DRIFTING TUTORIAL...
Hai' DoZo YoRoShiKu... pake' LSD, Low gear+high rev... kalo matic? hmmm sejauh ini aq ga' pernah nyuba' ya... kalo punya power tinggi bisa kale'... apalagi triptonic, tapi ada kekurangannya, ga' bsa cluth kick, khehehe...
"TuRn YouR StEeR RiGhT To gOiN LeFt"
need some DriFtiNg TuToRiAL ?
http://www.serayamotor.com/diskusi/view ... 39&start=0
My DriFtiNg ViDeO (uPdAtE)
http://www.serayamotor.com/diskusi/view ... &start=220
seandainya saat kita drift terus gearnya shift sendiri bahaya banget kan? kalu shift sendiri berarti mobil bisa hilang kendali tuch
learn about LSD
http://www.serayamotor.com/diskusi/viewtopic.php?t=5520
limiter di ECU CVT nya di-disable bisa gak ya?
MOD akan SEGERA menuju lokasi dan mengusut masalah
wah, susah juga ya kalo matic
- Daily Vehicle: Mitsubishi Man
apakah nge-D-in matic musti pake teknik 4WD? feint? sebangsa weight transfer?
minta fotonya dong
BURNOUTS
This is the stuff that legends, and tire-smoke, are made of. A burnout, as you may well know, is a car being stationary or near stationary whilst the drive-wheels are spinning at a speed considerably greater than the rest of the car. This produces large amounts of heat, large amounts of tire-wear, large amounts of smoke, and large amounts of cheering from passers-by. Unfortunately it also produces excessive noise and dangerous driving charges. Oh well.
Rear Wheel Drive
The classic burnout: A rear wheel drive V8 with both back tires smoking heavily on the spot...god it's nice to watch...and you don't need a V8. For an auto, put the transmission into L or 1, and have your power/economy switch to power. If you have air-con, turn it off. The basic auto technique is to apply pressure to the brake pedal with your left foot, then suddenly slam your accelerator to the floor with your right foot. With any luck, the car should remain still and the back wheels should liberate themselves, and at least one of them should start spinning. If this doesn't happen, back off the brake pedal a bit, you may be pushing too hard. If it doesn't work then, stop. Get out and pop the hood, and check if your throttle cable is extending fully. It's the thing that comes out when you press the accelerator down. If it is, then you're at the end of your tether, except for one last little trick: Get a pair of vice grips, and find your brake lines leading to your rear wheels. First, locate the master cylinder, and follow the pipes. When you DO find them, clamp the vice grips on the line nice and hard so as to restrict the flow of brake fluid. This will effectively put the back brakes temporarily out of action. Go and start your routine again, and if it still doesn't work, well, sell your (carbureted Toyota tercel ) and buy a real car.
Front Wheel Drive
FWD burnouts are simply a matter of reefing on the handbrake as hard as you can, getting every available kW of power to the front wheels and dropping the clutch/flooring the accelerator. The main difference between FWD and RWD burnouts is that non-use of the brake pedal. The handbrake should be sufficient to hold the car if it is a powerful car IE CRX or 3.5 litre Magna but anything less than that should attempt this burnout either with the front wheels in some sort of wet patch on the road, or with the back wheels "chocked". This means you have to get something to hold the back wheels still, a speed bump which is preferable, or if needs be, simply do the burnout on a roundabout and chock the wheels with the edge of the roundabout kerb. Oh, and if you're in the USA and you don't know what a roundabout is, it's a round thing that you give way to everyone on your right to drive around that's sometimes used instead of stop signs.
Now the manual technique. Nearly any rear-wheel drive car should be able to hold a static burnout with at least one wheel if it has manual transmission and a decent clutch. Put the heel of your right foot on the brake pedal, and lean the top of your foot over so that it's on the accelerator. Put the clutch in with your left foot, and push down on the accelerator and the brake at the same time. Rev the engine to about 5,000 rpm and then drop the clutch with your left foot, whilst flooring the accelerator. This should break the back wheels loose. You'll have to back off the accelerator fairly quickly to avoid redlining. Hold it at about 4/5000rpm for premium torque. Congratulations, you're now doing a burnout! You've just attracted the attention of every conservative and every revhead in the nearest 400 metres..now leave the scene before the law arrives. And make with the leaving already.
Rear Wheel Drive
Front Wheel Drive
learn about LSD
burnout yah? nice post
kalo udah spin sekarang waktunya doughnut donk wakakaka
learn about LSD
hehehe gapapalah perlihatkan kemampuan anak UPH. biar si keiichi tsuchiya datang nyariin. taunya ntar msyuk formula D
learn about LSD
nyoba di helipad? nyusahin asuransi kali selama belon dapet kunci
sayang mobil gua automatic ntar tranny-nya rusak dan itu mahal.
learn about LSD
pake CIty VTEC dia, kalo di tol liat Jazz ngejar2 CIty, udah pasti kita orang lagi 'main', houhouhou
sekarang sih udah gak lagi, belakangan di jam2 pulang mobil makin lama makin banyak, gak bisa kebut2an lagi neh, mo gak mo jadi pemakai jalan yg baik deh, hehehe
