Moderators: Ryan Steele , sh00t , r12qiSonH4ji , avantgardebronze , akbarfit
Posts: 26934 Joined: Sat Jan 31, 2009 17:48
Post
by DOHC » Sun Aug 21, 2022 1:49
Omnibus wrote: ↑ Sun Aug 21, 2022 1:33
DOHC wrote: ↑ Sun Aug 21, 2022 1:09
Omnibus wrote: ↑ Sat Aug 20, 2022 17:25
buat mbah delko cocok nih yg suka under/over tighten busi
dan sbg penyuka sesama jen ... eh sesama ratchet
VIDEO
*btw denger noh ... 25Nm is the perfect torque
Malah jd salfok ngeliat trelek meleyot nya, namanya apa ya, jd pengen punya satu
Udeee mbah, bahkan ampe si 1KR-JZGTE aj ud ta hajar 25 newton
namanya bent ratchet kl ga salah. ini ada
linknya
Bgitu buka link nya
Lgs keselek biji duren
blloewy
Posts: 1924 Joined: Mon Nov 18, 2019 1:54
Daily Vehicle: HR15 - 2012
Post
by blloewy » Sun Aug 21, 2022 3:00
singachu wrote: ↑ Sun Aug 21, 2022 0:32
chrisha wrote: ↑ Sat Aug 20, 2022 7:30
Rekomen obeng minus dan plus dong,
Kecil dan besar, yg penting magnet e kenceng, hahahaha
Makasih om2 semuaaaa
vessel, ktc
atau wera cyclops
tone bit set jg ok kayaknya
regards,
singachu
Aduh ada yg sebut Vessel...
*bukanajakanmembeli
Posts: 11035 Joined: Wed Oct 16, 2013 6:27
Post
by marmut » Sun Aug 21, 2022 3:10
mbah, itu.... kena apa musti segitu panjang sih?
Posts: 11332 Joined: Tue Apr 08, 2008 10:12
Post
by Omnibus » Sun Aug 21, 2022 3:22
marmut wrote: ↑ Sun Aug 21, 2022 3:10
spy kl seandainya mur kendor sampai lepas (ga ada mur) itu engine ga terbang kemana2 meskipun lagi ajrut2an mobilnya.
*sotoy lagi .....
Post
by Omnibus » Sun Aug 21, 2022 3:25
yanuarra wrote: ↑ Sun Aug 21, 2022 1:49
Itu diapain mbah? Nubi tydak paham
di hack mbah. spy bisa malem2 mobil jd genset ac tanpa lampu luar menyala. kl skrg itu menyala krn switch lampu auto (ga ada off)
Post
by DOHC » Sun Aug 21, 2022 3:29
Omnibus wrote: ↑ Sun Aug 21, 2022 3:25
Kl cara asemregez musatek dtmf atep proyek senen, ntuh kabel ke lampu d putus, trus bypass narik stroom lgs dr accu, on off nya pake toggle switch cebanan
Post
by DOHC » Sun Aug 21, 2022 3:31
Accord siapa mbah tuh
Post
by Omnibus » Sun Aug 21, 2022 3:40
DOHC wrote: ↑ Sun Aug 21, 2022 3:29
dan ownernya seneng2 aja lagi pas baru kelaar. pikirnya berhasil. eh ga ampe seminggu mobil langsung jd lautan api.
Post
by marmut » Sun Aug 21, 2022 4:03
DOHC wrote: ↑ Sun Aug 21, 2022 3:31
bukannya jawap malah nanya.... owe nanya serius ini.
civic mbah, punya mbah
saturday
Post
by DOHC » Sun Aug 21, 2022 4:35
marmut wrote: ↑ Sun Aug 21, 2022 4:03
saturday
Honda ya, sudah kuduga
Kl jawapan sotoy kta orang seh ngikut mbah masas
Atau
Bsa jg biar kl mo d colong emon nya dr kolong agak susah karena musti muterin baut ama sekrup nya sgitu panjang
yanuarra
Posts: 3925 Joined: Sat Dec 28, 2019 9:55
Post
by yanuarra » Sun Aug 21, 2022 5:18
blloewy wrote: ↑ Sun Aug 21, 2022 3:00
vessel, ktc
atau wera cyclops
regards,
singachu
*bukanajakanmembeli
Wuih apa tuh mbah?
yanuarra
Post
by yanuarra » Sun Aug 21, 2022 5:19
Oalah.. untung mobil nubi ga perlu hack2an udah bisa bgtu
Post
by Omnibus » Sun Aug 21, 2022 6:56
DOHC wrote: ↑ Sun Aug 21, 2022 4:35
saturday
Atau
ngikut saiya? salah lah. mana bisa nahan engine tanpa mur, wong itu turun engine nya ke bawah
yg bener itu stud nya panjang utk sbg guide pas masukin mesin dr bawah ketika proses assembling di pabrik. panjang pendeknya disesuaikan dgn yg bagian sisi lain mobil. jd pas masup engine dr bawah, stud itu (dan stud2 di sisi lainnya) yg meng-guide supaya posisi engine nya center.
gentongxz
Posts: 733 Joined: Sat Sep 19, 2015 17:13
Post
by gentongxz » Sun Aug 21, 2022 7:47
Omnibus wrote: ↑ Sun Aug 21, 2022 6:56
Atau
..,perasaan pernah liat waktu oprek mesin lain..
,saya pernah dapat itu baut di buat kerucut.. untuk mempermudah pemasangan..,dan menjaga drat baut biar tidak lecet..
apa lagi mesin berat/cover yang berat dan posisi blin spot..,meraba2..
KMIIW
Post
by Omnibus » Sun Aug 21, 2022 7:49
gentongxz wrote: ↑ Sun Aug 21, 2022 7:47
Atau
KMIIW
naaaaaahhhh ..... blind spot ..... ntu dia pak
gentongxz
Post
by gentongxz » Sun Aug 21, 2022 8:03
foto baru barang lama..
Dat510
Posts: 787 Joined: Sat Jan 03, 2015 12:58
Post
by Dat510 » Sun Aug 21, 2022 8:23
gentongxz wrote: ↑ Sun Aug 21, 2022 8:03
Gergaji nya keren mbah, kaya senjata gundam..
Post
by Omnibus » Sun Aug 21, 2022 9:11
ngomongin barang lama, tetiba ada kiriman gede banget gini ....
Post
by Omnibus » Sun Aug 21, 2022 9:13
isinya ...
Post
by Omnibus » Sun Aug 21, 2022 9:18
meskipun rada mihil utk ukuran barang NOS, tp harga segitu cuma ongkir doang kl beli ginian di mamajon
komplitnya sih no play2 nih .... sendal ai yg ukuran 46 kaga ada apa2nya
pompa nya msh bagus meski ada karat2 dikit batangnya, piston nya n seal msh oke bgt krn ada silicone grease nya, bisa dibuka dalemnya.
adaptor yg dr besi pada karat2 juga. thermometer manual wkwkwk msh baru bebas karat, msh plastikan.
worth it ga?
gentongxz
Post
by gentongxz » Sun Aug 21, 2022 9:35
Omnibus wrote: ↑ Sun Aug 21, 2022 9:13
isinya ...
..,di praktein.. mbah... biar tau cara pakainya...
termometernya cocok neh untuk cek air kopi itam 90ºc
Post
by Omnibus » Sun Aug 21, 2022 9:43
gentongxz wrote: ↑ Sun Aug 21, 2022 9:35
isinya ...
xixixi salah2 malah bikin radiator bener malah jd bocor
iya bener, thermo kayanya buat bikin kopi aja lah hehe
gentongxz
Post
by gentongxz » Sun Aug 21, 2022 9:46
Omnibus wrote: ↑ Sun Aug 21, 2022 9:43
isinya ...
..lama2 berkarat semua thu tutup besinya mbah..olesin penetrant aja + masukin plastik kecil2..
yanuarra
Post
by yanuarra » Sun Aug 21, 2022 10:08
Omnibus wrote: ↑ Sun Aug 21, 2022 9:18
worth it ga?
PM link
Post
by Omnibus » Sun Aug 21, 2022 10:09
gentongxz wrote: ↑ Sun Aug 21, 2022 9:46
iya pak, ide bagus.
mau sy rendem di cairan anti karat tp nanti jd ga mengkilat lagi ga ya?
