Pertamax Green
Pertamax Green
Yak seperti yg sudah digembar gemborkan, launching jg pertamax 92 + ethanol 5%, pricing saat launching per hari ini (24 juli 2023) di 13.500/liter. Mepet sama shell vpower dan bp ultimate di 13.780 dan revvo 95 di harga 13.580/liter (harga jkt).
Ada tmn2 yg minat nyoba?
2022 KS Smartstream 1.5G MPi
2022 DM Skyactiv-G PE-VPS
2019 DJ Skyactiv-G P5 VPS
2016 F30 B48B20
2016 F30 B48B20
Re: Pertamax Green
Yg enginenya ud pada diremap boleh coba tu.. kali2 bisa jd kg usah pertabo mulu
Sheer Repairing Pleasure
Re: Pertamax Green
di sini Pertabo 14,700 jadi tutup mata tetep pertabo yang pasti RON98 aja
kecuali harganya sama kayak Pertamax skrg, which is ga mungkin
Re: Pertamax Green
saya coba search / googling
"side effect ethanol gasoline"
selanjutnya pilihan ada di tangan masing2
Re: Pertamax Green
Ethanol may contribute to corrosion of fuel tanks and other fuel system components at a rapid rate. It is very important to pour in a fuel additive that guards against corrosion every time you fill the tank; this is especially true with small engines since many still use aluminium parts which corrode more quickly resulting in oxides that look like white rust.Suryaputra wrote: ↑Mon Jul 24, 2023 14:44 saya coba search / googling
source: https://www.goldeagle.com/tips-tools/wh ... gainst-it/
EWG’s review has found that:
• A higher ethanol blend may damage nonroad engines and emission control systems.
• Emissions from higher ethanol fuels may worsen health risks from air pollution.
• Distribution of higher ethanol fuel blends may pose new safety risks and higher fuel costs.
• Higher-ethanol fuel blends may compromise lifetime performance of non-flex fuel vehicles.
source: https://www.ewg.org/sites/default/files ... -paper.pdf
ngeri-ngeri sedap
Re: Pertamax Green
Hasil google sih wajib diatas 10% baru bahaya...
Sama katanya ethanol lebih boros
Tunggu ethanol 10% deh baru bikin sayembara uji coba pertamax vs pertamax green
Re: Pertamax Green
iya mbahAbdulHakim wrote: ↑Mon Jul 24, 2023 14:56Ethanol may contribute to corrosion of fuel tanks and other fuel system components at a rapid rate. It is very important to pour in a fuel additive that guards against corrosion every time you fill the tank; this is especially true with small engines since many still use aluminium parts which corrode more quickly resulting in oxides that look like white rust.Suryaputra wrote: ↑Mon Jul 24, 2023 14:44 saya coba search / googling
ngeri-ngeri sedap
klo ron 95.. sikat vivo, shell, or bp ajah
better service jg, toilet jg bersih, musholla juga layak dan bersih
- Daily Vehicle: Toyota
Re: Pertamax Green
Masih maen amanlah etanol 5% kalo uda 15% baru butuh penyesuaian
Re: Pertamax Green
Pricing harganya saat ini sama kayak Ron 95 merk lain, mending ngambil merk lain yg uda pasti aman ya. Agak2 skeptis jg sama ethanolnya.
2016 F30 B48B20
2016 F30 B48B20
Re: Pertamax Green
Brati siap naik yg laen ron 95nya
Pertamax eco kan diplotnya lbih ramah lingkungan
Lebih tinggi ron
Lebih hemat
Lebih kompetitif harga
Lebih tinggi ron
Lebih hemat
Re: Pertamax Green
Mobil sini tuh ga didesain buat ethanol sih, beda dengan di US yang udah banyak pakai flex fuel. Apalagi mobil2 jadul. Saya skip aja deh. Kalo kepepet yaa gapapa juga sih.
Re: Pertamax Green
Padahal di luar negri itu harga bensin ethanol lebih murah daripada yg regular
Kirain jual 10rb buat ganti pertalite
Re: Pertamax Green
Pemikiran orang Indonesia banget ga siy ini, kalo produk baru itu bakal lebih murah
Padahal produk-produk baru itu harganya lebih tinggi, ya paling gak buat nutup ongkos R&D nya
Re: Pertamax Green
semoga merk lain gak ikutan campur dengan 5% ethanol.
Re: Pertamax Green
Strategi marketing nya agak aneh, dijual mepet pertabo98,.
Bagi yg paham efek etanol pasti stay d regular Pertamax atau loncat sekalian ke 98, beda dikit. Kalo mau iseng, setelah isi d tank, 2 hari kemudian tes kadar air nya (d yutube ada caranya). Hihihi....kalo aman lanjuttt.
Kalo ni produk laku, ane yakin jumlah etanol bakal d push terus...bisa jadi beyond 15%, macam biosolar dulu. Tinggal liat siapa oligarki yg berkuasa ntar.
Re: Pertamax Green
Intinya tergantung regulasinya nanti seperti apa.
Namun, regulasi juga "terkadang" disetir oleh yang punya kepentingan
Re: Pertamax Green
https://www.shell.co.th/en_th/motorists ... rices.htmlAbdulHakim wrote: ↑Tue Jul 25, 2023 1:25 Pemikiran orang Indonesia banget ga siy ini, kalo produk baru itu bakal lebih murah
Fakta nya begitu om di luar negri lebih murah itu gasohol (gasoline-ethanol)
https://fuelprice.io/station/caltex-woolworths/
Re: Pertamax Green
psstt.. nanti disuruh pindah ke luar negri ajaZaxis wrote: ↑Tue Jul 25, 2023 2:46https://www.shell.co.th/en_th/motorists ... rices.htmlAbdulHakim wrote: ↑Tue Jul 25, 2023 1:25 Pemikiran orang Indonesia banget ga siy ini, kalo produk baru itu bakal lebih murah
- Daily Vehicle: Yamaha Vixion Toyota Corolla 1996
Re: Pertamax Green
tetep bbm swasta kalo saya
Re: Pertamax Green
mungkinkah buat persiapan di masa depan, pertalite diapus terus pertamax biasa yg jadi bensin subsidi?
Re: Pertamax Green
Nothing is impossible
Re: Pertamax Green
E5 masih safe lah buat mesin CKD sini .. lagian oktannya juga mayan RON 95
cuman harganya mepet bener sama 95 swasta
selangnya ungu kalo ga salah
Re: Pertamax Green
lucu
dsini koq bensin dicampur etanol harganya malah jd mahal
di aussie aj, bensin campuran etanol 10 persen oktan 94 aj jadi bensin paling terhina murah nya ktimbang kelas oktan 91
Re: Pertamax Green
tinggal diliat efek jangka panjangnya ke mesin. sama gmana penjualannya dibanding produk RON 95 dri kompetitor
btw, harga pertamax green beda 500 sama pertamax turbo. klo bgini rasanya mnding beli yg pertamax turbo skalian..
4 wheels:
Toyota KUN40 [2013 - now]
Nissan ND1W [2019 - now]
2 wheels:
Yamaha V100 [1988 - now]
2 wheels:
Re: Pertamax Green
Tebak² nih kalau full terus ethanol
bakal ilang pertalite murni, jadi Pertalite eco/green e5 ron 92 rp11.000
Pertamax jg ilang jd eco/green ron 95
Pertaturbo tetep
Kalau saat ini,sy pilih bp beli 25ltr gratis 1 ltr
Shell promo² cc
Pertaturbo tetep
Shell promo² cc
