Aki mobil yang dipakai
- Daily Vehicle: Innova diesel
Re: Aki mobil yang dipakai
Ngetest aki energizer, merk baru di aki. 630cca tipe 80d26l. Sebelumnya gs premium bertahan 3 tahun.
Btw aki baru ini, kalo hidup mesin, cek tegangan di colokan rokok cuman 13,6V kadang turun ke 13,4V dengan beban ac dan radio. Mobil tidak ada modifikasi. Kalau malam tetap di 13,4 V dengan beban lampu 130/100 watt. Normal kah? Atau perlu diservis alternatornya?
Lg coba aki incoe gold 80d26L sebelum pasang saya charge sendiri semaleman. d trid lama om sjamsul blgnya klo mo awet d charge dulu.
Ternyata butuh bbrp jam supaya full recharge
V engine enthusiast:
V6: VQ35DE{|}CVT
V8: 1UR-FSE{|}8AT
predecessor
V6: 2GR-FE{|}6AT
V6: VQ35DE{|}CVT
V8: 1UR-FSE{|}8AT
predecessor
V6: 2GR-FE{|}6AT
- Daily Vehicle: Diesel
Barusan ganti aki kuda diesel sy...GS premium lama bertahan 4tahun 11bulan...pas diganti blm mati total...cm mulai lemah..daripada tau2 koit
Ini saya rangkum dr channelnya ChrisFix. Coba check di terminal aki langsung Om. Sebab kl dr cig lighter ada voltage drop dibanding dr aki langsung. Case om 13.6V di cig lighter mungkin dpt 13.95V di terminal aki dlm keadaan under load. Kalo iya berarti charging ok.DrgFredysen wrote: ↑Wed Nov 06, 2019 5:48 Ngetest aki energizer, merk baru di aki. 630cca tipe 80d26l. Sebelumnya gs premium bertahan 3 tahun.
Battery Load Test
Static voltage min. 12.4V (normally 12.6V)
-- Release static potential by briefly turning on the front lights before performing test.
No-Load Test
Voltage Percent Charge
12.60V to 12.72V (100%)
12.45V (75%)
12.30V (50%)
12.15V (25%)
Readings obtained at 80°F (27°C)
In-rush cranking voltage min. 9.6V
Charging voltage 14.2-14.7V; 13.95V with all accessory loads on.
Negative voltage drop (-ve batt vs alternator casing; all accessories on) max. 0.1V @ 1500 rpm.
Positive voltage drop (+ve batt vs alternator B+; all accessories on) max. 0.3V @ 1500 rpm.
Thanks omnibus infonya lengkap x. Mantap.Omnibus wrote: ↑Wed Nov 06, 2019 6:56Ini saya rangkum dr channelnya ChrisFix. Coba check di terminal aki langsung Om. Sebab kl dr cig lighter ada voltage drop dibanding dr aki langsung. Case om 13.6V di cig lighter mungkin dpt 13.95V di terminal aki dlm keadaan under load. Kalo iya berarti charging ok.DrgFredysen wrote: ↑Wed Nov 06, 2019 5:48 Ngetest aki energizer, merk baru di aki. 630cca tipe 80d26l. Sebelumnya gs premium bertahan 3 tahun.
Battery Load Test
No-Load Test
12.45V (75%)
12.30V (50%)
12.15V (25%)
GNKI 2013 Bensin, pernah pake Delkor dari 2016 tp akhir 2019 drop.
Sekarang pake Koba 80D26L (70ah). Semoga awet.
- Daily Vehicle: [cencored]
Kok lama2 ya pengguna aki disini, setiap x beli aki (selalu basah), ga pernah tembus 2 tahun.
Ini tadi pagi mau berangkat kerja mobil Yasir ane ga bisa distarter, dicek ke tukang aki bilangnya sudah keok ga bisa disetrum lg.
Pakai Massiv XP NS60L terakhir pas beli tanggal 26 Januari 2018, ane jg laporan di trit ini, di halaman 29.
Rasanya ganti Masiv XP lg, harga 565.
Kira2 ritual apa yang bisa bikin awet ya? Ane diomongin penjualnya kalau mau awet abis diisi zuur, didiamkan dulu 1 hari baru besok dipasang. Apa bener begitu?
- Daily Vehicle: Delman
Ada pernah cek "rembes" listrik alias parasitic draw yang berlebih ndak om? Kalau di BeRes mungkin ada alatnya...kalau di service manual mobil owe, kalau average draw-nya >55mA maka dianggap ada yg bocor n mesti cek masing2 dari fuse...
Ga pernah sih om, cuma ritual 2 minggu sekali cek air aki aja.
Nah, itu misal ada kebocoran gitu bagaimana? Apa bisa diservis atau gimana?
Ini ternyata pas beli Masiv ada laporan disini tanggal 26 Januari 2018, 3 hari lg baru ultah ke-2, ternyata sudah keok duluan. Haha.
Ini ternyata beli Masiv XP lg, harga 565.
- Daily Vehicle: Toyota F653RM
Aki pake GS bawaan mobil dari baru. umur sudah 3 tahun lebih 4 bulan. masi oke. terakhir di cek Beres pas service rutin awal bulan ini, menurut mereka masi layak pakai.
padahal ngecek aki juga ga pernah. paling ya service rutin aja 6 bulanan itu.
Menurut SA yang melayani servis terakhir, karena perawatan bengkel mereka. Ya, saya iyain saja
Awet ini aki. Tapi dah siap2 catat semua nomer SnD dan ERA beres2 toyota sih.
Belum pernah ngalamin sih, tapi prakiraan saya mesti urut kabel. Kan tiap cabut satu fuse coba diliat apakah parasitic-nya turun. Misalkan pas cabut fuse audio, parasitic-nya turun....berarti mesti dicek kabel2 yg berhubungan dengan ntuh fuse. CMIIW.sintoni wrote: ↑Thu Jan 23, 2020 1:34
Btw owe baru tau ada aki merk masiv...haha...
Suka nemu deposit serbuk putih di kepala/tutup aki gak om?sintoni wrote: ↑Thu Jan 23, 2020 1:34Ga pernah sih om, cuma ritual 2 minggu sekali cek air aki aja.
Lha, masiv udah lama beredar om.josomba wrote: ↑Thu Jan 23, 2020 1:55Belum pernah ngalamin sih, tapi prakiraan saya mesti urut kabel. Kan tiap cabut satu fuse coba diliat apakah parasitic-nya turun. Misalkan pas cabut fuse audio, parasitic-nya turun....berarti mesti dicek kabel2 yg berhubungan dengan ntuh fuse. CMIIW.sintoni wrote: ↑Thu Jan 23, 2020 1:34
Makasih infonya om Josomba. Ini Masiv XP paling murah disini, kalau Ultra agak mahal.josomba wrote: ↑Thu Jan 23, 2020 1:55 Belum pernah ngalamin sih, tapi prakiraan saya mesti urut kabel. Kan tiap cabut satu fuse coba diliat apakah parasitic-nya turun. Misalkan pas cabut fuse audio, parasitic-nya turun....berarti mesti dicek kabel2 yg berhubungan dengan ntuh fuse. CMIIW.
Ini fotonya om, tapi ane curiga itu serbuk bs juga ketetes air aki pas lg top up kan?
Beli ini lg soalnya harga paling murah 565, GS Hybrid ane cek di S&D 710, GS premium di toko biasa 680, Yuasa jg segituan.
Fix overcharge.
Serbuk putih itu senyawa sulfat dari aki yg mendidih krn overcharge.
Servis alternatornya om.
- Daily Vehicle: Yamaha Jupiter Z
GS Premium di livina dari 17-10-2017, Alhamdulillah masih sehat. 1 minggu gak dihidupin masih greng starternya. Perawatan cuma cek air aki, kelistrikan masih standard, cuma ganti hu & nambah drl lamp. 1 lagi pesan dsri yang jual, setelah diisi air aki, diamkan aki minimal 24 jam baru dipasang
Sy juga pake ni merk. Gegara koit, ya udah ke toko sebelah punya AKI apa? Eh ditawarin INCOE.lemonadelovers wrote: ↑Wed Nov 06, 2019 6:06 Lg coba aki incoe gold 80d26L sebelum pasang saya charge sendiri semaleman. d trid lama om sjamsul blgnya klo mo awet d charge dulu.
loh koq , gue mau beli AKI (kakek) , ditawarin INCU (cucu)....
Kumaha ieu teh, ....
INCOE merk bagus kok Om, cuma agak susah nyarinya. Dilivina kawan 3 taun belum koityudhisuwandono wrote: ↑Thu Jan 23, 2020 7:58Sy juga pake ni merk. Gegara koit, ya udah ke toko sebelah punya AKI apa? Eh ditawarin INCOE.lemonadelovers wrote: ↑Wed Nov 06, 2019 6:06 Lg coba aki incoe gold 80d26L sebelum pasang saya charge sendiri semaleman. d trid lama om sjamsul blgnya klo mo awet d charge dulu.
- Daily Vehicle: G4EE MT 2011 + Hi Grade 1995 C223
Idem om, di saya, aki MF di mobil kia ane Rata2 2 thn aja. Kelistrikan extra cuma ampli monoblok buat sub. Merk pakai GS &sintoni wrote:Kok lama2 ya pengguna aki disini, setiap x beli aki (selalu basah), ga pernah tembus 2 tahun.
NS.
Aki bawaan pabrik made in Korea, lemah pas dah thn k 5.
Padahal capanya lebih kecil.. [emoji1787].
i am, a sleeper
Serbuk putih selain karena over charge ato ketetsan air zuur, biasanya krn pengaruh umur akinya om. Semakin berumur tingkat penguapan air aki semkin besar. Nah uap/air aki ini akan kluar dr lubang pernafasan yg ad d tutup aki. D atas tutup aki ad lubang kecil nah kluar dr situ.adityabp wrote: ↑Thu Jan 23, 2020 7:21Fix overcharge.
Apabila d perhatikan kadang2 d aki basah dr 6 lubang cm 1 ato 2 lubang yg bagian atasny tampak basah/berwarna hitam. Nah yg basah/warna hitam itu kondisi plat akinya sudah paling lemah d bandingkan dg lubang2 yg lainnya.
Aki d indo rata2 sekarang umurnya sekitar 2 tahun an utk merek kelas 1 macam delkor,amaron hilife, varta,gs astra, yuasa dll. Tp balik lg gmm pemakain, perawatan utk aki basah, dan HOKI...
Utk merk massiv xp rata2 pengalaman sy sekitar 10 bulan ampe 1 tahunan.
Cmiiw
Incoe grup astra jg, hanya beda pabrik dgn GS, saya pakai 80d26L 68A CCA490 klo mau yg lbh murah bisa pilih 65D26L 65A CCA433 harganya beda 250rb lumayan bgt cm selisih spek dikit harganya terpaut jauh. Tapi sebaliknya klo mau naik spek dan ruang mesin cukup naik ke 95d31L aja 80A CCA653 harga cm beda 100-150rbsupriyadi wrote: ↑Thu Jan 23, 2020 8:02INCOE merk bagus kok Om, cuma agak susah nyarinya. Dilivina kawan 3 taun belum koityudhisuwandono wrote: ↑Thu Jan 23, 2020 7:58Sy juga pake ni merk. Gegara koit, ya udah ke toko sebelah punya AKI apa? Eh ditawarin INCOE.lemonadelovers wrote: ↑Wed Nov 06, 2019 6:06 Lg coba aki incoe gold 80d26L sebelum pasang saya charge sendiri semaleman. d trid lama om sjamsul blgnya klo mo awet d charge dulu.
*data spec base on katalog produk d websitenya
V6: VQ35DE{|}CVT
V8: 1UR-FSE{|}8AT
predecessor
V6: 2GR-FE{|}6AT
V6: VQ35DE{|}CVT
V8: 1UR-FSE{|}8AT
predecessor
V6: 2GR-FE{|}6AT
apa ada yg pernah pakai FB (furukawa) produksi indonesia by jv fb-indombl? puas ga yg sdh pakai?
dulu sy pernah sampai 3thn krg dikit msh bagus, tp dptnya oem terpasang di mobil rakitan thailen. kl yg produksi dlm negri ga pernah. konon merk ini di jepunnya lbh populer drpd merk yg merajai di indo dm itu.
Kalo tegangan charging normal (13,7v), yg nguap cuma air (H2O) aja om.Jagonyaaki wrote: ↑Thu Jan 23, 2020 21:21
Cmiiw
Tapi kalo tegangannya lebih tinggi (overcharge), yg nguap bukan cuma air, tapi senyawa sulfatnya juga ikut nguap krn aki jadi mendidih.
Cek tegangan alternator setelah mobil dipake jalan utk memastikan.
Cb kl emang bener yg nguapnya cm H20.. begitu mesin nyala nyalain korek d atas lubang aki/tutup akinya.. liat hasilnya om.. sy pernah liat sendiri itu aki langsung meledakadityabp wrote: ↑Fri Jan 24, 2020 2:01Kalo tegangan charging normal (13,7v), yg nguap cuma air (H2O) aja om.Jagonyaaki wrote: ↑Thu Jan 23, 2020 21:21
Cmiiw
Cmiiw
Pengalaman sy d lapangan kualitas fb impor (thai or jepun) sama yg lokal bedanya jauhhhhh om.. yg lokal menang d harga aj yg lbh murah d banding yuasa & gs astra.Omnibus wrote: ↑Fri Jan 24, 2020 2:01 apa ada yg pernah pakai FB (furukawa) produksi indonesia by jv fb-indombl? puas ga yg sdh pakai?
