Kemarin saya angkat 2KD matic km200rb yang gak tau sejarah oli maticnya. Kuras atf ala gerlong sampe habis 8L, oli yg keluar masih butek aja.
Bengkelnya bilang suruh ganti filter matic.
Re: RE: Re: Kijang Innova D4 D - 2KD-FTV - PART 03
Approximately = perkiraan, based on winols calculationTurboman wrote: ↑Mon May 08, 2017 9:13abis remap then Dyno run dimana um ?arfs wrote:
Hasil remap hari ini di BeBong Motorsport by SVVR (A.K.A. b8099ok)...
Approximately power and torque gain to 160 hp and 380 Nm
Spec standard with BLT (Basic Light Tuning by Achien):
- EGR (Exhaust Gas Recirculation) Delete
- Super Ground Cable
- Turbo Wastegate hose change to smaller diameter and longer
- 2mm Wastegate ring bolt
Real dyno blm ada, knp? Om TM mau bayarin dyno nya?
sesekali sih ga ada salahnya dyno test.....
dyno test di tempat yg ekonomis aja......udah mayan banyak yg punya mesin dyno skg di Jkt en sekitar
nugroho bagor wrote: ↑Mon May 08, 2017 11:10Exhaust kalau mau nyicil dari muffler dulu,fyi saya pakai .kansaihtannis wrote: ↑Mon May 08, 2017 10:48Exhaust ganti full lah dari DP sampe ke muffler di ganti yg free flow. Transgo jelas bikin power delivery jauh lebih enak dan konstankepalaikan wrote: ↑Sun May 07, 2017 11:25 Suhu... mohon pencerahan...
Ipah nubie udah
-downpipe
-AF knn
-ground cable
-remap di GA
-fuel cooler
-atf cooler
Skr sdh kerasa mantep lah... tp pengen nambah di exhaust... nah exhaust yg paling di duluin mana dulu ya?
Target nya agar power yg ada selalu stabil aja... dan apakah transgo juga bikin stabil di power?
Nah ini maksudnya... hehehe yg di duluin yg mana...
Pengen nya nyicil dikit2, syukur2 ada sekenan gak kepake... hehehe
Downpipe aja dulu, trus transgo, baru muffler free flow
well it is, but who cares
Ganti kampas kopling diesel manual habis berapa ya, sama van belt dan timing belt... Udah usia nya
Sent from my Redmi Note 3 using Tapatalk
Salam kenal rekan2 Innova 2KD user, calon 2KD user nih, hasil kena racun di forum SM n KIOC, domisili bintaro..
Mohon izin para suhu dan sesepuh sekalian..
Saya ada rencana mau meminang Innova 2KD V AT 2014 akhir, odo di 36.000km
Yg ingin sy tanyakan:
1. Kalo ngeliat odo nya termasuk kategori wajar/tinggi odonya? Apa aja yg perlu dicek dlm meminang mobkas tsb?
2. Setelah meminang nanti saya ingin melakukan beberapa penyegaran:
a. Ganti oli mesin pake delvac 5w40
b. Ganti oli gardan pake red line 75w90 GL5
c. Kuras n ganti oli PS n oli rem, baiknya pakai yg type n merk apa ya?
d. Ganti filter udara pake sakura, ganti filter solar pakai ori, ganti filter kabin pakai ori
e. Purging, ada rekomendasi pakai obat apa?bayangan sy mau purging di toda bintaro, tanya2 biasa pakai merk liqui moly, apakah udah bagus?
f. Untuk oli matic dgn odo n usia mobil, apakah udah perlu diganti?
g. Pasang GC sekaligus delete EGR n ganjal wastegate di achien, kalo EGR dah ditutup apa bisa dikembalikan spt ori nya?
Kira-kira langkah dr a sampe g tsb apakah msh ada yg kelewat, dan mhn bantuan menjawab pertanyaan nubi ya
3. Setelah item no 2 a sampe g kelar, nubi pengen pasang Fuel Cooler n ATF cooler, kira2 skr brp DC nya?
4. Untuk BBM, ane mau pakai additif nya Schaeffer DT2000, apa udah bagus?ato ada rekomendasi merk lain?
Demikian kira2 angan2 nubi kalo unit inceran ane jadi deal, mhn arahan nya ya, mengingat selama ini belum pernah miara diesel. Terima kasih
Sent from my Infinix-X552 using Seraya Motor mobile app
semua dah oke itu yg ditulisagnov wrote:Salam kenal rekan2 Innova 2KD user, calon 2KD user nih, hasil kena racun di forum SM n KIOC, domisili bintaro..
Re: RE: Re: RE: Re: Kijang Innova D4 D - 2KD-FTV - PART 03
Om Turbo..tolong jawab yg pertanyaan no 1 2c 2f 2g..makasihTurboman wrote:semua dah oke itu yg ditulisagnov wrote:Salam kenal rekan2 Innova 2KD user, calon 2KD user nih, hasil kena racun di forum SM n KIOC, domisili bintaro..
kalo udah 2 tahun ya ATF ganti
minyak rem ganti
coolant nanti di tahun ke 4
minyak rem ganti
- Daily Vehicle: ISUZU MU-X
oom Turbo, saya mau tanya.
Apa bener bengkel dyno itu cenderung punya "vested interest" atas hasil dyno ?
Maksud saya gini. Giliran mobil yang dituned di bengkel mereka sendiri, maka angka dyno cenderung digede-gedein.
Kalau ada yang dituned di bengkel luar, dan numpang dyno kesana, maka angkanya dikecilin,..
begitu gosipnya..apa benar ada phenomena itu ?
btw, bengkel yang masih "fair" dan harga bersahabat dimaksud dimana oom ?
ya mungkin2 aja.......tapi biaya dyno run kan gak murah, mestinya sih hal tsb less likely to happenginting wrote:oom Turbo, saya mau tanya.
dyno run aja di bkl2 yg sering dipake media utk testing........yg udah terbukti objektif
pemilihan gigi saat dyno run juga mempengaruhi bacaan Hp
Kalo tuning diesel sih dyno run bagi saya yg paling penting utk mengetahui angka AFR / Boost / EGT saat run dgn load.......
ChZ wrote: ↑Sun Mar 05, 2017 17:27Oom arief uda mulai ga percaya Tuhan?arfs wrote:
Sent from my 2014817 using Seraya Motor mobile app
Bebonk sudah percaya Tuhan koq..
Sudah berubah dia sejak sering saya kunjungi..
kepada istri juga dia sudah lebih lovely cara ngomongnya..
Tapi masih perlu lebih banyak ke Karmel sih..buat pencerahan djiwa...
Tinggal sama FRD aja yang suka culas dia ngomongnya..
Gue sebenarnya pingin banget lihat bebonk ngomong ke FRD "Rid, elo kalo butuh apa di perantauan ngomong ya...oom akan bantu dengan sepenuh hati..."
- Daily Vehicle: Civic FK4
Errr.... itu jokes not to meant literally...ginting wrote: ↑Mon Jun 05, 2017 10:38
There once a joke "percaya bang sat ga percaya Tuhan"...
Hanya jokes jgn ditanggapi secara literal um...
Chz percaya FRD itu makanan ga,...
FWD + eRWD + 4WD + 4WD =
FRD iz a food... meant to be slaughtered for our ransom in post apocalypse...
- Daily Vehicle: Civic FD2
for internal use onlyChZ wrote: ↑Mon Jun 05, 2017 15:22Errr.... itu jokes not to meant literally...ginting wrote: ↑Mon Jun 05, 2017 10:38
2009 Honda Civic FD2
2015 Honda CR-V 2.4l A/T
food for every people on earth for 10 million years
Coba saya jawab ya:
Catrol Magnatec 5w30 itu terlalu encer buat Innova Diesel, pake yang 15w40 diesel saja. Fastron Diesel dan Mobil 1 MX dua-duanya 15w40, kalo yang bagus Mobil Delvac 1 5w40 / Mobil 1 Turbo Diesel Truck.
Oli gardan butuh yang spec GL-5, bisa Mobil 1 75w90 atau lainnya 80w90.
Transmisi matic pake T-IV.
Bisa juga masuk ke pembahasan oli mesin bro....
setsune wrote: ↑Thu Mar 23, 2017 14:07 halo suhu2 disini, terutama om turbo.. mau tny ane barusan ganti oli mesin, gardan, transmisi matic. oli mesin dikasih castrol magnatec profesional 5w-30 7lt itu gpp ya? ini aman dipakai untuk brp km ya? kalau di sby-mlg, ganti oli q8 yg rekomen dmn ya?
oya tipe oli gardan dan matic kemarin dikasih t-iv. itu gpp ya?
terima kasih sebelumnya.
Malam suhu2 semuanya..
Izin tanya lg donk..
Ada yg pernah make kaca film merk wincos? Gimana reviewnya?
Atau ada rekomendasi KF lain yg worht buat GNKI dono?
Makasih suhu2..mohon dibantu
Sent from my SM-G920F using Seraya Motor mobile app
Wincos bolehagnov wrote:Malam suhu2 semuanya..
dari luar tampilan mirip 3M BB
Ada saran tokonya yg jual Om?takut kena yg palsu nih...Turboman wrote:Wincos bolehagnov wrote:Malam suhu2 semuanya..
mau tanya nih, mau pasang kamera mundur di ipah v, kabel nya sudah ada sampai belakang, tinggal colok, apa harus tarik kabel sendiri juga ya?
lalu pasang engine start stop button di ipah, apa bisa ya ? pake punya vios bisa plug and play gak ya ?
- Daily Vehicle: 205系電車
kalau dah ada kabel kamera ya gak usah tarik kabel lagi. sumber daya kamera non standar 12v bisa ambil dari lampu rem karena standar dari hu 6v.
start stop gak cuma pasang tombol doang tapi juga harus disupport ecu. nah, pertanyaannya apakah ecu ipah 2kd support start/stop?
nah itu om, std ipah v udah ada kabel kamera nya belum ya??3mul wrote: ↑Wed Jun 07, 2017 6:48kalau dah ada kabel kamera ya gak usah tarik kabel lagi. sumber daya kamera non standar 12v bisa ambil dari lampu rem karena standar dari hu 6v.
