Nubie sempet baca-baca2 suatu artikel mengenai efek isi BBM full tank sampai ke bibir tanki di internet.
While it’s tempting to squeeze in as much gas as possible when you fill your tank, filling it past the pump’s first automatic shut-off can damage your car to the tune of hundreds of dollars. It can also adversely affect the environment and even risk your safety.
What can get damaged by overfilling your tank is the vehicle’s evaporative emissions control system. These systems have been in use for decades to control harmful emissions that occur when gasoline vaporizes, which it does quite readily. In any concentration, these vapors can be harmful to both the environment and anyone breathing them in.
Prior to having these systems, any gas vapors would collect at the top of the tank and fuel-filler neck, escaping either while you were driving (through the gas cap’s vent hole) or when you opened the gas cap to fill the tank. What the control system does is trap these vapors, then burn them in the engine along with the liquid gas.
Typically, the way this system works is by using a vacuum created by the engine to draw these vapors into a large canister filled with charcoal and, when the time is right, draw them into the engine to be burned.
These systems are only designed to work with vapors, not liquids. If you overfill your tank, it can cover the vapor intake hole with liquid gas, which can then be sucked into the charcoal canister. This can damage the canister and possibly other parts of the system, which will cause the car’s check-engine light to come on and could potentially cost hundreds of dollars to repair.
Adding to the concern of overfilling is that gasoline expands in volume by about 1% for every 15 degrees Fahrenheit, according to Consumer Reports. As it’s not uncommon for a day’s temperature range to vary by 30 degrees, that means that 15 gallons of gas put into a tank when it’s cool will expand by more than a quart when it warms up by 30 degrees. If the tank is overfilled, that could be enough to push gas into the charcoal canister’s feed line or force a leak, which is a major safety issue.
Overfilling: A Waste of Money
Because preventing gasoline vapors from escaping into the atmosphere is so important, a gas station’s fuel pumps are usually equipped with vapor recovery systems of their own to trap vapors generated as you’re filling your car with gas. That’s the reason for the large rubber collar or accordion-like tube on the pump handle that covers the opening of your filler neck while you’re filling your tank.
If you fill your tank past the first click, this system can suck in gas you just put in — and paid for — and could also damage the pump’s vapor control system. Overfilling can also cause gas to splash out, pouring a little more of your money onto the ground. This, however, is pocket change compared to the cost of the damage it could do to your car.
Menurut info di US mobil2 mulai tahun 1970 udh dilengkapi dengan evap ini karena faktor emisi. Yang nubi ingin tahu apakah mobil2 di indo juga dilengkapi dengan sistem evap seperti itu?
Dan apakah benar ada efek negatif evap charcoal canister karena didesain utk bekerja menangkap uap bbm, bukan bbm yang berwujud cair sehingga kalau kendaraan diisi full tank, menyebabkan si evap charcoal canister ini terendam bbm?
Sumber: https://www.cars.com/articles/what-happ ... as-442051/
Planned Obsolescence is inevitableluxury cars≠more reliable i.ibb.co/JckhCM5/20220918-013303-gif.gif
saya sih biasanya megang sendiri di spbu 31 dan selalu stop ketika sensornya berhenti. kebetulan pernah jd tukang isi bensin di negara lain dan memang dianjurkan seperti itu pas training, walaupun faktanya selalu di lapangan diisi sampe mau luber
daimler wrote: ↑Wed Sep 21, 2022 16:35
Dear all rekan2 SM
Biasa di bukman ada penjelasan mengenai refueling, ga ada spesifik dibilang rusakin vapor recovery.
Saya biasa sampe otomatis cetekkk aja juga. Haha
mbah, kalo saya perhatiin dari cetek sampai luber itu ada penambahan sekitar 30rb-an rupiah, jadi mungkin sekitar 2literan bensin ya selisih antara cetek sampe luber.
Di GV 2007 saya dulu sering sampe luber, terus bberapa bulan yg lalu sempat muncul bau bensin nyengat dalam kabin kalo isi sampe luber...
Sekali dua coba isi masih sama, muncul bau, trs pas bawa ke beres buat cek katanya dari canister sudah kena, walo belum parah, dibilangin akibat keseringan isi sampe luber...
Jadi skrg saya isi cukup cetek sekali baru genapin ke angka terdekatnya aja...
Ini case di mobil saya, gk tau kalo mobil lain...
vincewonk wrote: ↑Wed Sep 21, 2022 16:42
Nah dlu2 nubie isi full tank, ama petugasnya udh bunyi 'cetekk' pertama mungkin itu sensornya berhenti, masih dilanjutin ama petugasnya sampe bener2 full keliatan dr bibir tankinya. Dulu nubie ga ngerti juga jd didiemin nunggu petugasnya bilang 'full ya' sampe nyebut nominal yg tertera.
Iya sejauh ini di mobil ga ada problem apa2 yg berasa karena dulu2 pernah isi full tank. Petugasnya biasanya ngisiin lg dr bunyi cetekk pertama itu, sampe bener2 keliatan di ujung bibir tankinya
Selalu ngisi full sampai cetek kemudian tolong dibulatkan ke ribuan terdekat.
Ngisi sampai hampir luber itu modus memaksimalkan setiap rupiah supaya spbu untung.
Di sisi lain, mengisi sampai hampir luber membuat proses pengisian bbm jadi lebih lama, merugikan orang lain.
Kalau sampai luber resiko juga merusak cat.
MarYuko wrote: ↑Thu Sep 22, 2022 1:00
Brarti di GV sudah pakai evap canisternya ya
kendibocor wrote: ↑Thu Sep 22, 2022 1:59
Saya jg ngisi selalu sampe cetek pertama. Soalnya suka ngitung FC real brp.
Iya sepertinya yg aman ketika cetek pertama, kalo diisin petugas kasitau biar stop. Rata2 klo di spbu udh cetek pertama kalo nubi pas diem2 aja bakal ditambah lg
ilhami wrote: ↑Thu Sep 22, 2022 3:16
Brarti itu modus spbu ya kalo isi full tank, udah bunyi cetek pertama pun kalo kitanya diem2 aja bakal tetep diisi sampe hampir luber jd spbu lebih untung?
ijin sharing om,
kalo saya biasa isi bensin sampe switch otomatis pompa bensinnya bunyi cetek terus genapin nominalnya sampe bulet ini kalo isi full tank, atau kadang juga isi sesuai jumlah bar indikator yg kosong saja dikalikan literan perbarnya
Civic FD 2011 saya kabinnya bau bensin kalau isi bensin kepenuhan; dilebihkan sekitar 2 literan dari nozzle pertama kali klik.
Kalau ngisi bensinnya hanya sampai klik dilebihkan 1 literan sih tidak ada bau.
daimler wrote: ↑Thu Sep 22, 2022 4:27
Nah iya aman ga ya mbah kalo mobilnya ternyata udh pakai evap canister?
Oke mbah noted
mobil2 kaya ahond, mazdut brarti evap canisternya bisa kenapa2 ya kalo isi bbm full tank sampe hampir luber?
Ane ahond biasa ampe bibir sih. Biar meteran ga cepet turun. Wkwkwkwkwkw. Bete juga kadang baru pake sehari udah turun. Mayan 2 liter bisa 20-30km jalan.
Tp kalo sbenernya percuma (dan bahaya) abis ini sampe click aja deh.
oh no, saya SELALU isi semua boil ane sampe full mentok (tanpa pakai di goyang2) untuk cek full kons.
lucky sampe hari ini mobil ngga kenapa napa
suzuki ertiga
innova 2kd
toyota sienta.
bahkan sy pernah coba untuk innova 2kd itu dari solar keliatan di mulut tanki (busa sudah hilang) itu kalau sabar bisa masuk 15 liter asal sabar, akan turun pelan pelan. prosesnya bisa makan waktu 30 menit sampe benar2 full
Saya selalu isi bensin sampe full bibir tangki juga selama ini.
Apalagi kalo mobil diesel, anki 2gd isi dex abis dr klik masih bisa muat bnyk bgt karena berbusa jadi udh berenti. Mesti pelan2 isinya sambil nunggu busa ilang biar turun
well wrote: ↑Thu Sep 22, 2022 7:38
suzuki ertiga
innova 2kd
toyota sienta.
15 liter? Ngga salah Om? itu hampir 1/3 dari total kapasitas tangki
Saya di GNKI 2KD dari cetek sampe full mulut bibir tangki itu paling max jg 1 literan
2016 - Honda CRV 2.0 M/T
suzuki ertiga
innova 2kd
toyota sienta.
cobain di jalan miring waktu isi, dr mulut tanki dia akan turun perlahan perlahan banget. butuh waktu kira kira 30 menit untuk isi sampai benar benar full..
suzuki ertiga
innova 2kd
toyota sienta.
Tp masa iya sampe 15 liter Om? Banyak juga ya bisa masuknya. Berarti nambahnya sekitar 100rb itu dengan harga solar skg, mulai dr nozzle berhenti sampe bener2 full mulut bibir.
Saya sih ngga pernah coba di jalan miring yg gimana2 karena umumnya di SPBU yg biasa saya isi itu datar sih.
Berarti kalo isi sampe nozzle berhenti dan ngga dilanjut sampe bener2 mulut bibir itu jarum indikator nya ngga sampe F dong ya Om? Kalo di GNKI saya itu dr 3/4 sampe full mulut bibir biasanya sekitar 15 liter jg
sy juga udah lama selalu full tank sampe kira2 10-20cm dibawah bibir lubang pengisian, dari dulu pake calya, panther lalu skrg r3 diesel, ga pernah ada masalah.
kayaknya jarang banget denger evap canister jebol, malah sy umur hampir 40 baru tau ada benda ini di mobil. padahal praktek isi full sampe luber ini udah banyak banget dilakukan sejak puluhan tahun lalu.
apa mungkin mobil di indo jarang yg pake evap canister ini?
