Subaru Sportbike? (sorry kalo repost)
adjokasep
Post by adjokasep »
Sportbike 500CC Single Cylinder pake enjin Subaru, chassis kayaknya buatan china deh...
TUFF Stough
Daily Vehicle: Ipin - Ipah
Re: Subaru Sportbike? (sorry kalo repost)
Post by TUFF Stough »
kok tahu itu Subaru om?
adjokasep
Post by adjokasep »
coba look closer ke enjinnya deh.....
nih, model fairing depan yang agak beda:
adjokasep
Post by adjokasep »
ENGINE:
Type: SUBARU ES50, Water cooled, 4stroke,1-cylinder
Bore x stroke (mm): 96x 64.6
Compression Ratio: 10.8: 1
Max. power (kW/rpm): 37.5kw/8000rpm,50.0HP
Max. torque: 39.6N.m/8000rpm
Carburetion: Mikuni BSR42
Ignition: CDI
Starting: Electric/kick
Transmission: 1-N-2-3-4-5
Drive Train: Chain
CHASSIS
Suspension/Front: Telescopic
Suspension/Rear:Single swing arm
Brakes/Front:Dual ventilated hydraulic disc
Brakes/Rear:Ventilated hydraulic disc
Tires/Front: AT110/70-17 radial
Tire/Rear: AT160/70-17 radial
DIMENSIONS:
L x W x H (mm): 2,025 x 660 x 1,060
Seat Height(mm):830
Wheel base (mm): 1,395
Ground clearance(mm):208
Fuel Capacity(L):13.5
Dry Weight (kg): 168kg
OTHER:
Lighting : 12V35W/35W x 2(front):12V.5W/21W x 1(rear)
TUFF Stough
Post yang pertama gak kelihatan merk di enjinnya, tapi yang kedua jelas. :off_good_job:
adjokasep
Post by adjokasep »
Subaru Sportsbike
By Ben Purvis
New bikes
18 November 2007 15:00
This new single-cylinder sportsbike features a Subaru-badged engine and could be on sale next year at a bargain price.
The engine for the HS500sa comes directly from Fuji Heavy Industries, the parent company of Subaru. It’s a 499cc, water-cooled, DOHC single, originally developed to be used in quad bikes and used by Polaris. The motor is notable for its lightweight design – it tips the scales at 43kg – and its ability to meet American and European emissions restrictions, a vital part of Sasaki’s plan as he intends to sell the machine worldwide.
With 50bhp at 8000rpm, the motor is on a par with engines from more familiar manufacturers, and its 33lbft of torque, peaking at 7000rpm, should be enough to give the lightweight HS500sa decent acceleration.
The bike’s chassis is built in China to keep costs down. Like most of the latest Japanese sportsbikes, it’s made from cast aluminium – although the hefty-looking frame rails look over-engineered for a 50bhp single. The swingarm is also cast aluminium, and heavily braced – giving the look of a much more powerful bike.
Sasaki has tried to produce a single cylinder sports bike before with the Horex 644 Osca, powered by a Dominator engine. Trouble was it cost £22,000 so never really caught on. Check out this link to see the history of the motorcycle and it running in someone's garage.
diambil dari Motorcycle News
spin022
Post by spin022 »
mohon ijin buat bahan postingan di forum sbelah
indroee
Post by indroee »
MAsuk indo gak yah.???
Kalo masuk sini harga iadi berapa yah.?? :ungg:
danangms
Post by danangms »
harganya kalo di kurs-kan ke rupiah, mahal banget ya. secara di luar sana harganya £22,000.
Safety First
adjokasep
Post by adjokasep »
@danangms: yang harga £22,000. itu Horex 644 Osca yg mesinnya pake dominator bro... bukan yang inih
@spin22 : silahkenn
spin022
Post by spin022 »
@^ Horex itu motor jerman ya om?
TUFF Stough
^Mesinnya kek Royal Einfield yang dipake di moge Sach MadAss. :ungg:
adjokasep
Post by adjokasep »
horexnya yg ini boss
adjokasep
Post by adjokasep »
