GNKI white 2013 simple modified only for fun and drive
Hanya ingin showoff gerobak diesel yg menemani saya sehari2. Kalau ada rekan sm yg ingin tesst drive dan mau review, silahkan saja
MESIN :
- Ecushop Monster max with SVC controller + dastek q+ with throttle module
- Turbo borgwarner, max boost : 2.5 bar
- injector stage 2 bosch
- Custom Intercooler kit by REV
- Water Methanol Injection Stage 2
- Custom camshaft ex only, made in thai
- EGR deletion kit made in thai
- Fuel Pressure regurator AEM
- Custom surge tank made in thai
- Fuel pump bosch
RESULT : 320HP/630NM
- zero to 100kmh in 6sec
- 402m in 14.58sec
- 201m in 8.91sec
interior :
- ecushop monster gauge
- real italian leader
- custom launch control button
- custom wmi on/off button
- WMI adjust gauge
- Shadow boost + egt gauge
- GIZMO electronik boost controller built in turbo timer
kaki2 :
- shock hotbits dt-1 + per hotbits merah adjustable height and hard/soft front and rear
- velg compomotive type te37sl
- ban bridgestone ar20 225/55/17
jarak ban depan ke fender : 2 jari sempit
jarak ban belakang ke fender : 3 jari lega
rem :
- motul dot 5.1
- rs pro brainded steel brake line
- kevlar merah brake pd
gearbox :
- standard automatic gearbox upgrade with transgo kit
- atf cooler
- fuel cooler
exhaust system
- downpipe kansai
- custom stainless steel pipe 2.5"
- custom muffer
- custom stainless steel muffler tip 3"
di majalah car and tuning guide edisi 492
jok kulit
kalau lebih ceper lagi mentok gardan
velg pake list putih
waktu dibuka ganti camshaft
engine bay :
engine bay habis ganti pipa intake ke turbo pake alumunium :
0-100kmh
201m time
402m time
MESIN :
- Fuel pump bosch
- 402m in 14.58sec
- 201m in 8.91sec
interior :
- WMI adjust gauge
kaki2 :
rem :
- motul dot 5.1
gearbox :
- atf cooler
- fuel cooler
exhaust system
- downpipe kansai
- custom muffer
jok kulit
engine bay :
0-100kmh
201m time
402m time
well it is, but who cares
Re: GNKI white 2013 simple modified only for fun and drive
Wddihhhhh sereemmm...... Btw mentok ga tuh dibawa ke proyek?
kagak lah, kan kalau jalanan gak bisa masuk yah ditinggal atuh, masa dibawwa masuky_anjasrana wrote:Wddihhhhh sereemmm...... Btw mentok ga tuh dibawa ke proyek?
Absen aja,gak mau baca,ngeri racunnya
beuhhh mantep bener,real sleeper ipah
kpn2 pngin td bole y om... hehehehe
Billyd1773dz
Billyd1773dz
dibacaa dong om bagornugroho bagor wrote:Absen aja,gak mau baca,ngeri racunnya
boleh kapan aja mau dateng kke jkt silahkan kt kopddar di PIK, enak disana buat test2 mobil, bisa langsung masuk tol. Ntar mau di finish balance dulu jg, kalau diatas 150kmh agak getar ban nyabillyd1773dz wrote:beuhhh mantep bener,real sleeper ipah
- Daily Vehicle: b48 1gd 4a9
Top speed nya berapa ini ?
topspeed sih sesanggupnya rpm limit aja om, dulu belum lepas limiter kena cut di rpm 4300 kira2 190kmh di speedo, kira2 25 detik udah kena limiter, itu di test aja quarter miles 14.58 detik sudah hampir di speed 150kmh, power sih over gak kepake semua di speed segitu, skrg udah lepas limiter dan pake ban diameter lbih besar, belum coba lagi rpm 4500 itu di speed brpwalid_007 wrote:Top speed nya berapa ini ?
Bersihnyaaa engine bay om tannis...! Hmm.. warna body dan bannya serasi beudd..!
Interior...saya suka..saya sukaa..! Bersih, minimalis, warna terang. Absolutely my type, om....
The powaah.... ungngng... nganuu... ituu... *eh.. nyali ane udah ciut duluaan...
Test Drive? 630nm on rear drive?
*booking tiket ke Jkt... trus ajak ke sentul... time to drift and eating corners for breakfast...*
Obey the mahakitteh.
Side turn lamp nya keren, mod..
*eh
#salahfokuslagi..
*eh
#salahfokuslagi..
thx u om vanz, emang saya sukanya simple, gak ssuka rame2.VanzMatic wrote:Bersihnyaaa engine bay om tannis...! Hmm.. warna body dan bannya serasi beudd..!
power? thats where the all the fun from this car
cannot lah, no LSD yet, sponsor dulu dong, yg buat innova cuman ada merk CUSCO, harga 18 jt, mahal bener euymadcat015 wrote:Test Drive? 630nm on rear drive?
18jt
mending swap axle pke hilux dunk uda ada lsdnya ? dan ratio 3.7 topspeed bisa naik lagi
tp pcd jadi 6x139 wkwkw
minggkii
18jt
ciappp cant waitthtannis wrote:boleh kapan aja mau dateng kke jkt silahkan kt kopddar di PIK, enak disana buat test2 mobil, bisa langsung masuk tol. Ntar mau di finish balance dulu jg, kalau diatas 150kmh agak getar ban nyabillyd1773dz wrote:beuhhh mantep bener,real sleeper ipah
minggkii
Billyd1773dz
Billyd1773dz
Less chromey ipah... i like...VanzMatic wrote:Side turn lamp nya keren, mod..
*eh
#salahfokuslagi..
Nah, seperti yang ane buktikan di Apanja 1.5S dan 1.3G generasi pertama, kebetulan semua MT, tuh kaleng2 bisa ane ajak drift... Seharusnya Ipah dengan bobot yang lebih berat dan enjin diesel dengan torsi badak bisa drift...
Apalagi dengan 630nm... beghhh... ganti ban slick, lemme dance on the tarmac...
*jangan lupa, siapkan ambulan dan mobil derek... kali aja kebalik...*
Anjir... 18jeteng...htannis wrote:cannot lah, no LSD yet, sponsor dulu dong, yg buat innova cuman ada merk CUSCO, harga 18 jt, mahal bener euymadcat015 wrote:Test Drive? 630nm on rear drive?
*ngitungin recehan dulu... serebu... dua rebu... tiga rebu...*
Mahal? Mang SX-4 nya ga jadi ditendang ke kali depan rumah mod? Lumayn lah bisa sponsorin, mod... Pan bisa tempel stiker sponsor MADCAT mech warrior di body mobil om tannis.....
*eh..
*eh..
Ga jadi... Nunggu CX-3 dulu..., kalau oke, baru ane tendang ke depan kali...VanzMatic wrote:Mahal? Mang SX-4 nya ga jadi ditendang ke kali depan rumah mod? Lumayn lah bisa sponsorin, mod... Pan bisa tempel stiker sponsor MADCAT mech warrior di body mobil om tannis.....
*eh..
Yes2... ide bagus om, kalo ada duid, ane sponsorin dah... seperti ini misalnya...
Ini kan gambar yg ente dulu nggak tahu itu mobil apaan, padahal jualan ente dulumadcat015 wrote:Ga jadi... Nunggu CX-3 dulu..., kalau oke, baru ane tendang ke depan kali...VanzMatic wrote:Mahal? Mang SX-4 nya ga jadi ditendang ke kali depan rumah mod? Lumayn lah bisa sponsorin, mod... Pan bisa tempel stiker sponsor MADCAT mech warrior di body mobil om tannis.....
*eh..
Gambarnya bagus, mobilnya yg kagakmadcat015 wrote:Ga jadi... Nunggu CX-3 dulu..., kalau oke, baru ane tendang ke depan kali...VanzMatic wrote:Mahal? Mang SX-4 nya ga jadi ditendang ke kali depan rumah mod? Lumayn lah bisa sponsorin, mod... Pan bisa tempel stiker sponsor MADCAT mech warrior di body mobil om tannis.....
*eh..
Bagusan corolla ya om...artoodetoo wrote:Gambarnya bagus, mobilnya yg kagakmadcat015 wrote:Ga jadi... Nunggu CX-3 dulu..., kalau oke, baru ane tendang ke depan kali...VanzMatic wrote:Mahal? Mang SX-4 nya ga jadi ditendang ke kali depan rumah mod? Lumayn lah bisa sponsorin, mod... Pan bisa tempel stiker sponsor MADCAT mech warrior di body mobil om tannis.....
*eh..
gak bisa juga, kalau bisa jutsru dah banyak innova mau ganti, untuk ratio 3.7 sih kurang, soalnya matic nya rationya dah segitu kan? kalau manualnya 3.9billyd1773dz wrote:^^
18jt
yah maksudnya kalau gak pake lsd, kan gak ada dorongan tenaga, paling bannya yg overspin, kl pake lsd baru cantik. Jangan lupa sponsor ban baru yakmadcat015 wrote:
Ga bener ini... juragan ban minta di sponsorin ban...
Buat jalan2 ke Bali ?madcat015 wrote:Ga bener ini... juragan ban minta di sponsorin ban...
