Moderators: Ryan Steele , sh00t , r12qiSonH4ji , avantgardebronze , akbarfit
Posts: 26934 Joined: Sat Jan 31, 2009 17:48
Post
by DOHC » Sat Oct 16, 2021 9:00
Kita orang mala mo lepas neh
Itu tekiro 2 biji bkin sepet mata aj, kita orang lepas la 2 biji itu sapeceng aj
Ad yg mau ga ya
Posts: 11332 Joined: Tue Apr 08, 2008 10:12
Post
by Omnibus » Sat Oct 16, 2021 9:07
DOHC wrote: ↑ Sat Oct 16, 2021 9:00
Ad yg mau ga ya
ktc socket set ik ini sebenernya udah jarang banget kepake. kan sayang mending dilepas aja.
tapiiiiii ........ coba tengok mata socketnya.
12-pt mbah. kl ga punya n pas ketemu kepala baut 12-pt bisa nangis bombay.
*yg size 12 kebawah 6-pt
Posts: 11035 Joined: Wed Oct 16, 2013 6:27
Post
by marmut » Sat Oct 16, 2021 9:32
Omnibus wrote: ↑ Sat Oct 16, 2021 8:51
- socket 1/2" 19mm
- u-joint 1/2"
- extension 1/2" 50cm
- extension 1/2" 25cm (atau total 3x extension 25cm)
- tw 1/2"
sepertinya beda mbah...
yang tadi ada 3 point pengiketnya, pake baut kunci 14mm.
yang pinggir, posisinya agak keluar dan walopun saya belum ngintip, tapi sepertinya agak susah kalo dari atas.
Post
by marmut » Sat Oct 16, 2021 9:34
Omnibus wrote: ↑ Sat Oct 16, 2021 9:07
bihex socketnya simpen, gagang treleknya jual...
Post
by DOHC » Sat Oct 16, 2021 9:39
Ad yg mau ga ya
Mbah
Ini set K T C brapa dekade lalu beli nya ??
Njirrrr
Kl yg djual skrg punya itu " cuman" utk level mechanic use loh
Jgn d jual mbah, ud rare item loh ini
Post
by Omnibus » Sat Oct 16, 2021 9:44
marmut wrote: ↑ Sat Oct 16, 2021 9:34
trus kotaknya ompong2 gitu banyak ga keisi? bisa ga tidur 367 hari setaun saya.
Post
by Omnibus » Sat Oct 16, 2021 9:48
DOHC wrote: ↑ Sat Oct 16, 2021 9:39
Ad yg mau ga ya
Mbah
Njirrrr
circa 2002 beli baru dr ko ahwa yg sy ceritain
tahan karat, bagus bgt tuh barang
Profith83
Posts: 4588 Joined: Mon Jul 14, 2008 2:54
Post
by Profith83 » Sat Oct 16, 2021 10:01
KTC dr dulu gak play play yah. Padahal dah puluhan tahun masih bagus
Ini 3/8 dulu tapi sekuat 1/2 sekarang kekar 2x. Sekarang 3/8 gak sekuat jaman jadul ini sptnya
Post
by Omnibus » Sat Oct 16, 2021 10:17
Profith83 wrote: ↑ Sat Oct 16, 2021 10:01
ini bukan 3/8, tapi ini 1/2 mbah
itu mata socket gede2 gitu mbah, sampe maksimal nomor 32. ga ada 3/8 yg set nya sampai segede gitu.
Post
by Omnibus » Sat Oct 16, 2021 10:31
jadi ceritanya mbah profith bikin sy penasaran cobain buka kepala ratchet ktc. penasaran krn ada tanda titik di kepala sekrupnya apakah itu artinya sekrup di threadlock dr pabrik. emang iya sih ga bisa dibuka dgn mudah alias hrs dipaksa jd ane ga jadi, akhirnya dikencengin lagi. no thanks, cukup sekali ngerusakin koken jangan sampai ktc juga rusak.
searching2 gugling2, nah ternyata itu tanda titik di kepala sekrup artinya bukan itu tp artinya itu sekrup JIS (japan industrial standard) dan hrs pakai jis bits. kl pakai philips bits konon bisa slek. just sharing info aja, akhirnya ik tau artinya. pantesan tanda itu adanya cuma di ratchet jepang.
good news nya, ik yakin ktc n koken ik itu asli jepun he he
source: gugel
yanuarra
Posts: 3925 Joined: Sat Dec 28, 2019 9:55
Post
by yanuarra » Sat Oct 16, 2021 10:51
Omnibus wrote: ↑ Sat Oct 16, 2021 10:31
source: gugel
Kampretos makanya motor ane sering ganti sekrup... Ternyata krn ini toh...
Post
by Omnibus » Sat Oct 16, 2021 10:54
yanuarra wrote: ↑ Sat Oct 16, 2021 10:51
tiap negara pengen punya bentuk sekrup sendiri2.
dasar emang tuh
yanuarra
Post
by yanuarra » Sat Oct 16, 2021 11:00
Omnibus wrote: ↑ Sat Oct 16, 2021 10:54
dasar emang tuh
Ane iseng search obeng jis.. keluarlah jakemi paling atas...
Pantesan kok paling enak tuh obeng jakemi klo pas bongpas sekrup motor.... Tp sayangnya skrg gagang obengnya rusak... Dlu dpt suvenir pas turing yaris ke bandung. Jd ane kudu beli lg nih kayaknya
Yg punya ane engga sebagus yg ini sih
Itu dia obeng plusnya ada kode "J"
Profith83
Post
by Profith83 » Sat Oct 16, 2021 11:03
Omnibus wrote: ↑ Sat Oct 16, 2021 10:17
oh saya lihatnya be3 di extention, kalau sekarang be3 kode untuk 3/8. Jadi saya tebak 1 set 3/8
Profith83
Post
by Profith83 » Sat Oct 16, 2021 11:04
yanuarra wrote: ↑ Sat Oct 16, 2021 11:00
dasar emang tuh
cari bits nya aja, drpd beli obengnya.
Post
by Omnibus » Sat Oct 16, 2021 11:07
tapi ga ada J2 mbah, pdhl itu yg paling diperluin paling umum.
ngapain beli 1 set gitu, cari aja ketengan J2 doang (sama J1 kl perlu.)
Post
by Omnibus » Sat Oct 16, 2021 11:09
Profith83 wrote: ↑ Sat Oct 16, 2021 11:03
tulisannya BE30 mbah. sy justru ga tau kl BE3 itu artinya 3/8 maklum ga punya ktc 3/8 punyanya koken 3/8.
Poporing
Posts: 625 Joined: Sun Jun 14, 2020 6:46
Daily Vehicle: honda
Post
by Poporing » Sat Oct 16, 2021 11:13
dasar emang tuh
Atau beli obeng ktc/vessel/tamiya.. lol
Hampir bisa dipastikan itu JIS
Dulu2 ane googling pake keyword jis obeng, keluarnya jakemy ama tekiro -__-
Akhirnya beli dr ebay jp obeng tamiya
Vessel jg jis sih.. byk di toped...
Post
by DOHC » Sat Oct 16, 2021 11:17
Omnibus wrote: ↑ Sat Oct 16, 2021 9:48
Mbah
Njirrrr
Ahh sudah kuduga, pasti taon lama
Simpen bae2 mbah , buat anak cucu
Jd nanti bsa critain kl the real nihon tools tu kaya gini
Bahkan ktc ktc skrg aj ga skuat yg mbah punya loh
#btw, nanti kl maling in ruma mbah, kira2 tau d apa yg mo diincer dl
Poporing
Post
by Poporing » Sat Oct 16, 2021 11:35
Ad yg mau ga ya
Tjakep... bentuk gagang ratchetnya...
Post
by Omnibus » Sat Oct 16, 2021 11:43
DOHC wrote: ↑ Sat Oct 16, 2021 11:17
ambil lakoni sm kerisbowo mbah ...... wakakaka
eh tp kl martil ik msh akuin kerisbowo bagus.
Post
by Omnibus » Sat Oct 16, 2021 11:44
Poporing wrote: ↑ Sat Oct 16, 2021 11:35
Ad yg mau ga ya
sy malah lbh suka yg kaya mbah punya, bulet lbh enak dipegang. yg ini kayanya spesialis buat disambung pipa besi.
Post
by DOHC » Sat Oct 16, 2021 12:40
Omnibus wrote: ↑ Sat Oct 16, 2021 11:44
Lah justru nilai plus nya itu d model gagang itu mbah
Percis kaya snap on jaman dulu
Dan surprise2
Back in the days, Some of them indeed used steel pipe when necessary loh mbah
Btw ktc jaman skrg ud ga pake sekrup model JIS gt lg mbah, tp diganti malah pake sekrup besi baja asli
Malah si beta yg pake skrup model titik gt
yanuarra
Post
by yanuarra » Sat Oct 16, 2021 13:12
Neruga nyari bitnya aja
Post
by marmut » Sat Oct 16, 2021 13:14
yanuarra wrote: ↑ Sat Oct 16, 2021 13:12
priben kang.... sida tuku gagang trelek oglek panjang pendek beli?
