New Bebek Honda bernama Cefira / Revo ?
riofhaloho
Post by riofhaloho »
123stu wrote:CBR 125 kan yg (katanya) bakal masuk di Indo?
SOHC, menurut Bro bisa diandalkan gak spek mesinnya ini? :?
kl SOHC sih, nasibnya ama aja spt Vixion...!
CBR 125 gak ada perbedaan yg mencolok kecuali body doank mirip CBR 150...
gak deng, kerenan dikit dibanding CBR 150...
tp ttp aja, performanya malah gak sebagus Vixion..
mendingan gw rela2in make FU deh...!
kecuali harga secondnya CBR 125 ato Vixion udah jatuh bgt... br deh gw beli second-nya...
hehehehe... :D:P
123stu
Post by 123stu »
ha33x..
bisa aja bro...
nunggu jadi second mah ntar keburu muncul tuh sang Ninja 4 tak..
ntar bimbang lagi deh.... :wink: :e-dance:
novasonic
Post by novasonic »
Honda CBR 125 R 2007
General information
Model: Honda CBR125R
Year: 2007
Category: Sport
Rating: 66.4 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 124.70 ccm (7.61 cubic inches)
Engine type: Single cylinder
Stroke: 4
Power: 13.00 HP (9.5 kW)) @ 10000 RPM
Torque: 10.10 Nm (1.0 kgf-m or 7.4 ft.lbs) @ 8000 RPM
Compression: 11.0:1
Bore x stroke: 58.0 x 47.2 mm (2.3 x 1.9 inches)
Fuel system: Carburettor----> Injection kale??
Fuel control: SOHC
Ignition: Capacitor Discharge (CDI)
Starter: Electric
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
More details Consult a Honda repair manual.
Physical measures
Dry weight: 115.0 kg (253.5 pounds)
Seat height: 776 mm (30.6 inches) If adjustable, lowest setting.
Overall length: 1,920 mm (75.6 inches)
Ground clearance: 172 mm (6.8 inches)
Wheelbase: 1,294 mm (50.9 inches)
Chassis and dimensions
Front suspension: 31mm telescopic fork, 109mm axle travel
Rear suspension: Monoshock damper, 120mm axle travel
Front brakes: Double disc
Front brakes diameter: 276 mm (10.9 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Power/weight ratio: 0.1130 HP/kg
Other specifications
Fuel capacity: 10.00 litres (2.64 gallons)
Taken from: http://www.bikez.com
Hpnya gak lebih besar daripada Honda Sonic
Specifications
* Top Speed: 140km/h (estimate)
* 0-100km/h: 14.8 seconds
* Maximum RPM: 10,500
* HP: 13.5bhp
* Brakes: Disc brakes (front and back)
* Transmission: 5 speed manual
* Valves: 2
* Aspiration: Carburetor
* Fuel Tank: 4.2 Litres (Unleaded)
* Weight: 102.5Kgs (electric start model)
* Cooling: Liquid
* Fuel Consumption: 82 MPG
* Latest Model: 2005-2006 (Newest motorbike in Nova Sonic Family)
Taken from: Wikipedia
Berarti yang udah pernah pake Sonic, pasti tau tenaga CBR 125 R. Apalagi berat CBR 125 R lebih berat dikit daripada Sonic.
So, kalo dilihat dari data diatas..... yang pasti lebih powerful sonic lah.
123stu
Post by 123stu »
bro Novasonic dunk yang pernah make Sonic... he33x. :wink:
yaa... kalo kira2 hampir sama kyk sonic, mudah2n harganya murah dikit..(mungkin gak ya???)
hee3xx...
au ah...
harapan tipis nunggu motor idaman dari AHM... :roll:
novasonic
Post by novasonic »
Nih analisa gw (yg sok tau)......
harga sonic+Harga fairing+tangki (10 liter)=Rp (Max) 25 juta.
Kalo sonic menurut gw, untuk bebek dengan mesin 125 cc udah sangat2 top bgt dah...... (Meskipun masih diasepin ama Satria FU). Masalah speed no.2 setelah FU.
Tapi kalo ama MX n Kawasaki Kaze jangan ditanya deh........ (Kalo dilihat diatas kertas lohh...... Perkiraan hp, kompresi dsb). Koreksi yah kalo ada yang salah.........
Cuma kalo masalah harga n resale value.....hoek! bgt nih sonic. Punya gw cuma laku 11,5 jt (padahal belinya 21 jt).
123stu
Post by 123stu »
25 juta??
Tiger kelaut dunk he33x..
mending tiger yang polin aja speknya...
jadinya kyk dulu, Tiger motor paling keren dan mahal!!!
eksklusif deh sifatnya...
daripada main cc kecil...
Supra juga masih kuat kok megang pasar...
yah, apa karena BU ya bro makanya kalo mau jual lagi harganya jadi jatuh gitu?
tahun brp bro Novasonic nya?
novasonic
Post by novasonic »
123stu wrote:25 juta??
Yup gw setuju bro ama lo.......
Tiger with:
Engine upgrade
200 cc, water cooled, injection, compression 11:1, DOHC, 25 Hp @ 11.000 RPM, etc
Model Upgrade
Monoshock and hugger
dengan tiger upgrade seperti yg diatas, tanpa ngerubah body yang sekarang secara menyeluruh (paling ngerubah lampu depan, speedo digital dsb) harganya cuma nambah 3-4 jt. So harga yang paling masuk akal 25-27 jt. (Mimpi jadi petinggi AHM ahhhh.........).
Tul bro, gw BU tuhh, bosen pake sonic, trus kesengsem ama Pulsar (harga yang paling reasonable bagi gw karena gak nambah banyak2 heheheheheheehhe). :oops: :oops: :oops:
riofhaloho
123stu wrote:ha33x..
bisa aja bro...
nyantai aj bro...!
beli motor jg gak buru2 amat..
saat ini cocoknya nyantai bersila nyambi nyeruput segelas kopi nungguin motor2 baru yg cocok ama idaman doank...!
kl gak ada, ora opo2 cak..!
novasonic wrote:Cuma kalo masalah harga n resale value.....hoek! bgt nih sonic. Punya gw cuma laku 11,5 jt (padahal belinya 21 jt).
dulu gw sempet mo beli Sonic lho bro, habis ditaon 2004 si FU lama bgt indent-nya...
btw, jatuh bgt tuh harga second-nya sonic... :(
123stu
Post by 123stu »
hii333xx.. :lol:
duh...
AHM piye to...
mudah2n motor sport nya gak buat kecewa deh...
Gile...
kalo spek Tiger kyk gitu, bener2 keren tuh Tiger bro...
ha33xx. jadi deh AHM kyk dulu...
Rajanya 4 tak!!!
gak kyk sekarang... jadi pecundang...
:e-dance: :e-dance: :e-dance:
Yang penting Pulsar nya bikin puas deh...
biar gak kecewa lagi buat bro novasonic.. :wink:
novasonic
Post by novasonic »
@stu123
Iya nih bro, moga2 ajah puas....... hehehehehe......
