MItsubsishi Delica D5
Re: MItsubsishi Delica D5
Knob ac nya sangat khas PJS..
wait a minit, this car hv paddle pop? eh paddle shift
bukannya cuma di Pjs itu knob ac
ada juga di =
-serena C24
-OOtlander asli
-OOTlander spot
-Crv RD3
-DLL
knob elektrik....kastanya ditengah2 diantara ac digital n knop komfoor gasse
ada juga di =
-serena C24
-OOtlander asli
-OOTlander spot
-Crv RD3
-DLL
Pursuit of Perfection
Haha, itu knp pake nama ootlander asli segala? ada yg palsu ya? =P
bearti mira aja yg switch AC nya digital................................axala wrote:bukannya cuma di Pjs itu knob ac
ada juga di =
-serena C24
-OOtlander asli
-OOTlander spot
-Crv RD3
-DLL
Billyd1773dz
Billyd1773dz
yup ada paddleshiftnya.......................NYoman wrote:Knob ac nya sangat khas PJS..
powertrain n drivetrain mirip dgn outlander asli.......................
4B12 + jatco JF011E CVT with 6speed stepped paddleshift
yg diesel jg 4N14 kaya outlander asli................ tp mivec nya di sunat
Billyd1773dz
Billyd1773dz
akan terlalu mahal. sulit lakunya.
target nya KTB, terjual brp ?
trit bahela... bangkit lagi
gak ada yg bahas nih, padahal udah ramai buka harga Rp.409 jt
mivec 2.0
spec udah bertebaran
mivec 2.0
- Daily Vehicle: 2007 Toyota NCP93R-BEMGKD
Kalau lihat2 di FJB sebelah sih harga DKI 409Juta, speknya:
Exterior :
- Large Visibility
- Wide Spread Injection Washer
- HID Head lamp With Active Cornering Light
- Unique Grill Design ‘’Macho Look Design’’
- High Ground Clearance 190mm
- Rear Camera
- Alloy Wheel 215/70 R16
- Side Body Protection
- Rear Combination Lamp
- Front Body Protection
- High Approach Angle & Departure Angle
Interior :
- Power Steering with Paddle Shift
- Keyless lgnition Switch
- Cruise Control
- Audio Support iPod, AM/FM, CD w/ Unique Center Panel, USB and Digital Quartz Clock
- Multi Information Display (MID) Colour LCD
- Audio Quick Gesture Operating Instruction
- Auto Air Conditioner (pengaturan AC sudah model digital)
- Captain seat Bucket (front) dengan Armrest, Seating Agrrangement, Luggage Capacity
- Electrical Sliding Door KOS (Keyless Operating Sestem)
Performa :
- Mesin 2000cc MIVEC
- RON 90
- Compression Ratio 10.5;1
- Max Output : 150 PS (110 kW) / 6000 rpm
- Max Torque : 19.4 Kg.m (191 Nm) / 4200 rpm
- Auto Stop & Go
- Suspensi MacPherson Strut w/ coil spring (bagian depan)
- Suspensi Multy- Link w/ Coil Spring (bagian belakang)
- Transmisi CVT INVECS III 6 Speed
- ABS dan EBD+BA
- Radius putar 5.7 M
- Fuel Tank 66L
Keamanan :
- High tensile Steel Panel & Anti Corrosion (Rib Bone Frame /Rise Body dari bahan baja terbaik yg aman untuk melindungi penumpang di dalamnya)
- Front Seatbelt Pretensioner (sistem sabuk keselamatan yg bekerja sama dengan Air Bags dan headrest untuk menurunkan resiko yg dapat timbul akibat tabrakan frontal)
- Impact Absorbing mecaniscm (posisi stir yg akan masuk kedalam dan posisi pedal rem dan gas akan patah kedalam sehingga pengemudi terhindar dari himpitan pedal gas dan rem serta benturan dada)
- Dual Airbags & Knee Air Bag
- Hill Start Assit (HSA)
- Active Stability Control (ASC)
- Immobilizer
- Keyless Operating System (KOS) & Keyless Entry.
Ada beberapa penampakan di indo dari http://www.jualo.com/id/jawa-timur/sura ... -delica-d5
Sayangnya yg 4x4 dan triple Sunroof ga dimasukkan..
Exterior :
- Large Visibility
- Rear Camera
Interior :
- Cruise Control
Performa :
- RON 90
- Auto Stop & Go
- ABS dan EBD+BA
- Fuel Tank 66L
Keamanan :
- Immobilizer
2013 Toyota ZRR70R-APEXPD
oo itu nanti, 1-2 tahun ke depan.. delica dakar...azu wrote: Sayangnya yg 4x4 dan triple Sunroof ga dimasukkan..
Untuk sekaliber MPV Bannya gede juga yah 215/70/16
Kalo 409 jt berarti diposisikan melawan trio serena-biante-nav1 ya? Metkeeeeet! Bikinin liga nya dooong...
"The Power of ren-Dreams"
Kalau lihat spek yg hanya minta RON 90, berarti bisa ya kepaksa minum premium
Kalau pesaingnya seperti Biante, Serena, dan NAV1 kan udh GDI semua jadi ga bisa minum premium..
Saya kira bakal masuk yg triple sunroof seperti saat IIMS 2011 dulu, kan bagus setiap row dapet 1 sunroof
Semoga om kopat sekalian juga dengan mesin diesel dan bensin yg 2.4lmaskopat wrote:oo itu nanti, 1-2 tahun ke depan.. delica dakar...azu wrote: Sayangnya yg 4x4 dan triple Sunroof ga dimasukkan..
Karena Delica ini crossover antara MPV dan SUV makanya ada yg 4WD, jadi ukuran bannya juga mengikuti sebesar SUVglendotan wrote:Untuk sekaliber MPV Bannya gede juga yah 215/70/16
mitsu sebenernya memposisikan delica ini masuk ke crossover SUMPV, sport utility multipurpose vehicle.glendotan wrote:Untuk sekaliber MPV Bannya gede juga yah 215/70/16
kalo di jepang dan rusia, dah dibawa nyemplung ke sungai dan medium off road
keren juga yah , cocok buat kondisi di Indonesia sebenernya.. selama ini kendala punya MPV hanyalah ground clearance yang minim, terjawab sudah oleh Delica ini, dan harusnya basis 4x4 kaki2nya cukup kuat kalo hanya buat jalan jelek.. Coba ada dieselnya... yummymaskopat wrote:mitsu sebenernya memposisikan delica ini masuk ke crossover SUMPV, sport utility multipurpose vehicle.glendotan wrote:Untuk sekaliber MPV Bannya gede juga yah 215/70/16
di jepang ada om. launching tahun lalu. pake 4N14 2.2L DID AWD. sayang yang dipasang di D5 belum MIVEC DID, kalo di outlander sudah MIVEC DID.glendotan wrote:keren juga yah , cocok buat kondisi di Indonesia sebenernya.. selama ini kendala punya MPV hanyalah ground clearance yang minim, terjawab sudah oleh Delica ini, dan harusnya basis 4x4 kaki2nya cukup kuat kalo hanya buat jalan jelek.. Coba ada dieselnya... yummymaskopat wrote:mitsu sebenernya memposisikan delica ini masuk ke crossover SUMPV, sport utility multipurpose vehicle.glendotan wrote:Untuk sekaliber MPV Bannya gede juga yah 215/70/16
Semoga KTB berniat memasukkannya ke Indo, kan masih jarang tuh MPV diesel kecuali si people carrier H1.
Model Delica ini mengingatkan L300 Sliding door jaman dulu...
saya pribadi blg model exteriornya jelek interiornya pun jelek
lampu belakang kyk mata robocop ya
kalau di liat2
kalau di liat2
Bodynya gambot tp mesinnya 2000cc?
Hmmm
Hmmm
Delica ini pastinya utk costumer yg "extra-ordinary". Karena bentuknya yg "out-of-the-box" & cross-over SUV. Mungkin bukan selera semua orang (banyak pendapat yg bilang kotak, jelek), tapi yg pasti menurut ane ini product yg unik..
Andaikan ada yg Diesel 4x4 bakal lebih mantab lagi.. Di JDM arahnya lebih ke Off-Road MPV, mostly utk keperluan Outdoor
アイドリング!!!
Hmmmmm
exterior kelihatan tangguh, tapi kotak jadul gitu... dan sepertiny bukan menjadi pilihan mayoritas segmen nya.. biasanya tampang itu penting.. kecuali toyota/ honda..
interior juga kotak2 spt itu... berasa outdated juga...
price tag segitu mgkn org pilih SUV or other MPV...
sepertinya bakal jarang liat di jalanan...
kalo si Navi denger2 mau ada perubahan di IIMS,, ada yg udah liat???
ooh my....mungkin cocok untuk cipaganti
- Daily Vehicle: CX-5 KF
di iims masih yg lama om, tapi ganti model udh confirm. di SC udh ada unit new modelnya.yudhisuwandono wrote:kalo si Navi denger2 mau ada perubahan di IIMS,, ada yg udah liat???
