Koleksi hand tools [Part 04]
blloewy
Daily Vehicle: HR15 - 2012
Post by blloewy »
Yg nanya link Kompresor Portable kemarin disini mbah...
Cari di ecomm lain jg banyak kok.
Gratisan buat kamu! Pake kode ONGKIRGRATIS pas belanja di Bukalapak biar ongkir kamu gratis (maks. Rp30rb). Berlaku khusus pengguna baru. Yuk, belanja yuk! πŸ€—
Atau ketik taffware ATJ1166s
https://www.bukalapak.com/p/mobil-part- ... ource=apps
yanuarra
Post by yanuarra »
Omnibus wrote: ↑Sat Apr 17, 2021 2:14
yanuarra wrote: ↑Sat Apr 17, 2021 2:04
Omnibus wrote: ↑Sat Apr 17, 2021 1:38
awas diajak tuker guling ntar sm mbah delko ...... :big_grin:
katanya ngana mau ratchet beta nya? :big_biglaugh:
iyaa kmren2 mah mau sblm sold mbah..
kalo ane kan nunggu THR-an jd engga bisa cepet2 wkwkw
Biar kata di tuker guling ama 730D plus sambel ulek sekilo, ga akan saya lepas tuh beta oglek :big_smoking:
sintoni wrote: ↑Fri Apr 16, 2021 23:56
DOHC wrote: ↑Fri Apr 16, 2021 17:02
Lah kan katanya mbah mau beli yg soket set, jd ud cover mayoritas ukuran2 yg dipake.. 8, 10, 12, 14, 16.. cuman kl utk gardan biasa 24, atau ad jg chassis dan roda 19
Maksudnya yang 1/4 atau 3/8 atau 1/2 mbah?
Nahh ini balik lg ke seberapa "willing"mbah mau spend buat toolsnya
Ideal nya, 3/8 set ama 1/2 set... 1/4 ga tralu perlu, nice to have tp not a must
Tp kl mau irit2
Ya bsa beli yg 1/2 set aj
yanuarra wrote: ↑Fri Apr 16, 2021 23:00
DOHC wrote: ↑Fri Apr 16, 2021 15:22 ok
found it !!!
ternjata ceklek2 saya yg ijo ga bsa dipake buat tork baut2 suspensi inofa
bushing2 bawah dan ball joint arm bawah perlu 140 Nm, shock breaker 105 Nm
bushing atas 115 Nm, ball joint arm atas 110 Nm
kcuali
trekstang 55 Nm
selang minyak rem 24 Nm
Ini bisa mbah :e-whistle: :e-whistle:
Bersama baterai yg udah menemani 8 tahun and stay strong up to 1000x recharge :cupss:
Ini lg
Pemufakatan yg sama ama mbah masas dan mbah 69.. :big_bored:
udie_kidz wrote: ↑Fri Apr 16, 2021 18:05
DOHC wrote: ↑Fri Apr 16, 2021 16:59
Omnibus wrote: ↑Fri Apr 16, 2021 16:36
gini ane kasih tau caranya mbah. diurut aja misalnya dr 30Nm sambil diperhatiin bautnya muter ngga pas klik. kl engga, naikin lagi jd 35Nm. gitu terus naikin tiap 5Nm lagi sampai keliatan bautnya muter, maka kurang lebih segitu mula2nya torque spec nya.
paling ntar ada momen udah diset 100Nm belum muter juga, ya berarti diluar range manoskop anda. harap segera kunjungi misterworker atau amazon. :mky_07:
Td abis gugel2
Ternjata utk mobil2 casis tangga, apalagi yg model truck based sperti inofa.. baut2 nya perlu tork kisaran 100an mbah
Tp ga ampe 200 Nm sehh
Laen crita kl utk mobil2 FWD, rata2 baut2 kaki masi banyak bermain d bawah 100an
Tanggung amat yah si 730/10, coba kl range nya bsa cover 10 Nm ampe 150Nm.. kan ga perlu beli2 lg
Hmmmmmm :big_think:
Brati tinggal nambah lg mbah yg 40-200nm
Saya sehh nyari nya yg 200 ke atas.. kl 40 up to 100 kan ud kecover
k1493nk wrote: ↑Fri Apr 16, 2021 23:03
DOHC wrote:
marmut wrote: ↑Fri Apr 16, 2021 12:37
Omnibus wrote: ↑Fri Apr 16, 2021 12:02
mbah2
mo nanya donk, kl utk baut2 chassis, baut2 kaki itu torsi nya brapa yah ?
http://zatonevkredit.ru
Fsm toyota n Lexus, bahasa rusia, silakan buka di Chrome di pc biar bisa auto translate.
Ahhh makasih om :mky_03:
yanuarra
Post by yanuarra »
blloewy wrote: ↑Sat Apr 17, 2021 3:19 Yg nanya link Kompresor Portable kemarin disini mbah...
Okay mbah
indeskey
Post by indeskey »
Kalau torque spec nya honda2 global macam jazz/hrv ada nggak ya mbah? Mbah omni habis ya langganannya [emoji26]
Minggu kemaren nemenin temen ganti karet bushing lower control arm, lihat tukangnya ngencenin pake tjara mbah suhu dohc nggak tega liatnya hahaha.... pas nggak ceking lagi itu tukang lbh berisi wkwkw...
indeskey wrote: ↑Sat Apr 17, 2021 7:58 Kalau torque spec nya honda2 global macam jazz/hrv ada nggak ya mbah? Mbah omni habis ya langganannya [emoji26]
wah ini perlu skill ngencenginnya. ane aja belajar dr chief mechanic nismo ...... di cenel jdm mastah :big_biglaugh:
torque spec utk itu 93Nm utk kedua bautnya (yg dr bawah ke atas duluan dan lalu yg dr depan ke belakang.) mobil hrs dlm posisi berdiri di rodanya, bukan ketika msh tergantung dongkrak/jackstand. kl ga punya pit, hrs diukur jarak dr center hub ke bibir fender. lalu dongkrak control arm pakai dongkrak buaya sampai ke ketinggian tsb baru di torsi.
josomba
Daily Vehicle: Delman
Post by josomba »
Nubi nimbrung penggunaan c-clamp pagi ene.
Mau foto pengerjaannya tp ribet, comot dr sisitipi aja deh
Supporting tools:
- Trelek "ngaku JIS"
- Dongkrak "ngaku JIS"
- Ceklek2 jtc buat baut nge-torque pelek n skalian ngecek torsi baut2 shock n lower arm
- Siphon merah harga 40 rebuan sesuai arahan suhu di marih buat sedot sikit mintak rem
- crc brake quiet
- crc sta lube buat slider pin
Demikian iklan lewat dr super nubi dalam hal per-trelek-an n per-ceklek-an
:big_chicken:
indeskey
Post by indeskey »
Catet 93Nm, kayaknya bautnya gedhe tp lbh kecil dari locknut ban ini.
Nubi susah saya membayangkannya mbah suhu, kalau kemaren tukangnya ya pasang baut asal udah pas aja yg bawah dan depan. Dan semuanya keadaan lepas ban dll.
indeskey
Post by indeskey »
josomba wrote:Nubi nimbrung penggunaan c-clamp pagi ene.
Supporting tools:
- crc brake quiet
:big_chicken:
Mantabssssssss...
Omnibus wrote: ↑Sat Apr 17, 2021 8:38
93... yeshhhhhhh
Akhirnya ceklek2 saya kepake jg
Lgs meluncur kencengin
josomba wrote: ↑Sat Apr 17, 2021 8:59 Nubi nimbrung penggunaan c-clamp pagi ene.
Supporting tools:
- crc brake quiet
:big_chicken:
hebring bener ...... mbah suhu poles body nan mengkilat mau juga kotor2 di bagian onderstel :mky_03: :big_exellent:
Supporting tools:
- crc brake quiet
:big_chicken:
Mantepppp mbah shifu :big_exellent:
Btw, ati2 mbah ngandelin dongkrak tekiro doank loh, iya tekiro yg ngaku2 jis jepang, soalnya tekiro itu ga bgt kuat loh.. tekiro yg warna ijo2 ngaku2 jepang itu
DOHC wrote: ↑Sat Apr 17, 2021 9:11
93... yeshhhhhhh
yg bener prosedurnya, baca petunjuk ane jangan skim read. ntar malah jebol itu bushing, harusnya ga kenapa2 kl ga ngana sentuh2. :big_biglaugh:
jd inget coolant :big_biglaugh:
Omnibus wrote: ↑Sat Apr 17, 2021 9:14
93... yeshhhhhhh
Hmm ya ya
Ga bole d dongkrak
Bawah dulu baru baut2 samping
93 nm
Sipp gampang
indeskey wrote: ↑Sat Apr 17, 2021 9:07 Catet 93Nm, kayaknya bautnya gedhe tp lbh kecil dari locknut ban ini.
belum mengerti ya mbah maksud saya? wah bisa panjang ini kuliah 6 sks mbah. kl memang belum ngerti sy bikinin tutorialnya. beneran belum ngerti yg namanya prosedur preload?
mumpung malming nganggur maklum udah ga punya pacar.
DOHC wrote: ↑Sat Apr 17, 2021 9:20
93... yeshhhhhhh
Hmm ya ya
Ga bole d dongkrak
93 nm
Sipp gampang
91Nm kl pake manoskop 730 dan insert ratchet QR krn ada kompensasi panjang insert. yg rumus itu lho. tp udah lah beda 2Nm ini ga jd soal.
yanuarra
Post by yanuarra »
93... yeshhhhhhh
Hmm ya ya
Ga bole d dongkrak
93 nm
Sipp gampang
Nih mbah 93 lho
....... :ngacir:
yanuarra
Post by yanuarra »
Itu lho mbah mudahnya dikencengin sprti ketika seolah2 mobil dlm keadaan diam, pakai ban, dan nggk di dongkrak. Persis sprti mobil sedang parkir he he he
yanuarra
Post by yanuarra »
Omnibus wrote: ↑Sat Apr 17, 2021 9:25
Asyik bikinin dong mbaah masas :mky_04: :e-dance:
6 sks yg berharga ini mah :mky_02:
Kalo kuliah mbayar, kalo kuliah sm mbah masas gratis, bayarannya semoga dpt pahala setimpal dari tuhan krn membantu sesama.. ayey.. :e-dance:
yanuarra
Post by yanuarra »
Ga cari pacar lagi mbah?
...... :ngacir:
DOHC wrote: ↑Sat Apr 17, 2021 9:13
ini di save di notes HP jij. banyak itu yg bisa pake ceklek2 jij.
Torque Specs Honda Jazz GK5
- Lug Nuts: 108 Nm
- Oil Drain Plug: 39 Nm
- CVT Oil Drain Plug (3/8 sq.): 49 Nm
- CVT Filter Housing: 27 Nm
- Throttle Body: 22 Nm
- Intake Manifold: 22 Nm
- Fuel Rail Mounting Bolt: 12 Nm
- EGR Valve: 22 Nm
EGR gasket P/N 18715-5XH-K01
- O2 Sensor: 45 Nm
- PCV Valve: 45 Nm (not applicable to L15z)
- Engine block coolant drain plug: 78 Nm (P/N gasket: 90401-PR4-000)
- Ignition Coil Bolt: 10 Nm
- Spark Plug: 25 Nm
- Valve Adj. Lock Nuts: 14 Nm (10 lb-ft)
- Intake: .15 - .19 mm
- Exhaust: .26 - .30 mm
- Serpentine Belt Tensioner Bolt: 22 Nm
- Axle Spindle Nut: 182 Nm (head hex 32 mm)
- Strut top mount: 44 Nm
- Strut lower mount: 90 Nm
- Brake hose mount: 22 Nm
- Strut top to spring: 34 Nm
- Inner Tie Rod: 88 Nm
- Outer Tie Rod: 54 Nm
- Control arm ball joint castle nut: 64-74 Nm
- Control arm to body: 93 Nm
- Stabilizer Link: To shock absorber 29 Nm; to stabilizer bar 38 Nm
- Fuel Pump Amperage: Priming 270 mV (2.7A); Idle KOEO 15-20 mV (.15 - .20A)
- Brake Bleeder Nipple: Fr Disc 8.5 Nm; Rr Drum 6.9 Nm
- Front Brake Banjo Bolt: 34 Nm
- Front Brake Slider Pin Bolt: 23 Nm; Brake Hose Mounting Bolt: 22 Nm
-Front Brake Caliper Carrier to Knuckle: 108 Nm
