Spesifikasi Innova 1kd 500hp++ 1000nm++ daily use on biodiesel
LATEST DYNO RESULT : 533.9HP/1020NM BOOST 45 PSI
MY SIMPLE ENGINE BAY
Brembo brakes
NEW YOUTUBE VIDEO
prove of the FASTEST Innova 2kd D4D a/t only with WMI without NOS
http://m.youtube.com/watch?v=BUSER9umG-w
exhaust sound and black smoke
http://m.youtube.com/watch?v=m_u5g8VL3bs
old video
http://m.youtube.com/watch?v=hTudLc2PD4s
MESIN :
- 1KD 3050cc engine
- Turbo by Mitsubishi Heavy Industries (MHI) TE06h-24v
- BANGMODS external wastegate
- 3 Rotor commonrail pump already stroke up
- Nozzle edu3 denso 58psi
- Ecushop Monster max with SVC controller + dastek q+ with throttle module
- per klep BC crowler
- seal klep racing spec
- Custom camchaft from thailand
- Custom Intercooler kit by REV
- Water Methanol Injection Stage 2
- Intake custom bangmod
- Fuel Pressure regurator AEM
- Custom surge tank made in thai
- Fuel pump Walbro
interior :
- ecushop monster gauge
- real italian leader
- custom launch control button
- custom wmi on/off button
- WMI adjust gauge
- Shadow boost gauge + egt gauge
- GIZMO electronik boost controller built in turbo timer
kaki2 :
- shock hotbits dt-1 + per hotbits merah adjustable height and hard/soft front and rear
- velg compomotive type te37sl
- ban bridgestone ar20 225/55/17
rem depan :
- motul dot4 rbf
- rs pro brainded steel brake line
- Brembo 4 pot Big Brake Kit with 320mm rotor
- EBC yellow brake pad
rem belakang :
- standard
gearbox :
- standard automatic gearbox upgrade with transgo kit : HOTROD mode
- atf cooler
- fuel cooler
exhaust system
- equal lenght header bangmods
- modified KANSAI downpipe
- custom stainless steel front pipe 3"
- KANSAI freeflow muffler oem fit
- QTP cut off valve
di majalah car and tuning guide edisi 492 :
Foto2 lain :
Brembo brakes
NEW YOUTUBE VIDEO
old video
MESIN :
- 1KD 3050cc engine
- Fuel pump Walbro
interior :
- WMI adjust gauge
kaki2 :
rem depan :
- motul dot4 rbf
rem belakang :
- standard
gearbox :
- atf cooler
- fuel cooler
exhaust system
- QTP cut off valve
Foto2 lain :
well it is, but who cares
Re: Spesifikasi Innova 1kd 500hp++ 1000nm++ daily use on biodiesel
Cuma bisa bilang WOW.
Sent from my GT-N7100 using Tapatalk
Wow..... Amazing......, btw ini mobil kalo di tol bisa jebol spedo nya ya om, hehe
KEREEEN..
Om, kalo mobil udah di modif kayakgini, perawatan service mesin dll bagaimana?
Mobil std kan kalo kilometernya udah masuk masa service tinggal bawa ke beres atau bengkel umum.
Wah mobil greget nih,btw kalo mobil kenceng gini dibawa pelan ndut2an(brebet2) ga ya?
Thx u omecoy7 wrote:Cuma bisa bilang WOW.
Tetap ada limiter kena 192kmh speedo, power masih banyak sih ke 190kmh gak sampe 20 detik kalau dari diemery1973 wrote:Wow..... Amazing......, btw ini mobil kalo di tol bisa jebol spedo nya ya om, hehe
Service sendiri om saya ada mekanik sendiri kokSatya21 wrote:KEREEEN..
Gak ada masalah sih sama mesin dan ini matic, ndut2an karena dari transmisi dah setting bodyvalve ke hotrod jadi ganti gigi tanpa jeda cuman kl pelan yah 1 ke 2 nya ngehentak jadi kl pelan yah hentak pas 1 ke 2 aja, kl bejek pol kayak gak ganti gigi saling cepetnya gak brasaipat wrote:Wah mobil greget nih,btw kalo mobil kenceng gini dibawa pelan ndut2an(brebet2) ga ya?
HRD
Hauck Racing Development
- Daily Vehicle: TGN 41 - 2005 Kijang Innova 2700V AT
Salut om sama mobilnya , what an amazing car
As simple as possible to make it easier for you and everyone else
TGN 41 - 2005 Kijang Innova 2.7V A/T
Wow amazing......good job om... itu blok 1kd beli dmana n brp dc nya om?....tranny masih std jg?....
- Daily Vehicle: [cencored]
Mantap nih, mobil paling legendaris di SM.
Oh ya om, kalo best time untuk 0-60 atau 0-100 ada? Hehehe.
mantab spek nya om. bener2 sip.
mesinnya 1KD. mantabbb.
cm ada 1 yg menggelitik :
rem belakang :
- standard
rem belakang :
- standard
Wow ekren, udah ngalahin Hino aja nih tenaga n torsinya
Pertanyaan klise: apakah semua modip itu memenuhi ekspektasi kepuasan om htanis?hehehe
Apa mau di upgrade lagi?
Innova 1st gen yg paling gokil...
Ngeriiii.....
Update terakhir, a quarter mile tembus berapa Om?
dari semua paling terkesan tulisan "daily use on biodiesel"....
500 hp++ 1000nm++ using biodiesel, bye bye cummin, detroit and friends..
hail KD engine series
tinggal nunggu 800++ hp dan 1300++ Nm update nih...
abege yang pake scirocco knalpot berisik siap siap gigit jari ya diasepin
hormaaat grak. bener bener sleeeper abisss.
Ini mah bukan ipah lagi namanya. Tinggal casingnya doang yang ipah.hehe.
Enak ya punya bengkel sendiri.
- Daily Vehicle: Civic FD2
ama Yasir TRD Modcing yg stikernya bisa +600hp menang mana ya.....
2009 Honda Civic FD2
2015 Honda CR-V 2.4l A/T
Mantap koh
Total habis brp koh upgrade semuanya?
Ane jgn diasapin ya koh kl ktm dijalan ...........
Live as if you'll die today
Pengen... Biodiesel pula, maknyusss...
ngeriii.... Torsi segitu narik mobil yg beratnya 'cuma' segitu.
Por la Razon o la Fuerza
muaanttaappp.. pengen nyicipp
Billyd1773dz
Billyd1773dz
Nyicip mobilnya apa yg punya neh?billyd1773dz wrote:muaanttaappp.. pengen nyicipp
Kaburrrr............
