Accord CIELO Vs Corona ABSOLUTE
mohon informasi boss..
berencana beli mobil, anggaran terbatas kira2 50-75jt
stlh timbang2, mgkin pilihannya :
-absolute 2.0 97-98 ( sayangnya body kesannya gemuk n panjang )
-cielo 96-97
ttg harga kend/hrg spare part/keiritan bbm mgkin sudah ngerti dari baca di milis2, yg ingin ditanyakan adalah :
1. dimensi/ukuran (panjang x lebar x tinggi ) dan bobot dari 2 kend tsb
2. power engine 2 kend tsb (absolute 2.0 95-98 mungkin 3S-FE/96kW@6000rpm ya..? kalo cielonya yg g tahu..)
3. kenyamanan dan stabilitas pd kecepatan sedang dan tinggi, gimana penilaian antara 2 kend tsb?
thx atas bantuannya.
-cielo 96-97
Re: Accord CIELO Vs Corona ABSOLUTE
@ Selo...
Buat tambahan informasi aja. Pake bahasa Inggris ga pa pa khan...?
Harusnya kalo kobok2 di internet sendiri juga bisa dapat.
Yang Corona coba kobok2 sendiri dulu ...
1996 Honda Accord Performance
- 2,156 cc 2.2 liters 4 in-line front transverse engine with 85 mm bore, 95 mm stroke, 8.8 compression ratio, light alloy block, light alloy head, overhead cam and four valves per cylinder
- Unleaded fuel
- Fuel economy EPA highway (l/100km): 7.6
- Multi-point injection fuel system
- 64 liter fuel tank
- Power: 97 kW , 130 HP @ 5,300 rpm; 139 ft lb @ 4,200 rpm
1996 Honda Accord Handling
- 4.13:1 axle ratio
- Two disc brakes including two ventilated discs
- Spacesaver steel rim spare wheel
- Wishbone front suspension with stabilizer bar independent with coil springs , wishbone rear suspension independent with coil springs
1996 Honda Accord Exterior
- Body color body side molding
- Front and rear body color bumpers
- Driver and passenger internally adjustable body color door mirrors
- External dimensions: overall length (mm): 4,714, overall width (mm): 1,781, overall height (mm): 1,400, wheelbase (mm): 2,715, front track (mm): 1,514, rear track (mm): 1,501 and curb to curb turning circle (mm): 11,003
- Conventional lens halogen bulb single headlights
- Metallic paint , black paint , gloss paint , pearl paint
- Rear window
- Tinted glass
- Weights: gross vehicle weight rating (kg) 1,776 and curb weight (kg) 1,325
- Windshield wipers with fixed intermittent wipe
- Unleaded fuel
- 4.13:1 axle ratio
- Rear window
- Tinted glass
<< Whenever I drives in a hurry, I have to remember that it's not a top speed that can make me arrived in destination on time, but my average speed in traffic >>
ehem ... Kalo boleh kasih masukan nih ...
Accord, Kalo gak mikirin boros gaknya pemakaian BBM (1:6-7), plus mahal-tidaknya harga sparepart, mendingan nambahin duit dikit ambil Accord 1999-2000 (generasi setelah Cielo). Nanggung.....
Aku dulu pakai Accord 2000 punya fasilitas kantor. Kerasa mewahnya dan gak begitu ketinggalan jaman. Apalagi jika dapatnya yang sofa kulit warna terang (slide maju-mundur electric buat driver) dan interior dashboard dll kelas atas. Tutup spion electric....
Juga masih bisa geber s.d. 180kph di jalan dua jalur (di Batam
) tanpa mengurangi kenyamanan. Gak tau deh jika Corona bisa dibawa sekencang ini tetapi masih dengan kondisi nyaman.
Corona, secara pribadi, nyaris saya ambil buat pribadi beberapa waktu yang lalu. Bodynya lumayan dibandingkan Corolla. Tapi selain generasinya berakhir tahun 2002, harganya cukup tinggi. Jadi ambilnya Corolla '99 (tapi yang model Station karena buat keluarga) dimana generasinya masih berlanjut sampai tahun ini ...
Harusnya sudah ada Smers yang pernah pake Corona. nanti biar mereka yang cerita.
Hidup Corolla .....
Hidup Corolla .....
wah, gw ini awam mesin dan hal2 teknis, jadi gak bisa jelasin detil.
Tapi yang jelas dulu pernah bawa Corona Absolute 93 selama 2 tahunan.
Pernah jalan2 Jogja-Malang PP dan Jogja-Jakarta PP dan selama perjalanan OK2 saja.
Tarikan agresif dan stabil buat kenceng. Di tol cipularang pernah hampir tembus 150 km/jam, tapi udah disikut2 sama istri, hehehe. Jadi gak berani lebih kenceng lagi. Gak terasa ngebut deh walau sudah hampir 150 km/jam.
Kalau buat zig-zag agak terasa limbung.
Accord saya belum pernah nyoba. Kata orang, Honda itu fun to drive, jadi kalo naik Honda itu mesti nyetir, rugi kalo jadi penumpang. Lha jok penumpang fungsinya buat apa kalo gitu? Cabut aja, sisain 1 buat driver doang
Kalo dari tampang dan interior sih bagusan Cielo imo...Corona harus bener2 yg terawat baru keliatan bagus....setua itu udah jarang yg kinclong.
thx bro..
duhh, g kebayang sbelumnya kalo
overall length (mm): 4,714 (accord 96) dan panjang bodi absolute 4,62 m (dpt di tr lain)
padahal panjang garasi tersedia cuma 4,85 m
berat kosong
accord96 = curb weight (kg) 1,325
absolute97 = 1180kg (dpt di tr lain)
power
accord96 = 97 kW , 130 HP @ 5,300 rpm; 139 ft lb @ 4,200 rpm
absolute97 = 96kW@6000rpm = (96x1.341)HP = 129HP@6000rpm
berarti power engine hampir sama ya, pdhl cc absolut lebih kecil dikit
tapi @5,300rpm dan @6000rpm maksudnya gimna? ........
thx
berat kosong
power
thx
Kalo engga salah cielo 96/97 udah pake mesin Vtec (F22B1), jadi powernya sekitar 145an hp, torque sekitar 147lbft.
Kalo yg non Vtec (94/95) pake mesin F22B2 memang powernya cuma 130hp.....semua CMIIW ya....
kalo membandingkan berat kosong (Curb weight) sebaiknya melihat informasi negara/region dimana kedua mobil dijual bersamaan, soalnya spek satu negara ke negara lain beda2.....apalagi pada jaman dulu (96/97) yg perbedaan fitur antar negara sangat jomplang. Misalnya mbl yg stdnya pake fitur2 kaya sun/moon roof, airbag, abs, dll pasti jatonya lebih berat dibanding di mobil yg fiturnya gak lengkap.
Jadi accord yg beratnya 1325 kg (kalo liat di wiki atau website luar) belum tentu seberat itu di Indonesia.
Kalo soal model memang subjektif, IMO bagusan accord cielo vtec dibanding absolut pre facelift 96. Tapi kalo absolut yg abis facelit di 96 akhir kayaknya bagusan absolut model luarnya....keliatan gendutnya/gede
iya betul modelnya cielo lebih bagus ya.. simple, aerodinamis. tapi garasi g cukup
absolute97 grill nya lebih bagus dari model yg 96 tp agak gemuk
entah ntar pilih mana ya..
kemarin cek cielo, ada sgt bagus cuma th nya sdh 94, trus ada nawari 96 tapi merah (g menarik)
nih skrg sdg liat brg absolute97 lumayan bagus, msh nego serius
skrg sdh dpt absolute th 97 dg kondisi lumayan kenceng
mau nanya lagi bro :
1. setelah dpt absolute bekas walaupun kondisinya lumayan bagus, jika mau chek segala sesuatunya brgkali ada kelainan2
(kerusakan) tertentu, bagian-bagian apa saja antara lain yg penting untuk diperiksa (maaf terus terang kurang paham
mesin) ?
2. ttg mesin : nurut spek toyota dsebutk pake mesin 3S-FE (Compr=9.8.1/Power=96kW@6000rpm/Torque=178Nm@4400rpm),
tapi karena ini mobil bekas tentu performa mesinnya sudah berkurang jauh dibanding spek barunya. Untuk melihat kondisi
terkini dari performanya Power dan Torque, bengkel resmi apa bisa?
thx bro
mesin) ?
thx bro
Ah, akhirnya Anda sudah mengambil keputusan tepatselo wrote:skrg sdh dpt absolute th 97 dg kondisi lumayan kenceng
mesin) ?
thx bro
1. Coba periksa radiator, power steering, dan kaki-kaki. Khususnya radiator, walaupun punya Corona lebih bagus daripada punya Cielo, tetap mesti dicek karena rentan overheat. Pastikan kipas2 radiator masih nyala dengan sempurna.
2. Mestinya ya memang ke bengkel resmi.
Kalo mao tau tenaga dan torsi pastinya sekarang, ya musti di dyno bro.selo wrote: 2. ttg mesin : nurut spek toyota dsebutk pake mesin 3S-FE (Compr=9.8.1/Power=96kW@6000rpm/Torque=178Nm@4400rpm),
thx bro
Tapi kalo ane beli mobkas sih coba aja di jalan, gimana tenaga dan torsinya masih masuk ekspektasi ngga? Kalo iya, engga usah repot2 lah....yg penting rasanya puas.
Kalo bengkel resmi juga paling dicolok ke OBD untuk ngecek kondisi general mobil....gak ketauan jg berapa tenaga dan torsi yg ilang dibandingkan saat baru.......kecuali kalo memang tujuannya sekalian cek mobil.
thx atas pencerahan yg telah diberikan,
hari2 ini blm sempat nyoba performanya di jalan, tp itu saya pikir mgkn akhirnya g begitu penting sih
krn ya bs dibilang sdh cukup puas lah krn ini kend memang benar cukup nyaman
ttg kenyamanan kalo vs city yg seusia, bahkan soluna yg lebih muda, absolute jauh lebih nyaman padahal harganya jauh lebih murah (kata orang : harga nggak bisa bohong.., dlm konteks ini ternyata g berlaku).
klo dibanding cielo, absolute msh kalah nyaman, suspensi msh bagus punya cielo (g tau apa ini memang begitu scr umum?)
ttg performa engine-nya msh hanya punya penilaian : saat jalan 100kpj terasa sgt santai trus ke 150kpj jg mudah, klo nyoba top-nya jelas g berani krn belum cek segala sesuatunya, maklum mobil sdh tua.
mau tanya bro :
1. lampu depan absolute ini kurang terang, saya dengar2 ada jenis lampu HID apa bisa diterapkan di absolute?
2. absolute ini ada remote dan alarm (sptnya tambahan sendiri ya?). peralatan ini agak mengganggu (mgkin krn sdh g normal atau ada yg g beres). Saat semua pintu sdh ditutup dg benar (indikator pintu jg sdh ok/mati), tapi alarm berbunyi pelan tet.. tet.. tet.. sambil semua led indikator berkedip-kedip, distarter g bisa, selama 1-2menit dan akan mati sendiri, baru bisa distarter.
oleh pemilik lama sudah dilengkapi starter tombol, klo gakmau nunggu 1-2menit ya bisa langsung pake starter tombol. Jika pake starter tombol, saat kend jalan (semua led indikator jg msh kedip2 dan bunyi tet... tet...tet..) dan baru mati 1-2 menit kemudian. Kalo memang asalnya gak ada perangkat ini ya mgkin akan saya lepas aja.., atau sebenarnya ini kenapa bro ??
thx sebelumnya..
mau tanya bro :
thx sebelumnya..
Itu khan kendaraan bekas, bro.selo wrote: ttg kenyamanan kalo vs city yg seusia, bahkan soluna yg lebih muda, absolute jauh lebih nyaman padahal harganya jauh lebih murah (kata orang : harga nggak bisa bohong.., dlm konteks ini ternyata g berlaku).
Pernyataan itu juga gak berlaku untuk mobil baru produk Honda (karena harga Honda kemahalan, gak sesuai kualitas dan fitur yang ditawarkan) ..............
Saya belum pernah pake Cielo, tapi kata orang Honda itu terkenal suspensi keras untuk mengejar stabilitas. Jadi aneh kalo Anda bilang Absolute kalah nyaman. Mungkin itu "ulah" pemilik sebelumnya.selo wrote: klo dibanding cielo, absolute msh kalah nyaman, suspensi msh bagus punya cielo (g tau apa ini memang begitu scr umum?)
1. Buat no 1, mending ditanyaken langsung ke ahli2 lampu misal: bro Maxx, Satyr, Datsu, mungkin jg Om Sjamsul tuh.selo wrote:mau tanya bro :
thx sebelumnya..
2. Aslinya corona absolut gak ada tombol engine start/stop nya bos, itu kayaknya dipasang sendiri (produk after market) sama pemilik sebelomnya.
Wah........kayaknya pernah punya pengalaman jelek nih sama Honda?artoodetoo wrote:Itu khan kendaraan bekas, bro.selo wrote: ttg kenyamanan kalo vs city yg seusia, bahkan soluna yg lebih muda, absolute jauh lebih nyaman padahal harganya jauh lebih murah (kata orang : harga nggak bisa bohong.., dlm konteks ini ternyata g berlaku).Jadi pernyataan itu gak berlaku dong.
Pernyataan itu juga gak berlaku untuk mobil baru produk Honda (karena harga Honda kemahalan, gak sesuai kualitas dan fitur yang ditawarkan) ..............![]()
Saya belum pernah pake Cielo, tapi kata orang Honda itu terkenal suspensi keras untuk mengejar stabilitas. Jadi aneh kalo Anda bilang Absolute kalah nyaman. Mungkin itu "ulah" pemilik sebelumnya.[/quote]selo wrote: klo dibanding cielo, absolute msh kalah nyaman, suspensi msh bagus punya cielo (g tau apa ini memang begitu scr umum?)
ya benar koq, sebelumnya sering pake cielo, apa karena absolute ini pake ban 50 ya?
dari spec indo,
cielo = 1330kg matic & 1302kg manual, 140ps nonvtec & 145ps vtec.
kayanya dari dulu bobot merk ini memang rada berat2 di kelasnya, ferio = 1122kg matic dan 1098kg manual.
Ukuran bannya berapa?selo wrote: ya benar koq, sebelumnya sering pake cielo, apa karena absolute ini pake ban 50 ya?
artoodetoo wrote:Ukuran bannya berapa?selo wrote: ya benar koq, sebelumnya sering pake cielo, apa karena absolute ini pake ban 50 ya?
205-50-R16
Salam kenal buat smua.
Saya anggota baru di sn. Berharap rekan2 smua bs bntu kasih info n sharing.
Dari rekan2 semua, ada gak yg pernah punya tunggangan honda cielo yg udah V-tech.
Mohon share dunk ttg ketahanan, kelemahan ne boil yg potensial bwt ganti apa ajah, asumsi mobil kluaran 1998.
Sebelomya gw pake corona absolut 1997. gw rasa ne boil bikn kantong kempes krna suka jajan, n sparepartnya mahal bangt krn udah gak ada yg kw2. bensin sih lumaya irit, tp dari sisi kenyamanan kayanya kurng. 1thn gw pake mobil ne tp 10x lebih ne mobil bolak-balik bengkel. Akhirnya gw jual n brncana gnti cielo 1998.
Gw mohon infonya dr rekan2 smua yg punya pengalaman dgn cielo V-tech, Atw smuanya aja dech yg punya info ttg ne mobil. mulai dr sparepart, kelemahan (yg sring rusak) smpe pajak mobil /thn nya.
Thank a lot
Thank a lot
Sepertinya lebih baik Anda masuk ke trit Fans Cielo http://www.serayamotor.com/diskusi/view ... f=5&t=7232yudel wrote:Salam kenal buat smua.
Thank a lot
Saya pikir Anda dapat Corabsnya yang kurang bagus, pasti dulu beli 2nd khan?
Punya saya dulu boleh dibilang jarang kok rewel. Dan soal nyaman, Corabs itu jagonya. Padahal punya saya yang tahun 93.
Yach, namanya beli 2nd memang kadang seperti beli kucing dalam karung.
Untuk corona bisa gabung ke Corona Indonesian Club (CIC), milis: [email protected] atau buka sitenya di www.coronaindonesiaclub.com buat tambah-tambah wawasan corona
Regards,
a.budiarto
a.budiarto
Iye nich bro, kayaknya gw dl pas lg apes dpt tu boil.artoodetoo wrote:Sepertinya lebih baik Anda masuk ke trit Fans Cielo http://www.serayamotor.com/diskusi/view ... f=5&t=7232yudel wrote:Salam kenal buat smua.
Thank a lot
Saya pikir Anda dapat Corabsnya yang kurang bagus, pasti dulu beli 2nd khan?![]()
Habisnya susah bwngt cr corona absolut 1997 di sby...,
Yah namanya jg cari informasi, siapa tw bro2 skalian ada yg berkenan bagi info...
Ini nih susahnya kalo cuma mampu beli mobil 2nd,
mohon petunjuknya bro, dan para senior lain :
kondisi mobil corona abs saya scr umum bagus dan memuaskan, skrg baru muncul masalah
- Saat ditarik untk melaju lebih cepat (scr wajar) sering nyendat-nyendat, seperti telat suply BBM, ini terjadi pada semua tingkat transmisi (semua gigi).
- Saat digunakan melaju halus dan stabil dg kec tetap (tanpa nambah akselerasi), misalnya pada gigi: 2 kecepatan: 30km/j, sesekali terjadi hentakan/nyendat-nyendat, seperti suply bbm telat.
- Sdh ditangani bengkel dg memeriksa/memperbaiki bag pengapian, tapi tdk ada perubahan.
- Filter Bensin dan bagian injector sdh dilepas dan dibersihkan (awalnya filter bensin keruh) sampai benar2 bersih, juga belum ada perubahan.
Mobil : corona abs/1997/2000cc/injections/manual transm/bbm premium
Mohon petunjuk/penjelasannya bagian mana yg musti diperiksa/diperbaiki?
saya khawatir jgn2 yg bermasalah bagian ECUnya
fuel pump gmana om ? uda di cek di bengkel ? masi ok kah ?
