Yamaha kita ada keluar ini gak?
bis keren juga sich
btw sorry kalo gede banget gambarnya
ini speknya
General information
Model: Yamaha YBR 125
Year: 2005
Category: Naked bike
Engine and transmission
Displacement: 125.00 ccm (7.63 cubic inches)
Engine type: Single cylinder
Stroke: 4
Power: 10.00 HP (7.3 kW)) @ 8 RPM
Torque: 10.00 Nm (1.0 kgf-m or 7.4 ft.lbs) @ 6 RPM
Compression: 10.0:1
Bore x stroke: 54.0 x 54.0 mm (2.1 x 2.1 inches)
Fuel system: Carburettor. Mikuni VM22SH/1
Fuel control: SOHC
Ignition: Electronic
Cooling system: Air
Gearbox: 5-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 106.0 kg (233.7 pounds)
Seat height: 780 mm (30.7 inches) If adjustable, lowest setting.
Chassis and dimensions
Front tyre dimensions: 2.75-18 42P
Rear tyre dimensions: 90/90-18M/C 57P
Front brakes: Single disc
Front brakes diameter: 245 mm (9.6 inches)
Rear brakes: Expanding brake (drum brake)
Rear brakes diameter: 130 mm (5.1 inches)
Speed and acceleration
Top speed: 100.0 km/h (62.1 mph)
Power/weight ratio: 0.0943 HP/kg
Other specifications
Fuel capacity: 12.00 litres (3.17 gallons)
Fuel consumption pr. 10 km (6.2 miles): 2.50 litres (0.66 gallons)
General information
Year: 2005
Stroke: 4
Compression: 10.0:1
Fuel control: SOHC
Cooling system: Air
Gearbox: 5-speed
Transmission type
final drive: Chain
Physical measures
pernah kok disini
http://www.serayamotor.com/diskusi/viewtopic.php?t=3512
klik disini utk lihat infonya
di link itu Fazer 125 lho ya.crayon wrote:jadi apa bedanya Fazer sama YBR Bro Yoyoyo?
Fazer 125 adalah kakak Gladiator 125.
Dari sejak Fazer, blok mesin 11-12 dng YBR, tapi ternyata Fazer masih 4speed. Kemudian Gladiator dapet revisi jadi 5speed. Gladiator sangat mungkin versi india nya YBR (Body beda, mesin 11-12)
Kalau Fazer 250 sih beda lagi
coba search deh di arsip..
are you sure bro? take a look againp4nd4 wrote:bagusan juga gladiator sama-sama 125 cc yang baru di produksi di India
Mnrt gw sih, lebih cute YBR , desain body Fazer125 terlalu baplang, lampu blkg nya juga.
Klo YBR lebih clean gitu
