 3mul
Pake biosolar ato dex?
Sent from my LG-D855 using Tapatalk
Posted: Wed Mar 23, 2016 3:16
by ERH
dapet 255hp ya? mirip dengan pasport lama klo pake dastek ya. klo 2gd belum ada update lagi ya? masi dapet 200hp an.
Sekarang saa pakai fortie vnt pake dastek dapet 260hp, tertarik banget ni sama 4n15. 4n15 belum ada dastek kit nya y?
Posted: Wed Mar 23, 2016 7:29
by reinhard_harley
Waoww....gile peningkatan torsinya tinggi bgt. Standardnya aja sdh enak banget..biayanya brp om turbo pasang monsmax dimana?
Posted: Wed Mar 23, 2016 7:54
by htannis
tadi baru ngobrol langsung sama tunernya, katanya 255hp ini masih bisa naik lagi jauh cuman dia belum berani sementara ini, itu baru 1.7 bar, info turbo nya kuat dipake 2 bar, kalau 2 bar bisa deket ke 300hp
Kalau 2gd dah mentok pake ecushop 210hp
Posted: Wed Mar 23, 2016 7:59
by Turboman
reinhard_harley wrote:Waoww....gile peningkatan torsinya tinggi bgt. Standardnya aja sdh enak banget..biayanya brp om turbo pasang monsmax dimana?
kalo di Jkt di REV
kalo di Bdg bisa ke Garage Autowerkz, mrk ada mesin dyno yg bisa baca RWHP -
http://garageautowerks.com/
Btw bisa pake MonsMax atau Super 4, hasilnya mirip
Super 4 harga jauh lebi mura dr MonsMax
*bukan seles piggybek*
Posted: Wed Mar 23, 2016 8:04
by colai
htannis wrote:tadi baru ngobrol langsung sama tunernya, katanya 255hp ini masih bisa naik lagi jauh cuman dia belum berani sementara ini, itu baru 1.7 bar, info turbo nya kuat dipake 2 bar, kalau 2 bar bisa deket ke 300hp
berarti anki anf cuma mentok di 210hp an yah om .....
maap nih kalo pasang begituan , aman gak sih ? ndak pernah oprek mobil rada takut he3
dulu waktu muda oprek rxking ninja rr ...porting polish karburator di gedein dan dll
konsekwensi nya ....sering ganti ring piston sama kalo macet mesin overheat he3
tapi emang kalo mau lari ... jambakan setan om he3
kira2 perlu budget berapa tuh yah om ?
Turboman wrote:reinhard_harley wrote:Waoww....gile peningkatan torsinya tinggi bgt. Standardnya aja sdh enak banget..biayanya brp om turbo pasang monsmax dimana?
kalo di Jkt di REV
berarti 2gd lebih payah dong daripada 2kd .....mungkin penyunatan material kiri kanan sama toyota
Posted: Wed Mar 23, 2016 8:11
by ipat
Tanya dong om Turbo,cara mengurangi lag pada rpm bawah dakar(2014) gimana ya?
Posted: Wed Mar 23, 2016 8:19
by Turboman
@colai :
Yg penting ya nyetir yg wajar2 aja
Monitor EGT
Oli bagus
ATF cooler
BBM bagus / Biosolar kasi additip
Dah power gede gini kan neken gas-nya cukup toel2 aja.....hehehe
Posted: Wed Mar 23, 2016 8:24
by Turboman
ipat wrote:Tanya dong om Turbo,cara mengurangi lag pada rpm bawah dakar(2014) gimana ya?
Selama ini pakai Piggyback apa ?
Posted: Wed Mar 23, 2016 8:44
by ipat
Standar aja mod,apa krna jarang dipake(2000an km)?
Posted: Wed Mar 23, 2016 9:13
by htannis
colai wrote:htannis wrote:tadi baru ngobrol langsung sama tunernya, katanya 255hp ini masih bisa naik lagi jauh cuman dia belum berani sementara ini, itu baru 1.7 bar, info turbo nya kuat dipake 2 bar, kalau 2 bar bisa deket ke 300hp
kalo di Jkt di REV
untuk 4n15 sama 2gd ini saya gak brani ngomong masalah kuat apa kagak, ini sih tuner sah ambil safety margin juga. kalau 2kd sama 4d56 sih saya brani bilang "kuat" dakar saya dah 4 tahun dari baru pasang piggyback 260hp/580nm, sampe skrg aman2 aja keluar kota bejek2, cuman atf cooler sama extra fan saya dah pasang dan pengaruhnya banyak. Makanya saya kasih kuat dalam tanda petik harus ada pendukung dan perawatan umum kayak oli2 harus di cek. Untuk 2kd malah jauh lbh kuat drpd 4d15.
jujur aja gak bisa, kecuali main mekanikal seperti rombak crank, di trit lain saya pernah bilang tiap mesin ada karakter sendiri, peak power sama peak torque biasa nya ada di rpm tertentu, mau pake turbo gede atau turbo kecil pun biasa gak beda jauh2 amat peak rpm nya.
Posted: Wed Mar 23, 2016 10:11
by Turboman
ipat wrote:Standar aja mod,apa krna jarang dipake(2000an km)?
Wahhhhh
Kalau ingin mesin sehat & kinerja optimal, mobil harus sering dipake
Minimal 1000 Km / bulan, nah itu mesin enak dah.......en saat keluar kota di jalan2 tertentu geber sampe 70% Redline....bbrp X........abis balik dr luar kota pasti ketasa lebih enak
Oli dan BBM yg bagus juga
Khusus utk PJS, akselerasi dgn semi manual, lebih gesit drpd di D aja
Posted: Wed Mar 23, 2016 10:28
by ipat
Om htanis:wah begitu ya makasih infonya,saya baca di tret psl kaskus "katanya" dikasih Trhotle respone apa TC gitu bisa lumayan,
Om turbo:emang bener sih dibandingin si ipah d4d mt sy yg sring dipake luar kotaan kerasa bgt bedanya,sekali gas lgsung kerasa
Posted: Wed Mar 23, 2016 11:40
by htannis
ipat wrote:Om htanis:wah begitu ya makasih infonya,saya baca di tret psl kaskus "katanya" dikasih Trhotle respone apa TC gitu bisa lumayan,
tc bisa aja nolong buat "menipu" feeling saja, saya pribadi gak suka pake tc.
d4d mt bawahnya enak, cuman atasnya boyo (kita ngomong dengan kondisi sama2 std dengan dakar yah) kalau dakar kebalikannya bawah lemot atasnya ke 180kmh cepet
