All New Mazda CX60 - RWD & Hybrid 320hp
darrelund
Post by darrelund »
Source : https://www.whatcar.com/news/2022-mazda ... ate/n24255
Having been designed and engineered completely from the ground up, the CX-60 will be looking to compete against rivals such as the Audi Q5, BMW X3 and Lexus NX. Lexus in particular will be in Mazda’s sights, largely because it’s the only other premium Japanese brand in Europe.
The styling of the new CX-60 alone is evidence of the company’s new direction. Up front, the CX-60 displays a tougher, bolder look with a wide stance and long bonnet. The grille, indicators and LED headlights are also much more tightly integrated compared with current models such as the CX-5.
Around the side, Mazda’s signature smooth bodylines are present bar some strongly sculpted wheel arches. On lower trims, these arches will be clad in black plastic to give a more rugged look, and on upper trims the arches will be body-coloured. Around the back, a pair of wide, high-mounted LED tail lights also add to the sense of toughness as seen on the front end.
It’s in the interior, however, where Mazda has placed a particular focus on luxury. We've had the opportunity to sit inside the new model, and can confirm the driver's seat is nicely supportive and the materials on display are of a high quality. Leather, metal and wooden trim pieces feature in the places you touch and see regularly, while even the plastics used lower down feel soft.
The layout of the dashboard is also refreshingly simple, with a large 12.3in touchscreen spanning the central dashboard – and this can also be controlled via the screen or a rotary dial on the centre console. The climate controls are also mounted within good reach of the driver and consist of multiple toggle switches.
A head-up display is also fitted as standard on all models to limit driver distraction, and there’s also a 12.3in digital dashboard, which can show you driving data as well as the sat-nav map.
The new CX-60 will feature Mazda’s latest Connect infotainment system, which includes a new ‘See-Through View’ 360-degree camera system. This gives the driver a much clearer view around the car when manoeuvring, with the screen giving the impression that you can see through the centre of the car for a full 360-degree view.
Getting comfortable in the CX-60 is very easy, and this is largely thanks to a new ‘Driver Personalisation System’. This uses technology that identifies the driver’s stature, and it adjusts the driving position (including the mirrors and steering wheel) to a recommended setting. The driver is then free to adjust the seating position to suit, and the system memorises the position for the next journey.
Under the bonnet, the new CX-60 will be available as a petrol, diesel and plug-in hybrid. A fully-electric version is also rumoured to be on the way, however this is yet to be confirmed. At launch, the car will be available as a 323bhp plug-in hybrid (PHEV). This set-up combines a 2.5-litre four-cylinder petrol engine with an electric motor and a 17.8kWh battery, propelling the CX-60 to 62mph in 5.8sec. Torque is also rated at 369lb ft.
Further down the line, the CX-60 will be available with two brand new engines – a 3.0-litre straight-six petrol and a 3.3-litre straight-six diesel. Both engines will use a 48v mild hybrid system, which means that at lower revs there’s some additional electric muscle to assist the engine. This should help to improve performance, fuel economy and emissions.
Mazda’s i-Activ four-wheel drive system will be fitted as standard on plug-in hybrid versions, but the system will prioritise rear-wheel drive to give you a more sporty driving feel. The petrol and diesel models will also be available with four-wheel drive. All models will be available with an eight-speed automatic gearbox.
yok bisa yok masukin dijel kesini, 700nm pasti sedapppp :big_biglaugh:
dan yg menarik steering adjustmentnya sudah elektrik
Pugman
Re: All New Mazda CX60 - RWD & Hybrid 320hp
Post by Pugman »
Cakep ini, interior minimalis
jamutono351
Daily Vehicle: Rush
Post by jamutono351 »
Masuk indo ga ini mazda cx 60?
FMEAKD
Post by FMEAKD »
jadi pake mesin Rotary ga ?
rajapb
Post by rajapb »
sayang ya mazda6 RWD di-cancelled, jadi platform RWD-nya dilanjut di mobil ini
alunx65
Post by alunx65 »
semoga bisa kebeli mobil kek gini dalam waktu deket (20-30 tahun lagi)
:big_blushing:
darrelund
Post by darrelund »
jamutono351 wrote: Sat Jun 18, 2022 9:42 Masuk indo ga ini mazda cx 60?
masuk om, antara akhir tahun ini atau 2023
darrelund
Post by darrelund »
rajapb wrote: Sat Jun 18, 2022 11:44 sayang ya mazda6 RWD di-cancelled, jadi platform RWD-nya dilanjut di mobil ini
ya gimana om, mau saingan sama accord camry dah susah.
duit cekak, fokus bikin suv ajah yg jelas cetak duit :big_biglaugh:
darrelund
Post by darrelund »
FMEAKD wrote: Sat Jun 18, 2022 11:21 jadi pake mesin Rotary ga ?
rotary lanjut jadi range extender di MX30 EV om
jamutono351
Daily Vehicle: Rush
darrelund wrote: Wed Jun 22, 2022 18:44
wah menarik nih, kalo rentan harga 700an boleh lah jadi whislist. tinggal atpm nya aja nih dibenerin jualannya huhu
alunx65 wrote: Wed Jun 22, 2022 6:45 semoga bisa kebeli mobil kek gini dalam waktu deket (20-30 tahun lagi)
:big_blushing:
Semoga bumi masih ada 20 - 30 taon lagi :big_grin:
vanosz
Post by vanosz »
KielConstantine wrote: Thu Jun 23, 2022 5:58
:big_blushing:
ane kan ada spk mobil,
di tanya perempuan di rumah kapan keluar tuh mobil,
ane bilang taun depan,
di jawab lagi emang masih idup,
btw,
ngopi pagi gans,
Venturtle
Post by Venturtle »
cakep mobilnya.. semoga segera masuk ke sini :big_love:
banagher
Post by banagher »
yg PHEV katanya konsumsi bbm nya bisa 1:40
udah kaya motor matic 150-160 cc
CX-50 aja lebih lebar dr CX-5 gmn ini
kendibocor
Post by kendibocor »
Uda ada info pastinya om? Mobil menarik, tp agak pesimis bisa masuk kalo blm ada info resminya. Menuhin indent unit lineup sekarang aja uda ngos2an. Kena komplain sana sini.
2022 KS Smartstream 1.5G MPi
2022 DM Skyactiv-G PE-VPS
2019 DJ Skyactiv-G P5 VPS
2016 F30 B48B20
darrelund
Post by darrelund »
kendibocor wrote: Sat Aug 06, 2022 22:29
klo untuk tanggal itu asumsi saya, karena australia akhir 2022 akan dapat, jadi perkiraan saya sih harusnya ga jauh dari situ. dan scara global produksinya dah dimulai dari maret kemarin
tapi sudah confirm CX60 & CX80 akan masuk indo
https://otomotif.kompas.com/read/2021/1 ... 1?page=all
darrelund
Post by darrelund »
banagher wrote: Sat Aug 06, 2022 16:07 yg PHEV katanya konsumsi bbm nya bisa 1:40
CX50 masuk kategori produk mazda widebody om, dan itu khusus US aja. CX60 masuk kategori produk narrow body, dan lebarnya masih mirip CX5
selain US dapatnya yg narrow body
guzh
Post by guzh »
Dari status WA salah satu sales di Mazda Sunter pas ambil CX5 ada beginian.
Entah bener apa ga, sekalian tanya price list nih.
Sapa tau bisa trade in, mayan hybrid tapi power 300+hp kayanya menggoda.
darrelund
Post by darrelund »
keluar full option mesin, buat saat ini
gasoline:
3.3 6cyl skyactiv-G + Turbo : 284ps/450nm
3.0 6cyl e-skyactiv-X (mild hybrid) + supercharged : TBA (EU only)
hybrid:
2.5 4cyl skyactiv-G + e-motor : 192 + 136 : 327ps/500nm (range ev 60km, 0-100 5.8s)
diesel (mild hybrid):
3.3 6cyl e-skyactiv-d turbo : 200ps - 19km/l (RWD)/ 254ps - 21km/l (AWD).
fuel cons tsb standar WLTC
transmission:
8 speed auto w/ electronic multi clutch (tanpa torque converter hydraulic)
akhirnya forced induction jg :big_biglaugh:
darrelund
Post by darrelund »
guzh wrote: Tue Oct 11, 2022 13:36 Dari status WA salah satu sales di Mazda Sunter pas ambil CX5 ada beginian.
klo lihat harga luar bisa 800-900jt ini.....
ya ttp lebi murah dibanding bangsa X3, GLC apalagi Q5 :big_biglaugh:
itu 3.0 skyactiv-X um?
darrelund
Post by darrelund »
silakan ditebak harga & mesinnya :big_biglaugh:
RWD
AWD
MHEV AWD
klo oe sih liat" suv masda yg laen
CX60 kykna bisa 800-1M
kendibocor
Yg trim 4x2 sama AWD harga mepet CX5 AWD. Si CX5 awd kan 705 jt. Bisa ga ya harga gpp deh 750an tp dpt mesin 6 cyl nya :big_biglaugh:
Feeling ane jgn2 jadinya antiklimaks dimasukin mesin 2.5 lg, liat harganya ga beda jauh sama CX5 awd :big_biglaugh:
2016 F30 B48B20
ExorT
Post by ExorT »
darrelund wrote: Mon Mar 13, 2023 13:54 silakan ditebak harga & mesinnya :big_biglaugh:
RWD
AWD
MHEV AWD
Kalau njkb sama dengan CX-5 AWD bisa tuh 700 kecil.
Dan untuk varian PHEV di 850-900.
darrelund
Post by darrelund »
kendibocor wrote: Mon Mar 13, 2023 14:08 Yg trim 4x2 sama AWD harga mepet CX5 AWD. Si CX5 awd kan 705 jt. Bisa ga ya harga gpp deh 750an tp dpt mesin 6 cyl nya :big_biglaugh:
naini ga tau um taktik duar nya eurokars gmn
di japan soalnya masi ada varian pke mesin 2.5 jadul, ada rwd/awd
diesel jg ada rwd/awd, ga yakin masup sini :big_biglaugh:
klo MHEV 6 cyl gasoline liat spek ozzies sih, 280hp/450nm
darrelund
Post by darrelund »
ExorT wrote: Mon Mar 13, 2023 14:23
PHEV itu awd only
dan klo MHEV di specify, harusnya PHEV jg
berarti ya kemungkinan PHEV ga masup
tapi yah lets see
